The “Must haves” list
Post any and all methods for doing things here, if you think you have a good method, that you don't see most builders using
Re: The “Must haves” list
Netpackrat wrote: Sun Aug 18, 2019 8:58 pm
fallguy1000 wrote: Sun Aug 18, 2019 8:33 pm sandpaper (like 1000 sheets of 60 grit so far)
Yah but not everybody is building the Queen Mary. :lol:
Honestly, I am over 1000 I'd say :<
The Chironex
Post by The Chironex »
Haha... oh the sanding... rum, beer and a ton of sand paper. Simple enough :lol:
Online
Netpackrat
Post by Netpackrat »
narfi wrote: Sun Aug 18, 2019 9:37 pm 3M worktunes bluetooth ear muffs and a subscription to audible for all your hours of sanding
Inlaws got me a set of those for Christmas a couple years ago, they have never been out of the box. Not allowed to use them at work, and I keep forgetting they are there when I am working in the garage.
piperdown
Post by piperdown »
In addition to what others have said:
Hand planer
Rasp
Ended up using a power planer but still use my hand plane
3 1/2" makita trim saw. Used that for the majority of cutting the ply panels
Hand plane makes fast work on epoxy globs and doesn't require a mask. Just shaves it right down.
Eric (aka, piperdown)
jtdums
Post by jtdums »
Plastic cups. Lots of them.
I mix epoxy by volume, so I like the clear 18oz good quality.(Keg cups)
Even for mixing small batches of epoxy it is nice to have a bit extra room to stir and the tongue depressors reach the bottom.
I also add filler to epoxy in these cups since they are large enough and I keep my batches reasonably sized to avoid excess waste.
Sanding is cathartic...
cape man
Post by cape man »
Lots of clamps!
Plastic spoons for mixing and the small toddler spoons are great for making filets.
Dremmel tool for tight work
Drop cloth or plastic sheeting to protect areas from epoxy drips
GOOD painter's tape
I also use plastic cups for mixing.
A small diet scale for mixing by weight (Quick Fair).
LOTS of foam rollers and chip brushes.
The Chironex
Well good news is I have most of the stuff you’ve all mentioned. I do appreciate all of your input! :)
So stoked to get this show on the road!
Capt UB
Post by Capt UB »
Stanley Sure Form planes
piperdown
Post by piperdown »
Here's a small belt sander I picked up and it works great for smoothing out fillets and inside corner work.
https://www.harborfreight.com/power-too ... 62863.html
OrangeQuest
Post by OrangeQuest »
One is the best tools you can have when it comes to boat building is patience. You can never have enough and when it comes to epoxy, sanding, painting, fairing or just reading the plans you are always going to need more than you have! And when you need it the most you will almost always run out, so keep plenty on hand.
