Have you ever designed a "power sharpie"? Is that a phrase coined by Phil Bolger?jacquesmm wrote: ↑Mon Aug 26, 2019 6:09 pm I designed a Panga with cabin and that could be close to his requirements:
https://bateau.com/studyplans/PG25C_stu ... prod=PG25C.
Powerboat Fuel Efficiency
Re: Powerboat Fuel Efficiency
Jetski Power plants... Are there any plans that use the jet package from an older jetski? I know it might not be the most efficient package, but having the ability to much the LCG forward (compared to an outboard) could make the boat have the safety/stability of a larger (less efficient) boat.
In the builders power boat section at the top there is a pwc build.
There is a 50 page story about that on the forum. I drafted the plans 10 years ago:fpjeepy05 wrote: ↑Fri Sep 06, 2019 4:59 pm Jetski Power plants... Are there any plans that use the jet package from an older jetski? I know it might not be the most efficient package, but having the ability to much the LCG forward (compared to an outboard) could make the boat have the safety/stability of a larger (less efficient) boat.
https://forums.bateau2.com/viewtopic.php?f=12&t=40346
Plans here:
https://boatbuildercentral.com/wp/prodd ... ?prod=JA18
jacquesmm wrote: ↑Sat Sep 07, 2019 9:52 amThere is a 50 page story about that on the forum. I drafted the plans 10 years ago:fpjeepy05 wrote: ↑Fri Sep 06, 2019 4:59 pm Jetski Power plants... Are there any plans that use the jet package from an older jetski? I know it might not be the most efficient package, but having the ability to much the LCG forward (compared to an outboard) could make the boat have the safety/stability of a larger (less efficient) boat.
Plans here:
