Travel cradles
fallguy1000
Travel cradles
Post by fallguy1000 »
I need to build travel cradles for the Skoota.
The cradles would ideally locate under BH1 and BH5.
There are a couple of concerns...
1. I built a wood cradle, but it can break or fastenings can fail..
2. I can get a metal cradle made, but it would be heavy as hell.
3. Should the cradle fasten to the boat to avoid it moving for and aft? It could connect up onto the beam socket, but would be a lot of work to design/build that.
4. What about building an all glass or foam and glass cradle? Seems like a no brainer
Any thoughts are welcome.
Here is a side view of a current method. This is certainly not usable on a semi. To keep this cradle moving for and aft or more so the aft cradle falling off, we joined the two cradles with a long timber. You can see it laying there off and out of the way.
viewtopic.php?f=12&t=62495
piperdown
Re: Travel cradles
Post by piperdown »
I'd vote for the foam/glass cradle...after all your experience should be a breeze :D
Eric (aka, piperdown)
fallguy1000
Re: Travel cradles
Design for 1000# static load.
Dynamic?
Capt UB
Re: Travel cradles
Post by Capt UB »
See if you can talk to the Class 1 power boat owners, here are two on trailers. They may have a plan, idea and/or someone who could really help you.
><((((º>¸.•´¯`•><((((º> ¸.•´¯`•.¸¸><((((º> ¸.•´¯`•.><((((º>
Re: Travel cradles
Post by Jeff »
FallGuy, I forwarded your forum post to Richard Woods. Not sure where he is currently but lets see what ideas he has to offer!!! Jeff
narfi
Re: Travel cradles
Post by narfi »
Can the two hulls fit side by side on the road?
If so, how strong are your sockets? Could you build transport beams that integrate with your trailer?
Sort of a road worthy spin off of this concept,
https://www.youtube.com/watch?v=mGuAPFuXQRw
fallguy1000
Re: Travel cradles
narfi wrote: Thu Nov 07, 2019 2:25 pm Can the two hulls fit side by side on the road?
Yes. The two hulls can fit side by side on a semi trailer.
The idea to beam socket them together is interesting and a novel thought I had not considered. The funny thing is I have one unusable beam that is 9' 6" long that could be cut in half and used to stabilize the two. It would be 4' 9" in half and long enough to strap into the BH5 and BH1 sockets.
Of course this just helps them on the truck.
On the ground, these stands could also help with the assembly. The crane would lift the hull off the semi and ideally set it down on the attached cradle. Then the cradle could be moved or raised and lowered to level, although the primary function is to support them during transport.
If I don't keep on with the painting; it may never matter, but the next few days are a bust.
Re: Travel cradles
Post by Jeff »
Narfi, that is a pretty cool lift truck!!! Jeff
Netpackrat
Re: Travel cradles
Post by Netpackrat »
Jeff wrote: Thu Nov 07, 2019 3:12 pm Narfi, that is a pretty cool lift truck!!! Jeff
Those are pretty common up here, although I don't think I have seen one where the sides of the lift power extended out like that before.
narfi
Re: Travel cradles
Post by narfi »
Netpackrat wrote: Thu Nov 07, 2019 7:58 pm
Ours is on a ball hitch that we hook up to a tractor and the tractors hydraulics. Our width adjustments are purely manual (square tube sliding inside of square tube).
