Been working away at the oars this week, wanted to get a coat of resin on them, so I could clear coat the oars and gunwales at the same time.
This weekend I'll also work on a mount for some dolly wheels on the transom, hope to get clear coats started this weekend.
SG15 build
Re: SG15 build
Those are gorgeous oars right there!
- OrangeQuest
Re: SG15 build
Very much a nice set of oars.
Re: SG15 build
This weekend I sorted out how to mount wheels to the transom. I really didn't want them permanently mounted and I didn't want to make a wheeled cradle, as they can be cumbersome.
So, I needed to put a couple of eyes in the transom to lift the boat up into the carport for storage ( I'm hoping to lift is directly on and off the car roof racks for ease of transport) and had been thinking about using them to mount wheels somehow.
I came up with the idea of making a transom plate that hooked over the top and will be secured with a couple of pins through the eye bolts. Seconds to fit and remove, even in the water. The plate will get carpet and rubber on the inside to cushion the boat nicely.
Also got the epoxy on the gunwales sanded out today, epoxy on the oars still just a little soft, so will look at sanding and clearcoats after work during the week.
- Netpackrat
Re: SG15 build
I would put some stainless fender washers under those nuts on the inside.
Re: SG15 build
I considered going with larger washers, but I have 9mm plywood and the intersection of two layers of biax each side in that location. The bolts were also bonded in with epoxy as I installed them, to seal the wood and bond the bolts into the structure. The nuts aren't cranked down super tight either, so very little compression.Netpackrat wrote: ↑Sun Dec 01, 2019 1:09 pm I would put some stainless fender washers under those nuts on the inside.
They'll only ever be in shear, so I think they'll be fine. Time will tell!
Re: SG15 build
Beautiful work!!! Jeff
Re: SG15 build
The silly season has slowed me down, but the boat is ready to go. Oars need some leather and I need to finish off my boat loading frame for the car, but it's all just about there. Also sorted out my carport storage, super easy to lift. Still not 100% sure the boat will clear the roller door on the roof racks, but it will be close, and I can work around it easily enough if it doesn't.
Finished off my beach wheels as well, they turned out very nicely, and the boat is easy to move around on them as well!
- OrangeQuest
Re: SG15 build
NICE!!!
Re: SG15 build
Beautiful
Dougster
Dougster
