Please find attached a copy of your Drawig B289 5001
I am looking for the dimensions indicated with “?” on you drawing
The locations 1-4 are clear, they are on the Stations drawing.
Possibly I have overlooked something.
PG25C Cabin Frames B and C
Re: PG25C Cabin Frames B and C
Hi Dutchman, In the future just refer to the Drawing Number.
Posting the drawing is not acceptable as this data is copyrighted.
Jacques will know where to look.
I see those dimensions on drawing D289/4.
For example. you show, on frame B, the top corner of the cabin as missing but I clearly see it at 1168 above BL and 496 offset from CL, on the stations drawing 289/4..
Note that I do not repeat dimensions for each side. If I show something on the starboard side, it will be the same on the port side.
I show the outlines of each frame/station on the stations drawing and the details on the frames drawing.
If something is missing, tell me on which drawing (number) and what point.
PS: I love that boat, not enough are building her. If I did not have another cabin boat, that is the one I would build.
Post pictures please.
Dear Jacques
Thank you for your Response
Unfortunately the drawing D289_4 is not in my downloaded drawing package, I received D267/4, 10/1/04, “Stations” instead, which does not show the dimensions you are referring to.
Also I received D289_3 instead of B289_3 as listed on the plans packing list online (study plans), possibly the latter is just a typing error.
I already mentioned the above in a separate email.
Please send me the file B289_4 by email.
With regard to building the PG25 C, I live on Bintan Island (right on the beach), Indonesia and marine plywood, fiberglass and epoxy is not available here.
I am currently working on the restauration of a local made fiberglass “Sampan” (5m x 1,2m).
I flew in the fiberglass from Zurich, Switzerland (my 2nd home), bought the epoxy and plywood (full sheets cut into 4) in Singapore (50 km away by ferry).
I was just studying the Panga plans to get some inspiration for a possible small cabin on my sampan.
Since the materials to build the Panga could only be obtained through high efforts and costs and being already 73 now, I unfortunately must abandon the PG25 C project and just be daydreaming about it.
Last but not least I must mention that your site gives me great opportunities for learning and inspiration.
dutchman,
I checked our files and all the sheets seem to be there. When you received your download it came in the form of a zip file. The zip file had several PDF documents and one folder with two other PDF files in it. The main PDF that you need (and this is the one that you have already opened) is called PG25C_M. These is the standard sheet file for the PG25. Inside the folder "Large Sheets" there is a PDF file called "D267_4_m" This is the stations drawing that you are looking for. This is in a separate folder because it is scaled to print on a "D" size sheet, 24" x 36".
If you cannot find this file please send me an email and I will be sure to send you the completed file.
Thank you,
Reid
reid@boatbuildercentral.com
Thank you,
Reid
- Steven Wright
- Steven Wright
Reid
the issue is not solved, only my confusion increased
I will send you an email
Just for the record:
It appeared that my statements were justified, I finally received the drawing that was missing in my download.
