CS23
Re: CS23
jacquesmm wrote: Wed Sep 02, 2020 10:10 am Check all your measurements but whatever happens, that keel line should be straight.
Sometimes I design a small hog in it (concave) to make up for the thickness of the extra glass layers at the transom but never a hook.
I like the last sentence!
I would build about 3 mm of hog; but no hook. All for tapes and fairing..
How does he line up the transom to deal with the bevel for your plans?
erich.resch@gmx.at
Re: CS23
Post by erich.resch@gmx.at »
but the chine step is straight on both sides see photo
Re: CS23
erich.resch@gmx.at wrote: Wed Sep 02, 2020 11:56 am but the chine step is straight on both sides see photo
What lines did you draw on the stations?
What lines did you draw on the transom.
It looks like the very first station chine step is lower? No?
Can you check the chipboard station? It looks high which makes the step on the first or station look low.
How are you leveling? When I setup my boat, I got really out of whack with a bad level and got mad and went and got a new one and the laser.
Re: CS23
It'd be best if u get a cs builder to reply. The chine steps look like they were added later. How did you do that?
erich.resch@gmx.at
Re: CS23
no i measured everything from the baseline (BL)
Re: CS23
See this picture?
Your chine steps look off here. Do the batten notches line up?
So, you have baseline measurements to the keel for each station?
And you have a BL to transom bottom measurement?
If the station measures are right then something ain't level. If the chine steps are both right; my guess is your transom is too high. The bevel looks suspicious.
Re: CS23
Also, if the transom is wrong distance to the last station, it may drive the keel up.
erich.resch@gmx.at
Re: CS23
good morning I have a question for Jacques I made a sketch and a photo the BL is straight and the keel is straight and I have a gap at station E 5mm and at station D 9mm maybe we have a problem with the translation of inches or inch in millimeters?
erich.resch@gmx.at
Re: CS23
station C is from BL 459mm when I do station C 445mm everything is straight on the photo is the aluminum lath
TomTom
Re: CS23
Post by TomTom »
What if you Beveled your transom piece? Would all your frames line up correctly with the straight edge if the transom wasn’t there? Or the straight edge came to the front/ bow side of that transom corner. To me it looks like you are close. Ultimately you don’t want any hook or rocker after you have fitted and glassed and faired the panels together. That’s the ultimate aim. The frames are just there to help you get there. The more accurately you set up the jig, the easier that is to achieve but ultimately they are a means to an end. Remember when you tape over the transom to the bottom panels you will have a thicker layer of fiberglass there. In my experience it pays to try and account for this when you set up the panels. But invariably you will have some fairing/ filling to do - you just want it as minimal as possible!
Users browsing this forum: Google [Bot] and 3 guests
