Woods Skoota 32DM
Re: Woods Skoota 32DM
Today, lots of phone work.
I so far got a final pass of qf on one of the cockpit panel bottoms. Will sand and paint the bottom next.
Netpackrat
Post by Netpackrat »
fallguy1000 wrote: Tue Sep 15, 2020 1:15 am
glossieblack wrote: Tue Sep 15, 2020 12:23 am Angle iron or aluminium?
Stainless angle iron and stainless strapping with aluminum rivets into aluminum beam. Some galvanics might occur in the rivet or in the holes in the beam.. time will tell
Aluminum is the anode when in contact with stainless steel, and the Anode goes Away...
Netpackrat wrote: Tue Sep 15, 2020 3:28 pm
The ally rivets can be redone. I can even make new holes. The alternative was to build all my angles in aluminum, but the problem is this...a 4" wide by 2" high welded double angle. Attaching it to aluminum would have been a problem as the ally would bend under load. Already some concern this might.
The obvious alternatives are to build in composites, but this was the direction we went.
Even the rivets can be stepped up to 1/4". The biggest worry is the holes growing on the beam.
We also installed 316 rivnuts into the aluminum beam. I expect some galvanics. Perhaps the corrosion will be just a bit. Time will tell.
All aluminum was simply not strong enough.
Same story for the stainless beam strapping and stainless studs. Good news is those are galvanically isolated from the beam.
jonnymac
Post by jonnymac »
what are the angle irons used for in the boat? Nice to see it coming together!
jonnymac wrote: Tue Sep 15, 2020 8:37 pm what are the angle irons used for in the boat? Nice to see it coming together!
Cockpit panels.
106" wide by 88" long
topwater
Post by topwater »
use Tef-gel on the rivets when you put them in .
Novi 23 finally launched !
topwater wrote: Fri Sep 18, 2020 12:16 pm use Tef-gel on the rivets when you put them in .
Well past that stage. They were epoxied in..0
Well, we have been working hard on the Skoota. I have been doing my damndest to get the cockpit panels installed. The grew a little with some fairing and painting.
I purchased a 30x40x15 tent to keep the precipiation off.
Friday I worked on the conduits to go between cabin and hulls and got them dryfit. Placed cockpit panels that are a bit big.
Yesterday we got part of the tent structure up.
