Weekend update:
the roof is gone. I was up on the front deck peeling off fiberglass when I bumped the front corner of the roof and it lifted up off the side panel... ugh. 2 minutes later the whole roof was laying on the ground. I figured it would be easier to just start fresh than to try to re-tab the old roof back on as well as sand the underside and re-fair the topside. 2 sheets of plywood isn't too bad.
I got pretty much all of the remnants of the seat boxes sanded off (sanding disc on the angle grinder) then went over pretty much everything with the DA/60 grit. I am thinking one more good sanding session and it should be ready to start going back together.
I ordered up some simple seat pedestals to mount the seats that came with the boat. i'm thinking i'll glue down some 3/4" plywood as a stiffener to support the pedestal. For the rear of the boat I am really liking the Bote inflatable chairs. I think they'll be a nice option for when i have a full crew onboard. Given the slow speeds of the boat i'm thinking they should work well.
https://www.boteboard.com/products/infl ... 67EALw_wcB
Some pics:
HMD 19 - Yoda's legacy continues
Re: HMD 19 - Yoda's legacy continues
Cowbro, nice to see progress being made!!! Jeff
Phil,
It's great to see you modifying this boat to suit your needs. It's also great to see work getting done on it! I can't wait to see where you go with it.
Also, no worries about noting issues with the boat or how it was constructed. As you said, Dad was racing a bit to get it completed and likely took a few short cuts in doing so. Hopefully, nothing that gets in the way of the plans you have for it!
Awesome Phil,
Glad to see Yoda's boat coming along so good and eventually some of your ideas and sweat is going to be part of her
Marc
Marc
I like the reverse slanted windows. They are not too common down south but lots of them in this part of the world.
Nice Cowbro!!!! Jeff
That is really neat. Great idea.
I haven't been posting much, it seems like all of the pictures i take end up looking the same, but I've been working on the boat a little every day. I ran out of daylight today to get a good picture, so this one is a few days old. The new roof is on, filleted, tabbed and glassed on top. The entire outside of the boat has 2 coats of neat epoxy on it. Next step is to give the outside a quick fairing. I am hoping that it won't be too bad as most of the boat was already done once. lol.
We had 95* weather here all weekend, so that helps things along nicely. I know it won't last forever and that our mornings will start dipping down into the 50s, so it will be nice to get most of the epoxy work done soon.
Phil
Users browsing this forum: Google [Bot] and 7 guests
