LM18 Houston Tx
BB Sig
Re: LM18 Houston Tx
Post by BB Sig »
Better to catch it now than after you rip it off! :wink:
Re: LM18 Houston Tx
Post by Jeff »
ericwensel
Re: LM18 Houston Tx
Post by ericwensel »
BB Sig wrote: Wed Sep 23, 2020 5:58 am Fairing mix is not structural. Mock up the skeg and glass first and mark a grind line. Grind back enough fairing to get your skeg glued and glassed. The marks will hopefully keep you from grinding too much.
ericwensel
Re: LM18 Houston Tx
Jeff wrote: Wed Sep 23, 2020 7:13 am Eric, how did you and your family fair with all of the rain & flooding in and around Houston over the last few days? Jeff
We are OK. thanks for asking. The South and East side of town got hit much harder. I am on the west and got much less rain.
Re: LM18 Houston Tx
Post by Jeff »
Good Eric!!! Jeff
ericwensel
Re: LM18 Houston Tx
gstanfield
Re: LM18 Houston Tx
Post by gstanfield »
Current build: FL14 (+10%)
Re: LM18 Houston Tx
Post by Dougster »
You can smooth the skeg out by running over oyster beds after she's launched 8)
Re: LM18 Houston Tx
Post by Jeff »
Good progress Eric!!! Jeff
ericwensel
Re: LM18 Houston Tx
