I was going to go with a stick steer but the options are very limited and they seem to be priced high for what you get. I've seen a few affordable rotary steering systems but am wondering if, at this point, someone has installed/used/approved/rejected a particular system/supplier.
Thanks as always,
Any definitive recommendation for a rotary steer system? Fs4LS+10%
Re: Any definitive recommendation for a rotary steer system? Fs4LS+10%
Whatever brand I would recommend a No Feed Back helm. Even on a small engine the prop will want to turn the boat to port when you let go of the steering on a helm without it.
Noted Cape Man, thanks. Most of the ones I've been shopping put that high in the feature list. I wasn't really aware it was a safety issue related to letting go of the wheel, I thought it was more of a comfort thing. I'm a sailor, so I expect my boats to have some weather helm and to round up if I let go of the wheel, I guess that's not what you want with a micro-speed boat!
It's not only a safety thing, but comfort as well. Once you take a heading with a NFB helm you are not constantly having to hold the wheel or fight it to keep it from from turning.
I need that in my RV during crosswinds in kansas!
Too funny.
By the way, mine is a teleflex system.
Just ordered the same from Jamestown along with a wheel, thanks again!
I got the steering system and a wheel, showed up yesterday. Cable is large and quite stiff, I suspect you could hang a few chairlifts from it without stressing it. It's going to be a bit of a challenge getting it routed without giving up my completely sealed bilge. I wasn't shopping for more challenges but sometimes you just get an unexpected bonus.
The wheel has 3-4 inches of "dish" which is extremely valuable space that it does not need to take up. I'm gonna check with JD and see if there's a flat wheel available and also see if there are any helm options with a shorter shaft/bezel. Front to back, the helm and wheel is 12" deep. That's a lot of precious space in this over-sized SUP.
