Fuel tank venting pressure and vacum separately FL14LS +10%
VT_Jeff
Post by VT_Jeff »
I'd like to vent for pressure outboard and vent for vacum inboard(under the deck where the tank is) to eliminate the chance of siphoning water if/when I bury the bow. The P-trap style vents don't give me a lot of confidence that they will work in a submersion situation, they seem more geared to keep spray out.
For it to work, I'd need one-way valves on both sides, one outgoing and one incoming. Can anyone tell me if the appropriate valves exist and where I might find them? I'm concerned about the fuel pumps ability to overcome whatever resistance a check-valve may have and allow free air flow. On the pressure side, not as much of a concern, I think.
Thanks,
jeff
Re: Fuel tank venting pressure and vacum separately FL14LS +10%
VT_Jeff wrote: Tue Nov 17, 2020 6:08 pm I'd like to vent for pressure outboard and vent for vacum inboard(under the deck where the tank is) to eliminate the chance of siphoning water if/when I bury the bow. The P-trap style vents don't give me a lot of confidence that they will work in a submersion situation, they seem more geared to keep spray out.
Thanks,
jeff
Not allowed if I am following you correctly.
VT_Jeff
Post by VT_Jeff »
fallguy1000 wrote: Tue Nov 17, 2020 7:23 pm
Maybe thats why I'm not finding any info on doing that. Appreciate it.
If you bury the bow; it is a pretty dangerous situation. If you bury the stern; the boat sinks. Any way you can move the vent further aft?
VT_Jeff
Post by VT_Jeff »
fallguy1000 wrote: Tue Nov 17, 2020 8:20 pm If you bury the bow; it is a pretty dangerous situation. If you bury the stern; the boat sinks. Any way you can move the vent further aft?
I can. Would I need to step up the diameter as the length increases to avoid resistance? Tank is in front.
VT_Jeff wrote: Tue Nov 17, 2020 8:36 pm
Nope
TomW1
Post by TomW1 »
I can only type one handed due to my shoulder replacement surgery. This has been discussed a lot on here, do search. Go to the store also to get an idea of the hoses and vents you will need. The vent for the tank will need to face to back as as will the fill vent. You will make a loop in both hoses to keep water from coming in.
VT_Jeff
Post by VT_Jeff »
TomW1 wrote: Thu Nov 19, 2020 11:52 pm I can only type one handed due to my shoulder replacement surgery. This has been discussed a lot on here, do search. Go to the store also to get an idea of the hoses and vents you will need. The vent for the tank will need to face to back as as will the fill vent. You will make a loop in both hoses to keep water from coming in.
Appreciate the input, esp under duress!
BarraMan
Post by BarraMan »
You're overthinking it! :D
cape man
Post by cape man »
DO NOT LOOP THE FILL LINE! You will not be able to fill the tank. Once full you close it, so you don't need the loop.
