It was a chilly 50 degrees today so I had my Florida Winter coat on...a light pullover.
Jeffs FS14 LS
Re: Jeffs FS14 LS
Re: Jeffs FS14 LS
I just don't know how you guys get any boats built with nice weather in February!
Re: Jeffs FS14 LS
Got 3/4 hatches hinge-mortised. Spent a few nights after work this week practicing the procedure on scrap and it paid big dividends. By the third hatch, I knew about how many chisel strokes were needed to clean the corners.
For the 30mm wide hinges I bought, I used a 30mm forstner bit to create a template out of 3/4 mdf
which I screwed to the deck/lid. The template had brad holes along the x axis to make alignment easier. Once the template was screwed down I removed the brads.
I made a second template to cut the deep section at the edges, screwed to the deck/lid through the same holes to ensure alignment.
To set the right depth for the 2 router passes, I first used the hinge body
and then a scrap of 9mm ply
I spun the dial up a half turn on the hinge and a full turn on the ply to get a little extra depth
A centering drill bit made the screw holes a snap.
I eased the edges with some 60grit and they're about done.
The complete cast of tools is shown below.
The 3 separate drills made things go smoothly without the need to constantly move bits around. I used some brad's through scrap to set the lid spacing on all sides before marking/attaching the template.
Re: Jeffs FS14 LS
That's a lot of fiddly work but sure satisfying to do it right, I think.
Re: Jeffs FS14 LS
Great overview! I'm not skilled woodworker by any stretch of the imagination so I would be racking my brain on how to do that with any degree of repeatability. I'll be saving that post for sure.
Re: Jeffs FS14 LS
Are those friction hinges or are you to have to put stays in as well?
Re: Jeffs FS14 LS
Nice!!!! Jeff
Re: Jeffs FS14 LS
They are not. Friction hinges cost more than I could bring myself to spend. These can open 180 degrees and lie flat on themselves so stays not really needed and no plans now to add any.
Re: Jeffs FS14 LS
Agreed. I didnt really have any choice. I tried freehanding the router shy of the traced line and finishing with a chisel but was totally unable to get the radius clean. With 16 radius's, the fiddling was the far lesser evil.cracked_ribs wrote: ↑Sat Feb 20, 2021 10:54 pm That's a lot of fiddly work but sure satisfying to do it right, I think.
Re: Jeffs FS14 LS
Looks Great! I used a similar process to recess the hinges on the FS 19 I built. Really makes a difference on the finished boat. Remember to account for the thickness of the epoxy, primer and paint coats, other wise the hinges will end up being a bit proud of the surface.
Users browsing this forum: Google [Bot] and 15 guests
