Thanks. I gave the depth pin 1/2 a dial up after setting it to the hinge depth for the epoxy etc, it's a gamble but they should end up pretty flush.Browndog wrote: ↑Sun Feb 21, 2021 10:56 am Looks Great! I used a similar process to recess the hinges on the FS 19 I built. Really makes a difference on the finished boat. Remember to account for the thickness of the epoxy, primer and paint coats, other wise the hinges will end up being a bit proud of the surface.
Jeffs FS14 LS
Re: Jeffs FS14 LS
Re: Jeffs FS14 LS
Nice job Jeff. The consistency is worth every moment of fiddling. I like the OG Makita too!
The next step is to save the jig “for next time” and put it on a shelf for 10 years. ( what happens in my garage)
Re: Jeffs FS14 LS
Nice work. People can use this thread as a hinge mortising tutorial almost.
Re: Jeffs FS14 LS
Dan_Smullen wrote: ↑Tue Feb 23, 2021 6:14 am Nice job Jeff. The consistency is worth every moment of fiddling. I like the OG Makita too!
The OG Makita is on modified duty, it's close to being a pensioner! Got it in '91 to install audio/video systems in SoCal tract homes in a very former life.
Re: Jeffs FS14 LS
Appreciate that Dan! I did finally go back and fix the photo order.fallguy1000 wrote: ↑Tue Feb 23, 2021 8:46 am Nice work. People can use this thread as a hinge mortising tutorial almost.
This morning I over-drilled all the screw holes and started filling, I didn't dam some up well enough so there will need to be a Part II on that.
Re: Jeffs FS14 LS
Starting to think about the cockpit trim inside radius puzzle. I played with a few different ideas with little success. My chief technical advisor, Dan S, wisely recommended trying laid up veneers instead of cutting or bending the 3 inch radius. To that end I ordered the veneers that Dan found for me and started making the Male and female molds for the layup. I used a super simple radius jig on the bandsaw to make the molds out of pt plywood stacked up with hot glue.
Re: Jeffs FS14 LS
This is the simple radius jig used to make the Male and female forms.
The two holes are the pivot points for the single piece being cut into the two mold halves. The distance between the edges(not centers) of the holes = the thickness of the final layup, in this case 1/4".
The distance from the outside of the blade to the center of the outside hole = outside radius of the trim piece I need, in this case 3"
I did not really account for the blade thickness properly but I suspect my margin of error is at least as large so not going to sweat it.
My piece was scrounged scrap and none too pretty but it should work just fine, or at least it should not account for total failure, that will be due to something else.
Re: Jeffs FS14 LS
Jeff! This is beautiful! I can’t wait to see the veneer sandwich!
Re: Jeffs FS14 LS
Thanks. The veneer showed up today and looks great. Expensive shipping but very fast. It may be at least a few days or more before I get back to playing with that stuff, though I'm chomping at the bit to. Thanks again for the direction on this! Fingers crossed it all comes together but it's just gravy so no stress.Dan_Smullen wrote: ↑Wed Mar 10, 2021 3:50 pm Jeff! This is beautiful! I can’t wait to see the veneer sandwich!
Re: Jeffs FS14 LS
Shoot, Man. Glad to have something constructive to share.
How thick is the mold?
Users browsing this forum: Amazon [Bot], Google [Bot] and 18 guests
