Waited too long...
Post any and all methods for doing things here, if you think you have a good method, that you don't see most builders using
Dan_Smullen
Waited too long...
Post by Dan_Smullen »
To get off the 30 bucks for a kitchen scale.
Mixing epoxy by weight allows me to to mix the smallest of batches that are not limited to how small of a graduated container is on hand. It's a game changer.
Also, as much as I've read about drilling 2 holes in bubbles to fill, it was only today that I did it for the first time. Watching the bubble fill, and thickened epoxy ooze out of the 2nd hole, may have been the most satisfying thing I did this weekend. I'll never grind another bubble again!
VT_Jeff
Re: Waited too long...
Post by VT_Jeff »
Dan_Smullen wrote: Sun Mar 21, 2021 7:41 pm To get off the 30 bucks for a kitchen scale.
Agreed on the scale! I printed out a spreadsheet with all the ratios from like .1 oz. to 9.9 or whatever so I never need to use a calculator.
I usually mash bubbles, I need to try the 2 hole trick.
Dan_Smullen
VT_Jeff wrote: Sun Mar 21, 2021 7:51 pm
Try it!
VT_Jeff
Post by VT_Jeff »
Dan_Smullen wrote: Sun Mar 21, 2021 7:56 pm
Try it!
Someday. Glassing on this boat is, as they say in Hollywood, In the Can! 8)
fallguy1000
Post by fallguy1000 »
How much thickener?
viewtopic.php?f=12&t=62495
Dan_Smullen
fallguy1000 wrote: Sun Mar 21, 2021 9:14 pm How much thickener?
Enough to make it look like puss oozing out of the relief hole.
Regarding mixing with the scale, I just read the stickie at the top of the epoxy page. Mixing ratio for MarinEpoxy is not 2:1, but 1:.43.
Spreadsheet showing ratios from 1-60 now printed and close to the mixing bench.
Dan_Smullen
Dan_Smullen wrote: Mon Mar 22, 2021 7:33 pm
Enough silica to make it look like puss oozing out of the relief hole.
