panga 22
Re: panga 22
Changes to the hull glass schedule require the intervention of the designer.
Re: panga 22
You thinking of a kevlar biax cloth and biax tape or just a kevlar weave? Kevlar has good abrasion and puncture resistance but the role of the fabric in these boats is structural, not just protective like with your dingy.
I used kevlar on the bottom of my drift boat specifically for abrasion, but its design did not require any glass for strength, that was provided by the ply schedule.
In any case, welcome, hope you get the info you seek and build an amazing boat.
Re: panga 22
I guess we need you to answer some questions first. Where will you be using your PG22 for? Will it be run up on shells or reefs? Will it be mostly trailered?
I ask this because Kevlar in large areas is difficult to get to lay down properly. It can be a real PITA. It is not normally needed on these boats unless you are in unusually abusive condition. Several coats of graphite have proven adequate even for those in oyster bed territory.
I very much like the PG22 and you take pictures of your build and document it down it the Builders section.
Regards, Tom
Regards, Tom
Re: panga 22
My two cents, and based on the PG20 plans.
The bottom is already very sturdy. 9mm plywood with glass both sides, and the option of using a 1708 cloth on the bottom outside to increase further. If abrasion is an issue, then you probably won't want Kevlar as I understand it is difficult to repair.
I personally would glue thin sheets or strips of aluminium flat bar or UHMWPE to any protruding parts, and call it done. That is what I did on mine. 3mm Al flat bar on the keel, and UHMWPE on the chines, and rubrails.
- New Poster
Re: panga 22
I used kevlar on the bottom of my drift boat specifically for abrasion fishing equipment in Dubai , but its design did not require any glass for strength, that was provided by the ply schedule.
Last edited by memorablemoose on Mon Apr 26, 2021 5:54 am, edited 2 times in total.
Re: panga 22
Xynole or Dynel for abrasion only . Kevlar would be better on the interior for puncture or flex . If you are going to all the trouble with Kevlar just spend the money on S-2 glass .
Re: panga 22
panga 22, it does not show the DWL and I would like to know how much weight before water would come in the suppers? Plans say 8 inch draft, also 7 1/4 from bottom to cockpit sole
Re: panga 22
Aramid should be burried deep in the laminate of wood boats. It is incredibly hygroscopic, and if any of it gets abraded or otherwise exposed to water, it will soak it up like a sponge.
Last edited by cape_fisherman on Wed Apr 14, 2021 8:47 pm, edited 1 time in total.
Re: panga 22
<-----------read this three timescape_fisherman wrote: ↑Thu Apr 08, 2021 9:02 pm Aramid should be burried deep in the laminate of wood boats. It is incredibly hydroscopic, and if any of it gets abraded or otherwise exposed to water, it will soak it up like a sponge.
I have aramid buried in the laminates of the beaching keels. Only there is the keel is suffered on rocks for a long time.
Abrading it also results in unrepairable fuzz.
