If this is old news t you guys, you have saved a bunch in plastic cups.
Up until today, I would use 3 cups every time I mixed 2:1 epoxy, using the molded lines on the cup as gauges.
Short work with a measuring cup in the kitchen allowed me to make some simple 2:1 marks on one cup, which I will keep as a guide.
9 oz mix is a fairly hefty batch especially after adding cabosil and wood flour for gluing things together.
Plastic drinking cup measuring hack
Re: Plastic drinking cup measuring hack
I wash them out with acetone and forget now n then, but into year 4, I'd say $200 in buckets. It always annoys me how much we toss out in general trash.
That is a good tip with the cups. Fast, easy and accurate way to make 9 oz batches.
Took awhile to find this thread, but this is how I mixed all my epoxy and never had a bad batch:
viewtopic.php?f=4&t=25065&p=228292&hili ... xy#p228292
Completed: FL14, OD18
- OrangeQuest
I have always used a scale and a single cup per batch. Makes it very easy to use different size cups for different batch sizes. And using a single cup to measure and mix I can pop out the harden mix and reuse the cup if needed.
I eat a lot of take out soups and save the bowls the soup comes in and are handy for bigger batches and when mixing two part foam. They also work for paint. You just have to make sure you wash and dry them well. They also stack tightly together.
I like that method of yours Larry. I'd use it for a 2:1 or even a 3:1. But WEST is a 5:1. I use metered pumps and a digital scale, either at the start as a check or throughout for getting the optimum ratio.Larry B wrote: ↑Tue Dec 29, 2020 6:17 am Took awhile to find this thread, but this is how I mixed all my epoxy and never had a bad batch:
Put cup on scale, tare it, pump hardener, multiply by 6.4 (5.4:1 by weight for WEST 206) and pump resin until the total weight is as indicated. It's not hard if you don't mind the maths. 95% of the time the pumps are bang on. Only time they've ever been out enough to matter was because of low levels in the jug.
