Thank you for the comment. This is not something I am familiar with. For inside the climate controlled cabin; less a concern. But in the batt box, I can think of a couple of places...OrangeQuest wrote: ↑Fri Apr 23, 2021 1:31 pm Your wiring looks nice but I didn't see any drip loops in them for when moisture collects on them. The water will condensate enough to form drips that follow the wire to the terminals and corrode faster. Maybe a little cotton string tied at the lowest points will direct the drips away. Works the same as a lightning rod but for moisture.
When I go to do the work on the starter batteries, I will keep this in mind. Thanks. Good to know. I will try to keep the bus and batteries higher.
