1979 19 ft Sea Ox rebuild
Re: 1979 19 ft Sea Ox rebuild
I like the sound of that. I will do some searching around on the forum here to do some research on application and tips and tricks. Any guesstimate on how much I should order to cover just the bottom?
A pound will do it and then some. Sift it through a tea strainer or screen, and add epoxy till smooth. You can add the resin first and then the hardener. Mix it really well before adding the hardener and then mix it some more. First time I used it I had clumps. About 25% by volume.
It is not bulletproof, but easy to repair scratches later.
Like Capeman said it is a good way to go but do not think it is bullet proof. Best part is if needed it is easy to repair.
I have got the boat flipped back over and on dollys in the driveway. I did some much needed clean up in the shop and I am going to try and get it back in there tomorrow night to start getting the bottom ready.
I have read through some threads on the graphite coating and I have seen where some people sand in between coats and I saw where someone recommended wet on wet and to wait 30 minutes to an hour between coats. Will you get good results either way? I would prefer to be able to knock it all out at once and then sand once after all coats are applied. Also can I apply this directly to the bottom of the boat without the barrier coating? I was thinking after putting 3-5 layers of epoxy and graphite that that would seal the boat fine, then I would barrier coat the rest of the hull before paint
I would say sand the bottom with 40/60 grit to give the epoxy/graphite a tooth to hold to. Then go ahead and do coat on coat as soon as the last coat is tacky to the touch. Probably no more than an hour depending on temp. Wet sand after the last coat, maybe allow it a day to cure.
I am not sure what you are referring to as a barrier coat. Is this a primer over the fiberglass or something else?
The epoxy is a barrier coat. Several coats of epoxy and there is no need to add something else.
The barrier coat I’m referring to is a two part epoxy coating to seal the boat where I sanded through the old damaged gel coat and repaired blisters. I bought interprotect 2000e to do this when I was planning on going a different route with the bottom. I’m hoping to be able to get the graphite coating on this week. Still have some spots to work on on the hull bottom before I can apply
If you need to sand the epoxy/graphite, do it wet.
Those that have tried dry sanding share that it makes a huge mess and they wouldn't do that again!
I was so pissed off by dry sanding that I swore I’d never sand it again. Ever. Not even wet. Nothing that sees the bottom of my boat should complain. Fish don’t care. People know I bite.
I barely sand it for repairs. Graphite is going to be ugly if it is doing it’s job.
My someday CK17
My someday CK17
If that’s the case I will try to roll it on as smooth as I can and if it’s halfway decent I will let it ride. As long as it functions properly I’m not worried about it being pretty
