Folks, I made a change to the search system as part of the recent activities. I have implemented the new search backend this morning. In theory, searches should be faster and more accurate. Please take a few moments to test some searches and see if we find any errors. Everything looks good on my side, but would like to get you all to confirm for me.
Thanks!
Changes to searches
Changes to searches
Re: Changes to searches
I still wish the default search only brought up one instance of each thread. Get too many results from same thread and it makes sesrching difficult.
I found a way! First post only option does it.
fallguy1000 wrote: ↑Tue Oct 05, 2021 9:00 am I still wish the default search only brought up one instance of each thread. Get too many results from same thread and it makes sesrching difficult.
The problem is folks with LOOOONG threads that have the "key point" at two ends. For example, if I wanted to search for "wood power cat beam sockets" and only had one instance, i wouldn't see the latter photos of your cat assembled. I'm with you though that it can get overwhelming to find the one post you need with 2472928 results from a long thread.
May be unrelated, but found lost images again here.
viewtopic.php?p=144569&hilit=Ph22#p144569
Missing gallery link here.
viewtopic.php?p=95762&hilit=Ph22#p95762
I am trying to read up on PH22s is all.
Link to gallery corrected in the post (never would have worked).
The missing images predate a "worst-case disaster" that happened way back. Nearly all images were lost. I can't recover those.
Jaysen, I like it!!! Jeff
works fine for me.
