Hi all,
Mostly just wanted to introduce myself as I'm guessing I will have a few questions.
I've just purchased the flat skiff 12 plans and noticed that the plywood specs in the drawings specify 6mm and 10mm ply, while the study plans say 6mm and 9mm.
I have not come across 10mm ply in NZ so assuming that the 9mm is correct?
Regards from NZ
Flat skiff 12 plywood specs
Re: Flat skiff 12 plywood specs
Welcome to our little fun place
Yep 9 and 10 mm plywood are the same in this case. I think JM said in the past 10mm was made but not any longer.
Ask as you go, I am sure you will get answers. Some of them might even be correct
Thanks Fuzz, thought as much.
