Hi all!
I'm new here but have been browsing plans and kits here for years since the days of bateau.com
I'm finally to the point of getting ready to pull the trigger and love the LM18 for its draft and wide beam than the FS18 that I've always loved but I'm limited to 20hp and a smaller storage space so I'd like to scale it down 10% shorter without changing the beam.
Will this horribly affect performance and handling? And would i have to have the plans resized professionally to maintain hull proportions?
Thanks for any input,
Alexa
Shortened LM18
- New Poster
Re: Shortened LM18
Welcome Alexa. If you scale in one direction you should scale in all derections. While a 20HP is on the lower end of the recommend motors for the LM18 it will still propel you well. Depending on the weight as you leave the dock at 1250lbs you will have a top speed in the low mid 20's, 23-25. A 30 give speeds in the upper 20's. So I think you will be fine with a 20 if you are not a speed demon. Or over load the boat.
Re: Shortened LM18
Welcome to the Forum!NaplesEuroTech728 wrote: ↑Tue Nov 09, 2021 7:19 pm Hi all!
Alexa
As TomW1 suggests, you must scale in all directions. However, as far as the ability to scale the LM18, Jacques (designer) will have to be the one to ultimately approve this as a viable solution.
To offer another solution, have you taken a look at the FS14_LS. I know it is shorter than you may be considering but I think it is work a look considering your need for a shallow draft, sturdy skiff. The FS14 has a 60" beam, shallow draft, and is ideal for a 20 HP outboard.
Here are the study plans: https://www.boatbuildercentral.com/Stud ... STUDY.pdf
Best of luck!
-Reid
- Steven Wright
- Steven Wright
- New Poster
Re: Shortened LM18
Reid,
Thank you for your input. I have looked at it and teeter tottered back and forth. My only concern with the fs14-ls is that i commonly fish with my wife and I'm concerned about the space with 2 anglers
- New Poster
Re: Shortened LM18
Tom,
That's great to know. I'm a little bit of a speed demon but right now I have a 16 foot jet boat that i plan on keeping so I have my need for speed filled, however it's miserable even in 1.5 feet of water
Thank you,
Alexa
Thank you,
Alexa
Re: Shortened LM18
We have an FS14_LS sitting here in our shop (built by SeaSlug). I can tell you that two anglers is not an issue at all. Three is pushing it, however, on the FS14_LS.NaplesEuroTech728 wrote: ↑Wed Nov 10, 2021 10:24 am Reid,
-Reid
- Steven Wright
- Steven Wright
Re: Shortened LM18
I upscaled the FS14LS by 10%, run it with a 20hp and fish with my wife aboard 90% of the time, often with our dog. Works great. Link in my signature.
- New Poster
Re: Shortened LM18
Jeff,
I will definitely check it out! Somehow in all the discussion of scaling that option never crossed my mind. Oops
Thank you!
Reid,
Three anglers is not an option within my patience level lol. That sounds perfect
Thank you!
Reid,
- New Poster
Re: Shortened LM18
Jeff,
I love your boat and the sizing of it
How did you go about scaling it up?
Re: Shortened LM18
NaplesEuroTech728 wrote: ↑Wed Nov 10, 2021 5:18 pm Jeff,
Thanks! It's a great little boat: carries the two of us with ease but is small enough to paddle like a SUP when called for. I should have moved my B frame forward so my client-wife has more foot room, or else made my console vertical instead of swept, which would have reduced my footroom very slightly but increased hers quite a bit(though this would move weight rear-ward, so maybe not)
The scaling is pretty simple: go through each measurement on the plans, add 10%, cross off the old measurement and write in the new one. To easily calc the 10%, I created a spreadsheet that let me enter the inches, 1/2 inches, 1/4 inches and 1/8 inches and it would output the new measurement in inches, 1/2, 1/4, 1/8 etc.
So if I input 20 3/8, I'd get 27 3/4 output.
It's a bit slow, but effective.
Don't scale the transom height!
Users browsing this forum: Ahrefs [Bot] and 17 guests
