new build GT Cruiser 23
fallguy1000
Re: new build GT Cruiser 23
Post by fallguy1000 »
Gotta be honest, your picture is hard to deciper which is which..but I think the heavy stuff is transom.
The best way to do the transom is to drop it into finished hull. Glue it inside. Leave enough gap for thickened epoxy. After bonded, radius all edges. I use a Festool. After glasswork is done, the bottom radius is remade sharp.
Transoms are typically set on 12, up to 14 degree angles from the waterline, but you may already have that in the hullsides.
viewtopic.php?f=12&t=62495
fallguy1000
My transom was dropped into a measured hull for minimal grinding. I probably used some screws to hold it or else hot glue.
Post by Fuzz »
Pretty sure the transom goes inside of the side and bottom panels. Might want to check the plans and see if you can tell.
If dropping it inside bed it in some epoxy glue. With all the glass overlaps it will be plenty strong no matter what.
Reid
Post by Reid »
Ideally the outside face of the transom should sit flush with the edges of the hull panels. However, marine plywood has a mind of its own sometimes and you simply cannot get it to sit exactly where you want it. The most important aspect of the build, at this point, is that your panels are lining up with no concave or convex surfaces where there shouldn't be. The panels should be symmetrical. There should be a small gap between all panels to allow room for the fillet (this includes a gap around the transom seams). Ensure that the transom angle is set correctly and that the stringers are lined up correctly with the transom and motor well bulkhead. If all the above is correct and your hull panels do not quite reach the outer face of the transom that is ok. You will simply bridge the gaps with fillet, shape a radius with your sander around the transom seams and proceed to fiberglass tape the seams. Once everything is taped and glassed you will never know the panels were a bit shy.
Good luck and build on!
-Reid
- Steven Wright
TomW1
Post by TomW1 »
As Reid said the side should line up with the back of the transom. You are going to need a helper one to hold it in place and one to place some scresws in the side to hold it till it dries. Do one side at a time.
jonnymac
Post by jonnymac »
TomW1 wrote: Wed Nov 24, 2021 2:00 pm As Reid said the side should line up with the back of the transom. You are going to need a helper one to hold it in place and one to place some scresws in the side to hold it till it dries. Do one side at a time.
that’s not what Reid said exactly, ideally it would but its the least important part. he said make sure everything else is correct and if the side is shy it will be fixed in the glassing process.
LaChefels
Post by LaChefels »
Happy Thanksgiving
The transom is in, glued and looks good.
Thanks a bunch for all the great insight. Now I’m onto the bow transom.
LaChefels
Post by LaChefels »
Here is a picture of the transom.
TomW1
Post by TomW1 »
Looks great. Tom
Post by Fuzz »
Almost done. Just needs a little rounding over and some glass :D
Users browsing this forum: Bing [Bot], Jaysen and 1 guest
