Well, still not 100% with Covid.
But got some stuff done today. First coat only of varnish on the tabletop.
Stove is mounted and fridge back in the hole and water heater ready to be plugged in; cept for needs water.
Woods Skoota 32DM
Re: Woods Skoota 32DM
That cabin is really looking good! Looks like it is becoming more comfortable.
Nice work FallGuy!!! Hope you are better!!! Jeff
Everything looks good except the laying around with your feet up part
Looking good!
Today, a bit of dabbling on seen and unseens.
First, hooked up the nav/anchor lights using analog. Bit of a pita and don't like it, but works as long as it doesn't come off the spades. None of the lights work; it just goes to a terminal block for now. Have to hook the wires securely still.
Then installed the little sink. As with all things small; this took over 2 hours.
On that first picture, the red wire looks like it is pinched under the SS screw that holds the black conduit. It is lower left center. It doesn't look right?
Hope you are feeling better and not over pushing yourself.
Glassing hardtop gutters.
Is this for the hardtop over the pilot station? its looking good!
Users browsing this forum: Google [Bot], Yandex [Bot] and 9 guests
