Thanks cape man, Fuzz, pee wee, Jeff and Tom!
The pics give the impression that Feather Pram is coming together as sufficiently beautiful to need no makeup, just protective oil. But up close, the reality is a little different.
Perhaps 90% of her glued joints are precise enough that they will look fine when oiled. But the remainder have epoxy-glue filled gaps that when oiled will catch and jar the eye.
So I’ve taken a step back to see if there is a rescue option whereby I can use a heat gun and sharp chisel to remove the surface layer of the offending joints and make good with a more aesthetically attractive alternative when oiled.
Yesterday I started doing experimental test strips with alternate epoxy-glue mixtures. I tried various combinations of e-glue and e-filler with sawdust. It turned out the clear winner was straight EZ Quick Fair sans sawdust.
The bottom strip in the pic below shows oil over Quick Fair joints with various degrees of sawdust mixed in, while the circled joint is neat Quick Fair. The top strip shows oiled joints over the e-glue used to construct Feather Pram.
These results are good enough for me. This afternoon I removed visually jarring outer layers of interior joints and made good with neat Quick Fair. I’ll sand things up tomorrow morning and post the pic result.
I'm enjoying the challenges the 'no make up' oiling route is presenting.
- glossieblack
- glossieblack
Yesterday, using a heat gun and sharp chisel, I worked my way around the interior edges of Feather Pram's bow and stern transoms, removing approximately 1/16" of visible dark brown e-glue from the joints with the planking, and making good with Quick Fair. This morning I sanded the joints fair.
I'm delighted with the rescue results so far on both the bow transom (first pic) and the stern transom (second).
I'm increasingly confident the oiled interior is going to pass muster.
Onlinecape man
Labor of love!
- glossieblack
Onlinecape man
We all need both.
- glossieblack
- glossieblack
This morning Feather Pram asked that I do a little cosmetic surgery on her bow transom exterior too. Before and after:
- glossieblack
Oooops, double post. Apologies.
Beautiful work GB!!!!
looking good! A little testing pays off to figure out what looks best. And now future boat builders have some ideas to help them out too.
Users browsing this forum: Bing [Bot] and 20 guests
