And quite nicely!
Hybird MF14
Re: Hybird MF14
Re: Hybird MF14
The hull came back to the shop for hardware installation.
Bow handle:
Halyard fairlead and cleat:
Splash coaming:
(In the above photo you can also see the eyestrap for the daggerboard leash)
Bow handle:
Splash coaming:
Re: Hybird MF14
The forward wall of the cockpit received the open fairlead for the main sheet and the builder's plate:
And the transom received the rudder:
Re: Hybird MF14
Here's the completed hull:
Re: Hybird MF14
Vintage estate sale sail. My sister-in-law found it for $5.00!
I had some help lacing the sail onto the spars
Re: Hybird MF14
Finished!
I test-fit the mast and found I needed to remove the bottom eight inches of tape from the base for it to fit the mast step. Couldn't raise the sail in the driveway due to overhead power lines.
Sea trials in May when the waters warm up a bit.
Re: Hybird MF14
Beautiful work!!!! Jeff
Re: Hybird MF14
I want a ride!!!!
Re: Hybird MF14
Very beautiful boat but that trailer doesn't do it justice. It seems overkill for the fine lines of the boat.
Re: Hybird MF14
So do I!
Well, I didn't buy the trailer for its looks. That's a 250-pound capacity model from Trailex that's designed for small craft. I certainly didn't want anything with stiffer springs as the finished hull is 138 pounds. It would probably look more proportional if I'd gone with the standard 8-inch wheels. I'm going to be hauling this puppy 645 miles though - most at freeway speeds but the last hour or so is on dirt logging roads in dubious condition. Both freeway and rough roads favor 12-inch wheels so I went with that.OrangeQuest wrote: ↑Mon Mar 28, 2022 3:05 pm Very beautiful boat but that trailer doesn't do it justice. It seems overkill for the fine lines of the boat.
The trailer needs some adjusting to the boat, too. Aft the trailer has two long, straight bunks on either side of the centerline. That might be great for an outboard. The bottom of the MF-14 is curved though - both side to side and fore & aft. Right now the hull just teeters on two points on those bunks. I'm going to replace them with four adjustable pads to support it better.
Users browsing this forum: Bing [Bot] and 8 guests
