I decided to scrap my hatches and go with the custom fiberglass hatches on BBC
Im going with the 22”x22” on the front deck, 22”x16” on the rear. I close up the deck and glassed. Then used the router to remove about 1/8” where the flange rests. I’ll epoxy it in place then glass the seams.
Has anyone used these any suggestions?
BBC fiberglass hatch lm18
Re: BBC fiberglass hatch lm18
You gonna install drains?
Yeah, I’ll probably do it with pvc like some other builders have done
Those hatches will really kick your build up a notch.
More work I know, but the gains in having a flush deck and drier storage with better cosmetics is real.
You won’t be sorry. It will be worth it.
I'd venture it is quite a bit less work than making guttered hatches yourself. I had more time in making the hatch and surround for the skiff than rebuilding the casting deck and floor together.
A straight-edge could help as a guide for the router in cleaning up those relief cuts.
Definitely less workMatt Gent wrote: ↑Sat May 07, 2022 10:23 pm I'd venture it is quite a bit less work than making guttered hatches yourself. I had more time in making the hatch and surround for the skiff than rebuilding the casting deck and floor together.
Epoxied the hatch in place. I temporarily screwed it down with drywall screws, which spread the epoxy out really good and contact all around.
