Epoxy and black do not mix well in high heat areas or direct sunlight. Keep the epoxy/graphite mix to the waterline or a couple inches above it. Then use a lighter colored paint above that.
Graphite bottom application
Re: Graphite bottom application
I had horrible results with "uv resistant epoxy" I would venture to say it was no more uv resistant than regular epoxy. I used it on a carbon fiber grab bar and tiller extension.
I did not buy it here, in fact they weren't even selling it here at the time.
I know that the sun can wreak havoc on black epoxy SUP's that are on car racks in the sun, but your sides and transom are past vertical, and so will not get much full, direct sunlight. I'm always in the "Try it, see how it works, report back" camp on this stuff. Someone had to eat the first oyster!wpstarling wrote: ↑Fri May 27, 2022 8:56 am Has anyone done the entire bottom with graphite/epoxy? And by entire bottom I mean all the way up to the rub rail.
This is nothing to play with! The heat on the black graphite on the sides will weaken the epoxy/fiberglass bond leaving a side of the boat to be prone to failure. Remember in these boats it is the fiberglass layers that provide the strength to the boat, not the wood.VT_Jeff wrote: ↑Tue May 31, 2022 12:25 pmI know that the sun can wreak havoc on black epoxy SUP's that are on car racks in the sun, but your sides and transom are past vertical, and so will not get much full, direct sunlight. I'm always in the "Try it, see how it works, report back" camp on this stuff. Someone had to eat the first oyster!wpstarling wrote: ↑Fri May 27, 2022 8:56 am Has anyone done the entire bottom with graphite/epoxy? And by entire bottom I mean all the way up to the rub rail.
The sun and heat in FL is one thing compared to that in VT.
