You will never regret putting the extra iron in the slab. I put a lot of iron in my shop slab and 35 years later I have no cracking in a 40x60 slab.
House build
Re: House build
Re: House build
Yep, you will never regret the rebar. Here in the mountains where it can get cold, I went with a 12" grid of 3/8" bar centered in the concrete. they come in panels of 4x8'. For the outside patio we added fiberglass fibers to the concrete mix. No cracks after 32 years. Tom
Re: House build
Great Job!!!! I have been in the home building business for 49 years including building my own home at age 21......and I'll say again...Great Job!!
Re: House build
A cylinder of Vicane and a tent wrap will eliminate any cooties once you complete the build.
Richard
viewtopic.php?f=12&t=62146
Re: House build
Thank you for the compliments!
AA is this something I can buy over the counter?
Re: House build
Probably not, you’ll have to hire a professional. If you have a buddy in pest control he can hook you up.
Richard
Re: House build
Ok, I'll check it out
Re: House build
Totally agree with Richard and was going to post the same. Tent it and fumigate before you put anything in it. May set you back a bit, but the best way to make sure you get good penetration inside and out. Termador is a great treatment for carpenter ants and termites but won't get any beetles if they're in the wood.
Re: House build
Ok guys sounds good. I'll definitely do that then.
Re: House build
Tenting and gas is mostly used for dry wood termites , it,s a one time shot with no future protection , and costly . Taurus is a generic Termidor for termites and beetles , $100 of chemical to treat the house for termites , $100 bucks of boric acid product such as boracare or timbor to spray the wood for beetles , Google and shop . Just make sure there is no dye in the boric acid product you use , they put dye in most so you can see that you didn't miss a spot .
Users browsing this forum: Bing [Bot] and 7 guests
