Bottom coat and topside paint lm18
Edd
Post by Edd »
Yesterday I put the epoxy with graphite on the bottom of my lm18. When I put the top coat on should I bring he topcoat to the bottom coat. Then bring the bottom coat up a little (add more epoxy graphite) to overlap the topcoat? Or should I let the topcoat overlap onto the bottom coat?
I might be overthinking this.
TomW1
Re: Bottom coat and topside paint lm18
Post by TomW1 »
Edd I assume you will be trailering your LM18 and pulling it every time you use it. Then just overlap your graphite a little bit with the topcoat.
Edd
Post by Edd »
TomW1 wrote: Fri Aug 19, 2022 9:33 pm Edd I assume you will be trailering your LM18 and pulling it every time you use it. Then just overlap your graphite a little bit with the topcoat.
Yeah it’ll live on a trailer. The graphite/epoxy is on pretty thick. So it got me questioning what to do.
cape man
Post by cape man »
I just took the paint to the edge of the graphite. Can't really see any difference between the two in thickness.
Edd
Post by Edd »
cape man wrote: Sat Aug 20, 2022 10:12 am I just took the paint to the edge of the graphite. Can't really see any difference between the two in thickness.
Ok that’s what I was thinking I’d try. If it doesn’t look good I’ll just take the graphite up a little bit to overlap
wpstarling
Post by wpstarling »
I also brought my topside to the graphite. I may have overlapped the graphite by like a half millimeter but you can barely tell. You can feel it when you rub your finger over it but I could probably 'fix' that by wet sanding but it doesn't bother me enough to do anything about.
Boats restored: 1973 Glastron CV16, 1990 Proline 17 CC, 1993 Bass Boat
Boats built: custom 15ft flat bottom skiff, Soon-to-be-built TX18 (originally dborecky's build)
OrangeQuest
Post by OrangeQuest »
Since UV rays can bounce off surfaces, I decided to paint over all my graphite bottom. Even though when not in the water, it will be in a warehouse but that is for now, who knows what the future holds and don't want the graphite epoxy mix to start to fade from UV exposure.
A. A. Milne-- Winnie the Pooh
Dougster
Post by Dougster »
I does fade to a grey as I see on my LB22, but it doesn't seem to bother me. Someone a few years back found a product that you could wipe on and refresh it, but I can't recall what it was. Acetone? Nah, I don't remember.
Dougster
Edd
Post by Edd »
Anyone used this? Would it prevent gray/haze?
cape man
Post by cape man »
I have some but have never used it. They sell a Marine Epoxy version here. https://www.boatbuildercentral.com/prod ... llon-only/
You might ask Reid if there's any long-term results.
Where are you thinking of using it?
Users browsing this forum: Bing [Bot] and 16 guests
