stringer rules...how many and where???
Barry_CF
Re: stringer rules...how many and where???
Post by Barry_CF »
fallguy1000 wrote: Sun Aug 28, 2022 9:24 am I've looked at the pics and apparently I'm not ready for prime time bcuz I don't see the issue.
Look at the last pic, as the others, for me anyway, don't seem to show the issue. On the outside of the stinger at the base I *think* you can discern a trough about an inch wide, making it difficult to get the tabbing in.
BarraMan
Post by BarraMan »
Ditto! 8O
I can't figure this one out at all! :doh:
This bit? You can fill it all the way up or fillet both sides. Personally, I fill.
If filleting both sides; it would be best to extend the tapes to 2" past the last fillet. This may mean an extra tape to get the width you need.
But I still think I'm clueless.
We are looking at a low spot between the outside of the stringer and the hull. OWT suggested filling the low spot with a piece of wood bedded in epoxy glue to bring things up to level. And then running the tabbing out over that and onto the hull. At least this how I understand things. I see no reason that will not work and it will use a lot less epoxy.
OneWayTraffic
Post by OneWayTraffic »
Fuzz wrote: Sun Aug 28, 2022 8:02 pm We are looking at a low spot between the outside of the stringer and the hull. OWT suggested filling the low spot with a piece of wood bedded in epoxy glue to bring things up to level. And then running the tabbing out over that and onto the hull. At least this how I understand things. I see no reason that will not work and it will use a lot less epoxy.
Yes. I do not know for sure whether that is the best solution, but I saw that as preferable to glassing into that hollow. It might depend on just how rounded the hollow is. I considered other ways to fill, but wood and high strength fillers work best of anything I could think of. He might need to flatten with a grinder before glassing, if he can't get it wet on wet.
This is the backbone of the boat after all. I can't think of a better place to overbuild.
Saltfix
Post by Saltfix »
filling that with epoxy would require a LOT of epoxy..so I got some 3/4thick X 2"wide wood strips and fit them in..I will mix some epoxy and wood flour and bond them in..that gets me level with the flat portion and then I can fillet and put in my tabbing.
That was a great suggestion..and the easiest and cheapest way to go..:)
Saltfix
Post by Saltfix »
I filled the void with a strip of wood to bring up level. it looks short, it looks short at the transom end but I have to put in a motor well and it will fill that portion when I fit it in.
Now it will be an easy job of just filling gaps and making fillets..
Thanks for the advice.. great idea!!!
It has to be bedded in thickened resin...in case that is not obvious..the tabbing needs to be continuous against something solid, it is not just a former
Saltfix
Post by Saltfix »
yes..just like the stringer was.. I just have it sitting in there ..not even mixed my epoxy yet..when I bed it..exess will only have one way to go..up..right where I want it..:) then fill the gaps. doe my fillet.and will be ready to tab...
It will also put more strength in as well..
then I can start fitting in my crossmembers..
OneWayTraffic
I'd put a neat coat of epoxy on the wood first especially end grain before you fit it in. Or use a slightly runny mix so some epoxy can sink into the wood and still bond well. Probably doesn't matter much either way. Just make sure that you use enough.
