C17 open in France - launched
cape man
Re: C17 open in France - launched
Post by cape man »
Congratulations! Felicitation! She's beautiful and doing what you want!
mhd
Post by mhd »
Congratulations!!! Deserved reward for all the hard work.
Post by OlivierP »
Many thanks to all.
Here it is with the name stickers and the bimini.
For the name, the boat was built and will be based in Arzon, Britanny. I just hope a certain brand has a sense of humor...
I installed a short bimini to cover the helm station and leave the fishing decks uncovered.
Post by Jeff »
Congratulations!!! Jeff
Post by OlivierP »
I did some post-launch calculations to confirm the specs, for anyone interested in the C17
- my boat weighs around 580kg (1300lbs) fully equipped, with motor, battery, full tank, all equipment, but no crew. This is what I had estimated and is confirmed by the waterline level at launch. The hull alone weighs around 380kg, vs 280kg in the plans. Differences, for about 1/4 each : more epoxy, thicker plywood (8mm vs 6), floatation foam, deck equipment. Fiberglass just as specified, I didn't go the "glass everything" route to avoid more weight.
- I have raised the sole by 3,5 cm (1.4") vs plans. This puts the sole 5cm (2") above the water with no crew, and at water level at 900kg, or 2000lbs, vs the 1500lbs DWL in the plans. That leaves 320kg (a crew of 4 , or 3 + lots of beer), before the sole reaches water level. So the boat is self bailing and the scuppers can be left open at all times with a crew of 1 or 2 (I'll rely on the bilge pump above 3), which is what I was looking for for fishing. I think raising the sole by 2" would still work, the C17 can take it and remains very safe with its high freeboard.
Users browsing this forum: Ahrefs [Bot] and 2 guests
