AB 23
Re: AB 23
I made a jig that I clamped to the open side of transom a couple boards and some clamps for pressure. I also squared off the top of my transom for aesthetics. Make sure to glass wrap the transom top. I recommend glass wrapping the inside laminates and outside laminates for upright builds and the inside laminates for upside down work. If you don’t wrap; it’ll end check and open on you.
Re: AB 23
On my phantom build I routed the top edge of the transom and completely wrapped glass over the top edge. I will do the same on this transom. I agree it prevents the core from potentially opening up.
Completed D15, Completed PH18
Re: AB 23
The ply for the full transom will overlap the upper edge of the transom now I am thinking of this. I will wrap over the glass over the ply/transom joint and tab to the transom about 6 inches down.
Re: AB 23
I am working on glassing the bottom and side panels. I decided to lay the glass on like shingles with overlaps in order to work with smaller sections of glass. It is less stressful working with smaller sections and I can take my time.
Re: AB 23
Not my approach, but I get it. Work looks real good.
I roll the glass off a tube and always have a helper and go nuts.
- BarraMan
Re: AB 23
Ditto!fallguy1000 wrote: ↑Fri Mar 14, 2025 8:47 pm Not my approach, but I get it. Work looks real good.
More fairing your way but looks fine.
Users browsing this forum: No registered users and 45 guests
