Shine wrote:I think I understand what your talking about, let see if I have it right.....
You adding a bulkhead, a toilet, and extending the a cabin back? I would guess this adds at least 100 pounds.
Actually the bulkhead issue and toliet is really not an issue from what the original plans shows with the side steering consoles and windshield arrangment. The foward storage area, in the shots on your original plans, show a portable head located in the vee area, in between the open decking over, located in the drawing of the open windshield layout, foward of the side console. The drop down between the consoles on each side, will also be the access to the foward covered bunks. The difference is that the bow deck covers the decking, no difference than the picture that shows the cabin drawing, as represented in MadRus. IN the foward section, you have also drawn an 18 gallon fuel tank, located foward of the side steering consoles, too.
The added weight is the additional top extention of three feet, which will end up almost midships of the boat hull.
