C12 Fibreglass Cloth
Can somebody give me some direction on how to cut and apply the fibreglass cloth to the bottom of the C12?<BR><BR>In the kit there is 4 yds (12 lf) of 50" 6oz cloth. There is enough to cover the bottom length-wise, but I don´t see how there will be enough to cover the bottom and go 6" up the sides width-wise as the laminating sechedule calls for. The width is approximately 60" at the widest point.<BR><BR>If the cloth needs to be cut and spliced somehow, can you describe how it should be done?<BR><BR><BR><BR><font size=1>[ This message was edited by: Chuck on 07-03-2003 09:46 ]</font>
It´s done in two pieces: put the fabric on the bottom with the edge lined up with the keel, overlap 3".<BR>When you cut the glass to fit one side, 6" up the sides, the piece leftover can be turned fore and aft and will fit the other side.
Jacques -<BR><BR>After a couple of weeks away, I finally got a chance to try this...<BR><BR>I followed your directions with a template and unless I am misreading them, I don´t see how this will work.<BR><BR>Is there any chance you could post a diagram on how to cut and overlap the cloth??<BR><BR>Thank you.
We lost that drawing in our hard disk crash and I can´t remember how I did it. The area is there but I don´t remember the layout.<BR><BR>One easy way to cover the whole bottom is as follow: <BR>- lay the whole piece of fabric on the bottom, centered and cut around with the specified overlap. This will not cover the chine in the middle.<BR>- use the large pieces left from the bow to cover the chines.<BR>It is just as strong that way. You have one extra seam close to the chine but one less at the keel.<BR><BR>We always try to help the builder save but in this case it may not be worth the cutting: one extra yard of fabric cost less than $ 10.00.<BR>
Okay - I´ll try that. Should the seams near the chine overlap be 6"?<BR><BR>I definately agree that there seems to be plenty of material. <BR><BR>Thanks! <BR><BR>Chuck
