Everybody thinks I have gone crazy¦.and sometimes I wonder if I really have¦ this virtual community of boat builders is not real¦¦well I am going to find out¦stay tuned as Baba starts his first Boat building project.
Quick history: (How did this happen¦?)
I would have to blame my ex-boss Martin¦he showed me this website and talked about the Stitch and glue method for building boats: sounded easy, so I started lurking on http://boatplans-online.com ¦.reading discussion forums¦just being invisible. Two years later.. realized that I had become an addict¦I had to build a boat or I would go crazy. God Damn it¦Here I am¦
Don™t know anything about boats¦never really been in one either¦I have seen people in em ¦and its looks kinda fun. That™s about it¦oh and another thing¦I am not a handy man either¦until six months ago¦I had never even used a drill machine. If I fail this project I will be letting down the geeks of the world¦.Well that just ain™t gonna happen.
Target Start Date: April 1st 2006 (still too cold here)
Target Finish Date May 1st 2007.
Preparations so far:
I have a mental picture of how œMadMax 1
Baba’s FL14: MadMax in Toronto
Hi Baba! As you've discovered by now, this is not so much a hobby as a disease...!
Thanks for the kind words - - not sure they're deserved, but if I can help, just ask via the forum or direct by my email link.
Best of luck with your build - just take your time and you'll be fine. Enjoy!
Don't forget to post pics of your progress.
Cheers from Oz,
Mike
Cheers from Oz,
Mike
FL14 "Lake Dreamer" built.
Good luck. I have a similar strt date planned. I believe at this time I will build the OD16 as it is the boat that addicted me to the site. I also priced plywood at Noahs but I plan to do as you did and get the fiberglass kit here. I have motor/ trailer and an old bowrider that is too long in the tooth to be a practical repair. My present assests will let me get into the boatbuilding again at a minimum investment for the first boat.
We are in the same area. lets keep in touch and good luck!
The weather is pretty warm in Torornto for this time of year...so picked up the Meranti BS6566. Thought I'd get a head start...
4 hours to scribe the dimensions
and another 4 hours to cut the pieces
This ply splintered quite badly when cutting across the grains..changing to different types of Jig Saw blades did not help. Finally applying hocky tape to the cut lines worked...here is the mug shot of the splintered cuts (done without Hocky Tape).
I found this ply to be too light and fragile...
.....No believers in the family yet...
Good to see you've started, Baba!
It is easy to splinter any plywood with a jigsaw when cutting across the grain - it needs a fine toothed blade and a fairly slow, steady cut to avoid doing this, and even then it sometimes happens. (I used a metal blade rather than a wood blade because it has much finer teeth). Don't worry about it - the edges will all be covered with epoxy and glass tape, anyway!
Looking forward to more pics....
Thanks Rick and Mike....
Brushes with attitude....topless and grounded...trimmed the tops and added epoxy to the bottom.
Yours Truly...not taking any chances with epoxy or the cold winter nights of Toronto...
Long panels are now bonded...kept thinking about peanut butter consistency...looked more like melted Toffee when I applied it...I don't know if it was too much or too little...
Sanded the sides, wiped with tissue dipped in Ocetone, dried and then applied epoxy resin followed by the toffee glue...
About 7 hours for all this and clean up...also includes a child lock I installed to the Garage entrance ...:lol
Users browsing this forum: Google [Bot] and 2 guests
