FL14 Motor
anonymous
FL14 Motor
Post by anonymous »
I am new to boatbuilding so I am going to start with the FL14. What do I need to look for in an outboard motor. I keep seeing terms like "short shaft", "long shaft", "transom length". Can someone give me an answer as to what I need for the FL14?
Thanks,
PS - I am doing this to prove all of my buddies wrong. They are all betting it will sink on me.
tech_support
Post by tech_support »
FL14 is not a planing hull, so more engine will not make it go faster. I would say around 3-5 hp should be more than enough. short shaft
chrisobee
Post by chrisobee »
All buddies are alike. Be sure to sneer at them when you launch.
anonymous
Post by anonymous »
The FL 14 calls for a short shaft. That would be ideally 15 inches.
You should name your FL 14 "PERSONAL" floatation device"
Then just smile back at them on shore when your on the water and call it a MILLER MOMENT
Rick
Post by Rick »
Any gasoline-powered short-shaft outboard motor will push the FL14 to hull speed in any water you should be out in with that boat. Anything over 2-3hp won't make it go any faster, and will just weigh more and use more gas.
The new water-cooled 2HP Tohatsu 4-stroke sure looks like a sweetheart choice for this kind of boat: http://www.tohatsu.com/outboards/2_4st.html.
dewers
Post by dewers »
would this be true of the FL12 as well?
anonymous
Trolling motor
Post by anonymous »
I have seen some pics of the FL14 being powered by Trolling motors. Anyone tried this? If so, what results did you have?
rjezuit
Post by rjezuit »
I have a 30# thrust trolling motor that moves my FL14 along just fine in calm water with 4 people aboard. As long as you are not expecting to get anywhere fast, or fight a current it's a good way to go. Rick
Kent
Post by Kent »
I too have a 30# electric motor. I have been in a pretty good head wind and it holds it's own. It's not fast but it gets me where I want to go.
I also cut my transom down just a bit for the motor. It worked out well.
See my gallary at
http://gallery.bateau2.comindex.php?cat=10098
You'll love the FL14. My family had doubts when I built it but now I can't go out without them.
Good Luck!
Kent
CET
Post by CET »
Rick wrote:Any gasoline-powered short-shaft outboard motor will push the FL14 to hull speed in any water you should be out in with that boat. Anything over 2-3hp won't make it go any faster, and will just weigh more and use more gas.
What is the hull speed for the FL14? Thanks.
