student research project
Thanks for all the input.
Donations
Hey Robert
Very interesting post. I wish I'd had the opportunity to do something like that when I was young. I might have made some very different career choices.
If they don't give you the plans, I would be glad to pay for them for you. Also, you might want to check out issue #185 of Wooden Boat. There is a solar-electric launch on the cover and a very extensive article inside. Might be some resources or ideas you could tap into there.
Good Luck
Daniel Huckleberry
Good Luck
Daniel Huckleberry
Robert, I live in Sewell (South Jersey) and work in Cherry Hill. I built the FL14. I have in my garage one sheet of 1/4" Meranti (bought an extra in case I made mistakes, but the build was very easy and forgiving, thus no mistakes) from bateua as well as extra wood flour and some disposables that you can have. I only have a little epoxy that I am saving for repairs if necessary. You are welcome to it and I can bring it to Cherry Hill in my pick up if you want to come and get it. Post a reply here if you are interested.
JP
- tech_support
- tech_support
here is my reply.......
Hi Robert,
We will help you. The ph15 will not be the best choice though. I am assuming your boat will not have enough power to plane, therefore a displacement boat will be much more efficient and probably faster than a ph15 in displacement mode. We have helped a few teams in competitions using solar or hydrogen power - long thin boats are the way to go, even it means solar cell hanging over like an aircraft carrier.
To chose the best design let get some more info. What sort of motor (hp)? how much battery weight? How much area of solar cell? How much do the solar cells weigh?
Joel
Hi Robert,
Joel
The best candidate may be a catamaran made of two of our Cheap Canoes tied with cross beams.
This will require minimal power and offer a very large area for the panels.
It would be inexpensive and easy to build, plus, you can use the canoes before and after the experiment.
THANKS
Wow!
I want to thank you all so much for your support. I am sorry I couldn’t reply sooner but I spent all day yesterday going through my research. Joel I agree with you a catamaran or a displacement hull is the best choice for a solar powered boat.
JP I will definitely take you up on your offer when the time comes, THANKS.
Daniel thank you so much for your offer and issue #185 of wooden boat magazine was what really got me started on this project.
Joel, thank you for your time, offer and help. I still don’t know why I never got the emails. I will send you the info for the boat very soon. I just want to research a little further into another possibility I have developed.
Thanks,
Robert
Thanks,
Robert
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 14 guests
