jacquesmm wrote:You are correct but our initial goal was to design a trawler between 32 and 34' in the style of the TW28. I can not drop that project.
Please don't drop this project. All of the previous discussions I've read on here and the what seems to be overwhelming demand for a larger more capable version of the TW28. If you follow the entire evolution of this thread it'll become evident pretty quick that there's more than 1 boat being discussed and probably 3 different boats based on the requirements for different uses. I'm probably as much to blame as anybody for not keeping to the program on this one.
jacquesmm wrote:Right now we have to make a decision about the TW34. It must be in the style of the TW28 and we will give it as much range as possible.
I think I've expressed our requirements a number of times but what we're looking for is a Coastal & Inland cruiser which is capable of offshore jaunts (>=200 NM) when required. The ability to cross some big water (gulf stream) and skip through the Bahamas and Carribean is how we invision spending our retirement. The Great Loop, Downeast Loop & Inland waterways are also on the agenda which entails crossing some big freshwater lakes. A Trawler style boat, although designed for extended offshore cruising is also ideally suited for our intended purposes.
We really like the style of the TW28 and hope to build it before we progress to something larger. But, having a 25' boat now we definitely know we're not going to get all the ammenities and endurance to take us where we want to go. Fuel capacity isn't the most critical (or doesn't seem to be) factor so a boat with a capacity for 600-1000 NM is adequate. More is better of course. The ability to store or make fresh water as well as adequate refrigeration are greater concerns.
So, I guess if you must make a choice on which boat to develop first it'll be (or should be) determined by marketability. Who, of your clients that have expressed interest, are most likely to build (or capable of building) a coastal cruising, island hopping or canal wandering trawler or a fully capable ocean spanning heavy displacement passagemaker? Answer that and you'll probably see where the return on your investment in developing the product (100's if not 1000's of hours) is most likely to turn a profit. You also have to weigh the viability for an amateur builder (of which we are and why we're here) to undertake and complete any one of those boats.
The TW28 is a considerable challange for an amateur builder as I believe Macca is the only one to do it so far, Yavuz's was built by a professional. I feel I will be able to build a 28 after a few smaller projects and after having done that I think I could handle a 34. Could I jump in over my head and build a bigger, heavier, more complex passagemaker? Maybe but I severely doubt it. Maybe after having built 5 or 6 boats first. I'm not saying there aren't those that can just it's not for me.
So just stretch the TW28 as discussed earlier, give it the JM signatures that make it stand out and we'll build it one day. If there's guys that want more speed offer them the option for the WARP drive! "Damn It Scotty! I said More Power!" "I canna Captain, the degribulator drive conduit is stuffed again!" "Damn Klingons!"
FWIW
Rick
