After a little aggravation(self inflicted) I have an album started on the FS 14 we're building. Put the boot stripe on tonight, ready to flip over and final touchups on the topsides. We did the finishing up top first (for a long winded reason!) Now we're waiting on the new outboard thats on order, some fuel, rodholders and were off. New pictures will be added soon.
URL: http://gallery.bateau2.com/displayimage.php?pos=-11720
FS14 nearing completion
Rob Stidd
"RaceCity USA" NASCAR COUNTRY
retro,
Thank you for your remarks.
I think it is a right of passage to successfully post an album. As a result some of the pix aren't that great. If I earn my "album creating diploma", I will change them out for some better ones. I also want to post in one place the changes I made during construction, I know before I started there were several things I was looking for previous expertise on and maybe I can give some insight to somebody else.
Rob Stidd
Jacques, any ideas??
OK, we've gotten to splashdown on our FS14, put a brand new Merc 15hp on and we've done some running around on the lake. The boat handles great, jumps up on plane, but then starts to porpoise some. We've tried adjusting the transom angle on the motor, but it only planes out with the angle closest to the transom. If the motor is trimmed out to the third spot, she will stay bow high and not plane out.This all happens with just the operator sitting on the stern seat. When there is a passenger either in the bow seat or the middle seat, she still porpoises but not nearly as much. I know the bottom was flat, I kept an eye on that during construction., The only addition I made was a skeg about 42" long and 4" high tapered to an inch high forward.
I came across a post for trim tabs, called "Smart Tabs" I will go that way if necessary. Any Ideas?
Rob Stidd
Congratulations on the launch but the boat should not porpoise.
The center of lift is about 42% of the waterline forward of the transom. That is where the center of gravity should be.
With a tiller motor and alone in the boat, you need a tiller extension. It can be a simple PVC pipe.
With a passenger, try to find the proper balance.
Put weights forward: gas tank if possible, ground tackle, stuff.
It's a small boat, sensitive to weight.
OK, that makes it understandable. At 42% puts it right at the mid seat. A tiller extension could be a problem, you can't get to the gearshift. I think I'll get some weight into the bow locker. I was thinking the FS14 couild be a cute little center console, maybe someday we'll convert it that way.
Any thoughts on the tabs, waste of time and money?[/img]
Rob Stidd
You don't shift while you are on plane.
Check Bass Proshop, they have tiller extensions for around $ 30.00 and they control the throttle. A PVC pipe will also work and cost$ 2.00.
The center of gravity is not the only thing to watch. You should also spread the weights, get some weight forward.
Tabs will help but try to sit in the middle first.
