OlivierP wrote: ↑Wed Oct 09, 2024 2:10 am
Yes a stiffener may work, or adding extra side frames between the existing ones. Another issue is to draw the single side panels, the plans don't specify the overlap between the 2 side panels so it's not trivial to extrapolate the dimensions of the single panel.
This is definitely a factor. i have the C17 plans and I've played around with the idea of a single side panel. I replicated the side panels in CAD and overlaid them, matching up the bow and transom lines, they fit together well, but based on what has been posted by lots of builders, i am not confident that it would be tall enough as it often seems that the upper panel is a little short of meeting together at the bow. My plan would be to draw the one panel as best i could, but leave it long on the top (gunnel) side and trim the shear line to match the frames later.
