Hey Brian,brian in cc wrote:.....I had one small spot near the bow where I had sanded through the primer(wr 155) and oddly enough thats the only place the paint stuck.I'm glad others have had good results with this product, personally I will never use it again. must have been a bad batch.
What primer did you use...? and please explain what you mean by wet sanding...are you adding water while sanding...? or sanding while the epoxy/primer/paint is still wet...
I hope things work out for you....good luck..
