CS 25 Project
OffshrAngler
Post by OffshrAngler »
Alright, Ill send those back on monday and then send you the money throught paypal. Thanks.
OffshrAngler
J, forget it. I found the space for the 25.
OffshrAngler
Does any body know if the sell 1/2" or 3/4" MDF at Home Depot or Lowe's? If so, what are the prices? I think I am going to use MDF if I can find it and if it is cheaper than Ply, for Temporary molds. Thanks
MadRus
Post by MadRus »
MDF doesn't take a screw or nail well in the end-grain. You may have to use some 1 x 1 material to create nailers on the MDF.
OffshrAngler
The Questin is, what kind of wood should I use for the molds that will:
1.) not warp in the outside temp and weather changes. (covered by a tarp)
2.) like you said, be able to take screws well.
3.) Be tough enough to withstand the pressure of the boat.
If I can get a ply that will match all 3 of these, I will get it. Any ideas. The easiest thing possible would be to use OSB ply 1/2" thick but I dont know how it will handle the outdoors. Maybe having a tarp over it will be different. am I right? or not :D ?
maxgsx
Post by maxgsx »
Any board you use outside with take up moisture unless protected. Maybe you could paint them; one coat of almost any oil based paint would do it. Time to use up those odd tins that have sat in the shed for years :)
MadRus
Post by MadRus »
That's a great idea- paint cheap stuff that will take a screw and you should be fine under tarps.
Capt H
Post by Capt H »
Go ahead and use MDF. Put blocks on for screws and seal as mentioned with some sort of oil based paint and you will be fine. As far as strength I have walked on the bottom of my boat with no problem. Happy building
Capt H
ddbiiz
Post by ddbiiz »
The 3/4" T&G sub-floor partical board has a coating on it to protect from the rain during construction it holds up pretty good the mdf board will suck up water like a sponge on the edges if rained on. I would go with the T&G if in that situation. just my opinion hope this helps.
Don
OffshrAngler
Have any of you guys who have built under a tarp done anything special to your molds to protect them??
