CS 25 Project
Posted: Wed Jan 11, 2006 3:28 pm
by OffshrAngler
Well, I got started a little earlier then I planned. Cut the jig today and got some ply to cut the molds. I will probobly get started on them this weekend. I have a long road ahead of me and I cant wait
Great
Posted: Thu Jan 12, 2006 2:06 pm
by Deedaddy
Glad to see you get started.
Posted: Thu Jan 12, 2006 11:54 pm
by mike neal
Are you going with disposable frames?
Posted: Thu Jan 12, 2006 11:55 pm
by mike neal
Escuse me, disposable molds? Mike
Posted: Fri Jan 13, 2006 3:16 pm
by OffshrAngler
Mike, I am going with disposable molds. I am using 1/2" ULX for the molds, and BS1088 meranti for the transom. I will later use BS1088 Meranti for the frames.
Posted: Thu Jan 19, 2006 5:18 pm
by OffshrAngler
For the Jig, do you reccomend going 4' or shorter? will the width really make a difference other than stability of the jig?
Posted: Thu Jan 19, 2006 5:57 pm
4' where?
Posted: Thu Jan 19, 2006 6:02 pm
by OffshrAngler
on the plans it say make the jig at a width of 24" to 48"
Posted: Sat Jan 21, 2006 4:00 pm
by OffshrAngler
We have a small problem...... I found out today that I am not allowed to build this boat outside because our neighborhood has some kind of restricton against this. Luckily, I have about 25 ft of space in my garage. I now plan on shortening the length to 23 ft. but still using my 25' plans. J, how will I shorten the length to 23' 2" or so to be a CS23? Do I take a frame out? If so which frame? Thanks.
Posted: Sat Jan 21, 2006 4:05 pm
Dave, trade the plans for the CS23. I will charge only printing cost and shipping (around $ 15.00 total) if you return the CS25 plans.
Don't waste your time scaling.
Posted: Sat Jan 21, 2006 4:11 pm
by OffshrAngler
Alright, Ill send those back on monday and then send you the money throught paypal. Thanks.
Posted: Sat Jan 21, 2006 11:14 pm
by OffshrAngler
J, forget it. I found the space for the 25.
Posted: Wed Jan 25, 2006 9:06 pm
by OffshrAngler
Does any body know if the sell 1/2" or 3/4" MDF at Home Depot or Lowe's? If so, what are the prices? I think I am going to use MDF if I can find it and if it is cheaper than Ply, for Temporary molds. Thanks
Posted: Wed Jan 25, 2006 9:21 pm
by MadRus
MDF doesn't take a screw or nail well in the end-grain. You may have to use some 1 x 1 material to create nailers on the MDF.
Posted: Wed Jan 25, 2006 9:56 pm
by OffshrAngler
The Questin is, what kind of wood should I use for the molds that will:
1.) not warp in the outside temp and weather changes. (covered by a tarp)
2.) like you said, be able to take screws well.
3.) Be tough enough to withstand the pressure of the boat.
If I can get a ply that will match all 3 of these, I will get it. Any ideas. The easiest thing possible would be to use OSB ply 1/2" thick but I dont know how it will handle the outdoors. Maybe having a tarp over it will be different. am I right? or not
Posted: Thu Jan 26, 2006 1:36 am
by maxgsx
Any board you use outside with take up moisture unless protected. Maybe you could paint them; one coat of almost any oil based paint would do it. Time to use up those odd tins that have sat in the shed for years
Posted: Thu Jan 26, 2006 9:29 am
by MadRus
That's a great idea- paint cheap stuff that will take a screw and you should be fine under tarps.
by Capt H
Go ahead and use MDF. Put blocks on for screws and seal as mentioned with some sort of oil based paint and you will be fine. As far as strength I have walked on the bottom of my boat with no problem. Happy building
Capt H
Posted: Thu Jan 26, 2006 6:05 pm
by ddbiiz
The 3/4" T&G sub-floor partical board has a coating on it to protect from the rain during construction it holds up pretty good the mdf board will suck up water like a sponge on the edges if rained on. I would go with the T&G if in that situation. just my opinion hope this helps.
Don
Posted: Thu Jan 26, 2006 10:41 pm
by OffshrAngler
Have any of you guys who have built under a tarp done anything special to your molds to protect them??
Posted: Sun Feb 05, 2006 1:44 am
by OffshrAngler
Will the MDF suck in water if I cover the entire jig with a tarp when not building?
Posted: Sun Feb 05, 2006 1:01 pm
by OffshrAngler
J, will 15/32" BC Pine ULX exterior be ok for the molds or will I have to go 23/32"?
Posted: Sun Feb 12, 2006 12:20 am
by OffshrAngler
worked for about 1 1/2 hrs. today and cut my first 3 molds. Plan on cutting a few more tommarow. I am using BC Pine ULX outdoor 15/32" for the molds.
BTW, I also started a cheap canoe for my brother in law.
Posted: Mon Feb 20, 2006 11:40 pm
by OffshrAngler
All of my molds are now cut out and I think I am ready to order a few sheets of BS1088 for the transom.
-also about to order the epoxy kit for my CC
Posted: Mon Mar 06, 2006 7:15 pm
by OffshrAngler
J, is that trade for the 25' plans to 23' plans still up for $15? I think I am going to happen to trade now.
