FS19 in Sherwood, OR
Re: FS19 in Sherwood, OR
Nice progress Scrappy!!!! Jeff
Make sure to run a #10-12 bond wire to the tank. They should have a tab for you. That line also goes to deck fill and vent if metal and then to ground bus.
Looking good.
Looking good.
Copy on the bond wire. Thanks.fallguy1000 wrote: ↑Sun Jul 11, 2021 10:41 am Make sure to run a #10-12 bond wire to the tank. They should have a tab for you. That line also goes to deck fill and vent if metal and then to ground bus.
Looking good.
Sole is in but not glued. Totally unacceptable for billiards but not terrible for a boat. There are some high spots in the foam underneath and a few places where the cleats along the hull are too high. I’ll pull the panels out and work on leveling things out a bit more. Also need to install the fuel sender in the tank and make cut outs for cockpit drains and access panels as well as support for the mounts for the cooler seat that will be at the helm.
