Sintes 21 Rebuild
Posted: Mon Nov 21, 2016 12:56 am
Well now that I am retired I was planning on laying around the house eating bon-bons all winter. SWMBO has made it clear, in no uncertain terms, that my plan is not going to fly
So I thought now is a good time to work on other projects out in the shop. She never goes out there so I am good
This is what I came up with. It is a Dave Sintes design out of C-flex I built about 1990. It has had a hard life and needs some love.
Re: Sintes 21 Rebuild
Posted: Mon Nov 21, 2016 1:04 am
I thought the best thing to start with would be to peel off all the old gelcoat and fair the hull. This is where I ran into problem #1. The old gelcoat is soft and will not cut. It just gums up my sand paper
I ended up using a 7 inch grinder with 16 grit paper to clean up the transom. It only took me three hours to do that small area. At that rate it would take a month for the whole hull, anyone got a bright idea?
Posted: Mon Nov 21, 2016 7:44 am
by topwater
Nice looking hull Fuzz . Congrats on the retirement and welcome to the Cloof club
I know nothing about gel coat,
is it water soaked
My wife told me the same thing that's why i built my Novi .
Posted: Mon Nov 21, 2016 1:33 pm
Thanks Topwater,
The hull is not water soaked just really rough and beat up. The transom is rotted and I have removed 75% of it already. The stringers are solid. I do think the basic shape of the hull is nice looking so I want to save it. I do not think there will be many more of his designs built as I heard he passed not long ago.
The gel coat is well attached, just soft enough to clog up sandpaper and not cut well. I am wondering if I can get away with putting a coat of epoxy over the whole thing and then fairing it? Or would I be making more problems for myself?
Posted: Mon Nov 21, 2016 1:59 pm
by narfi
If its soft enough to clog paper I wonder if chemicals would cut it?
You said you are the original builder, do you remember what product it is? I dont know much on the topic but its a thought anyways......
Posted: Mon Nov 21, 2016 2:20 pm
by peter-curacao
Fuzz wrote: I was planning on laying around the house eating bon-bons all winter.
that made me chuckle, nice bow flare on that one
Posted: Mon Nov 21, 2016 5:36 pm
narfi wrote:If its soft enough to clog paper I wonder if chemicals would cut it?
I am sure it is an ISO gelcoat. That is all I used back then. I am pretty sure it did not have wax in it and thus the incomplete cure. Groups like this did not exist back then. I have made more than my fair share of boat building screw ups over the years. I am hoping to not have a repeat on this project. For now I guess I will get friendly with the sander and at least get things roughed up even if I do not get all the gelcoat removed. I will run it outside and sand for an hour or so until I get froze out. Sort of hard to work up much enthusiasm for outdoor work this time of the year.
Glad I got a smile out of you Peter
Posted: Tue Nov 22, 2016 6:22 am
by topwater
Fuzz i wouldn't put paint over anything you are not sure of , mister Murphy will rear his ugly head and bite you
right in the ass every time .
Posted: Tue Nov 22, 2016 1:55 pm
topwater wrote:Fuzz i wouldn't put paint over anything you are not sure of , mister Murphy will rear his ugly head and bite you
Thanks Topwater,
In my heart I knew that from the start. I just had a dream somebody had an idea that would save me from the sander
Well I guess I will just have to buck up like a big boy and go take my medicine
Posted: Thu Nov 24, 2016 1:13 am
Well I spent the afternoon with a 4 inch grinder and a bunch of 24 grit disks. I got one side done. One more and the bottom to go.
When I get done I will get to spend days cleaning up the gelcoat dust.
Posted: Thu Nov 24, 2016 9:12 am
by Jeff
Looks like a whole bunch of work accomplished Fuzz!! Have a nice holiday!! Jeff
Posted: Fri Nov 25, 2016 11:53 pm
Well I spent the day with the grinder and 24 grit disks. When I was done I looked like a snowman
Turns out the gelcoat on the bottom was hard and in pretty good shape. I just went over it lightly and still took about 50% of the gelcoat off. In case you do not already know it a 4 inch grinder with 24 grit disks will do bad things to fiberglass in one heck of a hurry
My plan is to fair the bottom and then coat it with epoxy/graphite. To make sure things bond well I am thinking I need to coat the bottom and then do my fairing over that. Anyone have an opinion
While I was at it I went ahead and took the gelcoat off the other side so the hull is ready for fairing now.
I should have stopped when I got the bottom done but it is such a nasty job I wanted to be done with that part. Now I am hobbling around like a Cloof
Probably be a few days before I heal up and get back to it.
Posted: Sat Nov 26, 2016 6:43 am
That is a nasty job that I don't envy! At least you got it done
I would roll a sealing coat of epoxy on before I started fairing.
Posted: Sat Nov 26, 2016 1:23 pm
Thanks Larry, that is how I will do it.
I wanted to do the grinding outside but the temp was in single digits and I do not handle the cold as well as I use to
So to get the job done I did it in the shop. Glass dust is every place, I will be cleaning that up forever. Oh well it was that or wait till spring and that was not going to work.
I had always used a 7 inch sander for heavy glass removing but read here that many used a 4 inch grinder so I tried that this time. I was impressed how well it worked. There is nothing subtle about the grinder but it will move some material in a hurry.
Posted: Sat Nov 26, 2016 3:28 pm
I'd move
Yep, an angle grinder will get-er-done, but it's an implement of destruction if not used with a light touch
And I know you have a mess of dust to clean up, polyester dust, which is not friendly at all. Ugh!
Posted: Sat Nov 26, 2016 6:37 pm
[/quote]
I'd move
[/quote]
We would both like to find at least a snowbird place. That was part of the reason for coming to this years meet. We would be really serious about it now but my folks are here close to me. They are both 87. Father time has taken a heavy toll on them so we need to be close to help out as much as we can.
Posted: Sun Nov 27, 2016 12:08 pm
by blueflood
Hi Fuzz,
There is something very alluring about Alaska
that is one place I would love to visit at some point. Nice boat
but...what is so wrong about hibernating and eating bon-bons all winter
Marc
Posted: Sun Nov 27, 2016 1:59 pm
blueflood wrote:Hi Fuzz,
Marc
There is no place I would rather be for June, July and August. If you are being generous you could add in May and September. That still leaves 7 months of the year that are not so nice
I have lost my interest in winter sports so winters can get really long. This is the main reason I built my shop, to have a way to keep busy during the non summer months.
If I laid around and ate bon-bons all winter I would weigh 300 pounds come spring
Better to have something to keep me moving. I really like your boat and all the details you are adding to it.
Posted: Sun Nov 27, 2016 5:04 pm
by blueflood
Hi Fuzz, I hear you - had to take up cross country skiing; too scared of downhill
Snowmobile - had one and it busted the clutch in the middle of nowhere woods. That was the last time I owned one and unless it's a new machine, forget it. Did semi-wilderness camping in -20C, that was a blast. Snowshoes is excellent to get the cobwebs out too. And for a French Canadian...I hate skating. The best part is taking them off then cozy up nude with a honey under blankets for a whole weekend
Rather be on a boat tho - in the sun
Enjoy your time Fuzz !...sorry about rambling on
Marc
Posted: Sun Nov 27, 2016 5:25 pm
Marc
I have lots of time at this point
I am a bit of a blabber mouth so no such thing as rambling on with me
I hear you on the snowmachines. They, and a cliff, are the reason I need to have three vertebrates in my neck operated on.
Posted: Sun Nov 27, 2016 8:30 pm
by narfi
They do make it easier to get around on the hard water though.......
Posted: Mon Nov 28, 2016 7:09 am
by blueflood
Sounds like a big ouch to me, Fuzz
Posted: Mon Nov 28, 2016 9:26 pm
blueflood wrote:Sounds like a big ouch to me, Fuzz
Yep............I spent 45 minutes laying at the bottom of the cliff before I could feel or move my arms and legs. Gives a guy plenty of time to think about what life would be like as a quadriplegic.
Bad part was I had already let the darn thing roll over me earlier in the day and was stiff and sore so I was going slow taking it easy. If I had been going faster things would have worked out better..............that time
One of the few times where faster was safer
Posted: Mon Nov 28, 2016 10:32 pm
by Aripeka Angler
Mighty nice looking hull
I'll sure follow along now that I found this thread.
What will you fish for on this boat when you get her rehabilitated?
Posted: Mon Nov 28, 2016 11:18 pm
Aripeka Angler wrote:Mighty nice looking hull
Do you remember my post on "how not to retrieve your boat"? In the spring and early summer it can be really good halibut and king fishing just off that beach. Problem being is you need the boat to be able to take a beating if it gets rough and you want to come in. If this hull is not bullet proof it is dang close. 3/4 to one inch bottom, 3/8 to 1/2 inch sides. 4 full height stringers. It is just nice to have a boat you feel no need to baby.
Posted: Sun Dec 04, 2016 11:52 pm
Well boat work came to a halt for a few days
Old man winter decided to show up around here. -10F here this morning
I spent the last few days expanding the partition in my shop so I can get the Sintes 21 in it. It is nice to have a large shop but it is too big to heat the whole thing this time of the year.
Posted: Mon Dec 05, 2016 3:29 am
by narfi
Similar temps here.... It's coooold.
Killed the battery in our car, I think it's froze.
So we were bundled up on the Honda going to an early Christmas party tonight. Got the boy sandwiched between me and his mom to keep him warm.
Think he was grateful?? Nope he was upset we didn't pull him on a sled behind........ none of the kids seem to mind the cold like we do.
Posted: Mon Dec 05, 2016 11:34 pm
by fallguy1000
Hey All,
Couldn't you just have sanded that thing a little rough and put a coat of 6 oz glass and epoxy over the entire thing?
Or is that like peanut butter over jelly?
The reason I'm asking is my 13' Whaler is going to get sanded and has some pretty bad aligators and I was gonna put a nice layer of 6 oz over the entire boat. I tried strippers, too hard on the gel coat. I don't see the value in taking all the gelcoat off.
No intention to hijack, but the project is similar.
Posted: Tue Dec 06, 2016 2:49 am
narfi wrote:Similar temps here.... It's coooold.
My daughter called me from Fairbanks today. She is going to UAF. It has been -30 to -40 the past few days and even with a heat blanket for her battery it got killed. To be fair it was getting up there in age so no surprise.
Posted: Tue Dec 06, 2016 2:56 am
fallguy1000 wrote:Hey All,
Couldn't you just have sanded that thing a little rough and put a coat of 6 oz glass and epoxy over the entire thing.
You could do that on a whaler I guess. The outside skin on a 13 foot whaler is pretty thin and the sander might go through if you were not careful. Rough it up good and I think the epoxy/glass would stick. Not sure, never tried doing it that way.
The reason I took most of the gel coat off was because it was in bad shape. Real bad shape. I need to do some patching and fairing and want something solid to tie to. Plus there is no need to add glass to this thing..............it is a tank.
Posted: Tue Dec 06, 2016 9:10 am
by fallguy1000
The weather here has been bizarre. The ground just started to freeze on Saturday, really late. But we are getting cold blast now and Friday the high is 19F. Minneapolis.. Yesterday my kid and I went to lunch and the bigger ponds were not frozen over yet.
The gelcoat on the Whaler has quite a few alligators and cracks and I tried to use stripper on the paint, but it started to eat gelcoat, so I stopped. Gonna sand the whole boat rough and glass it on the outside and paint. Inside, going to just gouge out the gelcoat where cracked, fair and paint.
Good luck with that boat. I can't wait to see it finished.
Posted: Tue Dec 06, 2016 10:48 am
by cape man
Posted: Tue Dec 06, 2016 11:06 am
Just remember next summer when you guys are too hot to move we will be loving life
I do wish I could figure out a way to snowbird to down there
Posted: Tue Dec 06, 2016 11:17 am
Fallguy,
Good luck with the whaler. Those 13 foot ones are handy like a pocket on a shirt. I have done repair work on both a 13 and a 17 foot model. I was shocked about how thin the glass is on them. The 17 footer had about a foot of its nose beat off on a dock and the 13 footer had its keel worn totally through for about a foot from running up on the beach. Start a thread and post pictures. I would really like to see how you fix the whaler up
I dream of getting the 21 done before spring but I do not think the weather or my body is going to let me
But either way I am going to plug along at it winter and see what happens
Posted: Fri Dec 09, 2016 10:18 am
by Frank_HdG
Love the lines...look familiar (
http://www.anglersedgemarine.com/Page.a ... 2-Bay.aspx)
I'll be watching this one.
Posted: Fri Dec 09, 2016 12:54 pm
Frank both of our boats do look a lot alike so we can keep an eye on each other
I looked at the link you gave and then went to Utube and looked at a Sintes boat and yes I do believe that one came from his design. Dave did a lot of different designs over the years.
Posted: Sat Dec 10, 2016 11:43 pm
Well I got my addition to my work area done. It is amazing how well two layers of plastic with an air gap will hold heat.
I got the first round of fairing done on one section. I am doing it in sections so I feel like I am making progress.
Some how when sanding this hull it grows from 21 feet to something over 50 feet
At least it feels that way to me
Posted: Sun Dec 11, 2016 9:22 am
by Jeff
Fuzz, glad you have a nice, warm area to work!! Happy holidays, Jeff
Posted: Sun Dec 11, 2016 10:22 pm
by fallguy1000
Does that boat have the c-flex?
Edit - I see that it does..Starting to look good. Yeah, that air gap is a good insulator for temporary work.
Posted: Mon Dec 12, 2016 1:22 am
Jeff wrote:Fuzz, glad you have a nice, warm area to work!! Happy holidays, Jeff
Happy holidays to you and yours also Jeff. and all the rest of the folks on here.
I might have a warm place to work but this time of the year I could be talked into trading you places
Posted: Mon Dec 12, 2016 1:39 am
fallguy1000 wrote:Does that boat have the c-flex?
This is the first C-Flex boat I ever built. It was not a bad way to go 30 years ago but not sure it still is. I do know it is now where as much fun as they way they are done here. Plus there is no support group like here and that makes a world of difference.
When I was much younger and full of energy I build this one also. It is 32x13. Not a very good finish on it but not needed for a work boat.
Posted: Mon Dec 12, 2016 9:35 am
by cape man
Had to look up C-flex.... Interesting. Boat is looking good. Weather looks like it sucks!
https://weather.com/weather/tenday/l/Ka ... K0123:1:US
Posted: Mon Dec 12, 2016 10:38 pm
Sucks is a good word
I hope that weather forecast is accurate, I have not seen it above zero here at the house in a while.
Posted: Mon Dec 12, 2016 10:39 pm
The boat picture is a few years old. We do not have that much snow yet. Maybe if it warms up it will snow some.
Posted: Mon Dec 12, 2016 11:12 pm
by Jaysen
Fuzz wrote: Maybe if it warms up it will snow some.
And that kids is why we live in the south!
I know it's true, but the idea that it needs to warm up to snow is just ... ... nuts. I know it's a beautiful place but I don't know how you folks survive up there.
Posted: Tue Dec 13, 2016 2:54 am
Well I admit this time of the year can be a little chilly but with good clothes and heaters it is not that hard to stay warm. Don't tell anyone. I like living in a state that has one square mile for every person living there. And as much as I liked being down south I am sure I could not handle the summer weather there. I could be a classic snowbird if given the chance though
Posted: Wed Dec 14, 2016 10:07 pm
Well I guess it is time to confess to my sins. I planned on using system3 and quick fair on the bottom of my boat and that is what I am doing. My sin is I let the glass supplier talk me into using vinyl ester and his fairing puddy on the sides. So I worked on one side and did like I was told. Problem was the S**T never kicked and got hard.
Crap was so soft there was no way to sand it so I ended up taking a chisel and scrapping 21 foot by 26 inches of hull with a 1/2 inch chisel
To top it off I got to break out the grinder and cover my shop with poly dust AGAIN
Taking a break from the boat before I return to drinking. On second thought I do believe a little rum is called for
Jaysen if you read this no matter how much you think you might have screwed up this should make you feel better
Posted: Thu Dec 15, 2016 2:09 am
Quick question. After washing your hull how long do you let it dry before glassing on it?
Posted: Thu Dec 15, 2016 7:57 am
by topwater
Fuzz looks like Mr Murphy bit you right in the A$$
Dude you know better
I know you just retired and you are looking for things to keep you busy but dam man i can think of better things
to do than scrape that crap off a hull
Posted: Thu Dec 15, 2016 8:16 am
by Jaysen
Fuzz wrote:Jaysen if you read this no matter how much you think you might have screwed up this should make you feel better
I'n your defense, you were using unknown product from a source that had to "talk you into" it. Let's call it "his fault" this time!
And for the record, the fact that guys like you do this is what has me terrified. If you can do it, what chance do I have of a "f me!" free build?
Posted: Thu Dec 15, 2016 8:54 am
And you knew better than that
Friends don't let friends use vinylester, especially in Alaska in the winter
Posted: Thu Dec 15, 2016 1:18 pm
topwater wrote:Fuzz looks like Mr Murphy bit you right in the A$$
Believe it or not as I was spreading the crap on I keep hearing your voice whispering in my ear about Mr.Murphy. Maybe when I hear voices I need to obey them
Posted: Thu Dec 15, 2016 1:24 pm
Jaysen wrote:Fuzz wrote:Jaysen if you read this no matter how much you think you might have screwed up this should make you feel better
Well everyone makes a few screw ups along the way. In almost every case they can be fixed. Might not be fun but it can be fixed. Safest thing to do is stick with the products sold here and stay on the proven path. My problem is I have always liked to try the new stuff. That carries more risk than most folks would like.
Posted: Thu Dec 15, 2016 1:30 pm
Cracker Larry wrote:My sin is I let the glass supplier talk me into using vinyl ester and his fairing puddy on the sides. So I worked on one side and did like I was told. Problem was the S**T never kicked and got hard.
Yep, in the end I did know better. I just thought I would give something new a try
Nothing like letting Mr Murphy bite you right in the butt.
I waited a couple of days to post this. I knew I was making myself look stupid. But if it helps somebody else from making the same screw up then I guess I will wear the dunce cap.
Posted: Thu Dec 15, 2016 1:42 pm
by Jaysen
Fuzz, my build plans all start like
1. Make sure Bateau has it, if not, you don't need it.
2. Go to the plans page and add EVERYTHING to the cart. BUY IT ALL.
3. Call Jeff and double the epoxy and add all the things everyone told you you'd need.
4. Pay Jacques and crew then begin drinking to CL on High for build blessings.
And yes, there are planS. This will not be the only boat in our yard.
Posted: Thu Dec 15, 2016 2:46 pm
by Jeff
Nice comments Jaysen!!! Happy holidays to you and your family!! Tell your Paratrooper I said happy holidays as well!! Jeff
Posted: Thu Dec 15, 2016 2:51 pm
by cape man
When I built the OD18 I posted every F Up I made with the same intent. Humbling myself publicly is a way to assure I don't do the same thing again, and others can read it and say "Whoa! Won't do the same thing as that dumb ass!"
And as we often say here in Florida..."Aint nothing but a thang."
P.S. At work today in shorts, a light T shirt, and sandals..
Posted: Thu Dec 15, 2016 4:08 pm
CapeMan you are killing me
As I sit here looking at it snowing outside. Well at least it has warmed up
Posted: Sun Dec 18, 2016 2:12 am
Well I have been plugging along trying to clean things up. I used wood flower glue to fill in some low spots that were bigger than I wanted to fill with Quickfair. That is the darker spots you see.
And here is the side that I have been having so much fun with
This is after two rounds of fairing and then some blue guide coat so I can see where I am at. I am hoping two more rounds of fairing will be enough, we will see
The hull does not look like it has that much dead rise but I have learned that after putting a seal coat of epoxy on it the only way to keep from sliding off was to sand it with 60 grit to have a little traction. That dang epoxy is some slick stuff
Posted: Sun Dec 18, 2016 7:13 am
by Jeff
Fuzz, really good progress!!! Hope you guys are warm up there!!! Happy holidays, Jeff
Posted: Tue Dec 20, 2016 4:16 am
Well I got to the point I was chasing my tail so I put a thin layer of primer on the side to see where I am at.
The primer was still wet when I took the pictures and quit for the day. That is why the primer looks spotty. Getting lazy, it was only midnight
Posted: Tue Dec 20, 2016 4:35 am
by gonandkarl
Hi,
You are working fast but most probably that is the only way to get a move on with a bigger boat. I could not imagine to work until midnight. It is good to see your progress on the side of the boat documented with a picture because I will be doing the bottom and the sides soon and I always learn from detailed pictures. Have a happy and not to cold up there festive season.
Greetings from Karl
Posted: Tue Dec 20, 2016 5:00 am
Thanks Karl,
This hull was pot marked like a teenage boy with a bad case of acne.
The first pictures did not show how bad it really was. I am still not too sure how well this is going to come out
My first plan was to gel coat the sides. My thought was this would not shine like paint and show all the little flaws. That did work out so well
so I went to plan "B".
I will bring the graphite up the sides about three inches so I did not prime that area. The shear line will get a bunch of work so I am not worrying with that area yet also. I still do not have a plan for painting the sides so when I get to that point I will be seeking lots of advice.
One more round of fairing on the bottom finished today. So question for the pros, should I prime the bottom or just go ahead and lay the graphite on it?
Posted: Tue Dec 20, 2016 5:36 am
by Jaysen
There was another build thread that asked the same. Don't recall if it was an od or ob. I believe the outcome come was "don't waste the primer" as it doesn't do anything for you. I believe CL commented to that effect.
Found it!!
http://forums.bateau2.com/viewtopic.php ... ry#p382333
Posted: Tue Dec 20, 2016 11:17 am
by topwater
Fuzz Go right to graphite .
Posted: Tue Dec 20, 2016 3:32 pm
Straight to graphite it will be. Thanks for the advice Topwater and the link Jaysen.
Might be a day or so. After looking at the bottom at least one more round of fairing is called for. And it looks like I will get to spend most of today plowing snow
Posted: Tue Dec 20, 2016 3:42 pm
by gonandkarl
Hi,
We just have a wiff of snow 1 cm so I can still cycle with my Winter dog everyday 6 km. She is a cross between a Bernese mountain dog and a Samojede and I hope she will one day be a waterdog sailing with me on the Adelie. Good luck with the graphite.
Greetings from Karl
Posted: Wed Dec 21, 2016 3:39 am
Change of plans due to a Cloof moment.
About a week ago I "misplaced" my wallet. I was sure I would stumble across it in a day or so but after three days of looking no go
so after going to DMV for a new drivers licence I cancelled all my debit and credit cards. I was told 3-7 days for replacements. We will see about that. Now all of this would be nothing but a "thang" if I did not need to order some stuff. I was totally sure I had plenty of graphite to do my boat but sure enough I am no where close
. So I guess I will keep on working the sides over until I can get my supplies.
Posted: Wed Dec 21, 2016 10:36 am
by cape man
What really sucks, is if you are like me, two or three days after you replace everything you will find the old wallet.
Posted: Thu Dec 22, 2016 6:54 pm
by cracked_ribs
cape man wrote:What really sucks, is if you are like me, two or three days after you replace everything you will find the old wallet.
That's the only way to guarantee it wasn't stolen.
If you do nothing, it will turn out to have been stolen, and you will have a big fight with your bank trying to get money back.
If you report it, it will turn out to have been in a jacket you forgot you wore.
It's the same as weather. If it's beautiful so you plan a fishing trip for Saturday, you just ruined the weather for everyone. If you volunteer to work because you're sure the perfect weather won't last all week and then the weekend too, all your friends will haul in the best fish of the year.
Unavoidable.
Posted: Thu Dec 22, 2016 8:43 pm
Thanks guys,
Now that I have applied for a new drivers licence and all new credit cards I am shocked my wallet has not shown up
As for the weather.................I spent my entire working career working remote/offshore. I either worked week on week off, or two on two off, for most of that time. I can not tell you how often I sat and watched perfect weather while working only to come home to wind and rain
I think I still hold the record at my old work place for longest stuck waiting on weather. Almost 6 full days of my 7 days off
Now that we have been trained to use plastic for everything it is a real pain when you do not have it. Oh well, I have plenty to keep me busy, it is just not what I want to be doing
Posted: Tue Jan 03, 2017 1:47 am
For X-mas my wife bought me new sweat pants. She does not like me wearing the ones covered in epoxy around the house for some reason
Funny part was my daughter did the same thing. So the second thing I received from both of them was a new wallet
And of course right after that my old wallet turned up..........big surprise, that is the way it works. Couple of days later I received a new credit card and was able to call the good folks here up and get some graphite ordered. So I have been taking a little time off and watching all the ball games. I hope to have something worth pictures in a few days.
Posted: Wed Jan 04, 2017 1:38 am
I got the graphite ordered from Jeff and the team a couple of days before New Years. Today was the first day the post office was open and low and behold there is a box from Bateau waiting on me. Guess the holidays are over and I have to go back to work on the skiff
Really fast shipping guys, thank you very much
Posted: Wed Jan 04, 2017 1:49 am
by narfi
Looking forward to seeing how it looks
Posted: Sat Jan 07, 2017 3:28 am
Got to the point of laying the first coat of graphite on the bottom. I used a "best quality" short nap mini roller to spread it. As you can see I got some fuzzies. I will have to do a light sanding and hope it takes them out. I might end up going with a west system roller but I understand they do not work very well either. Oh well I guess in the end only the fish will see the bottom, I hope
Bateau sent me some more quickfare also. Good thing as after priming the sides I see some areas that need more work. I do not know if System3 has changed the formula a little or if I just got some much fresher than I am used to but this stuff is much creamier and spreads better.
Posted: Sat Jan 07, 2017 8:07 am
by cape_fisherman
Use a guide coat & all the spots that need work will show up.
Posted: Sat Jan 07, 2017 8:10 am
by Jeff
Fuzz, hope you are warm and the weather is reasonable!!! No change to the System Three QuickFair!! I agree builders love it!! Jeff
Posted: Sat Jan 07, 2017 8:38 am
by topwater
Fuzz try the west roller on the next coat then use a heat gun to try and get it to flow out .
John
Posted: Sat Jan 07, 2017 9:33 am
by pee wee
One tip on reducing roller fuzzies is to get some sticky tape and run the roller over that first. That will pull a lot of the loose fuzz off of there before you use it.
Posted: Sat Jan 07, 2017 12:38 pm
Jeff for some reason this batch of System3 is more creamy that any other I have used. It is even nicer to use than normal
As for the weather well...........it is a nice balmy 10 below zero this morning. If I did not know better I would say this is Alaska in January
Peewee and Topwater I will give both of your roller tricks a try. It takes about 24oz to cover this bottom so I need to find something that works.
Yep need to give the sides another guide coat and get them a little closer. There is not much area that is straight so it has been a pain the the rump
Posted: Sat Jan 07, 2017 12:40 pm
Cape Fisherman thanks for the reply.
Had a cloof moment and had to go back to see your handle
Posted: Sat Jan 07, 2017 9:01 pm
by cape_fisherman
Yeah, those c-flex boats require a lot of fairing to get right. But it'll be solid in the end.
Posted: Sat Jan 07, 2017 11:53 pm
cape_fisherman wrote:Yeah, those c-flex boats require a lot of fairing to get right. But it'll be solid in the end.
It didn't help that it was
A. My first C-flex boat.
B. I did not have a frame kit. I cut the frames from mylar.
C. I really was just learning to fibreglass
D. I got in a hurry so I could use it for the up coming fishing season.
There are some waves, small ones, in the bottom that are not going to ever come out. Just going to live with them.
Glass was cheap back then. I thought I followed the lamination schedule but this thing is over built to the max. All that said I still want it to look decent. It will never be up to the standard of some of the builds here. I will be happy with something less than Butt-ugly
Posted: Tue Jan 10, 2017 12:42 am
by cracked_ribs
In general, how did you find the C-flex process and results?
I saw it for the first time fairly recently (although I know it's already fairly old) and thought it was kind of interesting. Heavier for sure, but if you don't like cored materials and you want compound curves it's an interesting way to go. Looks pretty nasty to wet out, though, and someone was telling me that doing it with epoxy isn't really an option, although I have no idea whether that's actually true or not.
Posted: Tue Jan 10, 2017 12:59 am
cracked_ribs wrote:In general, how did you find the C-flex process and results?
Building boats like we do here is a lot more enjoyable. First you get much better support and second you are not dealing with all the fumes.
I am not too sure how the folks here feel about discussions involving other building methods and I do not want to misuse this forum so if you want to know more please send me a PM with your email and I would be happy to chat about it more.
Posted: Tue Jan 10, 2017 1:07 am
Well I now have 2 coats of graphite on the bottom. I will need to add at least one more. I have not been able to stay in the 24 hour window but I needed to sand anyway. What grit paper do you folks think is needed?
I did a little sanding on the sides before taking this picture so the bottom is a little dusty.
Posted: Tue Jan 10, 2017 7:03 pm
by Aripeka Angler
You're making great progress
120-180 grit. That's all you need, looking good
Posted: Tue Jan 10, 2017 11:46 pm
Aripeka Angler wrote:You're making great progress
Thanks Richard. I have a bunch of 150 grit so I will give it a try.
Some days I think I am gaining and the next I am asking what did I get myself into
I keep telling myself not to rush this part, done that before, but I am ready to move on to the next phase.
Posted: Wed Jan 11, 2017 9:10 pm
It has been cold and clear here the past few weeks. Wake up this morning and it has warmed up to 10f. This would be nice except we had heavy fog to go with it. Normally no big deal but today SWMBO had a flight out to Mother Russia. Flight got cancelled. Three different airlines were involved to get her there and the only answer I get from them is "tough beans" buy new tickets. Travel insurance bought and same story from them. Mommas not happy so I am mad at the world today
Posted: Wed Jan 11, 2017 9:19 pm
by Jeff
Bad day Fuzz, hope tomorrow is better for you both!! Jeff
Posted: Wed Jan 18, 2017 12:18 am
Well I got SWMBO off to visit family so I had some time to work on the boat.
That black graphite sure shows up every little flaw
Oh well only me and the fish will know. I have a little more touch up to do and then it will be time to flip this thing over.
Posted: Wed Jan 18, 2017 12:27 am
One of the side. It is far from perfect but it is a lot better than before. Had one of my fishing partners stop by and he commented that it was looking much better so that made me feel like it is worth the effort.
Posted: Wed Jan 18, 2017 6:08 am
by Jeff
Nice Fuzz!!! Jeff
Posted: Wed Jan 18, 2017 8:58 am
by cape man
Definitely looking better!
Posted: Wed Jan 18, 2017 10:00 am
by cvincent
Your rebuild is coming along nicely. I really like the lines of the Sintes designed hulls. I looked up Sintes and their shop is Metairie, LA, only about a 45 minute drive from my house.
Posted: Wed Jan 18, 2017 1:20 pm
cvincent wrote: ↑Wed Jan 18, 2017 10:00 am
Better call first and make sure they are open. Dave was a really nice guy but it is my understanding he passed a few months ago.
Posted: Wed Jan 18, 2017 2:00 pm
I knew I felt a bit of a nip in the air this morning
Just got around to checking the temperature, it is -30
You southern boys do not know the fun you are missing
Posted: Wed Jan 18, 2017 7:13 pm
by Aripeka Angler
Yes, looking much better! Your hull has nice lines as well.
What do you do for heat in your shop when it's -30F?
Posted: Wed Jan 18, 2017 9:31 pm
When I built the shop I put in floor heating loops. I have a 125,000BTU diesel fired boiler. Makes for really nice and even heat. I did not put any zones in the loops so I have to heat the whole place if I use the floor heat. With the price of diesel being what it is I made a partition about 18x24 to work in during the winter. That way I heat a much smaller area. I have two diesel fired heaters in the partitioned area that are 40,000BTU each. Even with that I will still probably hold off on boat work until it warms up to -10 or better. The room is warm but the slab is not and my poor little feeties get cold
Posted: Wed Jan 18, 2017 11:52 pm
by glossieblack
Just discovered this thread Fuzz. So this is what you've been up to. Very interesting hull form and project. What's the extension on the transom?
Posted: Thu Jan 19, 2017 2:41 am
I have been wondering when somebody was going to ask about the extension.
I have not gone into it much because JM does not really want to have anything to do with a home made bracket for some very good reasons and I respect that. So short answer is I will be building my own bracket for the boat. I will welcome any and all input from the group with the caveat that this has not been approved by the designer. I like to try new stuff and live with it not working out sometimes. You of all people should understand that given the project you have on your hands. I am not sure my sense of adventure reaches the same heights as yours
But I do admire and envy you for yours
Posted: Sat Jan 28, 2017 2:26 am
by glossieblack
Fuzz wrote: ↑Thu Jan 19, 2017 2:41 am
Sounds interesting Fuzz. How are you constructing the bracket, and to what size etc. This info and a few pics should get a discussion started.
Posted: Sat Jan 28, 2017 2:43 am
Thanks for the interest there GlossieBlack.
I need to get the bottom finished and flip it over before some of what I have in mind will be easier to see and talk about. I have seen it done before like what I have in mind but we will have to see how it all works out.
I have not worked on the boat for the past couple of weeks. Lives curve balls have sort of taken priority. First I came down with the flu. And then my father passed. I have been dealing with all that entails but hope to get back to the boat soon. Nice thing about boat building is it takes your mind off of other things for a while. My father lived a full and rich life with many dear friends. His passing was as easy as most could hope for. The rest of us should be so lucky when our time comes.
Posted: Sat Jan 28, 2017 4:23 am
by glossieblack
Fuzz wrote: ↑Sat Jan 28, 2017 2:43 am And then my father passed..... My father lived a full and rich life with many dear friends. His passing was as easy as most could hope for. The rest of us should be so lucky when our time comes.a
Sorry to hear about your father Fuzz. I lost mine in the same circumstances. In retrospect, my only regret is that I did not spend more time with his life long friends when his time was up. Because all too soon, they were gone too.
Posted: Sat Jan 28, 2017 11:01 am
by fallguy1000
Sorry about your father Fuzz. Can't wait to see the Sintes flipped. Dan in Mn
Posted: Sat Jan 28, 2017 12:32 pm
by narfi
Sorry to hear about your father.
Posted: Sat Jan 28, 2017 1:25 pm
by Jeff
Fuzz, sorry to hear about the loss of your father!! Jeff
Posted: Sun Jan 29, 2017 12:44 am
Thanks guys, very much.
One really neat thing happened out of this. The 4 grandsons got together and asked for the right to build the casket. They did a wonderful job. I did not inherit the carpenter genes from him but it was clear they are not lost and the boys have them
Next posts will be back dealing with boat stuff
Posted: Sun Jan 29, 2017 7:34 am
by cape man
Really cool about the casket.
Posted: Sun Jan 29, 2017 10:28 am
by Jeff
Fuzz, what a great memory for the grandson's!!! Jeff
Posted: Tue Jan 31, 2017 12:57 am
Well I got a little time to mess with the boat today. Getting closer to the flip but I keep finding little places that still need a little more work.
All that flare is a real pain to fare. If I get a couple more good days it should be good to flip.
Posted: Tue Jan 31, 2017 1:40 am
GlossieBlack when you asked me about my plans for the bracket I was thinking I had a sort of novel plan.............nope should have known better
I knew I had seen it done before and after just a little searching sure enough I found where I had seen it before. I plan on doing things pretty much like DayTrip did on his Bertram. Hope he does not mind but I am stealing his idea
Posted: Tue Jan 31, 2017 6:13 am
by topwater
[quote]All that flare is a real pain to fare./quote]
Fuzz you're a poet
But it sure does look good
Posted: Tue Jan 31, 2017 6:36 am
by cape man
I really dig the lines on her. Looks like she wants to run...flat or rough and sloppy...
Posted: Wed Feb 01, 2017 4:02 am
by glossieblack
Fuzz wrote: ↑Tue Jan 31, 2017 1:40 am
Great precedent! If my memory serves me correctly, Peter C provided Day Tripper with an of the back of the truck dimensioned drawing from Armstrong. Your boat is looking great.
Posted: Wed Feb 01, 2017 7:20 pm
The Flip!
Turns out there are two ways of doing it. One way is to have a well thought out plan, lots of help and all the rigging needed.
The other way is I am all by myself and I want this done today. Sort of the old "hold my beer and watch this" deal. I chose the latter.
It goes like this. Drill hole in side of boat and install BIG eyebolt with large backing.
Hoist boat up onto its side
Let uncontrolled flip commence
Go take a break until heart rate returns to normal. Inspect and see no blood no foul
The advantage of my chosen method is it allows you to check out how tough that new graphite bottom really is.
Posted: Wed Feb 01, 2017 7:36 pm
by Jeff
Wow Fuzz, all by yourself on this flip??? Glad it went well with that big boat!!! Jeff
Posted: Wed Feb 01, 2017 9:44 pm
Thanks Jeff,
I am just glad I did not drop it this time. I did that once before when it was about 10 foot in the air. Made a heck of a lot of dust fly
here she is all tucked back into her warm spot.
I am tired, think I will call it a day.
Posted: Thu Feb 02, 2017 12:16 am
by glossieblack
Great day's work Fuzz.
Now enjoy a drink or two.
Posted: Thu Feb 02, 2017 6:34 am
by Jeff
Yes, I think you deserve a break Fuzz!!! Looks nice tucked back in the shop!! Jeff
Posted: Thu Feb 02, 2017 10:23 pm
Spent the day removing the old transom and cutting back the stringers.The old transom was rotten but it was not about to come out easy.
This was the result of today’s work. Still have one more good day to get all the old stuff out. I am sure it could be done without my sonic crafter but I am not sure how. That little sucker paid for its self today.
Posted: Fri Feb 03, 2017 6:15 am
by glossieblack
Holy mother of ducks nuts Fuzz. If you ever run into the low life bastard responsible for that crap built interior, beat the shit out of him.
Posted: Fri Feb 03, 2017 7:51 am
by topwater
Glossie I am pretty sure Fuzz built it
Posted: Fri Feb 03, 2017 10:58 am
by Jaysen
I think that's the humor of GB's post...
Posted: Fri Feb 03, 2017 11:11 am
by cape man
Get ya' some! Looks like brutal work!
Posted: Fri Feb 03, 2017 11:53 am
glossieblack wrote: ↑Fri Feb 03, 2017 6:15 am
Not to worry Glossieblack, the moron who built this thing has been getting his butt kicked on a regular basis. I am pretty sure he is going to receive another one today also
Posted: Fri Feb 03, 2017 1:34 pm
by narfi
This sort of stuff is as interesting or more so than the new build threads.
I go through bouts of excitement planning and thinking about my build, read through all the build threads and see how great different peoples boats look when they are done, but I know the story doesn't stop there.
These rebuild threads make me wonder what I need to be careful of with the initial build to minimize issues down the road. I see lots of mentions of rotten transoms and rotten floors.
I know its important to over-drill and pack any holes drilled with resin.
What do you think caused the rot in your transom?
I know that Jacques doesn't require glass on the top of the sole and decks, but lists 4 or 6 oz as optional.
Just how durable is several coats of resin over time? It seems that inevitably something dings the floor allowing an entry point for moisture?
Fuzz, what would you have told your younger self to do differently, to make this project easier today?
Posted: Fri Feb 03, 2017 4:21 pm
narfi wrote: ↑Fri Feb 03, 2017 1:34 pm
A couple of things led to the rotten transom. One was it was not totally sealed. Two polyester was used and not epoxy. No matter what some might say poly just does not bond and stay bonded to wood. Three 25 years of time tends to work on things and find the flaws. This transom had a layer of mat between each layer of plywood. All that did was to make it a bigger pain to cut out. I am still not done, need to go town and get more blades for my sonic crafter.
The stringers were totally wrapped with about a 1/4 inch of glass. They are dry but with that much glass I do not think it matters. They would be plenty strong if the wood was not there and they were hollow. The deck is 3/4 plywood, just plain old CDX, with two layers of 1708 on top and nothing on the under side. So far the deck has been solid but I may cut it out just because. I have not decided on that yet.
The way to make it last is to get things well sealed so moisture has no way in. On the under side I think 2-3 coats of neat epoxy will do the trick but for the top side I like to add some glass. I am not sure you use much less epoxy going three coats than you use if you lay some glass with it. Somebody might have numbers and correct me on this but still I will glass any place that can see abuse.
Only thing I can think of to have made it easier today would to have made a lot more money so I could hire the crap work out
Posted: Fri Feb 03, 2017 10:48 pm
Just to make Glossie happy sure enough the moron got a butt kicking today
Spent the day with my sonic crafter, an air chisel and a crow bar. Just to top the afternoon off I broke out my little WMD for about an hour. I hate that thing but it does move some glass.
One clean transom to show for the days misery.
Posted: Fri Feb 03, 2017 10:51 pm
Surprisingly the outside transom skin is only about 3/16 inch thick. I am wondering if I need to build it up a little before installing the plywood
Posted: Sat Feb 04, 2017 5:44 am
by glossieblack
Fuzz wrote: ↑Fri Feb 03, 2017 10:48 pm
Fuzz, you're such a SNAG. Why not dynamite too?
Seriously, congratulations on the necessary surgery you're doing without blinking.
Posted: Sat Feb 04, 2017 11:59 am
Thanks Glossie
Well right after asking about the transom thickness I started hearing that damn Topwater and his buddy Murphy whispering in my ear. I got to be careful, I am starting the listen to the little voices
I have a bunch of 17oz biax so I think I will go ahead and add some.
Posted: Sun Feb 05, 2017 7:50 am
by cape man
Looking good Fuzz. I have to ask...wtf is a wmd?
Posted: Sun Feb 05, 2017 7:58 am
by Jaysen
Last time he and CL were passing the "weapon of mass destruction" label around it was in reference to an angle grinder.
Or was it a pot of beans?
Either way, something is getting messed up...
Posted: Sun Feb 05, 2017 9:50 am
by topwater
[quote] I started hearing that damn Topwater and his buddy Murphy whispering in my ear./quote]
Mr Murphy is unforgiving , you are a good man Fuzz
Posted: Sun Feb 05, 2017 12:07 pm
Good memory there Jaysen. 4 inch grinder with a 24 grit disk = WMD. If you want to move a bunch of glass it works like a champ but there is nothing subtle about it. If you are not careful you can cause yourself a lot of grieve.
Man you Florida boys, Topwater, Capeman and Jaysen are up and posting early. And on a Sunday no less.
Posted: Sun Feb 05, 2017 3:04 pm
by Jaysen
Early? I slept in a few hours.
Posted: Mon Feb 06, 2017 6:20 am
by cape man
Times awasting man!
Posted: Mon Feb 06, 2017 8:23 am
by topwater
I would post earlier but i can't log in between 700 am and 800 am
Posted: Mon Feb 06, 2017 11:32 am
Thinking about the plywood for the transom and stringers. The only thing I can get my hands on around here is fir marine. Anyone see a problem with that? It will be well covered with epoxy. I knew I should have bit the bullet and ordered a bunch of wood from here but I am not sure what all I might want.
And to make it pay out I would need to get a fairly large amount at one time. Having a bunch of extra plywood laying around might cause me to do something stupid
Posted: Mon Feb 06, 2017 11:49 am
by cape man
Posted: Mon Feb 06, 2017 1:36 pm
by Jaysen
Fuzz wrote: ↑Mon Feb 06, 2017 11:32 amHaving a bunch of extra plywood laying around might cause me to do something stupid
-er
fixed it for you...
Posted: Mon Feb 06, 2017 3:26 pm
by cvincent
I have a pirogue made from marine fir and epoxy that has been outside for 10 years or so. The boat is still as solid as the day I built it. Fir will last but will suck up more epoxy.
Posted: Mon Feb 06, 2017 5:53 pm
Posted: Mon Feb 06, 2017 5:55 pm
cvincent wrote: ↑Mon Feb 06, 2017 3:26 pm
Thanks Cvincent.
Sort of my thoughts but wanted to check before proceeding. If this rebuild lasts 25 years someone else will have to do the next rebuild
Posted: Mon Feb 06, 2017 8:23 pm
by Jaysen
I fully expect you to return the favor this weekend.
Posted: Tue Feb 07, 2017 12:05 am
[/quote]
[/quote]
You do know the longer you wait to show us an update the more critical this crowd will be
Posted: Tue Feb 07, 2017 4:28 am
by glossieblack
I've been pondering how you will install the new transom. As I understand it, you've got a freestanding existing skin of fibreglass, and you'll be installing the new transom on the inside or forward of it.Is this correct? If so, the challenge is get an excellent bond between the new transom and the existing skin, especially as the new o/b bracket is hanging of the aft face if the skin. Is this the situation?
Posted: Tue Feb 07, 2017 7:57 am
by Jaysen
Fuzz wrote: ↑Tue Feb 07, 2017 12:05 am
I want to give you guys plenty of ammo. Honestly though... all weather and daylight.
glossieblack wrote: ↑Tue Feb 07, 2017 4:28 am
I've the same question. All I can come up with is over drilling for bolts every 10-12" then using backing boards to distribute pressure (using torque wrench on bolts to ensure even pressure to backing boards) but that seems like a bad idea. Maybe using some steel L or U with some spacers could to reduce the number of holes but still... Seems wrong. Should be interesting to see how this is done.
Posted: Tue Feb 07, 2017 9:20 am
by cvincent
How about clamping a piece of plywood on the outside skin and then use screws from the inside to apply even clamping pressure when laminating your transom. Apply packing tape to the inside face of the exterior plywood mold so epoxy will not adhere to it. Once done remove screws and outside plywood mold and fill screw holes with epoxy. Just an idea.
Posted: Tue Feb 07, 2017 11:52 am
Funny you guys are all thinking about that. Me too. The plan is to drill holes in the skin and use bolts and 2x4 strong backs to suck it up tight. Lay a liberal coat of wood/epoxy glue on both the transom and plywood and setting it in place. I have been thinking about drilling a bunch of holes in the plywood to allow squeeze out and know I have a good bond.
First things first, I need to build up the transom skin some before I move on. That will be today’s project if all goes well.
Posted: Tue Feb 07, 2017 5:04 pm
by Aripeka Angler
Looking good Fuzz
You are a better man than me the way you attacked that transom. Nice looking work!
You are working pretty fast, do you have an estimated date that you will be crossing the finish line?
Posted: Wed Feb 08, 2017 12:16 am
Right now it is just me and SWMBO's dog at home so I have lots of time to mess with the boat. I do not expect this to last so I am making hay while the sun shines. I do not really expect to be done this year but we will see what happens. Some time next week I hope to get in a little winter king fishing.
Today I made up a filler piece to go in the transom cut out and then laid 58oz , 2 12oz and 2 17 oz, of biax on the outside skin to give it a little more thickness. Not sure it really needed it but I feel better about it so that is what counts I guess.
If things go well I hope to be putting in some plywood tomorrow.
Posted: Wed Feb 08, 2017 12:25 am
Right now all 4 stringers are cut back about 1 foot. The plan is to cut windows in the transom and carry the middle two stringers out and tie them into the bracket. Do you think I should cut the centre two back some more or just plan on using a bunch of glass to tie the old and new ones together?
Just checked my epoxy supply and almost went into a panic.
Need to call Jeff and the team in the morning and get a reload.
Posted: Wed Feb 08, 2017 8:25 am
by topwater
I don't know what the professionals would do but i was thinking run your stringers out to the bracket and glass them to
the existing ones in the boat then sister them right to the transom and glass. But i am not a naval architect nor do i play one on TV
Posted: Wed Feb 08, 2017 5:01 pm
by glossieblack
Fuzz wrote: ↑Wed Feb 08, 2017 12:25 am
Does this mean that the bottom section of the two extended stringers would become vertical skegs or fins on the underside of the bracket, because the bracket's bottom sits higher than the transom bottom?
Posted: Wed Feb 08, 2017 5:59 pm
The stringer extensions will carry through the transom and out to the end of the bracket. They will be cut to fit the bracket. Nothing will be outside of the hull or the bracket. I hope I explained this ok
I hope in a few days to be able to post pictures that will make things a little more clear.
Posted: Wed Feb 08, 2017 6:36 pm
Called the team at Bateau this morning for a little more epoxy. It was really nice to talk with them and they jumped right on my order. First class service
Just for info I paid less than I could have got it here and I do not have to drive 4 hours to go get it
Posted: Wed Feb 08, 2017 7:06 pm
by Jeff
Fuzz, thank you for the kind comments!! You just stay warm up there and rebuild that transom as soon as possible!!! Jeff
Posted: Thu Feb 09, 2017 1:25 am
Got the first layer of plywood installed today. I will need to wait until I get more epoxy to add more plywood. Thats ok I have plenty of other stuff to keep me busy for a few days.
My strong back clamping system seems to have worked pretty good. Had to drill and screw some blocks in the corners to get them pulled in good.
Posted: Thu Feb 09, 2017 3:34 am
by glossieblack
Fast and confident work. Go Fuzz!
Posted: Thu Feb 09, 2017 6:35 am
by cape man
70 F this morning. Transom is looking stout.
Posted: Thu Feb 09, 2017 12:15 pm
cape man wrote: ↑Thu Feb 09, 2017 6:35 am
Heck its 16F and snowing here this morning. This warming trend keeps up and I will have to go do a little fishing
70F is a great summer day here. On good years we might even get half a dozen days like that a year
Posted: Thu Feb 09, 2017 12:17 pm
glossieblack wrote: ↑Thu Feb 09, 2017 3:34 am
I am pretty much just following along with the way it is shown in the tutorial here.
I am sure things are going to be better than the first time around.
Posted: Thu Feb 09, 2017 8:14 pm
by Aripeka Angler
82'F was the high here today
Fuzz, what capeman didn't tell you was the part about the plunging temps here tonight
Brrrr, 45'F
I sure hope it warms up soon...
Posted: Thu Feb 09, 2017 9:33 pm
by Frank_HdG
Looking good Fuzz, really like the like the lines of that boat.
Posted: Thu Feb 09, 2017 11:54 pm
Aripeka Angler wrote: ↑Thu Feb 09, 2017 8:14 pm
Brrrr, 45'F
That sounds like perfect temperature to me. Nice and warm in the day and cool enough to sleep good at night
Posted: Thu Feb 09, 2017 11:57 pm
Frank_HdG wrote: ↑Thu Feb 09, 2017 9:33 pm
You better like the lines. They are pretty darn close to your boat
Hope your weather improves soon so you can get back to work
Posted: Fri Feb 10, 2017 8:19 pm
Well it is snowing to beat the band here today.
So could not really do anything outside until the snow stops. Waiting on my epoxy order and got to looking at the boat. Nothing good came from this
Next thing I knew the power tools came out. Now it looks like I am going to take this thing down to a bare hull and go from there.
I think I will take the deck out in sections so I have a level place to work from.
Posted: Fri Feb 10, 2017 9:26 pm
by Aripeka Angler
That's a pretty good dusting of snow!
I kid you about our warm weather, I really enjoy a little cold weather myself.
I look forward to checking out your boat this summer when we get up there
Posted: Sat Feb 11, 2017 12:37 am
Snowed most of the day but it was fine flacks so it did not amount to more than 4-5 inches.
I don't mind the weather kidding. The better the weather the more people who live there. I do not do crowds very well so crappy weather is the price paid.
Richard I am hoping by the time you get here I don't have to hide this thing in shame
I guess we will just have to wait and see
Posted: Sat Feb 11, 2017 5:56 am
by glossieblack
Am I seeing right? Everything including stringers stripped out?
Posted: Sat Feb 11, 2017 11:08 am
glossieblack wrote: ↑Sat Feb 11, 2017 5:56 am
No I am not that crazy
The deck and stringers are still there. The stringers are 2 one inch and 2 two inch. they are wrapped with close to 1/4 inch of glass. With that much glass I do not think it matters if the stringers are rotten or not. They would be fine if they were hollow. When I cut the stringers back they were solid so I am guessing the rest of them will be. When I remove the deck I will know for sure.
Posted: Sat Feb 11, 2017 2:23 pm
by cape man
76 F.
Posted: Sat Feb 11, 2017 3:43 pm
by BB Sig
77 F up here! That cool ocean breeze must be keeping the temp down for you.
Posted: Sat Feb 11, 2017 4:24 pm
by Jaysen
67 out here in the barrier islands. A thermometer over the sun warmed SAN reads much higher.
Posted: Sat Feb 11, 2017 5:40 pm
by narfi
-4f it's warming up was -20 this morning.
Posted: Sat Feb 11, 2017 5:46 pm
by Jeff
That is COLD!!! Try to stay warm!! Jeff
Posted: Sat Feb 11, 2017 5:48 pm
Narfi you are in a cold spot. It was only -8 here this morning, and it is a balmy 6f here now
Posted: Sat Feb 11, 2017 8:45 pm
by glossieblack
86 F.
Posted: Sat Feb 11, 2017 9:57 pm
Well the weather improved today
And the temperature was not too bad in the shop
Best I can do to defend us Narfi
Posted: Sat Feb 11, 2017 10:10 pm
I don't know what it says for the builder but this thing is a real bear to take apart
Cutting out a 1/4 inch of glass is about as easy as it has been
Posted: Sun Feb 12, 2017 8:48 am
by Jeff
Fuzz, nice warm shop!! A a beautiful picture of the area!!! Jeff
Posted: Sun Feb 12, 2017 9:52 am
by pee wee
I don't think I've ever seen a thermometer that went down to -60!! I guess there's not much need for them around these parts.
Good luck on dismantling that tank.
Posted: Sun Feb 12, 2017 1:27 pm
Jeff wrote: ↑Sun Feb 12, 2017 8:48 am
Thanks Jeff. At times this is truly a beautiful place to live. But then there are a lot of nice places on this old rock.
Posted: Sun Feb 12, 2017 1:34 pm
pee wee wrote: ↑Sun Feb 12, 2017 9:52 am
It is really tough when you see one pegged out. Makes the old nose hairs crackle
I finally said enough of the messing around and broke out the 7 1/4 skill saw and some carbide blades. Makes a mess but it will cut some glass. I have seen 40 foot hulls cut in half in no time using a circular saw and carbide blades
Posted: Sun Feb 12, 2017 3:16 pm
by cape man
We have a minus 80 C freezer at work for samples.
What are you cutting now?
Posted: Sun Feb 12, 2017 5:34 pm
Posted: Mon Feb 13, 2017 8:11 pm
No rest for the weary around here. I ordered more epoxy on Wednesday the 8th. Today I go check the mail and low and behold I have my order. 5 days and 2 of them were weekend days. Pretty darn good service I would say. Looks like it will be back to the transom in the morning.
Posted: Mon Feb 13, 2017 8:40 pm
by Jeff
Fuzz, yes, I must admit, USPS is not a bad service!! Glad it got there that quick!! Send me photos!! Jeff
Posted: Tue Feb 14, 2017 4:38 pm
Got the second layer of plywood installed. One more to go.
I installed three layers, total of 2 inches, in the bracket transom. Plan is to core the bracket with plywood and then install the stringer extensions. Does anyone see a problem doing it this way?
Posted: Tue Feb 14, 2017 4:50 pm
by Jeff
Fuzz, That looks great!! That was also a lot of work to get to where your are!!! Jeff
Posted: Wed Feb 15, 2017 12:50 am
Nothing picture worthy but it feels good to get the last layer of transom plywood installed. I hope to be to the point of tabbing things in tomorrow. I have a roll of 17oz biax so I am planning on using it for the tabbing. How many layers should I use? I think 3-4 but this is just a guess.
Posted: Wed Feb 15, 2017 2:29 am
by glossieblack
Bit of a milestone getting the 3 transom layers in. It's sundowner time here, so I'm having a cold one for you.
Sorry I can't give any advice on laminations, detailing the bracket and stringers etc - way out of my league. What hp o/b engine are you hanging of that bracket?
Posted: Wed Feb 15, 2017 11:11 am
glossieblack wrote: ↑Wed Feb 15, 2017 2:29 am
Thanks Glossieblack,
I am happy to get that part in back of me. I would sure hate to try and cut this puppy out. I am thinking I will put 150-200hp on it. I have an older 150 2-stroke that I will use at least for testing when the time comes.
Re: Sintes 21 Rebuild
Posted: Wed Feb 15, 2017 4:29 pm
by cape man
With the whole thing boxed in with ply and then tabbed, taped, and glassed with 1708, stringers running back all the way, can't see where anything should move at all. The main force will be transmitted forward through the stringers, and I just can't see how the torque could move that transom or the bracket with that much "beef" on it. The only thing I might want to add would be two diagonal/triangular shaped braces (2 pieces each of 3/8" ply laminated together) running from the top of the bracket down to the stringers.
All that said, ask the main man to be sure!
Am loving this rebuild David. When you first started posting I thought you were nuts, but now that her sexy lines are coming out of the haze she's a beauty for sure. Good on you for dressing her up for another decade or two of dancing. If I'm lucky you can take me for a wild ride one day. Just don't know if I want to try that beach trailer stuff though...
Posted: Wed Feb 15, 2017 4:35 pm
by cape man
Maybe it was just the 55 gallon barrels that made her look shabby...
Posted: Thu Feb 16, 2017 1:23 am
Well I did not get as far as I hoped today. I spent a large part of the day ploughing snow. Part of the price for living here I guess.
I did get the transom bedded and ready for tabbing in the morning if all goes well
Posted: Thu Feb 16, 2017 1:38 am
cape man wrote: ↑Wed Feb 15, 2017 4:29 pm
I sort of had the same thing in mind for the transom bracket. Between the stringers and the extra bracing I think it will be strong enough.
You are not the only one who thinks I am nuts. On more than one day I too am pretty sure I am nuts.
I always thought she had good bones just needed to be cleaned up some. Sort of like that girl we all knew in high school and never paid any attention to. 10 years later you run into her and realise you were an idiot.
You ever get up this way we will defiantly go kill some fish. And I promise to keep you off THAT beach
Posted: Thu Feb 16, 2017 1:46 am
cape man wrote: ↑Wed Feb 15, 2017 4:35 pm
What, you do not like my stylish boat stands
Posted: Thu Feb 16, 2017 10:51 pm
Might not look like much change but she is all tabbed in and two layers of 17oz biax applied.
I have always used the fast hardner but for this job I had the guys include some medium also. Boy am I glad as I am pretty sure the fast would have been going off before I was ready for it to. I will have to give it a light sanding and scrub down tomorrow and the lay two more layers of the 17oz biax on it.
Posted: Fri Feb 17, 2017 5:28 am
by cape man
That'll do.
Posted: Fri Feb 17, 2017 5:29 am
by cape man
Stout!
Posted: Fri Feb 17, 2017 6:26 am
by Jeff
Fuzz, nice work and glad the medium worked well for you!! Jeff
Posted: Fri Feb 17, 2017 9:00 am
by topwater
Nice , that's not going to come out
Posted: Fri Feb 17, 2017 9:25 am
by Jaysen
topwater wrote: ↑Fri Feb 17, 2017 9:00 am
Fuzz, I think you've just been challenged. I'm sure we can figure out how many HP it will require to meet said challenge.
Kidding aside, I may need to risk my sanity and fly up there (with a case or 7 of something distilled). I have a feeling a guy like me could learn a lot from a week working along side you.
Posted: Sat Feb 18, 2017 1:08 am
Well I got the transom lamination finished. does not look much different than before just more glass. I am having internet and photobucket problems today
Will post pictures when I can.
Thanks guys I think by the time the stringers and bracing are done there will not be much worry about this transom.
Jaysen it would be great to have you and the MRS come for a visit some time. I always have time for fishing and boat building
I am not too sure how much you would learn from me other than what not to do
Posted: Sat Feb 18, 2017 1:11 am
I have an idea for your challenge. I could put an eyebolt in the bracket and then take it over to the brother in laws place. We could pick it up by the bracket with one of his cranes and see if it stays put or not
Posted: Sat Feb 18, 2017 10:55 am
by Jaysen
Careful fuzz... you may find a bundled up, rum carrying southerner on your doorstep. CL would suggest that it's an idle threat but that's because the Mrs has been protecting him by constantly finding things that require immediate attention. Your problem is that she WANTS to visit Alaska.
My thought on the test was more along the lines of "more power!" Until either the boat or the humans are screaming in terror. I suspect the latter will occur before the former based on what I witnessed this morning (did you know you can actually hear grown men screaming over the sound of 3x350 outboards quite a distance away?).
Posted: Sat Feb 18, 2017 11:54 am
Those guys who put all that HP on their boats are just using it for a d... measuring devise. Only about 10% of the time you could use even part of the speed around here. But I guess it looks good.
As for you and SWMBO knocking on my door you would be welcome. I do suggest the summer months might be more enjoyable though. right now you would get to sharpen your snow ploughing skills.
Looks like I am going to get me some of that as soon as it is daylight.
Posted: Sat Feb 18, 2017 8:01 pm
With all the over laps on the inside of the bracket glass there was no way to have an even surface to bed the plywood to on the bottom and sides. So my solution was to cut the plywood into strips and bed each one in wood glue. I am sure I used extra material doing it this way but I got good bonding and that is what counts.
Posted: Sat Feb 18, 2017 8:14 pm
by Jaysen
Only because I'm slow...
How'd you keep the strips level/straight to the desired plane?
Posted: Sun Feb 19, 2017 12:26 am
Jaysen wrote: ↑Sat Feb 18, 2017 8:14 pm
Crude.............put down a pretty thick layer of glue and then wiggle each piece down to get good contact. After all the wood was in I placed a couple of 2x4s over them and put weight on the 2xs. For the sides I just drilled a few holes in the glass and used 2x4s and screws to pull things in good. Like I say crude but it worked
Posted: Sun Feb 19, 2017 8:08 am
by Jaysen
Whew. That's what I was thinking of as a solution to my own question. Glad to see I'm thinking "right" on how to solve things like that.
The other question that I don't seem to have an answer for in my head is why you ran the strips longitudinally and not transversely. If I understand how you plan to extend the stringers, wouldn't transverse strips distributed any force between the bracket and the stringers across the length of the strip vs just the width of a strip?
Posted: Sun Feb 19, 2017 12:40 pm
Jaysen wrote: ↑Sun Feb 19, 2017 8:08 am
Thanks for your question. To tell the truth I guess I did not think it through as well as I should have
My thought was the force from the transom bracket would be mostly push and pull so I laid the plywood thinking of that. The sides are cored the same way so they and the stringers should handle those forces. After thinking about it what you suggest would have been better. Maybe you should show up with that bottle of rum, good stuff please, and teach me a thing or two
Posted: Sun Feb 19, 2017 12:58 pm
by Jaysen
I was thinking "the stringers handle thrust load" leaving the bracket bottom to deal with bouancy and wave loads. I'm sure it's not as critical as we are thinking.
Rum acquired. It's 70+ here. I'm rethinking the visit until "global warming" gets a better foothold up there.
Posted: Sun Feb 19, 2017 1:04 pm
Maybe I will have Richard go visit your MRS and take the choice out of your hands
Probably should add he loves Alaska and might get her excited to come see this place.
Posted: Tue Feb 21, 2017 2:36 am
Nothing picture worthy today. Just laid some glass in the bracket getting ready to install the stringers. I have been pondering, could be bad I know, about the tie in of the new to old stringers. I am thinking of cutting the old stringers back at a 45 degree angle. The long part on top, short part next to the hull. My thought is it would act sort of like a key way and lock the new stringers in even better. Anyone have thoughts.
Posted: Tue Feb 21, 2017 8:28 am
by Jaysen
didn't you say the stringers are under 3/4" FG and the wood is just ... there? why not just removed the stringer say 4-5 inches and just use the FG as a connecting sleeve?
Posted: Tue Feb 21, 2017 9:20 am
by Aripeka Angler
Fuzz wrote: ↑Sun Feb 19, 2017 1:04 pm
I don't know how good my counselling skills are but I highly recommend a summer Alaska Vacation.
We are all booked and ready to go in August.
This will be my 4th trip, I absolutely love it up there. The fishing is fantastic and the weather is nice.
I also need to add that the folks are very friendly and super tolerant of us tourists
Posted: Tue Feb 21, 2017 1:07 pm
It has been nice and warm here ,10-25, the past few days. So last night two things happened. One my main house heater malfunctioned. 2 the weather did a sneaky and it is -18 this morning. Guess I will be working on the heater instead of doing boat stuff
Posted: Fri Feb 24, 2017 12:02 am
Well I got done pushing snow around the place and got the heater working so I had time to mess with the boat a little.
This is what I meant by cutting a sort of key-way in the stringers.
While I was at it I installed a float chamber in the bow. And installed some bracing for where the cleats and anchor winch will go.
Posted: Fri Feb 24, 2017 12:07 am
The float chamber is foamed in. After it was 95% full I left the stern piece of wood off and then pored foam and set the 1/2 over the top. The foam expanded and came out the hole. This gave me full contact with the plywood. That really stiffened up the plywood.
Posted: Fri Feb 24, 2017 6:24 am
by Jeff
Fuzz, I like the stringer cuts!!! Good idea!! Jeff
Posted: Fri Feb 24, 2017 9:24 am
by Eric1
That's looking really nice!
Posted: Fri Feb 24, 2017 1:25 pm
Jeff wrote: ↑Fri Feb 24, 2017 6:24 am
Thanks Jeff.
The stringer key way just seemed like a good idea as it sort of locks the new ones in place. We will see how it all works
Posted: Fri Feb 24, 2017 1:26 pm
Eric1 wrote: ↑Fri Feb 24, 2017 9:24 am
Thanks Eric. Your build puts this to shame but I can live with it.
Posted: Fri Feb 24, 2017 2:56 pm
by cape man
While in theory this may be "better", between the wood, the glue (epoxy), and a lamination schedule like you did on the transom, that baby aint moving in any direction. Looking good Fuzz! She's coming back to life!
Posted: Fri Feb 24, 2017 3:45 pm
Thanks Craig,
Jaysen had a very good point but I do not think it will make much difference in the end. Boy will I be glad to be done working inside that bracket. I seem to have a new epoxy ratio when working in there. One part on the bracket and one part on me
One good thing is I now have lots of water proof clothes
Have a new question and could use a little input on. I keep thinking I need to raise the sides to keep from falling out of the back of it. The big problem is I see no way to do it and not spoil her lines. So I am thinking I will put some wide gunnel’s on her and add handrails in the stern. What do you guys think?
Posted: Fri Feb 24, 2017 4:12 pm
by Jaysen
Sailboat style lifelines?
Tie a rope around your neck and affix the other end to something middle of the boat?
Strap yourself into one of those motorized chairs so you can't stand up but can still maneuver around the boat?
The Boss suggests "ignore everything the idiot says"
Posted: Fri Feb 24, 2017 4:20 pm
by cape man
why in the world are you worried about falling into that warm water? Please don't mess with her lines! Wide gunwales yes. Hand rails, maybe...
Posted: Fri Feb 24, 2017 4:39 pm
Jaysen wrote: ↑Fri Feb 24, 2017 4:12 pm
Posted: Fri Feb 24, 2017 4:54 pm
cape man wrote: ↑Fri Feb 24, 2017 4:20 pm
A buddy of mine stopped by and I was asking him the same thing. He had the same reaction as you and that got me to thinking. I am pretty sure it just not look right so wide gunwales it is. When the time comes we will talk about the handrails.
Posted: Fri Feb 24, 2017 10:27 pm
We have a pretty firm rule around here year around. Fall in the water without a survival suit on and they call your Mrs. a widow.
Last summer one of my fishing buddies fell in at the dock launching his boat. When he got out he claimed it was a good thing he was done having kids since he had just received a vasectomy
Posted: Sat Feb 25, 2017 1:28 pm
by fallguy1000
Can we get a better picture of the whole boat topsides or did I miss it?
I like the transom better full across.
Aren't the stringer extensions going to be too high on the bottom for the bracket? You don't want the bottom of the bracket beneath the hull plane right? It looks like you might need to make them higher and taper the bottoms to match the hull, but I'm just guessing. If you run a board out the back through the keyhole and put a straightedge on the boat hull; you'll see what I mean. Like I said-guessing here.
Posted: Sat Feb 25, 2017 2:27 pm
The stringer extensions were cut to match the old hull and the bracket both. They are in but not glassed yet. I will try to post pictures of them soon. As for the topsides not much to show. It is just a bare hull at this point but I will include one of those also. I am sitting here trying to decide if now is the time to cut all the old deck out or not. I will do it sooner or later but I hate to give up the level working area. It is a real pain walking around on a slant. Something sail boaters know too well
Posted: Sat Feb 25, 2017 3:22 pm
by Jaysen
Do it now while it's easy. Otherwise you'll be kicking yourself later.
Posted: Sun Feb 26, 2017 2:49 am
Jaysen wrote: ↑Sat Feb 25, 2017 3:22 pm
Nag, Nag, Nag. This should make you happy.
And NO the stringers are NOT coming out
Got the transom stringers in and bedded. Still need to glass them in. Probably will give the whole inside a bath first.
Posted: Sun Feb 26, 2017 5:25 am
by Jaysen
You said the wife was out visiting family... didn't want you forgetting how it works!
You built this when? 10yrs ago? Epoxy based or polyester?
I'm a bit jealous of your shop space. I spent more than an appropriate amount of time standing in the middle of my yard mumbling "post here... there... 24in on center... roof... walls... I'd need to budget for concrete... she needs to get a better job!" At least in neighbor will grab the boss today and tell her "get him on meds, he's scaring the biker gang again."
I think you'll be happier knowing you did that clean out now. All solid. Done right. No "Jaysen style hack" there.
Posted: Sun Feb 26, 2017 12:50 pm
I am pretty sure I built this hull in 1989. The whole thing was built using polyester. The deck was plain old 3/4 inch CDX plywood. It was covered with two layers 1708 on the top only. The underside was just raw wood. The deck was still solid but you could see the wood was starting to break down. In a few more years it would have been shot.
By using epoxy and the things I have learned since I built it I am sure it is going to be much better. I am sure it will still be around long after I am gone.
I was asked for a picture of the whole boat. If I roll it out into the main shop area for a bath I will try to get one. Might have a cloof moment and forget but I will try.
Posted: Sun Feb 26, 2017 1:00 pm
Jaysen you asked about the shop.
I was tired of working outside under tarps and what not trying to get my boat ready to fish every year. I did not even have a carport. In 1987 we had a fantastic fishing season and I had a ton of money burning a hole in my pocket. Without giving it a lot of thought I called a company up and had them come build me a shop. It is 40x60, 18 foot eves and the roll up door is 16x16. In hindsight there is a lot I would have done different. Starting with it is too big. Most of the space is just used for dry storage. A pole barn would have worked just as well for that and been much cheaper. Thats life, we live and learn hopefully
Posted: Sun Feb 26, 2017 4:41 pm
by glossieblack
Nice progress Fuzz.
Posted: Sun Feb 26, 2017 6:34 pm
glossieblack wrote: ↑Sun Feb 26, 2017 4:41 pm
Nice progress Fuzz.
Well well the travelling man is back
So how was NZ?
Thanks for the progress comment. I am not sure if I moved forward or not on some of this but I had to keep somebody happy
Posted: Sun Feb 26, 2017 7:15 pm
by glossieblack
Fuzz wrote: ↑Sun Feb 26, 2017 6:34 pm
So how was NZ?
A friend gave me the use of his lakeside cottage in Queenstown as a 70th birthday present. It has a good library and cellar, and immaculate Jaguar and Porsche sports cars in the garage that need to be driven. The narrow winding mountain roads radiating from Queenstown are as scenic as they are exciting to drive. So a wonderful holiday. Back to boat building tomorrow.
Posted: Sun Feb 26, 2017 7:25 pm
by Jeff
Glossieblack, sounds like a great holiday!! Welcome back to boat building!! Jef
Posted: Sun Feb 26, 2017 9:43 pm
glossieblack wrote: ↑Sun Feb 26, 2017 7:15 pm
So how was NZ?
Congratulations on the birthday. Ones that end in a 0 are big ones.
I think I need to upgrade my group of friends
Posted: Sun Feb 26, 2017 10:15 pm
by Jaysen
Fuzz wrote: ↑Sun Feb 26, 2017 9:43 pm
So how was NZ?
Only the ones ending in 0?
I thought the real big deal was actually witnessing someone adding 1 to your age. Otherwise...
Posted: Mon Feb 27, 2017 8:48 am
by fallguy1000
I have a Lund 16' aluminum 1988 predator. Not the same class of boat, but the reason I mention it is because it has rod boxes build in under the gunnels on each side. You could extend a flat section (mine are about 7-8" wide without measuring), and then drop a vertical board down and see if you get any rodspace, or with a 21' boat(looks beamy, mine is 84" outsides), I suppose you could go 10" horizontal if the angles don't work out. My hullsides are almost vertical and I think you have a little more flair, but just a guess. Anyhow, then there is a thin strip of aluminum on each side of the gunnel and you can set clippers, pliers, sinkers, beer, cigar, etc. on the top edge of the gunnel without fear of a kerplop.
I'd cut a board and rout a groove for plywood where the decks were desired and then in your case, glass it all up with 6 oz, and I'd be tempted to leave the printthrough for a little dirtcatcher, shoegrip, work surface, etc. Then the routed board makes the outside edge that keeps stuff from falling out of the boat. My rubber handled pliers ends up there a lot. And it makes the edge a nice place to lean without feeling like you are going over, and you can step on the gunnels getting in and out. And my gunnels are mounting area for not less than cleats, downrigger, marine antenna, RAM Mount for my fishfinder (I move it when I go out to a ball peg), bow and stern light mounts, trolling motor mount (for'd). There is also a nice locker near the captain's chair aft under the gunnel where I keep all the important stuff, sunglasses, skeeter dope, fuses, bag of candy, etc. The same box on the other side is for all my electronics-that one goes to the floor.
Regards, the boat looks really nice and clean inside.
Posted: Mon Feb 27, 2017 1:21 pm
FallGuy 1000 thanks for the input. I still remember I owe you a full size picture
As for the gunwales I have been thinking very much along the same lines as you posted. It will either be under them or some form of rocket launcher to hold the rods. Each has plus and minus to it. I to seem to use them for a shelf at times so they need a small lip to keep stuff from falling overboard. The boat has a fair amount of flare and I want them wide enough so that when you step to the side of the boat your leg hits them before your foot hits the hull.
I am planning on putting some form of cabin on this boat but I am still trying to work that out in my head. It will be just enough for day fishing with no plan to overnight. It would be easy if I was going centre console but that does not work so good here. I had a 20 foot open Whaler and while it worked just fine the fun factor was low on most days. Something about being cold and wet kept me from being able to have any fishing partners
And SWMBO says no head, no go
Posted: Mon Feb 27, 2017 1:51 pm
by Jaysen
Fuzz wrote: ↑Mon Feb 27, 2017 1:21 pm SWMBO says ...
That's the end of all arguments.
Posted: Mon Feb 27, 2017 2:03 pm
And it gets worse
It has to be private not just everybody leave the cabin till I am done. I am thinking something along the lines of what Peter did but maybe not so fancy.
Posted: Mon Feb 27, 2017 2:06 pm
by Jaysen
A 5 gal bucket and the costume from "Karate Kid" opening scenes won't cut it for you either? I thought only My SWMBO was that particular.
Posted: Mon Feb 27, 2017 6:05 pm
Nope...........I think they are all that way. And if you do not want to return home from fishing and find your new lodging to be with the dog I think it is worth the effort to keep them happy.
Posted: Tue Feb 28, 2017 1:05 am
After cutting out the deck there was a small lip left around the hull. I thought I would take care of it and then do some glassing. Nope..........no way
I did not want to grind it off so I used the SOB tool, Jaysen's term for a multi-tool. Ended up being an all day job. There was the usual 1/4-5/16 of solid glass to cut through. Had to stop part way through and go buy more carbide blades.
Posted: Tue Feb 28, 2017 5:10 am
by fallguy1000
Time for a little honesty. Too much caffeine can get me into trouble and the last thing you want to do is head to shore when you are miles out and the fishing is good or you have four downriggers out. The head serves all.
There is no purpose in making a boat to freeze in. Maybe like a lobster boat with a crouch down head in the front and a small 2 person enclosed helm to keep the water off?
You don't owe me a picture. The picture of the for'd section was enough.
Posted: Tue Feb 28, 2017 5:17 am
by fallguy1000
By the way, with all the width between the stringers, I'd be thinking about making a walkway to the head in between them with a step down from the helm and you'd pick up a foot of headroom for a crouch down head you could put for'd of the helm. If you do it, make sure you block it off from any fumes or you'll get a deadly CO backdraft. In your case, bracketed outboards-no, but for anyone else, relevant, so I mention. We had a little girl here in Mn die a year or three ago from boat CO. She got sick from a CO leak while sitting in the cockpit and they put her in the cuddy to rest and the cuddy had the worst CO and she didn't survive. All the best to you.
Posted: Tue Feb 28, 2017 9:34 am
by Jaysen
The SOB tool it still aptly named in my book.
1. When you first see it you think "What was that SOB thinking when he suggested this monstrosity?"
2. When you get it out and turn it on the first time you think "SOB! this thing is going to destroy my boat!"
3. Later you do something and say to yourself "S! O! B! Why did I do that?!? Where's that SOB tool so I can fix this"
4. And finally you get to the Fuzz status and say "This SOB [thing that is wrong] ain't a problem... I've got a SOB of my own just waiting to cut that off."
Am I wrong?
Posted: Tue Feb 28, 2017 12:21 pm
fallguy1000 wrote: ↑Tue Feb 28, 2017 5:17 am
You and I are thinking much alike. I have been looking at the space between the strings and trying to figure out how to use it. It is tough to put a cabin on a boat like this and it not look like crap. I will have to mess with it and see what I can come up with.
Posted: Tue Feb 28, 2017 12:26 pm
Jaysen wrote: ↑Tue Feb 28, 2017 9:34 am
Am I wrong?
I do think you have it correct.
When I first saw one I thought there is a waste of money. But then I read here that the Cracker just loved his so I had to buy one and give it a try. The more I use it the more things I find it is good for. Blades and such are spendy but there is nothing cheap about a boat
Posted: Thu Mar 02, 2017 12:57 am
Well I broke out the power washer and gave it a good bath today. Pictures do not look much different but it is cleaner.
I got the first round of glassing done on the stringers to transom. If things go well I hope to have the stringers all glassed in tomorrow.
Posted: Thu Mar 02, 2017 5:32 am
by Eric1
I rinsed my build yesterday. I had to get the dust off, that stuff gets everywhere.
Your looking good Fuzz!
Posted: Thu Mar 02, 2017 9:58 am
by Frank_HdG
Looking good, taking notes from this build so I can apply them to mine. I appreciate the detail on materials and methods for stringer and transom repair.
Posted: Thu Mar 02, 2017 11:38 pm
by glossieblack
Sure looks good after the clean.
Posted: Fri Mar 03, 2017 1:38 am
glossieblack wrote: ↑Thu Mar 02, 2017 11:38 pm
Thanks guys
If nothing else it is much nicer to work in a clean area.
So today I got the two other stringers set in place. Just the first round of tabbing done. After it goes off I will add more glass.
And I am done glassing inside the bracket.............maybe. I might get told to bring braces up from the stringers to the top of the bracket
Thinking of you here Capeman. There is three or more layers of 17oz biax on everything. If anyone is interested between adding the extra skin thickness and what not I have close to 7 gallons of epoxy in this transom rebuild so far.
Posted: Fri Mar 03, 2017 2:10 am
Thinking about the new gunwales. If they are supported every 18 inches how thick of plywood is needed? 1/4, 3/8 or 1/2
Posted: Fri Mar 03, 2017 5:07 am
by Eric1
Fuzz wrote: ↑Fri Mar 03, 2017 2:10 am
Fuzz, For what it's worth my C21 plans call for 1/4".
Posted: Fri Mar 03, 2017 5:53 am
by topwater
All my side decks and foredeck are 1/4 ". All backing plates for cleats and rod holders are 1/2" . I did not make individual backing plates
for each rod holder i made long sections . So the back 8 feet of the deck is 3/4 " thick .
Posted: Sat Mar 04, 2017 1:36 am
topwater wrote: ↑Fri Mar 03, 2017 5:53 am
Hey Topwater, what thickness material are the sides and roof on your boat made of?
And you too Eric if it is on your plans.
Heck you two might be up and on the forum before I go to bed if yesterday means anything
Thanks guys
Posted: Sat Mar 04, 2017 7:05 am
by Eric1
Fuzz wrote: ↑Sat Mar 04, 2017 1:36 am
Thanks guys
Hey Buddy,
The sides on my C21 are 1/4", Two layers of biax outside one inside up to the trim line. The design overlaps two side panels, I believe this yields a good bit of extra strength. You really have to build one of Jacques designs to see what he has put into them. I was clueless in the beginning but now I can see why he has designed the build the way he has.
Posted: Sat Mar 04, 2017 10:42 am
by topwater
Fuzz my pilot house sides , cabin sides and roof are 3/8". The pilot house top is 5/8 " divinycell foam with one layer of
12 oz biaxe each side.
Posted: Sat Mar 04, 2017 12:20 pm
Eric and Topwater thanks for the info. I am a long ways from building the cabin but I am trying to work up a material list. sort of hard to do when you are still working on the overall plan.
Posted: Sat Mar 04, 2017 1:00 pm
by Eric1
topwater wrote: ↑Sat Mar 04, 2017 10:42 am
I like the idea of foam for the top. I'll bet that cuts the weight down a good bit. I've seen a you tube video of a Yacht builder doing a top from foam/glass and carbon fiber. It turned out really nice.
Posted: Sat Mar 04, 2017 6:54 pm
by BB Sig
Not speaking from experience!
Jacques has routinely said not to expect weight savings when using foam. His reasoning in the past four using foam in this instance has been due to cabin comfort. Apparently, the use of wood will cause the moisture to build up on the inside where the foam doesn't have that issue. He could explain it better!
The weight savings would be me due to using Moore layers to support the cabin.
I would get a second, more experienced opinion though!
Posted: Sat Mar 04, 2017 9:22 pm
Divinacell is really nice to work with. My first skiff was built using it. Later I built the cabin of a 32 foot gillnet boat with it. The cabin was nice because no sweating and was warmer. It is a bit of a pain any place you need to fasten to. This was way before I knew anything about using epoxy. I am not sure I will fully enclose this cabin. Maybe just something to keep the wind and rain off of me. I am still trying to work a plan out in my head
Posted: Sun Mar 05, 2017 11:21 am
by topwater
I don't think my top weighed 10 lb. If you want to save weight up high that's the way to do it .
Also because i used foam i didn't have to put additional support under it like you would with ply,
makes for a cleaner install. because of the camber in the top it's real strong " i can kneel on it
and it doesn't move " and that's with one layer of glass each side.
Posted: Sun Mar 05, 2017 1:04 pm
BB Sig and TopWater ,
You guys have me thinking and that can lead to bad places
It just so happens I have three sheets of 5/8 divincell laying around the shop. I very well might use them for this project. Now I have more to ponder over
Posted: Sun Mar 05, 2017 1:16 pm
by Jaysen
Someone call the Russians. Tell them we need fuzz's wife sent back ASAP. Trouble is brewing. Just tell her "he's thinking". That should be adequate.
Posted: Sun Mar 05, 2017 6:01 pm
Jaysen wrote: ↑Sun Mar 05, 2017 1:16 pm
As long as when she returns and finds her dog and plants still alive I should be ok. I guess I should add and no more boats in the yard. I bought one when she was gone last time and it was not good for me
Dang Russians have no sense of humour they go from I am not pleased with you straight to here is your nuke
Posted: Sun Mar 05, 2017 8:44 pm
by seaslug
Hey Fuzz, Been following along the entire build, and the boat is looking great. I like the foam idea, and as you've seen in person, Johns' boat is beautifully done, and I was really impressed with the hard top. If you're concerned with having a top more solid to anchor to, but still remaining very light in weight, I built a hard top years ago for a 41' sportfish by making a simple mold with 2x6's cut on a camber, screwing down plywood, than covering with clear plastic sheeting. I used kiln dried Cedar ordered from the west coast, probably Oregon, milled down to 1/4" thick by 2" wide strips. The first layer went down with a pin nailer, so the nails could be pulled out later, than the remaining 2 layers in opposing directions slathered heavily with thickened epoxy, held down with stainless staples to be left in. Popped right out of the mold, and at 100 sq. feet was light as a feather for its size. Cut it to the desired size and shape, made a beautiful Mahogany border, and did a V groove varnished Teak underside that made it the most beautiful hard top I've ever seen on a sportfish. Of course it was glassed top and bottom also. Anyway, just another way of doing it, and very easy. Mike
Posted: Mon Mar 06, 2017 2:19 am
seaslug wrote: ↑Sun Mar 05, 2017 8:44 pm
Mike I would love to see a picture of the cedar hard top if you have one. It sounds like a work of art. I am still thinking about what to use on the cabin. Heck I am still trying to figure out what it is going to look like. As much as I appreciate beautiful wood work I know it is beyond me. Man has to know his limitations
I am sure every boat that was at last years boat builders meet was better than my best but that does not stop me from loving them.
I have three needs at this point for the boat.
1. It must have a head for SWMBO
2 It must be able to keep 2-4 people out of the weather at least when running. There no plan for ever sleeping on the boat, just daytrip fishing.
3. I must be able to set and retrieve the anchor without having to walk on outside decks. I want very little to no chance of falling over the side.
At this time I use a buoy to pull the anchor. It works good and you can do it all from the back deck but there is a degree of risk doing it that way. I anchor in 5-6 knots of current all the time. If you screw up and get the line in the prop you have big problems. I have two different friends who had this happen to them. Before they could do a thing the boat was swamped and they were washed away. One group made it and one did not. So if I can get away from the buoy deal I want to.
Posted: Mon Mar 06, 2017 8:48 pm
by seaslug
Hey Fuzz, I would like to see pictures of the hard top also, but that won't happen until I dig through boxes of old pictures. The build was pre- digital, so they aren't on the computer.
Posted: Wed Mar 08, 2017 2:28 am
Mike if you ever find the picture please post it. I keep thinking about it and I just know it had to be something to see.
Posted: Wed Mar 08, 2017 2:41 am
by glossieblack
Fuzz, have you got enough space to do a roundish 'bubble' shelter like DAYTRIP, with narrow sole-level passageways either side to get forward to anchor?
Posted: Wed Mar 08, 2017 4:39 am
by cape man
Hand rails and a safety line for when it's rough.
Posted: Wed Mar 08, 2017 10:36 am
by Aripeka Angler
I agree with Craig. This is a custom made boat I had several years ago. The bow rail kept me out of the water MANY times...
Posted: Wed Mar 08, 2017 1:27 pm
glossieblack wrote: ↑Wed Mar 08, 2017 2:41 am
I thought about something like that but I need to be able to run the boat from inside. Even on good days running across the water at 30mph gets to be a little cool. Add in a little rain and the fun goes away quick.
I do like the idea of deck level walkway forward. I am thinking of only making the walkway on one side. Don't need a full walk around like other places.
Posted: Wed Mar 08, 2017 1:29 pm
cape man wrote: ↑Wed Mar 08, 2017 4:39 am
I thought you were not too sold on handrails for this boat. I do agree they are a big help.
Posted: Wed Mar 08, 2017 1:36 pm
Aripeka Angler wrote: ↑Wed Mar 08, 2017 10:36 am
Dang, that is a nice boat
I am thinking about a way to have the head up forward with the door in the front. Solid bulkhead between cabin and head. Total privacy for the girls would make the boss happy. It is hard to squeeze everything in and it not look like crap.
Got some time to ponder on things. Not much boat work happening right now. got a little fight with the flu bug going on. So far it is a tie.
Posted: Wed Mar 08, 2017 2:04 pm
by Aripeka Angler
That's exactly the way my current center console is set up. I love it.
Posted: Wed Mar 08, 2017 3:54 pm
by Jeff
Richard, that is a beautiful 32!! Jeff
Posted: Wed Mar 08, 2017 10:31 pm
by fallguy1000
I don't think the boat is big enough to mess with anything other than a head forward under the helm. You can leverage the area under the sole for headroom (go right off the hull) and you can make a nice set of double doors and a step down from inside the helm and you can even put a little bubble for another 6" of headroom and still see just fine underway.
For the anchor, can't you run a winch, from either opening a window and manually, or spend some bucks on electric to avoid the hassle of walking or slipping into the sea? I don't like the idea of accessing and operating the anchor from within the head; too much sht can go wrong.
For all the headache, I'd rather go electric. Then if you are forced to untangle or go outside, you can just run grabrails on the pilothouse and the foredeck for safety, or another possibility would be to create an emergency access to the anchor via the head. Nice piece of tinted lexan and a hatch with simple release from inside only. Doubles as light for inside the head. I might have hinge parts to send you if you pay the freight. I have a hatch glass, too, but personally think it is too heavy (tempered and all).
Anyhow, small boat reduces the complexity of choices and makes the design easier. Your boat is smaller than Peter's, so I don't think you'll have the space to enter the head from for'd and also get a nice, dry boat for Alaska.
Just my 2 cents.
Posted: Wed Mar 08, 2017 11:26 pm
fallguy1000 wrote: ↑Wed Mar 08, 2017 10:31 pm
Just my 2 cents.
Fallguy you are correct on many of the points you made. The boat is too small to have everything in it. That is why I said it will be a day boat only with no plan to ever spend the night on it. I keep going round and round on the head. I know momma would like total isolation from anyone else on the boat. I had thought of using lexan for hatches. Letting light in makes things much nicer. And no matter what I will plan on the walking area being right on the hull. This will help the cabin height down and still have standing head room where it is needed. Putting a cabin on and it not looking like crap is going to be a challenge. I think I need to spend some time doing a mock up or two to get an idea of what works.
Thank you for the hinge offer but I am not even sure what I am going to do yet
Posted: Thu Mar 09, 2017 11:01 am
by fallguy1000
For the privacy in the head; easy, just let her turn on the weather radio when she heads in there and turn it up nice and loud for her. For the smells, you can even put in a vent or a DC fan. Then, for the extra appeal, a nice bottle of scented hand sanitizer.
Look at the 1987 Coastal Yachts Lobster boat for some ideas on lines. I think you are pretty heavy boat, so you could easily put a foam cabin on it without raising up the center of gravity too much I'd say on a good guess. And then with a motor out back, you might actually pick up some balance on your buoyancy with the cabin for'd. All speculation on my part, but I think you can make that boat really nice. The 87 Coastal is 3 1/2 feet longer, you just scratch the bunks and go head only for'd. But just think if you get another 10 years; you might not want to go pull the anchor from the stern, so consider all options.
Posted: Thu Mar 09, 2017 11:35 am
by Aripeka Angler
Fuzz, have you looked at the small cabin on the P-19?
Maybe build a similar cabin and add an electric windlass?
Posted: Fri Mar 10, 2017 4:02 am
Fallguy 1000 thanks for the input. No matter what I do I hope to make it look pretty decent.
Posted: Fri Mar 10, 2017 4:07 am
Aripeka Angler wrote: ↑Thu Mar 09, 2017 11:35 am
Good idea to look at that cabin. Thanks. I keep going around in circles but it is ok for now. I am not working on the boat for a few days until I get over this flu or whatever it is.
I have a Profish windless. Not sure of the model I will check it out and report back. Speaking of windless does anyone know a good place to get controls for it? I would love to be able to run it from the cabin.
Posted: Fri Mar 10, 2017 8:23 am
by topwater
You should be able to order them direct from Lewmar .
Posted: Fri Mar 10, 2017 1:08 pm
by fallguy1000
Lots of good going electric. If you get your anchor stuck in current/stone, you can even throttle up a bit, all from inside. Much harder to fight the current by hand. And since you are doing all the work; you can reward yourself a little. Just don't throttle up and forget. I did it once and my buddy held my ankles while I held my breath and dove for the prop with a fillet knife. There is no emoticon that does this justice. Least the water was mid 60s.
Posted: Fri Mar 10, 2017 1:58 pm
topwater wrote: ↑Fri Mar 10, 2017 8:23 am
That was my first thought. I went to their site and was directed to retailers.
Posted: Fri Mar 10, 2017 2:05 pm
by cape man
I am not sold on any of this! That is one sweet looking boat with beautiful lines that would be awesome with a center console and nothing else. Maybe a nice T top with zip up protection for foul weather.
But then you start talking about being scared about falling in that cold water, wrapping an anchor line around the prop and dying, and the woman has a shy bladder...now we're looking at some god-aweful cabin, a stinky head, and electric windless. After all that what the heck is a grab rail going to do to mess with the lines?
(you do know I'm just giving you crap. After all I'm old and my wife is fat
Posted: Fri Mar 10, 2017 2:09 pm
fallguy1000 wrote: ↑Fri Mar 10, 2017 1:08 pm
Getting hung up on the stern is something to avoided at all costs in strong currents. And it really does not matter the boat size. I once saw an ocean going 80 foot tug setting anchors for a new oil platforms derrick barge make that mistake. They were setting huge anchors off the stern and running out the rode and letting the buoy roll over the stern when all the rode was out. Something happened and the buoy end was not loose. They were going down current and when they came to the end the boat stopped current rolled over the stern and tug was gone in less than one minute.
Posted: Fri Mar 10, 2017 2:19 pm
by cape man
The water doesn't have to be "Alaska Cold"...
http://www.tampabay.com/news/humaninter ... ll/1075378
The story doesn't give the detail that they tied the anchor line to the stern when they were trying to break it free. Twin outboards pulled her down fast!
Posted: Fri Mar 10, 2017 2:20 pm
by cape man
Okay, enough of that. Boat porn time! Feed us something Fuzz!
Posted: Fri Mar 10, 2017 2:30 pm
cape man wrote: ↑Fri Mar 10, 2017 2:05 pm
Well you are younger than me and having met your wife I know she is NOT fat.
Problem is I know you are right about the centre console dag gum it.
Posted: Fri Mar 10, 2017 2:31 pm
by Jaysen
I still think the answer is the "Karate Kid" opening costume...
But then I'm not the one that will have to deal with your angry Russian.
Posted: Fri Mar 10, 2017 3:53 pm
by cape man
just a quick google search and looky looky what I found.
http://www.gandermountain.com/modperl/p ... Ai3I8P8HAQ
In Russian they call it Без перевода, which is "hidden toilet".
And then there's this for anyone who can't stay in the boat!
All way below the price of a fugly cabin!
Posted: Fri Mar 10, 2017 3:56 pm
by cape man
But if you're sure you need a cabin, here's a possible design suggestion...
Okay...I'll stop. As soon as you deliver some pictures of that boat!
Posted: Fri Mar 10, 2017 4:08 pm
by Jeff
Nice cabin Cape Man!!!!! Probably a fast one too!! Jeff
Posted: Fri Mar 10, 2017 6:09 pm
by Aripeka Angler
You don't need a windlass to pull the anchor.
25 lb anchor, 30 feet of 3/8" chain, 250' of rode, no problem.
You just gotta invite a couple of stout friends to go fishing with you
Posted: Fri Mar 10, 2017 10:24 pm
Jaysen wrote: ↑Fri Mar 10, 2017 2:31 pm
What is your address? I might send her to have a little talk with you.
Posted: Fri Mar 10, 2017 10:27 pm
cape man wrote: ↑Fri Mar 10, 2017 3:53 pm
You might find it funny but I keep a suit just like that on the boat for every passenger.
Posted: Fri Mar 10, 2017 10:34 pm
cape man wrote: ↑Fri Mar 10, 2017 3:56 pm
That right there is what I am afraid of happening. Will try to avoid it at all costs.
I do not mind the ribbing at all
If I did not want you folks input I would not be asking for it.
Here is a picture just to keep the wolves at bay. I have not done much the past couple of days, been a little under the weather.
Posted: Sat Mar 11, 2017 1:53 am
Aripeka Angler wrote: ↑Fri Mar 10, 2017 6:09 pm
Does this mean you and your son will be pulling the anchor this summer
Posted: Sat Mar 11, 2017 3:47 am
by Eric1
Thanks for the boat porn! You have really come a long way with this rebuild and she's looking great. Thank again for your input on casters. I left them off as I'm vertically challenged as the kids say. It would be nice to roll her outside for a proper wash down. That's a must before primer or paint too.
Posted: Sat Mar 11, 2017 8:53 am
by fallguy1000
Center consoles are overrated for certain places. What is the real reason for center console vs enclosed helm? The center console is generally and simply more open, at least that is what I see. You can cast off the foredeck, run the sides, etc. You can't run cabin heater in vinyl. So, while it might look pretty, for an Alaskan boat that Fuzz might get his Mrs. into; he probably needs to enclose it. If he were down in FL, different story, but up there when it is 40-50F on the morning; an enclosure keeps the coffee warm.
Sorry Fuzz, don't mean to be a dream killer. But do you see many center consoles up there? It wouldn't be my first choice. We don't even see them much on the Great Lakes. Guys troll with cabins on Superior, or fish out of open boats cuz they don't have a cabin boat.
Posted: Sat Mar 11, 2017 7:54 pm
by cracked_ribs
I would tend to agree with the above re: centre consoles.
I think of CC boats as extremely specialized instruments; the sportbikes of the boat world. The question is rarely "is there any reason not to use this as my general purpose boat" and frequently "do you match the specific requirements that this machine is suited for?"
I'm much further south on the west coast than Alaska...but even here, CC boats are really rare. They do get used for specific applications and I grew up on open boats myself because I am descended from a long line of people who are inexplicably indifferent to the cold, but now I would only have one as a second boat, and only if I was primarily interested in fishing.
Since my wife is usually on the boat with me, it's not really a practical configuration. Besides which I generally launch out of a river and the bar crossing is such that without an enclosed bow, I'd have a boat full of water half the time. Scuppers are great and all but they're not instant and I'm not super excited about having to put everything in lashed down dry bags just to keep it intact.
Anyway I guess the point I'm trying to make is that CC boats get a ton of press, but I think that's because the internet is dominated by Florida boating culture. Further north, I don't think they do what most people need. But then if you have multiple boats that's less of a concern. I wouldn't own a GSXR1000 as my only bike if I lived in Dawson City, Yukon...but if I already had a R1100GS, I might buy one as a summer toy.
Posted: Sun Mar 12, 2017 3:34 am
Cracked ribs and Fall guy thanks for the input. Both of you are correct in your thinking, I really need to be able to get out of the weather at times. I have run an open whaler for a few years and there has been more than one trip that I thought hypothermia was going to set in.
The problem is Capeman is also correct in that the boat was born to be a centre console and putting a cabin on it might make it look like crap.
I am still flipping back and forth on this one. For now there is a bunch of stuff that I can do while I am making up my mind.
Posted: Sun Mar 12, 2017 9:31 am
by cape_fisherman
Why not compromise, go with a center console, and build a doghouse? I'm not a doghouse type of guy, but I see their benefits in the proper climates.
Posted: Sun Mar 12, 2017 1:56 pm
by fallguy1000
Take a picture of the boat from the front at a good angle, print it out, and just start some sketches on paper first.
The CC is not a boat for cold climates. These FL and SC guys have never experienced the morning run at 39 degrees. Alaska's average high temperature doesn't hit 70F all year. That is like the low temp for FL. I am only in the middle ground here in MN, but we rarely see CCs here on any big water. The salmon fishing on the Great Lakes are typically May and June, where lows are 40s and highs are 80, but morning runs are still cold and damp. Add rain and you are done fishing without a cabin. Only the hardest guys go fishing in the colder weather in open boats. I'm one of them, but it isn't something I'd like to do if I'm 75.
Miami's average temperature is the lowest in January at 60F. Anchorage average temperature is the lowest at 10F in January. The temperature swing is literally about 50 degrees on the low and 32 on the high.
Posted: Sun Mar 12, 2017 2:40 pm
by cape_fisherman
Posted: Sun Mar 12, 2017 2:48 pm
by BrianC
Cut and paste these to see what it will look like:
http://bateau.com/studyplans/C_PH2_study.pdf
Posted: Sun Mar 12, 2017 6:31 pm
by cape man
So I was fishing in the strait of Juan del Fueco, between the Olympic Peninsula and Puegot Sound two years ago in February, snow flurries as we ran in, quartering into 5 to 6 foot breakers. Only thing that saved us was the full cabin on the 18 foot boat we were in. Got it. Weather and water can suck.
All I'm saying is this boat has a VERY sexy set of lines as an open boat. All of you are right. We are spoiled down here.
Finish her, bring her down to Florida, and I'll build a shed you can park her under until you find that vacation house you talked about
Or put a nice cover on and we'll come up and fish there.
Posted: Sun Mar 12, 2017 6:54 pm
How about we do both? Finish this thing and bring it south and leave something to fish up here. Now that there is my dream
Posted: Sun Mar 12, 2017 8:14 pm
by Jeff
Fuzz, I think you and Cape Man may be on to s great plan for both of you!! Jeff
Posted: Sun Mar 12, 2017 8:22 pm
by Aripeka Angler
Google Parker boats. They have nice enclosed cabins on small boats.
I think something like this would work for you...
This is a 21' boat. Ignore the girl on the swim platform, it's the only pic of the boat I could find
Posted: Sun Mar 12, 2017 8:49 pm
by Aripeka Angler
fallguy1000 wrote: ↑Sun Mar 12, 2017 1:56 pm
You sure about that?
I have fished the GOM for over 50 years.
I don't have enough fingers and toes to count the number of times I have run offshore in very cold conditions.
Some of the time in center consoles while freezing to death
Posted: Sun Mar 12, 2017 9:51 pm
Aripeka Angler wrote: ↑Sun Mar 12, 2017 8:22 pm
Those Parkers would make good fishing boats for this part of the world. Being an east coast boat we do not see too mkany of them around here but the ones I have seen look nice.
As for the girl................I am a male the only way I could ignore her would be if my heart stopped beating
Posted: Sun Mar 12, 2017 10:02 pm
by Jaysen
Fuzz wrote: ↑Sun Mar 12, 2017 9:51 pm
Get caught staring and madam Fuzz may assist with stopping the heart beat.
Posted: Mon Mar 13, 2017 7:31 am
by glossieblack
Here's the deal. You take the boat, I'll take the girl.
Posted: Mon Mar 13, 2017 9:58 am
by topwater
What boat
Posted: Mon Mar 13, 2017 7:20 pm
by fallguy1000
I really like her lines!
Posted: Mon Mar 13, 2017 9:20 pm
Well it is pretty clear what will liven up a thread in a hurry
Posted: Fri Mar 17, 2017 6:55 pm
by cape man
One would think these guys' wives were in Russia!
Posted: Fri Mar 17, 2017 7:48 pm
by Eric1
Posted: Fri Mar 17, 2017 9:24 pm
No boat building around here the past few days. I lost my battle with the flu bug and it has been kicking my butt
I hope to be back on it in a day or two.
Posted: Fri Mar 17, 2017 9:32 pm
by Jaysen
Get better old man.
And stop looking at pics of those young chicks. You know they all turn into pecking hens over time...
Posted: Sat Mar 18, 2017 3:06 am
Jaysen wrote: ↑Fri Mar 17, 2017 9:32 pm
High end boats and young chicks are both nice to look at even if that is as far as it will ever go
As for the pecking part I have learned it does not matter what part of the world they are from. In the end they are all sisters.
Posted: Sat Mar 18, 2017 7:04 am
by Eric1
Hope you feel better soon!
Posted: Sun Mar 19, 2017 5:37 am
by glossieblack
When you're crook you lay low and at times drift in and out of productive thought.
The downside is that it mostly feels like shit.
The upside is that occasionally a blindingly obvious good idea drifts into consciousness.
Anything cogitating on the shelter/cabin front?
Posted: Sun Mar 19, 2017 1:17 pm
Thanks for the get well wishes guys. I am over the hump, I think, just a little weak still.
Glossieblack while I was doing nothing but laying around I did have an idea. I want to do a mock up first to see how it looks. If I do go this way I will have to decide if I will post pictures or not. CapeMan will hate it enough he might send a hit man for me
If the mock up works I will explain my reasoning but no reason to borrow trouble.
Posted: Sun Mar 19, 2017 9:47 pm
Well I got around to pouring a little foam in between the stringers. I used about a quart and thought this is not going to ever fill the space, maybe it is too cold
So I take my turkey fryer and warm some water up to about 120f, pour it in a cooler, put a gallon of foam in the cooler and let it heat soak for about 15 minutes.
It was like I was using a totally new product. When I poured the clear part into the mixing cup it was foaming just a little. When I added the dark part B I had about 5 seconds of stirring before the chemical reaction started. Maybe it was a little too warm
I will say I got a lot more expansion than what I am used to. Anybody know the ideal temperature for this stuff?
Posted: Sun Mar 19, 2017 9:57 pm
by Jaysen
Put one in the hot water, the other outside... shoot for the middle
by Eric1
Glad you are back at it. Good idea to water bath the foam.
Posted: Sun Mar 19, 2017 10:02 pm
I had it sitting in front of the shop heater. It was probably about 70f. boat is around 60F, best guess. I thought I read 85f was a good temperature so that is why I tried the warm up deal.
Posted: Tue Mar 21, 2017 1:43 am
Ok need a little input. What size chase tube for two #10 wires. Also size for fuel line and any other stuff. I have a roll of 1 inch and a roll of 1/2 inch flex conduit.
Also is it better for control cables to exit the transom straight on or from the side?
Thanks guys
Posted: Tue Mar 21, 2017 6:46 am
by cape man
1".
Posted: Tue Mar 21, 2017 4:21 pm
by AmbitiousRookie
I don't have my uglys reference handy but think it's 6 #10 wires in 1/2 emt.but that's get I think a little tight if you have to pull more. Bigger always better unless it's emt and your the one bending it lol
Posted: Tue Mar 21, 2017 4:29 pm
by cape man
My choice was based on having to pick from big (1") or small (1/2"). Ask me how I know you can run a chase that's too small....
Never again. You have plenty of space for the larger tubes.
Posted: Tue Mar 21, 2017 5:17 pm
by AmbitiousRookie
So we don't like 3/4
I know what you saying I was only pointing out If I was telling someone else do it i always went bigger if I did it I weight the pro and cons a little closer 1" would kick my butt sometimes running 500or600 ft bending around everything.
Posted: Tue Mar 21, 2017 11:08 pm
Ok what size for shift/throttle cables? I will have three 90s, long sweep, in the line.
Posted: Wed Mar 22, 2017 6:17 am
by cape man
1.5" with sweep 90s. That's what I used and they ran no problem.
Posted: Wed Mar 22, 2017 11:08 am
Thanks Cape Man. Glad I asked before running them. Seems strange but I do not remember ever running chase tubes before.
Posted: Wed Mar 22, 2017 11:42 am
by Jeff
Fuzz, Are you back to full speed with your health? Jeff
Posted: Wed Mar 22, 2017 11:47 am
Jeff thanks for asking. I would say I am 90% or better. But 90% of a cloof is not all that much at times
Posted: Wed Mar 22, 2017 11:56 am
by Jeff
Fuzz, Just glad you are better!!! Jeff
Posted: Wed Mar 22, 2017 2:14 pm
That almost all went down hill this morning. I went out to the shop to mess with the boat a little bit. Got hungry and headed back to the house. As soon as I got out the shop door I ran nose to nose with a moose. She was not happy, I was really not happy. This time of the year they are tired from the snow and cold to go along with being hungry. Tends to make them just a little aggressive.
Retreated back into the shop as fast as I could and gave her 30 minutes to move on. At least it was daylight so I could see her.
Posted: Wed Mar 22, 2017 2:19 pm
by Jaysen
Just out of curiosity, go you folks keep a couple pair of spare shorts near the doors up there? I would have needed to change mine after that.
Posted: Wed Mar 22, 2017 2:25 pm
I have lots of clothes and a washer and dryer in the shop. Never know when you will need them
Posted: Wed Mar 22, 2017 3:24 pm
by Eric1
Fuzz wrote: ↑Wed Mar 22, 2017 2:25 pm
Maybe TV hypes it up but I would not walk outside without a .44 mag in the least if I lived up there.
Posted: Wed Mar 22, 2017 5:42 pm
Yep TV hypes it way up for ratings. We have lots of moose around all the time and very rarely a bear. Other than that there is not a lot to worry about. Compare that to you folks down south. Insects, snakes, gators and all the other stuff that bites. I figure it is way safer here than there.
Posted: Wed Mar 22, 2017 5:47 pm
by Jaysen
The gators and bugs are pretty passive when you compare them to the meth heads down here. We can ship a few your way if you'd like to experience them yourself. A warning though... they tend to procreate at the expense of the tax payer.
Posted: Wed Mar 22, 2017 9:01 pm
Unfortunately we have plenty of those just like everybody else
But thanks for the kind offer.
Posted: Wed Mar 22, 2017 9:07 pm
by Jeff
Yes guys, too many everywhere in the US!! Jeff
Posted: Wed Mar 22, 2017 9:08 pm
Eric1 wrote: ↑Wed Mar 22, 2017 3:24 pm
I used to carry of 44 but I upgraded to a 500 smith a few years ago. It makes a 44 seem like a 38 special. Shocking part is it does not kick much more but boy does it hit harder.
Posted: Wed Mar 22, 2017 9:10 pm
Jeff wrote: ↑Wed Mar 22, 2017 9:07 pm
It is sad to say that the most dangerous thing around is another human being no matter where you live.
Posted: Wed Mar 22, 2017 10:09 pm
I have been doing a little on the boat. I remembered Cape Man talking about a brace running from the stringers up the transom so I made up a solid glass bracket and glassed it in. The motor will bolt through it on one side and I think I will bolt through it to the transom also. Just trying to keep Top Waters buddy at bay.
I will fill where the foam is and then glass over it. The middle will be open with a drain plug.
Posted: Wed Mar 22, 2017 10:12 pm
I want plenty of flotation in this hull so I am filling between the inside stringers and glassing over them. Sort of like a SeaCrafts stringers.
Posted: Wed Mar 22, 2017 10:22 pm
Crash bulkhead installed. The centre section is the rode locker for my Lewmar Profish anchor winch. I have the winch but still need to find a place to order the switchs and control box. No luck going to the Lewmar site. They refer me to dealer sites.
No more boat work till next week. Got to go down south and teach some chumps they still do not know how to play hearts
Posted: Thu Mar 23, 2017 5:40 am
by Eric1
Fuzz wrote: ↑Wed Mar 22, 2017 9:08 pm
I may have to upgrade, I love large bore handguns! I like to deer hunt with them. I hunt dense thickets mostly. Shots seldom go more than 80 yards.
The boat work looks great, What temp did you finally go with on the foam?
Posted: Thu Mar 23, 2017 9:14 am
by topwater
Fuzz nice work
My buddy is not to happy right now , nothing to do but he is always watching
For winch parts check out Defender.com they might have what you need or Jamestown distributors .
Posted: Thu Mar 23, 2017 9:21 am
Eric I went with about 100f. The first gallon I heated up to about 120f and you only had about 10 seconds to stir before it started to go off.
Top Water thanks for the info I will check them out when I get back. So far you have your buddy under control but I am not sure it will last
Posted: Thu Mar 23, 2017 9:36 am
by Eric1
Fuzz wrote: ↑Thu Mar 23, 2017 9:21 am
Thank You.
Posted: Sat Apr 01, 2017 10:26 pm
Well I got back from my little trip and back on the boat. Nothing picture worthy just starting to install some deck. I am using 3/4 nidacore for the deck. I will be glad to get some deck down so I do not have to walk on a slant.
Posted: Sat Apr 01, 2017 10:28 pm
Speaking of the deck I am planning on 3/4 nidacore with 17oz on the under side and two layers on top. Anybody who has used this stuff does that sound like enough glass?
Re: Sintes 21 Rebuild
Posted: Sun Apr 02, 2017 3:25 am
by glossieblack
Fuzz, It's just past 5 o'clock Sunday here in Noosa, so I've just raised a glass to Cracker Larry. Now I'm raising one to you as a fellow deck builder.
Posted: Sun Apr 02, 2017 12:56 pm
Thanks GB, it is nice to be in the same toast as CL
I am not feeling like there is any rush on the boat today. This winter is never going to end so no need for a boat. I woke up to 3 inches of fresh snow on the ground.
April fools one day late I guess.
Posted: Sun Apr 02, 2017 8:45 pm
by Aripeka Angler
Fuzz wrote: ↑Sat Apr 01, 2017 10:28 pm
I have fished with a commercial guy who had a nidacore deck.
He was pretty redneck, I'm sure he didn't put two layers of 17oz on the topside.
The deck was strong and didn't flex, but it was well supported with stringers and framing.
The lamination schedule you are suggesting should work well...
Are you going to be using 1708?
Posted: Sun Apr 02, 2017 11:17 pm
Thanks Richard. I have both 1708 and some 17 oz plain biax. I like to use the plain biax more because the 1708 is a pain to wet out. I think I can put down two layers of 17oz and use the same amount of resin as one layer of 1708. I have not kept close track but it sure feels that way to me. As for the span the max is just under 20 inches. I made up a 27 inch by 96 inch panel with 2 and 1 layer of 17oz biax. When I picked it up by one end I could see some flex in the panel. Not sure if that means anything or not
I would love to go ahead and get all the deck down but I am waiting for my fuel tank to arrive.
Posted: Mon Apr 03, 2017 12:23 am
Well I am feeling brave so I thought I would show what I am thinking of making my boat look like.
This design looks strange to you folks down south but it works better in so many ways I just want to try it.
All that being said if anyone sees CapeMan buying tickets to Alaska please give me a little warning
Posted: Mon Apr 03, 2017 12:28 am
by narfi
I like it (And the 185......)
Gives me some ideas too....
Posted: Mon Apr 03, 2017 12:36 am
narfi wrote: ↑Mon Apr 03, 2017 12:28 am
The 185
Posted: Mon Apr 03, 2017 12:38 am
by narfi
Fuzz wrote: ↑Mon Apr 03, 2017 12:36 am
The 185
Hehe look at your picture again. 2 things take up the entire image...... your eyes only saw one.
Posted: Mon Apr 03, 2017 12:42 am
The mind only sees what it wants to. You fly boys are wired just a little different
Posted: Mon Apr 03, 2017 4:38 am
by Eric1
It's different to us east coasters but it will take care of the head issue. That is gonna be a strange looking Captain's chair!!
Posted: Mon Apr 03, 2017 6:08 am
by glossieblack
Fuzz wrote: ↑Mon Apr 03, 2017 12:23 am
I think it's a winner for your conditions. It's the same functional layout used by cray boats in the cold climes and at times brutal sea states of southern Tasmania, Australia. Same functional logic, same salty appearance. And yours will look better than the boat in the picture, because yours has a prettier hull form. I like it a lot.
Go Fuzz!
Posted: Mon Apr 03, 2017 6:34 am
by Jeff
Nice Fuzz!!! Jeff
Posted: Mon Apr 03, 2017 9:24 am
by Jaysen
what's the point of mounting the plane sideways on the boat? That would make for a very abrupt, one time landing...
I could see that being an attractive solution up your way.
Posted: Mon Apr 03, 2017 1:05 pm
by cape man
What about this?
Posted: Mon Apr 03, 2017 1:41 pm
I was wondering what your reaction was going to be
I have to tell you I actually laughed until I had tears. Best laugh I have had in a long time.
I know you do not love it but it does work for my wants in so many ways. So now I just have to see if I can pull it off. It would be much easier with a larger boat.
Posted: Mon Apr 03, 2017 3:08 pm
by cape man
Posted: Tue Apr 04, 2017 1:30 am
CapeMan that is a beautiful boat! I agree the swept back look does look nice. I could easily go either way with the cabin front so I will look at it both ways. It is hard to tell when you are chain yanking sometimes and I was not expecting a serious reply from you
I still need to do mock ups to see how it is going to look.
Posted: Tue Apr 04, 2017 9:08 am
by topwater
Posted: Tue Apr 04, 2017 1:17 pm
by cape man
Moi?
Posted: Tue Apr 04, 2017 8:42 pm
by Aripeka Angler
Funny/strange, you were asking about your nidacore deck. This is the boat I was talking about with the nidacore deck and it also has a an aft cabin. Doesn't look much like a commercial fishing boat but I can assure you it was. The Captain is the GOAT grouper digger in the GOM. I learned pretty much everything I know from this guy. 3/4 inch thick lexan windshield kept the flying fish out of the helm at 60 kts. I digress but maybe you can get an idea from the shape of the cabin.
Posted: Tue Apr 04, 2017 9:51 pm
by peter-curacao
Damn that's nice
Posted: Tue Apr 04, 2017 10:14 pm
by Aripeka Angler
1,000 diesel horsepower
Helluva fish box too...
Posted: Wed Apr 05, 2017 12:32 am
That is one fine looking boat
And it has the house shape CapeMan likes
That thing must be well over 40 foot. It is one thing to make a big boat look good but doing it in only 21 feet is going to be tough to pull off. I going to try and I guess we will see what happens. One thing for sure it is nice to sit in the back of the boat when the water is a little lumpy. I know guys who screwed up their boats when they switched to aft cabins. They did not think the boat was taking as bad of a beating as it was.
Posted: Wed Apr 05, 2017 12:40 am
This is the boat with only one layer of glass each side of the nida-core? He must have really tried to keep it light for the speed
Posted: Wed Apr 05, 2017 5:23 am
by Eric1
It's going to be interesting to see how you balance the aft cabin design.
Posted: Wed Apr 05, 2017 5:24 am
by Aripeka Angler
You have a good eye
The boat in the photo is 45' long and the beam was 8'-6".
It was built light and right and it would absolutely scream.
The Captain ran commercial charters to the Middle Grounds- 100-150 miles offshore.
He could make the run in less than 3 hours each way.
Not sure I can find the guy to confirm the lamination schedule of the decks
Posted: Wed Apr 05, 2017 5:29 am
by Eric1
Aripeka Angler wrote: ↑Wed Apr 05, 2017 5:24 am
That is hauling High Knee!!!
Posted: Wed Apr 05, 2017 6:33 am
by Jeff
AA, that is one serious off-shore fishing boat!!! I would love to see engine compartment and cabin photos if you have any or could send me a link!! Jeff
Posted: Wed Apr 05, 2017 8:26 am
by peter-curacao
Jeff wrote: ↑Wed Apr 05, 2017 6:33 am
Yeah or post it here
Posted: Wed Apr 05, 2017 8:30 am
by peter-curacao
Would love to do that for him
Posted: Wed Apr 05, 2017 9:57 am
by Aripeka Angler
I have some actual pics on the boat, I'll try to dig them up.
here is a video of the boat at a weigh in...
https://www.youtube.com/watch?v=T516bEn ... e=youtu.be
and a video of it on the water
https://www.youtube.com/watch?v=O80mHQ50b60
Posted: Wed Apr 05, 2017 11:15 am
AA don't worry about the lamination schedule. I put one section of deck down and it seems like it will be fine. I can not put much more deck down until my fuel tank arrives.
Posted: Wed Apr 05, 2017 12:15 pm
by peter-curacao
Funny in the picture it looked way bigger
Posted: Wed Apr 05, 2017 12:57 pm
by cape man
That's what she said.
Posted: Wed Apr 05, 2017 2:12 pm
by Eric1
Posted: Wed Apr 05, 2017 2:38 pm
Posted: Wed Apr 05, 2017 2:45 pm
by cape man
I thought we were giving this thread some class!
So here' the deal. You post pictures of actually building something, and we will stop messing around! For instance, you off-handed mention laying down a piece of deck, but no picture....?
Posted: Wed Apr 05, 2017 2:50 pm
by Jaysen
Do we laugh or cry? I'm not sure.
Posted: Wed Apr 05, 2017 4:56 pm
by peter-curacao
cape man wrote: ↑Wed Apr 05, 2017 12:57 pm
That's because of your small hands also showing in the pic
Posted: Wed Apr 05, 2017 5:10 pm
by Eric1
I just did the online qualification for grand jury duty three weeks ago. So far I've heard nothing. I hope that remains the case.
Posted: Wed Apr 05, 2017 8:10 pm
Well CapeMan was asking for a picture. There is not much to show. I have only put down one small section of deck for now. My fuel tank is supposed to be here in one week and I am waiting till it is here just in case I have to modify something. Trying my best to keep Mr.Murphy bored.
While I am waiting I will work on the gunwales as seen port bow here. Just starting on that.
Posted: Thu Apr 06, 2017 8:58 am
by topwater
Mr Murphy is watching always watching and waiting always waiting to pounce like a hawk on a june bugs ass
Posted: Thu Apr 06, 2017 9:10 am
by cape man
Thanks! I feel better! I am digging the wide gunwales, and how much space is inside that boat. Are you taking the inwales all the way down to the sides? If so, have you thought about putting some lockers in for stowing smaller stuff (deck lines, essential/often used terminal tackle, etc.)?
Posted: Thu Apr 06, 2017 9:26 am
by topwater
Like Cape Man said , put some tilt outs in for tackle boxes .
Posted: Thu Apr 06, 2017 4:55 pm
I had not thought of using that space in the gunwales so now I have some thinking to do.
Been working on the deck/swim step for the transom. Here is where I am so far. It is made of 3/4 nidacore.
Posted: Thu Apr 06, 2017 4:59 pm
by Jaysen
Fuzz wrote: ↑Thu Apr 06, 2017 4:55 pm
There goes your productivity ...
Posted: Thu Apr 06, 2017 5:03 pm
by Eric1
Years ago I had an 18' Boat that had storage in the gunwales. I was thinking about doing on my C21. It's a handy way to stow plastic tackle boxes.
Posted: Thu Apr 06, 2017 5:04 pm
Yep the stopping and thinking part has always been the hardest part for me
But at least I got lots of it as kid while riding the short bus
Posted: Thu Apr 06, 2017 5:06 pm
by Jeff
Fuzz, I really like NidaCore!! Great stuff!! Jeff
Posted: Thu Apr 06, 2017 5:13 pm
Jeff I like it also. The only problem with it is finishing off the ends if they will be seen. I got a plan and we will how it works. This thing is going to be a true composite boat. Glass hull, plywood stringers and transom, nidacore decks and maybe foam cabin. not sure about the cabin part yet
Posted: Thu Apr 06, 2017 7:31 pm
by Jeff
Nice Fuzz!!! I really like the use of honeycomb and foam!! Really nice stuff to work with!! Jef
Posted: Thu Apr 06, 2017 8:16 pm
by Eric1
Fuzz wrote: ↑Thu Apr 06, 2017 5:13 pm
I hope you choose foam. I want to see how you go at it.
Posted: Fri Apr 07, 2017 2:50 am
topwater wrote: ↑Thu Apr 06, 2017 9:26 am
Hey TopWater do you have something showing these tip outs you were talking about? I like the idea but sort of lost from there.
Posted: Fri Apr 07, 2017 3:19 am
Eric1 wrote: ↑Thu Mar 23, 2017 5:40 am
Eric just a little info for you. In looking over the inventory from my dads gun shop I found a 8 3/8s 460 S&W. I had a good friend who said he wanted it so we took it out and shot it. It kicks about like a hot 44 or just a little more. Not too bad at all. My Horniday book says you can safely get 1900FPS with a 240 grain bullet or 1600 with a 300 grain bullet. That would make it a flat shooting round for hunting.
Posted: Fri Apr 07, 2017 6:15 am
by Eric1
Fuzz wrote: ↑Fri Apr 07, 2017 3:19 am
SWEET!
Posted: Fri Apr 07, 2017 2:51 pm
by cape man
I aint Topwater, but here's the idea. You can easily make them.
http://www.boatoutfitters.com/tilt-out- ... oCH3fw_wcB
Posted: Fri Apr 07, 2017 5:17 pm
Hey Capeman thanks for the reply. With the picture I have a much better idea of how those work.
Posted: Fri Apr 07, 2017 5:20 pm
I made up a piece of glass to cover the raw ends. One layer of 1708 laid up with epoxy is pretty flexible and made the turn with no problem.
Posted: Fri Apr 07, 2017 7:31 pm
by Jeff
Fuzz, nice method!! See some updated photos after about 24 hours!! Jeff
Posted: Fri Apr 07, 2017 8:36 pm
I am expecting my boat working time to be much shorter starting tomorrow. SWMBO comes back from her 3 month vacation and I am sure there will be plenty of honey-does that must be done right now
With a little luck I will be able to trim the bracket up and post another picture. Might be late at night but what the hay it is daylight till 2130 here now
We are gaining 6 minutes each day. In two weeks sun up will be at 0530 and sunset at 2230. Summer and 24 hour a day fishing is coming
Posted: Sat Apr 08, 2017 5:26 am
by Eric1
Fuzz, I'm not sure what I'm seeing. Did you fill the voids with wood flour and the cover with 1708?
Posted: Sun Apr 09, 2017 12:00 am
I wiped the voids full of wood flower glue but I do not know if it will stick there or not. The wood around the edges helped to stiffen things up and gave something to bond to.
Top still needs a little finish work
Posted: Sun Apr 09, 2017 4:36 am
by Eric1
Nice job Fuzz
Posted: Sun Apr 09, 2017 7:49 am
by topwater
I am pretty sure when joel built his coffin box he did it the same way , filled the edges with a mix .
Posted: Sun Apr 09, 2017 9:03 am
by cape_fisherman
Thickened epoxy is how it's done, but I normally don't see the wood trim...just usually fill & fair. But for a platform it makes sense for stiffness. Looks good!
Posted: Sun Apr 09, 2017 10:03 am
by Jeff
Fuzz, looks good, nice work!! Jeff
Posted: Sun Apr 09, 2017 11:51 am
by glossieblack
Fuzz wrote: ↑Sun Apr 09, 2017 12:00 am
Well thought through Fuzz.
Posted: Sun Apr 09, 2017 12:15 pm
Thanks guys.
I was really surprised how flexible the piece of 1708 was. It was still just a little green when I wrapped it around the corners and it went with zero problems. 24 hours after that and it is hard as a rock. Could be that I am only working in 60 degree temps?
Posted: Sun Apr 09, 2017 12:48 pm
by Jaysen
Fuzz wrote: ↑Sun Apr 09, 2017 12:15 pm
An advantage to living in an area where water only exists in two states... frozen and dang frozen.
Got to take the win that's handed to you.
Posted: Sun Apr 09, 2017 1:49 pm
Jaysen wrote: ↑Sun Apr 09, 2017 12:48 pm
Yep any win is a good win. Are you able to go back to boat work or are you still laid up on a rocky shore?
Posted: Sun Apr 09, 2017 1:52 pm
by Jaysen
Hoping to be back Wednesday or so. Gone from 60% motion to about 80%. Just want the Dr to sign off before I get serious. Did uncover her and cried. There's going to be a lot of sanding. A lot. As in my wife will be a widow which means she will be happy.
Posted: Sun Apr 09, 2017 1:59 pm
Pretty sure she will want you to hang around long enough to finish HER boat
Don't push it a few weeks either way is not the end of the world. I always start stuff thinking this will not take long and end up asking myself why is this not done yet
Posted: Sun Apr 09, 2017 2:56 pm
by Jaysen
That question came and went in December!
The real question is "have you made up your dang mind about the cabin yet?" I like the aft as an idea but it runs counter to everything I've been on that passes for a fishing boat. Some of the crab boats around here are like that but they are much larger. Assuming your road and reel fishing how do you work that layout for bringing fish on board?
I may just be missing something obvious.
Posted: Sun Apr 09, 2017 5:40 pm
Well let me ask this. How many centre console boats have an outboard bracket and outboards hanging off the back? They have to land all fish over the side right? And if you need to chase a fish does this work better using the pointy end or the flat end?
I am going to put the cabin on the stern unless it looks so bad I just can not stand it. And I am an old work boat guy so effective trumps pretty all day long for me.
My old mentor told me a boat was something to get a job done. Quit thinking of them as yachts and start calling them work platforms. That being said I still do not want butt-ugly
Posted: Sun Apr 09, 2017 5:56 pm
by Jaysen
Not sure how the multi-engine guys do it. All the CC I've been on are singles. Most with no bracket and low decking making it simple to pull catch over stern. I always assumed the big CC pulls catch onto bracket then over stern.
I'm with you on chasing with pointy end. The times I've been after bigger things on a CC the drill was get to front of boat while captain chases for you. But move aft once youre at the boat. I guess it's the difference between "sport" and "work".
Beauty is in the eye of the beholder (otherwise both of us would be single (or so I assume)). Who cares what she looks like as long as you like the ride. And you get that full head in there
Posted: Sun Apr 09, 2017 6:44 pm
by glossieblack
A thought .... If you make it a seating cabin, not a standing one, you've got a fair chance of making it look good. The way you handled the sweep of the roof would make or break the look. You could set up another parallel helming station outside further forward. With the low profile cabin you could use a sliding hatch on the roof combined with a sliding or swing door to manoeuvre in and out. Limit functions in the cabin to head, wet locker and a couple of seats, one for the foul weather helming. If you were putting a cabin forward on a 21' boat, would it be a standing one? Just a thought.
Posted: Sun Apr 09, 2017 7:56 pm
Glossieblack you are one smart cookie
And you might be able to read my mind from half way around the world. The stringers are 12 inches tall in this hull. I have planned from the start to step down between them for the walkway. Forward or aft cabin. And if I go aft cabin I will build a sliding hatch over the walk way for head room. The hatch top will be made of plexy glass. I think this will make the cabin feel more open and not so closed in. Still thinking about slant of the cabin-forward or aft? Got to do a mock up of both and see how they look.
Posted: Sun Apr 09, 2017 8:06 pm
Couple of more thoughts. What are you speaking of with the "sweep" of the roof? And I just happen to have a dual helm set laying around so there will be two steering stations.
Posted: Sun Apr 09, 2017 8:12 pm
by Jaysen
Fuzz wrote: ↑Sun Apr 09, 2017 7:56 pm
These two sentences seem to be mutually exclusive.
Posted: Sun Apr 09, 2017 11:16 pm
Jaysen wrote: ↑Sun Apr 09, 2017 8:12 pm
Why Ike what ever do you mean
Posted: Mon Apr 10, 2017 4:19 am
by glossieblack
Well my 2 cents worth, with the benefit of not having seen the boat up front and personal
is to have the forward face of a low slung cabin vertical, but curved in a shallow arc in plan, to have the aft side a flat plane sloping down and aft, to have the sides vertical but curved to follow the curved side decks which are allowed to run all the way aft for aesthetic reasons, in order to accommodate inset curved in plan but vertical sides between the side decks and the low slung cabin roof, and having the cabin roof cantilevering at least 6" from all four sides.
Well, perhaps my 3 cents worth.
Posted: Mon Apr 10, 2017 4:39 pm
by fallguy1000
my 2 nickels are worth more than the other guys 3 cents
Cabin for'd.
Deck roof slanted for'd so you have ample headroom when walking in and less headroom as unneeded at for'd helm and to allow for the rain to roll forward instead of on your head (you can gutter it either way; the headroom is the real story)
2nd helm station as far aft as possible so you can troll/manage lines while out of the helm (keep a kill switch near that station).
It'll look great.
Too bad for the miles, I have a starfire 24 windshield I'd give you. It has windows that open even and was all setup for a hardtop.
Posted: Mon Apr 10, 2017 5:37 pm
Fallguy 1000 thanks for the input and the kind offer. I know 99.9% of folks think the cabin belongs on the front of the boat but I am pretty sure it will go on the stern of this one. If you are going to have a custom boat why have it look like all the others? And in the end if it does not work out I might just cut the whole mess off and make it a Florida centre console just to make Capeman happy
Posted: Mon Apr 10, 2017 6:14 pm
by cape man
Awwww....
Posted: Mon Apr 10, 2017 6:22 pm
by cape man
So pattie and I are talking...not this summer, but next. Florida Cracker coming to you!
Posted: Mon Apr 10, 2017 6:23 pm
by fallguy1000
just make sure you don't put too much weight aft or your beautiful boat will swim like a porpoise
Posted: Mon Apr 10, 2017 11:20 pm
cape man wrote: ↑Mon Apr 10, 2017 6:22 pm
That would tickle me to death. You two will be more than welcome
We have room so plan on staying with us. I have not meet one person from this site that I would not welcome for a visit. Nothing but great people here and that is so unusual for an internet site.
Posted: Mon Apr 10, 2017 11:22 pm
fallguy1000 wrote: ↑Mon Apr 10, 2017 6:23 pm
Cabin will just be something to get out of the weather. I will do my best to keep her balanced.
Posted: Wed Apr 12, 2017 3:31 am
Well once again my latest order got here in no time. The team at Bateau does a wonderful job
Still waiting for my fuel tank to arrive. It is supposed to be here 4-13 so not much longer. I am leery of going much further until it is here. Mr.Murphy is watching way too closely.
Posted: Wed Apr 12, 2017 5:58 am
by cape man
Agree about this group and the Bateau service. Thanks for the offer.
Posted: Wed Apr 12, 2017 8:03 am
by Jaysen
Who's betting on Mr Murphy?
Fuzz, stop worrying. After all the crap you've done already, Murphy can't do too much to knock you down. At least nothing you can't recover from quick. You do owe us all some type of sketch on this aft cabin you're planning. We want to poke at it sooner than later.
Posted: Wed Apr 12, 2017 8:24 am
by Jeff
Fuzz/Cape Man, thank you for the kind words!! Always nice to hear!! Jeff
Posted: Fri Apr 14, 2017 12:29 am
Ok here is a rough mock up. Just look at the painted part of the plywood.
And here is one with the other slant to the windows
And one more to get a better idea of what it looks like. I think the angle distorts things as it makes the cabin look really short.
Bear in mind this just a rough mock up with no overhangs or anything else. So pick one and let me know. Sorry to say I am pretty set on an aft cabin.
Posted: Fri Apr 14, 2017 12:34 am
by narfi
I think the slopes back "aerodynamic" windshield looks best
Posted: Fri Apr 14, 2017 2:21 am
by glossieblack
I'd encourage you to do a mock up with the cabin roof sweep matching that of the gunwale, with the top and bottom of the windows doing likewise. Like the way you're keeping the sides inboard of the side decks, and I like the front of the cabin sloping back. If you cantilever the cabin all round, and if you can keep the height of the cabin above the deck to equal to or less than the height of the gunwales above waterline (do you really need full head height in a foul weather cabin?), I reckon the boat will look sweet.
Posted: Fri Apr 14, 2017 4:09 am
Narfi and GlossieBlack I think most folks are going to like the rear slope the best. I think the boat needs to be bigger to make the forward slope windows work.
Glossie thanks for reminding me of the rule of thumb on cabin heights. I had read it some place before but it had slipped my mind. I am not shooting for standing head room, just sitting. I will need to measure it a little more to see if it can work. This hull is pretty darn low in the stern. I really appreciate your taking the time to share your well thought out ideas.
Posted: Fri Apr 14, 2017 6:08 am
by Eric1
Fuzz wrote: ↑Fri Apr 14, 2017 4:09 am
I agree. Quick question where will you mount the Laser Cannons?
Posted: Fri Apr 14, 2017 6:39 am
by cape man
Sloping back.
Posted: Fri Apr 14, 2017 7:58 am
by Jaysen
I like the forward slope. Which means it is probably a bad idea.
Posted: Fri Apr 14, 2017 8:10 am
by cape_fisherman
If you're going to do it, go with the classic forward slope. Keep it LIGHT...as you already know. Weight will add up faster than you think.
Posted: Fri Apr 14, 2017 8:19 am
by tcason
In Alaska - forward slope with overhang - think Deadliest Catch
Posted: Fri Apr 14, 2017 11:01 am
by cape_fisherman
Certainly not the same proportions or style...but it does show classic Carolina styling.
Posted: Fri Apr 14, 2017 6:51 pm
by glossieblack
Just a thought. If you moved the cabin a little further forward so that its forward face commenced where the gunwale is still high, the height of the cabin will become less problematic. Add Cape Man's sloping aft face, and it could look sweet.
Posted: Sat Apr 15, 2017 2:26 am
Still playing with the cabin location trying to make it look decent. Glossie has some really good ideas for me to look at.
One nice surprise this showed up today.
61 gallons should be good for day trips. SpeedyTanks makes a nice tank just like many on here have said.
Posted: Tue Apr 18, 2017 2:42 am
No messing with the boat today. I went fishing for winter king salmon. I think it was too cold for them to risk coming out of the water
It was 28f when we started but by mid afternoon it had warmed up to a balmy 42. By the time we got off the water it was 35f
Snow line is still down pretty low. We caught two but turned them loose, not big enough to keep.
This guy was warm and happy though
sorry did not zoom in on the otter.
Posted: Tue Apr 18, 2017 6:36 am
by cape man
At least it looked flat calm.
Posted: Tue Apr 18, 2017 7:40 am
by Eric1
Looks like a day well spent!
Posted: Tue Apr 18, 2017 7:49 am
by Jaysen
It was 72F at 5:30A local time this morning. And it was comfortable for my run. I don't think I could live up your way.
Pretty as all get out, but you really need to figure out how to warm that place up.
Posted: Tue Apr 18, 2017 7:50 am
by Jeff
Looks like a nice but still cool day up there!! I bet the Otter is cool in that water!! Jeff
Posted: Fri Apr 21, 2017 4:39 am
by glossieblack
Double post corrected. Apologies.
by glossieblack
Fuzz wrote: ↑Mon Nov 21, 2016 12:56 am
Well now that I am retired I was planning on laying around the house eating bon-bons all winter. SWMBO has made it clear, in no uncertain terms, that my plan is not going to fly
So I thought now is a good time to work on other projects out in the shop. She never goes out there so I am good
HAPPY CLOOF BIRTHDAY FUZZ. 61 NO LESS.
Posted: Fri Apr 21, 2017 6:20 am
by Jeff
Fuzz, Happy Birthday!!! Hope you have a great day!! Jeff
Posted: Fri Apr 21, 2017 6:30 am
by cape man
Happy birthday. Send boat pics!
Posted: Fri Apr 21, 2017 8:21 am
by Jaysen
Birthday? She let you see another year pass? Clearly doing it right up there!
I'll take Murphy off your hands for the day. That should ensure you have the best possible day.
Seriously, happy birthday. May you see many more, all of them blessed by family and friends to celebrate with (even if it is virtual).
Posted: Fri Apr 21, 2017 8:32 am
by narfi
Happy birthday!
Posted: Fri Apr 21, 2017 8:57 am
by topwater
Happy birthday from Mr Murphy
Posted: Fri Apr 21, 2017 9:43 am
by gonandkarl
Happy birthday and please send pictures, all of them you sent sofar are nice. One can practically feel the cold up your way on the crisp clear picture in your harbour.
Posted: Fri Apr 21, 2017 6:50 pm
Thank you one and all for the birthday wishes.
So this morning sitting by my computer is a card from my loving wife. It goes like this. Another birthday and your body is still like a high performance race car
So I am feeling good about the world. Then I open it up and what does it say? You too need a specialist for every part
As for the boat work I keep plugging along but not much picture worthy. Should have something worth posting in the next few days.
Posted: Fri Apr 21, 2017 8:11 pm
by Eric1
Fuzz wrote: ↑Fri Apr 21, 2017 6:50 pm
Fine tuned Machine
Posted: Fri Apr 21, 2017 8:12 pm
by Jeff
Nice card Fuzz!!!! Hope you had a good day!! Jeff
Posted: Sat Apr 29, 2017 12:48 am
I have not had a lot of time to mess with the boat the past week. Wife had to make an emergency trip back to Russia. Her mother is not doing well
I hate it, Momma is my buddy, but father time cuts no one any slack.
Posted: Sat Apr 29, 2017 2:52 am
by glossieblack
Sorry to hear your news Fuzz.
Posted: Sat Apr 29, 2017 3:20 am
Thanks Glossie,
Just part of life. The sad part but one that can not be avoided. We will pray for the best and go from there.
On the boat front with SWMBO gone I will have more time for the boat project. But I will only have a few more days to mess with it. It is time to get the dory and Seasport ready to go kill fish. Weather has warmed up and the geese have returned so it is spring.
It is never spring until the geese arrive, those boys and girls are never wrong
Posted: Sat Apr 29, 2017 6:52 am
by Jaysen
Always unpleasant when someone we appreciate and whose company we enjoy starts to diminish. Hopefully you and SWMBO find comfort together.
I'm kicking myself for declaring loudly and in public "I SHALL NOT FISH TILL IM FISHING IN LIL BIT!!" Forking moron. What kind of idiot says crap like that?
Those geese are already on the second round of offspring here. They show up mid Feb and get right to work procreating. I think the gator got a few of them from the first round. I fuse that makes it late spring or early summer here?
Posted: Sun Apr 30, 2017 2:07 am
Well I got the fuel tank prepared and ready to drop in the boat. As long as nothing distracts me it should happen tomorrow.
SpeedyTanks sent instructions saying to glue the rubber to the tank with 5200 and not to foam it in.
Posted: Sun Apr 30, 2017 6:45 am
by Jaysen
Wait. I thought it was fish getting time? That does not look like gotten fish.
This is going between the two central stringers, correct?
Posted: Mon May 01, 2017 2:27 am
Jaysen wrote: ↑Sun Apr 30, 2017 6:45 am
No fishing yet but it is time to uncover the boats and do all the pre-launch stuff.
Yep the tank is going between the stringers. Mr. Murphy was here and doing his thing. Somebody forgot to allow for the fittings on top of the tank when he ordered it
Good thing the decks are not glued down yet. That would have really sucked. Small step backwards but it can be fixed
Posted: Mon May 01, 2017 3:37 am
by gonandkarl
Does that mean the tank fitting will stick out (up) of the deck, or will you house it on deck with some box ?
Posted: Mon May 01, 2017 4:05 am
gonandkarl wrote: ↑Mon May 01, 2017 3:37 am
I really did not want to raise the deck but no matter how I looked it if I did not raise the deck I was going to have a tripping hazard. So I opted to raise the deck. We will see how it all works out.
Posted: Mon May 01, 2017 6:17 am
by glossieblack
Not easier to modify the tank?
Posted: Mon May 01, 2017 8:05 am
by Jaysen
I thought you settled on aft cabin/wheelhouse... can't you adjust sizing to burry it in some space in that structure?
Posted: Tue May 02, 2017 2:45 am
I do not really want anyone around here messing with this tank. For one thing it would mess up the nice coating they put on the tank.
As for putting it in the cabin that would force me to raise the cabin floor and then that would mean raising the cabin sides.
I am trying to keep it low as possible so it looks semi decent.
Both good questions guys, thanks for asking.
Posted: Tue May 02, 2017 6:41 am
by cape man
How high is the fitting?
Posted: Tue May 02, 2017 7:52 am
by Jaysen
Ok... since the head was such a big deal, can you situation it so the head is close enough to it to prevent the trip hazard?
Posted: Tue May 02, 2017 12:41 pm
cape man wrote: ↑Tue May 02, 2017 6:41 am
It stands 2.5 inches above the tank. with room to get the hose on I am 3 inches too high. Raising the deck is not going to be that big of a deal, I hope.
Posted: Tue May 02, 2017 12:45 pm
Jaysen wrote: ↑Tue May 02, 2017 7:52 am
Fuel tank is going in forward of the cabin. I am not sure I have ever seen a boat with the gas tank under the cabin sole. Diesel yes but never gas.
Posted: Tue May 02, 2017 1:12 pm
by Jaysen
Fuzz wrote: ↑Tue May 02, 2017 12:45 pm
Stop pointing out the obvious errors in my question!
There has to be a better solution than raising the deck by 3.5"
Posted: Tue May 02, 2017 2:23 pm
by narfi
Jaysen wrote: ↑Tue May 02, 2017 1:12 pm
Lower the hull by 3.5"
Problem solved!
Posted: Tue May 02, 2017 4:21 pm
narfi wrote: ↑Tue May 02, 2017 2:23 pm
Problem solved!
Posted: Tue May 02, 2017 4:24 pm
by Jeff
Nice guys!!! Jeff
Posted: Tue May 02, 2017 4:28 pm
Well I am sure there is a better answer, I am just not sure what it is at this point.
It is spring time so it is time to go fishing
I might just bag this mess until the fall. Give my pea brain some time to chew it over.
I never thought I would be done before summer and I will need a winter project.
Posted: Tue May 02, 2017 8:35 pm
by glossieblack
Fuzz wrote: ↑Tue May 02, 2017 4:28 pm
Excellent solution Fuzz! Enjoy!
Please post fishing and scenery pics.
Posted: Tue May 02, 2017 10:35 pm
Thanks Glossieblack
I will make sure to post pictures when I have something new.
Posted: Wed May 03, 2017 3:33 am
by Eric1
Tight lines brother.
Posted: Wed May 03, 2017 5:31 am
by Aripeka Angler
"Gone fishing" are my favorite two words
Halibut or salmon?
Posted: Wed May 03, 2017 10:48 am
Aripeka Angler wrote: ↑Wed May 03, 2017 5:31 am
Halibut or salmon?
This time of the year it will be Halibut. Might try for a winter king but it is just a little early for this years kings.
On the boat building front I cut up and epoxy coated a bunch of bracing to raise the deck. Just before mixing the glue I got to looking and asked myself is this going to really be the best solution? This is what told me I need to take some time and think things over. No matter what I was never going to have it ready for this summer so it is a good time for a break.
Posted: Wed May 03, 2017 11:33 am
by Jaysen
Just because I like to post dumb solutions to problems to other people's threads...
Since this is in middle of the boat, can you put a bench/storage locker to cover it? Think a place for SWMBO to recline while she waits for you to catch your limit (she's waiting because she hit her limit in 10 minutes while you've not caught a dang thing)(this may be a regular occurrence in my world and one of the reasons i refuse to fish with women (not really but I think about it)).
Posted: Wed May 03, 2017 2:19 pm
Jaysen I will give that some thought. That is one of the reasons for taking a summer break. Not a lot of opportunity to lay around in your bathing suit here. Well that is unless you count polar fleece and Helly Hansons as a bathing suit
We judge girls by how well they look in Carharts and bunny boots around here
Posted: Wed May 03, 2017 2:42 pm
by Jaysen
You need to think about moving down this way. We judge more by "you need to cover that stuff up" method.
Posted: Wed May 03, 2017 4:04 pm
by narfi
Fuzz wrote: ↑Wed May 03, 2017 2:19 pmWe judge girls by how well they look in Carharts and bunny boots around here
"Nice tooth!"
Posted: Wed May 03, 2017 8:27 pm
by Aripeka Angler
Fuzz wrote: ↑Wed May 03, 2017 10:48 am
Great idea to take a break, enjoy the halibut fishing. I'm jealous.
I have to tell you a story, not very funny but a story nonetheless.
First time I went to Alaska, I brought my white grouper digging boots on a halibut boat.
I'm pretty sure they were laughing at me
So the next day, I buy a pair of the brown boots that y'all use up there-just to blend in.
Fast forward, I bring the brown boots home in August and strap them on for my next grouper trip on my boat.
I have to use them, right?
About the time the sun got to blazing I figured out why y'all use brown boots in AK
Posted: Wed May 03, 2017 8:36 pm
Those Goodyear X-tra tuffs are known as Alaska tennis shoes. you know you are in the sticks when you see girls out dancing in them
The number one thing they have going for them IMHO is traction. I have never found anything that compares when you are on a boat.
Funny you bring them up, I just went to town and got a new pair today
Posted: Wed May 03, 2017 8:58 pm
by Aripeka Angler
That's it Xtra tuff! Bad ass boots!
I don't know if you have seen this video, white boots in action in Florida
https://m.youtube.com/watch?v=echkQm12Tfo
Posted: Wed May 03, 2017 9:59 pm
by seaslug
Fuzz, I love the "Alaska tennis shoes". Some people just do not appreciate fine fashion. Funny story. When my wife first saw me wearing my white boots many years ago she laughed her ass off. 'What the Hell are those things'? she said. Well, I grew up on Long Island, and all the bay men wore those boots, especially all the clammers, and they were a tough bunch. I don't think they got laughed at in the local bars much, in fact they usually got the girl. Still love my white boots.
Posted: Thu May 04, 2017 9:33 am
by gonandkarl
Hi,
I love the different ways you guys are judging girls, but when it gets down to the nitty gritty I think this picture beats you all. I just received it from a sailor friend who is at present in Sweden and seen this card at a harbour masters window.
If one looks carefully it originates from our Aussie friends.
Greetings from Karl
Posted: Thu May 04, 2017 11:04 am
by Jeff
Great post Karl!!! Jeff
Posted: Thu May 04, 2017 12:45 pm
That is a great video Richard
Thanks for posting the link I had never seen it. Nice looking boat too
But maybe needs more power
You guys down there sure put a bunch of power on your boats.
Posted: Thu May 04, 2017 12:51 pm
by Jeff
Richard, Great video and great fishing!!! Jeff
Posted: Thu May 04, 2017 12:53 pm
seaslug wrote: ↑Wed May 03, 2017 9:59 pm
The wife is always on my case about how I dress. I dress up for church and if we go out but other than take it is what works and is comfortable. Sweat pants around the house and in the shop. They get boat building materials on them, epoxy, paint and such, and she wants me to throw them away. Heck they are just getting broke in
Posted: Thu May 04, 2017 12:54 pm
Karl that is a great sign
Every true boat needs one.
Posted: Thu May 04, 2017 6:54 pm
by Aripeka Angler
Fuzz wrote: ↑Thu May 04, 2017 12:45 pm
Thanks David
We were having fun for sure. The total duration of the trip was 4:10 which included a 64 mile round trip run of which 4 miles was idle speed/no wake. All of our trip aren't that good, it was just a nice day...
The old girl was designed when Jacques was engineering boats for Pursuit. I think he worked on this 2670 hull design.
She is the best production boat I have ever owned. She has brought me home a few times in some pretty awful conditions.
As for the horsepower, the boat is heavy. It takes a lot of umph to get her on plane. It's rated for 450 hp, I ordered it a little on the conservative side at 400. Top speed is 45 kts.
Back to your thread. I'm waiting for your halibut pics, quit holding out on us
Posted: Thu May 04, 2017 7:56 pm
Got the Seasport uncovered and test run the main and kicker today. I was planning on a trip Saturday but the weather forecast is for 35 knots and 9 foot seas
I am not thinking that would be a whole lot of fun. As soon as I can get out I promise to post pictures.
Posted: Fri May 05, 2017 8:22 am
by topwater
That sounds like it's getting downright nautical
Posted: Sat May 27, 2017 2:03 am
Ok so the boat is no where ready to paint but I am getting close to ordering other stuff and need input on colors. I am not worth a crap at this part
I am thinking seafoam or empress blue for the hull. So what would go well with them for the house and trim?
Any and all suggestions welcome, and needed.
Posted: Sat May 27, 2017 3:57 am
by glossieblack
If sun generated heat loading isn't an issue, then a dark colour for the house and a light colour for the hull could be the go, as this will reduce the visual height of the house.
Posted: Sat May 27, 2017 5:12 am
by Aripeka Angler
Fuzz wrote: ↑Sat May 27, 2017 2:03 am
I kinda like the idea of the hull from under the rub rail down in the empress blue as well as the house.
Chevy white or whisper gray on the decks, rub rail base, inside parts of the hull and inside the house.
Maybe do a little bit of the trim on the house (such as the window trim) with the light color?
So it doesn't overpower the eyes with too much blue...
Posted: Sat May 27, 2017 8:06 am
by Jaysen
Pink and florescent green
You should take the smart path and ask the boss lady. That's what I did. See how well that turned out?
Posted: Sat May 27, 2017 2:44 pm
SWMBO is still in Russia. So asking her before ordering is out. I will go with the colors you suggest. You can then explain it to her in October
Posted: Sat May 27, 2017 2:53 pm
by Jaysen
I have no fear of defending those colors. And don't they have phones over there? How hard can it be?
Fuzz: Hey Baby. How's it going?
SWIMBO: You! Talk fast! You stop spending my money!
F: Colors for boat, what should I use?
S: You! You bother me with this? Pink and florescent green!
See? Easy.
Posted: Sat May 27, 2017 3:03 pm
Posted: Sat May 27, 2017 3:19 pm
by Jaysen
Someone should be worried. I'm pretty sure it's our respective bosses.
Posted: Sat May 27, 2017 5:28 pm
glossieblack wrote: ↑Sat May 27, 2017 3:57 am
The only heat loading around here is caused by a Dickerson stove.
That is a good tip about how to use colors to lessen the cabin height look. I like Richards idea also. I guess more pondering is called for
Posted: Mon Jun 12, 2017 6:56 pm
by glossieblack
Anything happening on the pondering front Fuzz?
Posted: Mon Jun 12, 2017 9:41 pm
Thanks for checking in on me GlossieBlack. I am still pondering but I have a plan. When in doubt default to the BIG brain. I already warned Richard I was going to take out fishing trips in trade for picking his brain
So I will get him to look this thing over and then pick his brain while we are on the water and he is trapped
Posted: Mon Jun 12, 2017 9:46 pm
by Jaysen
Launch from that beach and threaten to make him ride it in unless he BUILDS it too.
You see that stuff he's building?
Posted: Mon Jun 12, 2017 9:57 pm
by Aripeka Angler
Posted: Tue Jun 13, 2017 12:32 am
Jaysen wrote: ↑Mon Jun 12, 2017 9:46 pm
Jasen we just might be brothers from a different mother..............well except for that blow boat problem you have
I just love watching a pro do his thing. I would say he makes it look easy but I remember those gloves he had laying on the hull
Posted: Tue Jun 13, 2017 12:34 am
I have another buddy coming up mid July so by the time you get here I should be up to full fishing speed
Posted: Tue Jun 13, 2017 3:05 am
by glossieblack
Fuzz wrote: ↑Mon Jun 12, 2017 9:41 pm
Sounds like a smart plan.
Posted: Tue Jun 13, 2017 7:45 am
by topwater
55 days , won't it be winter again
Posted: Tue Jun 13, 2017 10:25 pm
topwater wrote: ↑Tue Jun 13, 2017 7:45 am
We will be chillin in 65f weather, killing fish, while you will be sweating your tail off
Well that is IF mother nature plays nice. So far she has emerged from winter on the wrong side of the bed.
Posted: Wed Jun 14, 2017 8:17 am
by topwater
You got that right , i sweat in the winter down here
Posted: Wed Jun 14, 2017 10:11 am
by blueflood
You guys crack me up
Marc
Posted: Wed Jun 14, 2017 6:23 pm
by Aripeka Angler
blueflood wrote: ↑Wed Jun 14, 2017 10:11 am
Marc
You should meet us in person, we are much worse after midnight
Posted: Thu Jun 15, 2017 6:18 am
by blueflood
Hi Richard,
I really do want to meet; even did some preliminary travel planning a while ago; one to partake in a get-together in Florida (minus the boat and another to meet / go see Larry during my winter but now it's too late for that
) Yes, I can only imagine to goings-on when you are all together
Marc
Posted: Thu Jun 15, 2017 1:17 pm
Blueflood you are not alone in missing the chance to go meet Larry. I passed close by his place last year but did not really know it. It remains a major regret.
If you get the chance to make it to a builders meet you should do it. I went last year and had a great time. Meet lots of really great people there and just as important no butt heads
From what little I know last years meet was pretty tame compared to some of the others.
Posted: Thu Jun 15, 2017 2:10 pm
by cape man
We spent a lot of time together!
Posted: Thu Jun 15, 2017 9:17 pm
As long as Richard does not come home with any horror stories I am hoping to spend time with you and Pattie next summer
Posted: Thu Jun 15, 2017 10:21 pm
by cape man
Come stay with us before or after the meet in October.
Posted: Thu Jun 15, 2017 10:36 pm
by Aripeka Angler
cape man wrote: ↑Thu Jun 15, 2017 10:21 pm
Maybe we could all go grouper fishing?
Posted: Thu Jun 15, 2017 11:49 pm
Well if Richard is still speaking to me after this summer..........................would before or after the meet be better? I am sort of thinking after but not sure why.
Heck of a nice offer from Richard, bet it would be fun.
Posted: Fri Jun 16, 2017 6:22 am
by cape man
Whichever works better for you.
Posted: Fri Jun 16, 2017 9:21 pm
I am waiting for SWMBO to return home before making plans. I find that helps keep me out of trouble.
Posted: Fri Jun 16, 2017 9:27 pm
by Jaysen
No boat or fish pics. What have you been actually doing? Get at it man!
Posted: Fri Jun 16, 2017 10:10 pm
by Aripeka Angler
Fuzz wrote: ↑Fri Jun 16, 2017 9:21 pm
I hear you. We are finishing the renovation of the fishing house. I bet the Mrs would be happy here for a couple of days.
Posted: Sat Jun 17, 2017 5:28 pm
by Aripeka Angler
Ok, here are the parts from the winch kit.
Which parts are you missing?
Posted: Sun Jun 18, 2017 2:24 am
by gonandkarl
Hi,
I am impressed what you power boat builders all have to mount and I think at the same time about you guys behind these massive efforts for finishing boats that look then like perfect miracles out of professional boat builder shops which I could witness at last years meet. For all newbies planning to go go to the meet there are a lot of nice people to talk to and as David said no buttheads whatsoever. I wish I could go there again.
Greetings from Karl
Posted: Sun Jun 18, 2017 2:56 am
Aripeka Angler wrote: ↑Sat Jun 17, 2017 5:28 pm
which parts are you missing?
All three of those. But now I know what I need. Thank you for taking the time to dig those out and show them to me.
I can even read the part numbers
Posted: Sun Jun 18, 2017 2:59 am
gonandkarl wrote: ↑Sun Jun 18, 2017 2:24 am
Hi,
Greetings from Karl
Yep lots of stuff to mount on power boats. But I am not too sure the sail boats are much easier. A simple little skiff with just a pull start outboard sure sounds good at times.
Posted: Sun Jun 18, 2017 7:16 am
by Jaysen
Building from a JM design... heck yeah! The build is a little more complicated than power but it is all spelled out. All us blow boat types need to guess at are a few points to secure lines. You power boaters... jack plates, trim tabs, fuel, electrical, props... no thanks. Give me the wind and oars for simple.
My back would appreciate a motor though.
Posted: Sun Jun 18, 2017 11:49 am
Jaysen I did a little sailing when I was young. I learned two things. 1 sailing is no fun without wind. 2 wind on the water in Alaska and its cold no matter the time of year. I read someplace that sailboats should stay below the 40th latitude and I tend to agree.
Posted: Sun Jun 18, 2017 11:58 am
by Jaysen
Problem is sailing east. Got to go north to cross the big water. Or waaaaay south.
Posted: Sun Jun 18, 2017 3:03 pm
by Aripeka Angler
Fuzz wrote: ↑Sun Jun 18, 2017 2:56 am
You want me to find a set of all three for you?
It's no trouble at all, I can bring them up in my suitcase.
Posted: Sun Jun 18, 2017 7:48 pm
[/quote]
[/quote]
Thank you very much for the kind offer but you have plenty to do. Now that I know what I need I can order them. I hate trying to order stuff sight un seen. But you even showed me part numbers so even I can not screw this up................I think
Posted: Fri Jun 23, 2017 9:32 am
by cape man
Posted: Fri Jun 23, 2017 1:08 pm
Really sad event. The bear has been located and put down. Like always there are conflicting reports about what really happened. The bottom line is a young man lost his life while participating in what should have been a fun event.
The blacks tend to be more dangerous for people than browns for a couple of reasons. One there are more of them so you are more likely to run into one. And two people are closer to a blacks size so you are viewed as a bigger threat. The browns treat you as a pest, give you a good swat and move on.
Posted: Fri Jun 23, 2017 1:12 pm
by Eric1
That's horrible. Prayers for the family.
Posted: Fri Jun 23, 2017 1:43 pm
by Jeff
Agree with Eric!! Terrible for the family!! Jeff
Posted: Mon Jun 26, 2017 2:00 am
Well the news gets worse
https://www.adn.com/alaska-news/2017/06 ... -saturday/
Another black bear attacked two women killing one of them. The fish and game are calling them predatory attacks.
And Saturday there were two separate attacks by brown bears. In both cases the browns were doing what is called defensive attacks. At least one involved a sow with a cub.
The link will give much more info for those who might be interested. Needless to say I do not recommend spending lots of time in the woods without proper bear protection around here. This is a high number of attacks in such a short period of time.
Posted: Mon Jun 26, 2017 6:07 am
by Eric1
Good Lord, Why didn't they carry?
Posted: Mon Jun 26, 2017 9:52 am
In today’s anti-gun society lots of folks touting the use of non-lethal force, yes even here in Alaska. Use bear spray it is much kinder to the animal. Call me old fashioned, I believe in rapid moving large chunks of lead
Posted: Mon Jun 26, 2017 10:08 am
by Jaysen
Fuzz wrote: ↑Mon Jun 26, 2017 9:52 am
multiple rapid moving large chunks of lead
fixed it...
Posted: Mon Jun 26, 2017 11:34 am
by Eric1
Jaysen wrote: ↑Mon Jun 26, 2017 10:08 am
fixed it...
BINGO!
Posted: Mon Jun 26, 2017 12:02 pm
by narfi
Posted: Mon Jun 26, 2017 12:14 pm
by BB Sig
Posted: Tue Jun 27, 2017 8:33 am
by topwater
Posted: Sat Jul 01, 2017 3:13 am
Well PhotoBucket has really messed things up for those of use that used them. I sort of figured out how to post new pictures but it really takes a long time so if there was a picture anyone wants to see let me know.
It is easy to understand why Cracker Larry did not want to spend the time reposting all of his.
Posted: Sat Jul 01, 2017 5:10 am
by enolja
Imgur is a pretty solid image hosting site.
I went to elementary school in Alaska. I've seen a lot of bears. I live in Washington now, and when I go hunting or hiking I pack bear-spray in addition to carrying a larger caliber pistol if I can.
Posted: Sat Jul 01, 2017 11:51 am
Cool, where did you go to school at and when?
I am told the spray works. Even heard it is better than lead
I have never used the spray so I go with what I know. That would be LARGE hunks of lead
I have seen first hand how lacking a 44 mag can be so now my woods carry is a 500 S&W.
Posted: Sat Jul 01, 2017 12:16 pm
by Jaysen
Fuzz wrote: ↑Sat Jul 01, 2017 11:51 am
cannon.
Fixed it.
Posted: Sat Jul 22, 2017 8:56 pm
by glossieblack
Any news on the rebuild front Fuzz?
Posted: Mon Jul 24, 2017 3:52 am
No, sorry Glossie I have been slacking big time. I am just fishing and spending time with some old friends. Plus I am waiting for AA to get here so I can pick the big brain and get a solid since of direction. He will be here in a little over two weeks so sometime after that I will be back in the building mode.
Posted: Mon Jul 24, 2017 9:31 pm
by Aripeka Angler
I'm looking forward to checking out your rebuild project in a couple of weeks
Posted: Tue Jul 25, 2017 8:57 pm
by Aripeka Angler
Fuzz, I'm packing my gear for AK. I'm bringing my Cracker Larry built 8 weight fly rod and reel, a St. Croix rod with a Shimano spinning reel and a Shimano two speed conventional reel with 80 lb. power pro braid. Can I buy a good fishing rod up there to go with the conventional reel or do I need to ship a rod up to you? All of my big halibut/grouper sized rods are one piece.
I've researched trevalla two piece bottom fishing rods, I can buy one if you think that would be better.
Posted: Wed Jul 26, 2017 12:41 am
Bring your reel if it is one you really like. As long as it is not a monster I have you covered on rods. I have several that work real well up to 125-150 pounds and a stiffer one if we find some big ones
Hate to say this but halibut fishing has been real spotty the last two times out but I am hoping for things to change in the next two weeks
I plan on doing more scouting between now and then.
Had a good friend up for 6 days. Took us three tries to fill one 50# box with fillets. I was starting to worry
My buddy with the numbers is working on halibut spots. He told me today he is out of room for more salmon so he will be targeting the big butts
Posted: Wed Jul 26, 2017 5:20 am
by Aripeka Angler
You know, it really doesn't matter if the halibut fishing is slow.
A nice, cool day on the water is fine by me.
Posted: Wed Jul 26, 2017 2:26 pm
Matters to me! Guests go home with fish, one way or another
Send me a picture of the reel you want to use. I need to make sure it will fit on one of my poles.
Posted: Thu Jul 27, 2017 8:44 pm
So Tom, and anyone else, I got the numbers you need I hope. The boat weighs 5300 all up with all but people. Add 700 and call it 6000 leaving the dock. Engine is an 1989 200hp 2-stroke Merc. Prop is a 13 pitch solas. At 6000 rpm boat is going 37mph. This is with some throttle left and not trying to get things trimmed out.
There is a planning pad that goes about 6 foot forward and tapers into the keel.
Looking at the bow
And I am having some cavitation on the prop that is causing this I think. You can feel the low spots that have formed. They just showed up this year for some reason
Any help would be greatly appreciated.
Posted: Thu Jul 27, 2017 11:02 pm
by TomW1
Fuzz okay I will work up some numbers. I hate to see that cavitation marks on the prop, not good. I still need the length at the waterline I am guessing 18-19 ft.
I have to say the Sintes 21 is a beautiful boat.
Posted: Thu Jul 27, 2017 11:48 pm
Sorry I did not start another thread. This boat is the 22 foot Seasport I put the bracket on two years ago. The Sintes 21 is still in the shop waiting on the Big Brain
I have no idea why the prop seems to be cavitating. I do not feel anything running or turning. It did not do it last year as far as I know. I am hoping a 4 blade stainless will help with that problem also. I have the motor mounted in the lowest hole. I received a template from the builder with the bracket. They build all of them for the factory new boats so I am pretty sure they have it correct.
Best guess on waterline is 19 foot. I can go measure it if needed.
Posted: Fri Jul 28, 2017 9:27 am
by topwater
Fuzz take a pic from the side showing the motor down , bracket, transom, bottom relationship .
I think i just used a 3 syllable word ....to much coffee this morning
Posted: Fri Jul 28, 2017 5:13 pm
by TomW1
Fuzz cavitation is usually caused by something in front of the propeller causing the air bubbles that then are drawn in to the prop. Check to see if there is any damage to the shaft in front before the prop. Any sort of ding or dang can cause bubbles that can be drawn into the prop causing cavitation damage. Even a paint chip can cause problems.
Posted: Fri Jul 28, 2017 5:45 pm
Topwater the picture you asked for is now posted in my I/O to outboard thread. I should have posted all my last questions there but got lazy
Tom I will move all of this to the other thread. Thanks.
Posted: Sat Jul 29, 2017 10:20 pm
by Aripeka Angler
Fuzz wrote: ↑Wed Jul 26, 2017 2:26 pm
Fuzz, Harrison scored me a big tube to bring my one piece conventional rig to AK.
I'll talk to you soon!
Posted: Sun Aug 13, 2017 7:08 am
by glossieblack
How goes it Fuzz? Has Richard arrived yet?
Posted: Sun Aug 13, 2017 1:21 pm
The weather has not been the best but other than that life is going ok I guess. Richard and family are in Homer now. In fact they should be fishing halibut on a charter as I write this. On his way back to Sterling he is planning on stopping by and we can talk boats
We have a silver fishing trip out of Seward planned for Wednesday.
The wind is blowing here so I looked for where AA is at now. Be interesting to learn how much fun they had, 25-30 knots and 7 foot seas
Posted: Sun Aug 13, 2017 2:59 pm
by Jeff
Fuzz, I am sure that is somewhat reasonable for Alaska, but 7 foot seas is really tough in our part of the world!! Jeff
Posted: Sun Aug 13, 2017 3:19 pm
by pee wee
Jeff wrote: ↑Sun Aug 13, 2017 2:59 pm
That may be bumpy water, but it's 93 degrees in south Florida and 53 degrees in Homer right now! Richard was looking forward to cooler air, looks like he found it. Hope he finds the fish, too.
Posted: Sun Aug 13, 2017 7:53 pm
I too really am hoping he finds some fish. I hate it if folks come to fish and it does not turn out so good. If he is where I think they are it will be short nasty chop and that is no fun at all doesn't matter what the water temp is.
Posted: Sun Aug 20, 2017 3:45 am
by glossieblack
Looking forward to hearing what layout you've decided on, now that you've had the chance to throw around ideas on-site with AA.
Posted: Sun Aug 20, 2017 6:08 pm
Thanks for your interest there Glossie
AA has convinced me to finish it out with the house forward. The hull is just too short to make an aft house look right. I will admit I really have the urge to have an aft house but I guess that will need to wait. I am still doing a little fishing and home projects. Need to get things done before freeze up, not something most of you guys need worry about
I do not think I will get serious about boat work until after this years builders meet.
Posted: Sun Aug 20, 2017 7:20 pm
by glossieblack
Peace of mind comes with a well formed plan.
Posted: Sun Aug 20, 2017 8:02 pm
glossieblack wrote: ↑Sun Aug 20, 2017 7:20 pm
That is one wise saying right there.
Posted: Sun Aug 20, 2017 8:48 pm
by cape man
Chaos leads to creativity.
Posted: Mon Aug 21, 2017 9:22 pm
by Aripeka Angler
IMHO, a well executed plan is way better than chaos.
I had the opportunity to look over Fuzz's Sintes 21 for a good long time.
It was great to visit his home and see this build, his OD18 and other boats. Not to mention his frames for future builds and a host of cool inboard and outboard motors.
The lines of the Sintes are very nice and the hull is clean and fair.
David has done a fantastic job on this rebuild!
The sheer line of his boat much resembles a well-built warm water bay boat.
With the built in transom bracket, I think the boat will ride well with proper trim.
I fear an aft cabin would load the boat too heavy in the stern...
Posted: Mon Aug 21, 2017 9:27 pm
cape man wrote: ↑Sun Aug 20, 2017 8:48 pm
My problem is sometimes there is not much method to my madness. Things come out more like,oh crap how did that happen
Posted: Mon Aug 21, 2017 9:31 pm
Aripeka Angler wrote: ↑Mon Aug 21, 2017 9:22 pm
Thanks AA. It was great for me to be able to sit and talk boats with a master builder.
I think you are correct on cabin location. And this will make CapeMan happy
Be even better to make it a CC and drag it down to your part of the world.
Posted: Mon Aug 21, 2017 10:00 pm
by Jaysen
Fuzz, don't you mean, "oh crap, how do I get myself out of this!?!"
Posted: Tue Aug 22, 2017 1:04 am
Posted: Wed Aug 23, 2017 7:08 am
by glossieblack
Can you be coaxed into disclosing how the forward cabin is going to be laid out, and what its going to look like?
Posted: Wed Aug 23, 2017 10:14 am
by Jaysen
I think the requirement was "enclosed head". And that the boss lady's requirement. So the layout is likely "head in cabin, Fuzz sits at tiller".
Re: Sintes 21 Rebuild
Posted: Wed Aug 23, 2017 12:16 pm
by topwater
So that means outhouse in the bow , Fuzz in the back
Posted: Wed Aug 23, 2017 5:07 pm
by Jaysen
That should seem right to every married guy...
Posted: Wed Aug 23, 2017 6:40 pm
by glossieblack
Nah. She on tiller, he doing as he pleases. lol:
Posted: Wed Aug 23, 2017 8:27 pm
glossieblack wrote: ↑Wed Aug 23, 2017 6:40 pm
I am just guessing here but I do not think you have dealt with a Red headed Russian much
I would love to let you know what the cabin will look like but I am still working that out in my pea brain
Right now I am thinking something like TopWaters but with the windows laid back more. I will just have to do a mock up and see how it looks.
Posted: Thu Aug 31, 2017 6:22 am
by glossieblack
Fuzz wrote: ↑Wed Aug 23, 2017 8:27 pm
I've gone back and looked at Topwater's build. What a nice job!
When you say something like Topwater's, do you mean a pilothouse/cabin with a stepped roof, the aft section with standing room for helming, then through a centre door into a seating only forward cabin with seats either side and a head under a lid in the centre? Your's is an interesting project.
Posted: Thu Aug 31, 2017 1:24 pm
Glossie I am thinking more like a walk around cabin with a few twists. It will only have a walkway on one side of the cabin. I will be able to enter mommas head from the front only. Small trunk cabin, used as dry storage only, helm area sort of open like a lobster boat. this is only a day fishing boat so no provision will be made for overnighting.
Posted: Sat Oct 28, 2017 3:45 am
Well I am done with my brake, it has snowed here so time to get back to boat work. Might have something picture worthy soon.
Posted: Sat Oct 28, 2017 8:40 am
by topwater
About time you got back to work you slacker
Posted: Sat Oct 28, 2017 8:57 am
by Eric1
Glad you are back on the build Fuzz. Look forward to the pictures.
Posted: Sat Oct 28, 2017 9:00 am
by Jaysen
That boat still exists? I thought you secretly scuttled it on one of the "fishing trips" that had no actual fish caught.
Posted: Sat Oct 28, 2017 1:00 pm
Eric1 wrote: ↑Sat Oct 28, 2017 8:57 am
Thanks Eric. I see you are feeling up to some sanding so you must be healing pretty well. That is good to know.
Posted: Sat Oct 28, 2017 1:03 pm
Jaysen wrote: ↑Sat Oct 28, 2017 9:00 am
Ok so you either have to start building a boat or show us more of your sailing prowess so I have ammo to fight back with. I thought I was going to be able to get you drunk and take pictures but you managed to avoid my clever plan.
Posted: Tue Oct 31, 2017 2:41 am
It has been a while since I posted any boat pictures. I will try to do something about that tomorrow. In the mean time here is a picture of my new lawnmower. Works on its own but does not cut too straight.
Posted: Tue Oct 31, 2017 4:05 am
by Eric1
That's pretty cool Fuzz!
Posted: Tue Oct 31, 2017 6:34 am
by Aripeka Angler
Nice looking animal.
He'd cut a straighter line if you got him a bigger mower
Posted: Tue Oct 31, 2017 6:37 am
by cape man
Keep him away from Mila's roses!
Posted: Tue Oct 31, 2017 7:46 am
by Jeff
Very cool Fuzz!!! Not something you see down here, ever!!! Jeff
Posted: Tue Oct 31, 2017 12:46 pm
by narfi
I am pretty sure I see 3 lawnmowers in that picture..... which one is the new one?
Posted: Wed Nov 01, 2017 1:07 am
The new mower is the walking one. But if he makes the mistake of getting into Momma's roses he might end up in the freezer. Good thing she has taken them all in for the winter. Saves me from homesteading the moose
On to boat stuff. Gave up on the aft house just could not make it work. So this is the latest plan. sort of a walkaround but only on one side. I wanted to extra room for dry storage and it gives a little more room in the head.
Still working out the windshield deal. Doing some trail and error to see what it would look like.
Posted: Wed Nov 01, 2017 10:02 am
by Jeff
Looks good Fuzz!! Love the new mower!! Jeff
Posted: Wed Nov 01, 2017 5:46 pm
by fallguy1000
Want to see the boat from another angle Fuzz. From the front side it looks like the helm is 6' up in the air.
I actually think your for'd head is an awesome idea for that rig. Beats going in a bucket in front of all the passengers.
Posted: Wed Nov 01, 2017 11:28 pm
Yep it looks way too tall to me too. That is why in the last picture there is what looks like upper and lower windshields.
I wanted to see what it would look like with a lower windshield. Either way I need a hardtop to keep the rain off my head so a builder I have a lot of respect for suggested building the hardtop and hanging it first to see what it looked like then.
This hull is really made to be a centre console boat. Problem is those are only good for 4-6 days out of the year around here. I had a centre console whaler and it seemed like nobody ever wanted to go fishing with me
At least not more than once
Posted: Fri Nov 03, 2017 7:07 pm
by fallguy1000
close in the pilothouse Fuzz
I have been on too many wet and rough rides in my boat.
I think you need to revise the layout so the door to the head is accessed from inside the pilothouse. My Starfire 24 I took to the dump had a lift off hatch that allowed access to the forward vee and a little door that opened. Basically, you cut out the dashboard for an access. Keep the head for'd, but walk to the head from inside the pilot to gain space and balance the pilothouse. Right now, you created a hallway around the boat so that someone can crap or pee and it isn't noisy or smelly for the crew. You can just set a house rule if anyone uses the crapper, everyone has to go have a smoke on the poop deck.
I made a picture for you. I will try to figure out how to upload it.
Posted: Fri Nov 03, 2017 7:15 pm
by fallguy1000
I put my drawing for you on my build thread, no rights here I guess. I might be missing a key element, but in a nutshell, this is the approach I would take. I had a Starfire 24 with exactly this layout, only there was a full berth in the forward section and a portapotti under the middle. The lift hatch was in the middle and you might need to do the same. They had the section for the cabin sole raised up a bit to help, not sure if you'd need to do that, but maybe. It is nicer to be on one level for fishing I know, but if you need to get headroom for the head; that is a way to do so by raising everything up 7".
All the best. Dan
Posted: Sat Nov 04, 2017 1:57 am
Dan my SeaSport has a set up a lot like what you are showing and I agree it works good and is very versatile. The problem is my wife has her heart set on the head having complete privacy. This is just about all she has ever asked for so I really want to honour that request. But thank you for following along and making suggestions.
I love your project but man you have bitten off one big elephant. Well as the Cracker would say one bite at a time and it will all get eaten
Posted: Sat Nov 04, 2017 7:27 am
by fallguy1000
Seal it off with a windshield gasket; make the door outta polystyrene, and put fans, parlor music, purell, moisturizer, air fresheners, and wallpaper it. You need access to the helm; so put a 2" removeable foam wall in. Polystyrene is cheap, light, low water absorption, r value, and you can stiffen it with 6 oz. You could even use thin poly and soundproof the head with monkeyfur. Hell, while you are at it; you could put in a little heater even. Boats too small for hallway if you ask me. The hallway can be cabin space for staying warm n dry on the rides to n fro. You can vent the head, too. Just use a bilge blower setup and a side vent like the bayliners use. Intake air from the cabin-assuming some warmth and exhaust out the head passively.
I get keeping the women happy. I maintain a 165 yard single hole golf course for my wife with real bent grass and all the fun bent grass provides. I'm a regular Carl Spackler.
Do you have a steering wheel? I have a morse teleflex around here. Bit big, but the one in the picture. The little wood pieces move with a set screw. Anyhow, I don't think it'd work with hydraulic steering.
Posted: Sat Nov 04, 2017 10:30 pm
First thank you for the offer but as you suspected I will be using hydraulic steering.
As for the cabin there is not really going to be one. Just a private head for SWMBO and something to keep the wind and rain off when needed.
Not much boat work lately. I got distracted, Jaysen will love this, looking at a blow boat with a buddy. That and changing over to snow tires on three vehicles.
Posted: Sat Nov 04, 2017 10:36 pm
by Jaysen
Define “looking at”. I’m guessing that means different things for the two of us.
Posted: Sat Nov 04, 2017 10:45 pm
So one of oldest friend called and asked me to go look at a 36 foot Cape George cutter with him. He has been wanting another sail boat for a long time. It was a really nice boat and we could not find a thing wrong with it. So I will just wait and see where it goes from here. I am betting it is better than 50-50 he will cut a check for it.
Posted: Sat Nov 04, 2017 11:06 pm
by Jaysen
Oh that sounds nice. Very nice. I’d already be packing my bags and selling everything else
Posted: Sun Nov 05, 2017 9:37 am
by fallguy1000
I hate getting wet. I figured you were making a small enclosed helm for passengers. I would definitely install a head. I hate fishing without one on big waters.
Nothing worse than a bag of donuts, fishing, and coffee at 4 am. The fishing ends up a problem.
Posted: Tue Nov 07, 2017 10:40 pm
I have been working on the hardtop. I had some nidacore laying around so that is what I am using to build it out of. There will be 1.5 inch crown in it. Hardtop is 8 x 5 foot. I have a bunch of 17oz biax so that is what I am using. Will have to see what I think after I get one layer on each side.
I thought I had a different picture but this one with the rifle is all I had.
Posted: Tue Nov 07, 2017 11:48 pm
by fallguy1000
I figured maybe you were tired of me arguing about the plans with you so you left the convincer out!
Good luck, take it slow.
Posted: Wed Nov 08, 2017 12:56 am
Not to worry about having different ideas, EVER. If I did not want to know what others think I would not post stuff. Plus the best way to learn stuff is to post and ask questions. Watching your little project has been very educational.
Posted: Thu Nov 09, 2017 10:07 am
by glossieblack
Time for some Sintes action. Fooling around in blow boats should not interfere with boating building
Posted: Thu Nov 09, 2017 5:18 pm
I have been working on the hardtop. Figure I better post something or Glossieblack is going to hold out giving us the good stuff
This is trying to get a feel for what it might look like.
And this starting to put the trim on it. The board in the middle is temporary. It will be a lifting eye to get it on and off as needed. The hardtop is not very heavy but it is large enough to be a pain for one man.
Posted: Thu Nov 09, 2017 5:32 pm
by Jaysen
Head entrance, with windscreen aft... so the entrance to the head faces forward and is not protected. Did I get that right?
Posted: Thu Nov 09, 2017 5:42 pm
Yep
After all there should be a limit on how nice a potty is.
Not going to be used while under way so I think it will work out ok...............we will see.
If this turns into a total mess I can always cut it all off and make it into an open skiff. Always need a backup plan
Posted: Thu Nov 09, 2017 5:45 pm
by Jaysen
Fuzz wrote: ↑Thu Nov 09, 2017 5:42 pm
Yep
Sounds perfect for me to take a ride in... open the hatch, open throttle and wash my last months worth of lunches out the scuppers.
I actually think that's not a bad plan. The head entrance, not the method of dealing with my presence on board.
Posted: Thu Nov 09, 2017 9:07 pm
Well before I can deal with you onboard you are going to have to include me on your trip around the world to see builders boats
Posted: Thu Nov 09, 2017 9:33 pm
by Aripeka Angler
I like the hardtop, wish I could put an actual eyeball on it.
The proportion looks pretty good, keep up the good work.
If you want me to rag on your fairing, it's not going to happen.
I think you are doing fine work...
Edit..Siri can't spell "you"
Posted: Thu Nov 09, 2017 9:49 pm
by Jaysen
Fuzz wrote: ↑Thu Nov 09, 2017 9:07 pm
Right now the big target is first week of May. Little place outside Brisbane. It goes by the name of “Noosa”. Not sure the full path yet.
Posted: Thu Nov 09, 2017 10:11 pm
by Eric1
That looks nice Fuzz, keep up the good work!
Posted: Thu Nov 09, 2017 10:50 pm
That should be a wonderful trip Jaysen. Australia is about the only place left on my personal bucket list. Not sure if it will ever happen at this point in my life
Posted: Thu Nov 09, 2017 10:53 pm
Eric1 wrote: ↑Thu Nov 09, 2017 10:11 pm
Thanks Eric. I am hoping with a little dressing up it will look ok. Lots more angles than you would think at first glance.
Posted: Fri Nov 10, 2017 6:25 am
by Eric1
Fuzz wrote: ↑Thu Nov 09, 2017 10:53 pm
Oh no, I get it. That's a crap load of work! But in the future you can work at taking a crap in private.
Seriously, Keep the pictures coming! I think I'll learn a thing or two.
Posted: Fri Nov 10, 2017 9:29 pm
by glossieblack
Nice progress Fuzz. What did you decide about the tank installation?
Posted: Sat Nov 11, 2017 2:32 am
Got a little more work done on the hardtop.
That is close to the end product as far as looks go. Well unless someone has a great idea
Went ahead and flipped it back over to do some work on the underside. I am using wood flour as a first pass fairing compound. The grey is just tinted epoxy. I needed to put a seal coat on and thought why not tint it?
Glossieblack asked about the fuel tank. I will do as advised and not foam it in. With me totally changing the original plan I ended up putting the tank in the centre of the boat. I will be putting back to back seating over it so my needing to raise the deck problem has been solved.
Posted: Sat Nov 11, 2017 4:00 am
by glossieblack
Fuzz wrote: ↑Sat Nov 11, 2017 2:32 am
Posted: Sat Nov 11, 2017 5:21 am
by Eric1
One smart fella felt smart! Say it three times quickly.
Posted: Sat Nov 11, 2017 6:13 am
by cape man
That's one hell of a top! Are you leaving the edges as bright work? Might look nice...
Posted: Sat Nov 11, 2017 11:05 am
by fallguy1000
Does the hardtop cover the entire cockpit?
I want another perspective!
Thanks.
Posted: Sat Nov 11, 2017 6:20 pm
by Aripeka Angler
fallguy1000 wrote: ↑Sat Nov 11, 2017 11:05 am
Thanks.
Me too! When you get a chance, center the top up on the house and post a pic.
Looks great!
Posted: Sat Nov 11, 2017 6:34 pm
Eric1 wrote: ↑Sat Nov 11, 2017 5:21 am
Surprised that came from you Eric. More like something Peter would come up with
Posted: Sat Nov 11, 2017 6:38 pm
Craig I would like to have some bright finished wood on this boat as i love the looks of it. I will have to see if the trip is in good enough shape when finished to leave it bright or not. I do have some UV resistant marine epoxy for just that purpose. Have any of you used it and if so how is it doing?
Posted: Sat Nov 11, 2017 6:47 pm
Fallguy and AA I will post a picture of it on the boat in a few days. I need to get a little more done on it before I do that. I am wanting to see how it looks myself
The size is 8 foot by 5 foot. It will cover from just in front of the windshield to just aft of the seating area. There will be about 4 foot of the stern that is not covered. I want room to work fishing rods and move around. One of my main fishing buddies is about 6foot three so I am trying to be a good guy and have it clear his head.
Posted: Sat Nov 11, 2017 7:13 pm
by Jeff
Fuzz, really looking forward to seeing those photos!! Jeff
Posted: Sun Nov 12, 2017 2:51 am
by gonandkarl
Hi,
You made a beautiful hardtop. I am looking forward to the next pictures. How do you handle such a big piece 8 x 5 foot ? With a pulley overhead or is it manageable for one person ?
Greetings from Karl
Posted: Sun Nov 12, 2017 1:24 pm
Karl it is not too heavy at this time. Maybe about the same as a sheet of 1/2 inch plywood. The problem is it is so bulky and no handles it is hard to handle. When I go to set it on the boat I will try to remember to weigh it. I sort of wonder what it will weigh myself.
Posted: Tue Nov 14, 2017 2:36 am
I got the hardtop primed with a first coat. Next move is to get it back up on boat to see how it looks.
Posted: Tue Nov 14, 2017 5:54 am
by Eric1
Looking Good Fuzz!
Posted: Tue Nov 14, 2017 6:36 am
by Jaysen
Did you read the hidden message in eric1’s post? I’ve “made it bigger” for you.
Eric1 wrote: ↑Tue Nov 14, 2017 5:54 am
Looking Good Fuzz!
Now you need to sand it. I’ve sent you a box of paper all the way to 3000. I want to see it shine!
Posted: Tue Nov 14, 2017 1:45 pm
Posted: Thu Nov 16, 2017 9:55 pm
5x8 1708 both sides of 3/4 nidacore. Anyone want to make a guess what it weighs?
Posted: Thu Nov 16, 2017 10:19 pm
by Jaysen
Assuming you’re not using lead based epoxy or making a sloppy mess of it, the numbers say right around 200. But that seems really high. I’m thinking i messed up the volume comparisons (sqft v sqyd v ft3)
Posted: Thu Nov 16, 2017 10:38 pm
by cape man
50 lbs
Posted: Fri Nov 17, 2017 3:40 am
Jaysen wrote: ↑Thu Nov 16, 2017 10:19 pm
Dang man did you think the core is made of concrete? I will say it is between your guess and CapeMan's with him being way closer
Posted: Fri Nov 17, 2017 4:08 am
by narfi
Around 30lbs plus the core weight..... I can't find info on nidacore weights.....
Posted: Fri Nov 17, 2017 4:49 am
by glossieblack
My call is that it will be 51 lbs.
Craig is about the only builder I'm aware of who set out to seriously build to a weight budget (Hermine at 100lbs). He built fractionally over.
He's called the Fuzztop at 50 lbs. So I'm calling it 51lbs.
Posted: Fri Nov 17, 2017 5:48 am
by Aripeka Angler
It weighs 26.09 kilos.
Posted: Fri Nov 17, 2017 6:17 am
by cape man
I beg your pardon!! Hermine is 98 lbs!
Posted: Fri Nov 17, 2017 6:32 am
by Jaysen
Fuzz wrote: ↑Fri Nov 17, 2017 3:40 am
No. I put the core are about 6lbs based on 5lb/ft3 researches on line. But 1708 at a 50/50 ratio is 34oz per sqft. 2x that for top+bottom and 68oz/sqft. 68x40=2720oz total in glass and resin. Divide that by 16 and you get 170lbs. So before we factor in “fuzz factor” we are at 175lbs.
Now read the last sentence of my post. I may be messing up a volume or weight conversion somewhere.
Posted: Fri Nov 17, 2017 7:23 am
by glossieblack
Perspective, dear Jaysen, perspective.
You've deduced that the Fuzztop is around 175 lbs, with the disclaimer you may have miscalculated.
With Craig advising he has built the entire 16 foot Hermine at under 100 lbs .....
Posted: Fri Nov 17, 2017 7:29 am
by Jaysen
In my defense...
Hermine was built skinny. Light tape. Light materials. Fuzz is not a skinny builder. The math on 1708 isn’t really a question though. It’s 17+oz/sqft. Just the fabric is 17ox so the matt has to put it over 17/ft. The the normal
“Experts hit 50:50” type things and you wind up at 200.
I knew it was off hence my closing statement. I just can figure out where I missed the conversion.
Posted: Fri Nov 17, 2017 7:42 am
by glossieblack
Try around 17 oz per square yard.
Posted: Fri Nov 17, 2017 8:04 am
by Jaysen
And there we have the “idiot step”. 17/sqyd.
So 5x8 == 6x7 == 2x2.3== 4.7sqyd
4.7x17x2==81.9 oz fabric
81.9x2==163.8oz fab+resin
164/16==10.25 lbs fab+resin
Nida is 5lb/4x8@3/4”
Fuzzy has 1.25 sheets for 6.25lbs
Let’s round that all up to 20lbs
What we are missing is the matting and “fuzz factor”. We know 50 is light. We also know it is stupid cold up there. And he married a Russian. That must mean fuzz does things “manly!” That means we have to triple the base weight and say...
My redo was guess is 61.325lbs.
Thank you glossieblack
Posted: Fri Nov 17, 2017 9:03 am
by cape_fisherman
My buddy builds decks from 3" honeycomb...he averages 1.2#/sqft. At that rate you would be around 48#...with 3" core.
Posted: Fri Nov 17, 2017 9:05 am
by Jaysen
Fuzz wrote: ↑Fri Nov 17, 2017 3:40 am I will say it is between your guess and CapeMan's with him being way closer
Cape man, the fuzz factor needs to be factored in here...
Posted: Fri Nov 17, 2017 11:24 am
by narfi
So where do you find weights for nidacore?
I read 1708 is 17oz cloth and 8oz matt so 25oz sqyrd
(25oz*2sides)*(2 for the resin) = 100 Oz sqyrd
5x8 = 40 sqft
40sqft*100oz = 4000oz
4000oz = 250lbs
250lbs /9(ft in a yard) = 27.77lbs
Roundup for the edges and any heavy spots and you get 30lbs without the core.
Posted: Fri Nov 17, 2017 12:46 pm
by pee wee
I'm going with 64 pounds, and that's a w.a.g.
Posted: Fri Nov 17, 2017 1:01 pm
by Jaysen
narfi wrote: ↑Fri Nov 17, 2017 11:24 am
There’s this little site called google...
Posted: Fri Nov 17, 2017 1:02 pm
by cape man
Posted: Fri Nov 17, 2017 1:26 pm
by narfi
Jaysen wrote: ↑Fri Nov 17, 2017 1:01 pm
And here I was flipping through Encyclopedia Britannica......
Posted: Fri Nov 17, 2017 2:15 pm
by Jaysen
narfi wrote: ↑Fri Nov 17, 2017 1:26 pm
I googled "nidacore weight" and looked at a few sites. The seem to suggest a common weight.
Posted: Fri Nov 17, 2017 3:03 pm
I am not sure if AA was just messing with us or what but 26.09 kilos equal 57.398 pounds and my new electronic scale said 58 pounds. Have account for the trim and such
All in all I am pretty happy with the weight. Now I just have to figure out how I am going to attach it. I have a plan for the back but the front.........not so much
My biggest worry is it blowing off driving down the road.
Posted: Fri Nov 17, 2017 4:05 pm
by Aripeka Angler
Fuzz wrote: ↑Fri Nov 17, 2017 3:03 pm
I'm pissed. I thought I would be closer than that.
Posted: Fri Nov 17, 2017 6:06 pm
by Jaysen
Son of a...
5200 will hold it down.
Posted: Fri Nov 17, 2017 6:53 pm
cape_fisherman wrote: ↑Fri Nov 17, 2017 9:03 am
It would be nice to spend time watching professionals build. Getting paid to work with all the latest materials and not having to worry over a budget would be a dream. Unfortunately a totally self taught builder in Alaska does not those opportunities so we do the best we can.
Posted: Fri Nov 17, 2017 7:18 pm
by cape_fisherman
Fuzz wrote: ↑Fri Nov 17, 2017 6:53 pm
I would imagine the core isn't exponentially heavier. The difference probably comes from the fact he bags all of his stuff. That epoxy is heavy stuff.
Your build is awesome. Grateful to be watching you work.
Posted: Sat Nov 18, 2017 2:33 am
cape_fisherman wrote: ↑Fri Nov 17, 2017 7:18 pm
My build is just something to keep me busy during the winter when I can't go fishing. On the best day it is far short of awesome, I have seen some builds at the last two meets that count as awesome. Not many yacht builders in this area. Those that build lean to work boats and to them it is all about getting the job done. I am hoping this will end up something a little better than work boat but we will see
Posted: Sat Nov 18, 2017 7:47 am
by topwater
David i ran one layer of 12 oz outside and inside where it meets the windshield frame. I have 1" stiffeners along each side
glued to the top of the side walls . That gave me 1 3/8" glueing surface along both sides and i stuck it with epoxy no tape.
I have hauled it at 85 mph with no problems all the way from Chicago .
Posted: Sun Nov 19, 2017 12:26 am
The way your roof is built I am not surprised it works good TopWater. This is not planned to be a cabin and roof but more like a centre console hardtop. I am thinking it will have either one or two posts each side on the bow section supporting it. I will post pictures when I get a little closer so it makes since...........sort of
Posted: Sun Nov 19, 2017 7:31 am
by Jaysen
Break out the crayons and give it a go.
Posted: Sat Nov 25, 2017 1:49 am
Been messing with the boat a little. And to prove to Jaysen I have not been hibernating I got the fuel tank in place. I will have back to back seating over the top of it so raising the deck in that area has turned out to be no problem.
Posted: Sat Nov 25, 2017 7:19 am
by Jaysen
I wasn’t thinking you were hibernating as much as maybe the Russians had had enough.
Making sure I understand, there’s a seat over the tank. Yes?
Posted: Sat Nov 25, 2017 1:14 pm
Seat over the back of the tank and some floor board over the front part. I need to get a better picture of it over all.
Posted: Mon Dec 18, 2017 7:21 pm
by doug42190
Well, what happened?
Posted: Mon Dec 18, 2017 8:58 pm
doug42190 wrote: ↑Mon Dec 18, 2017 7:21 pm
Life
Both my mother and my mother-in-law have had some pretty sever heath issues and that has been taking up most of my time.
I have been remiss in posting anything on the boat but thanks for asking. Been doing a little here and there on the boat but not much picture worthy. I am hoping to change this in the next few weeks.
Posted: Mon Dec 18, 2017 9:01 pm
by Jeff
Fuzz, so sorry to hear about your mother and mother-in-law!! Certainly hoping for a speedy recovery for the both of them this holiday season!! Jeff
Posted: Mon Dec 18, 2017 9:24 pm
Thanks Jeff. It is just end of life stuff that we all go through sooner or later.
I feel like my whole family has already received a wonderful Christmas present. Saturday one of my nephews wife hit some black ice, slid off the road and flipped her suburban end over end. She had the one year old girl and six year old boy with her and they all walked away unhurt. Hard to beat that for an x-mas gift.
Posted: Mon Dec 18, 2017 10:01 pm
by Madgar
Your absolutely right fuzz. Although hard sometimes, recognizing the positives that come out of negative events puts life in perspective. The fact that they all survived an accident like that definitely makes you recognize what's important. Hope the remainder of your Xmas is as positive as that story.
Posted: Tue Dec 19, 2017 2:49 am
by Eric1
Fuzz wrote: ↑Mon Dec 18, 2017 9:24 pm
WOW! That such a blessing!!!
Posted: Tue Dec 19, 2017 7:38 am
by doug42190
I am so sorry to hear of the trials you and your family are dealing with. It is said often that this is the season of miracles and it sounds like that has been true for you. Blessings.
Doug
Posted: Tue Dec 19, 2017 1:52 pm
by TomW1
Fuzz sorry to hear about your troubles at this time of year. May God bless your family and keep them well in this time of miracles. Merry Christmas and Happy New Year.
Posted: Tue Dec 19, 2017 2:15 pm
Thanks Guys, one and all. I did not post that looking for sympathy just trying to ease my guilt for not posting any boat building stuff in a while.
Still really warm here. If the weather patterns follow their normal path you folks on the southern east coast will be having a bit of cool weather
Posted: Tue Dec 19, 2017 2:22 pm
by Jeff
Wow, Fuzz!! That is truly amazing they walked-away!! Good for them and your family!! Happy holidays, Jeff
Posted: Tue Dec 19, 2017 2:56 pm
Thanks Jeff, we got lucky but as they say it is better to be lucky than good
Back to boat building stuff. I am building a few hatches and have a question I am sure you guys can answer.
I have this latch and it has two screw holes in it. My question is after you cut the hole out what do you screw to
And to go with that question what holds the latch in place. I am sure it will be simple when explained to me
Posted: Tue Dec 19, 2017 7:52 pm
by seaslug
Hey David, The latches should have come with a backing plate that is about 1/4" larger in diameter than the hole the latch fits tightly into. The plate has a cut out so it fits around the part that spins to lock the latch, and you use 2 machine screws with nuts to tighten it up to the underside of the hatch. Be sure to drill the hole for the latch in the correct location so you can have that pivoting arm close under either the hatch gutter or a piece of hardware you attach to the inside edge of the gutter. Hope this helps. Mike
Posted: Wed Dec 20, 2017 12:52 am
Hey thanks for the info Mike. That makes sense but for what ever reason mine did not come with the backing plate. I ended up making my own but I am sure they will not be as nice. I did mount a catch under the lid for the lever to catch on. We will see how it all works out.
Posted: Fri Dec 22, 2017 3:21 pm
Big day here today. The days are getting longer
Sun up at 1013 and set at 354 a gain of 8 seconds over yesterday
Got to get busy with boat work as spring is almost here.
Posted: Fri Dec 22, 2017 5:03 pm
by Jeff
Wow Fuzz, that is just too wild!!!! Jeff
Posted: Fri Dec 22, 2017 6:00 pm
by Aripeka Angler
Fuzz wrote: ↑Fri Dec 22, 2017 3:21 pm
Crazy, wild and beautiful place where you live.
I looking forward to my next trip up there in 2019. In the Summer though.
Posted: Fri Dec 22, 2017 9:07 pm
And you know we are looking forward to hosting you and Sandy. And if Craig and Patty do not make it up here next summer you MUST drag them along with you
Had to drive to Homer to pick up some fuel fill and vent hose yesterday. To go with that does anyone have a preferred fill and vent fitting?
Posted: Sat Dec 23, 2017 5:19 am
by glossieblack
Season's greeting Fuzz! And go the Sintes rebuild!
Posted: Sat Dec 23, 2017 6:41 pm
Not sure where is the best place to post this so here it is.
I hope one and all have great holidays and next year is nothing but the best for each of you.
Posted: Sat Dec 23, 2017 6:54 pm
by Jeff
Fuzz, thanks!!! You stay warm up there and enjoy the holidays!! Jeff
Posted: Fri Dec 29, 2017 2:46 am
Got around to doing a little boat work the last few days. First thing was wrap glass over the gunwales and down the sides a couple of inches. I wanted a nice straight line so I used a batten and hot glued it to the side. Then used partall to keep the epoxy from sticking. The next day when I went to peel the batten off it took primer and fairing compound with it
So now I have a mess to try and clean up.
The good news is I am hoping I will never have this view of the fuel tank.
One step forward and one back. Thats the way it goes sometimes.
Posted: Fri Dec 29, 2017 6:32 am
by topwater
David are you going to put any sealer between the hold down straps and the tank
you don't want any crevice corrosion .
Posted: Fri Dec 29, 2017 6:47 am
by Jaysen
What's a little more fairing, painting and ... SANDING!!!?
How's it feel to be back on the boat a bit?
Posted: Fri Dec 29, 2017 7:30 am
by Jeff
Fuzz, just nice to see you back working on your boat!!! Have a great 2018!! Jeff
Posted: Fri Dec 29, 2017 9:53 am
by fallguy1000
Use gorilla shipping tape on the batten next time. If there is any difference in the compounds in the steel between the tank and the holddown; you'll likely end up with galvanic corrosion. Make sure to put something in between them no matter what. The other fellow gave you great advice and I 2nd it.
Posted: Fri Dec 29, 2017 1:29 pm
topwater wrote: ↑Fri Dec 29, 2017 6:32 am
Good to hear from you John. There is nothing between the straps and the tank. I can still raise them and either put some of the rubber they sent in there or use 5200. What do you guys think? All other support spots have the rubber straps put on the tank with 5200. This what Speedy Tanks said to do and is recommended by Prisco. I never thought about the tie down straps
Posted: Fri Dec 29, 2017 1:32 pm
It is good to be back doing some boat work. My summer break went a little longer than planned.
Posted: Fri Dec 29, 2017 2:02 pm
by OrangeQuest
Fuzz wrote: ↑Fri Dec 29, 2017 1:29 pm
Use 5200 between the strap and the rubber. Will keep the rubber from moving and "if" you ever need to remove the tank the straps will not stick to the tank.
Posted: Fri Dec 29, 2017 8:00 pm
Fallguy and Orangequest thank both of you for the tips. I will give both a try.
Posted: Fri Dec 29, 2017 9:55 pm
by TomW1
Fuzz glad to see you working on her.
Posted: Sat Dec 30, 2017 5:07 am
by glossieblack
TomW1 wrote: ↑Fri Dec 29, 2017 9:55 pm
x2
Posted: Sat Dec 30, 2017 6:45 am
by Eric1
I'm glad one of us is working!
Posted: Sat Dec 30, 2017 7:34 am
by cape man
I'm done for awhile
Posted: Sat Dec 30, 2017 1:31 pm
Eric1 wrote: ↑Sat Dec 30, 2017 6:45 am
I bet you get more done in an hour than I do in a day.
It is not unusual for me have to go back and redo half of what I did
Posted: Sat Dec 30, 2017 1:34 pm
cape man wrote: ↑Sat Dec 30, 2017 7:34 am
I'm done for awhile
I could be done but I need something like the rebuild to keep me moving during the winter months. If not come spring I would emerge from my den at 300 lbs
I am hoping the Alaska Blast does not show up about the time you do your Cape Sable trip.
Posted: Sat Dec 30, 2017 3:22 pm
by cape man
It is coming through Monday, and we're going down Tuesday. 15 to 20 from the North Tuesday night. Beach faces South so we're good. May be an interesting ride for Hermine going out!
Cold is good! Cold or bugs. That's the choice.
Happy New Year my friend!
Posted: Sun Dec 31, 2017 4:07 am
Happy new year to you and Patti too. I hope your trip turns out good. We will be waiting for pictures
Posted: Sun Dec 31, 2017 8:00 am
by glossieblack
Happy new year David and Craig.
Posted: Sun Dec 31, 2017 8:15 am
by cape man
They just showed the fireworks in Aukland. So how does 2018 feel so far?
Posted: Sun Dec 31, 2017 8:31 am
by glossieblack
cape man wrote: ↑Sun Dec 31, 2017 8:15 am
Aukland? Quite a nice spot, but there are a lot of New Zealanders over there.
Generally, Aussies view New Zealanders much the same way as Americans view Canadians: sort of slightly bland and taken for granted members of the extended family.
Posted: Thu Jan 04, 2018 12:41 am
Got a little time to work on the boat. I have the chase tubes installed. Hope I got enough cause it ain't going to change now. 2- two inch and 2 inch and a half in the deck plus 3 one inch and 1 half inch in the side going to the stern. 1 one inch and one half inch to the bow.
Posted: Thu Jan 04, 2018 7:47 am
by Jeff
Good stuff Fuzz!!!
Posted: Thu Jan 04, 2018 8:08 am
by topwater
I hate to admit it but now i totally feel chase tube inadequate
What are you going to be running back there a crane
Posted: Thu Jan 04, 2018 8:33 am
by Eric1
I think you may have it covered.
Posted: Thu Jan 04, 2018 11:39 am
by TomW1
I think that will cover it
Posted: Thu Jan 04, 2018 12:28 pm
by narfi
I am curious if you coat the inside of the holes in the side braces that the tubes go through?
Posted: Thu Jan 04, 2018 1:53 pm
The plan is to have a remote controlled kicker to go with the main so I ran extra tubes for it also. I am pretty sure I will mount the batteries midship so I needed a tube for them also. The fuel line runs between the centre stringers.
Narfi I just cut the holes and then gave them a coat of resin. Given where they are if they need more water proofing than that I have bigger issues
Posted: Thu Jan 04, 2018 3:10 pm
by Jaysen
separate tubes for primary and kicker?
Posted: Thu Jan 04, 2018 8:03 pm
Jaysen wrote: ↑Thu Jan 04, 2018 3:10 pm
I have never run the controls through tubes before but I did not think I could get two sets of cables though one tube so I ran one for each motor. If it turns out I could have then I guess I will just have extra tubes if needed later on.
Posted: Thu Jan 04, 2018 8:31 pm
by Jeff
Fuzz, I agree!! You never have too many!!! Jeff
Posted: Thu Jan 04, 2018 9:35 pm
by Jaysen
Fuzz wrote: ↑Thu Jan 04, 2018 8:03 pm
Now I’m responsible for anticipating and developing plans to mitigate/recover from “hold my beer” situations (aka “fork me we’re screwed!!!”). I tend to look at everything through glasses that say “fork me that’s a disaster waiting to happen”. So...
It seems to me that you would want to run all backup systems through separate conduit. This would prevent any that gets in a conduit and damages one motor from getting both of them. And since you seem to insist on living in a place that is the other end of hell’s thermostat I think true redundancy would be a good way to make sure you make it home.
But that’s just me thinking. Which explains the beeping fire alarms.
Posted: Thu Jan 04, 2018 10:52 pm
Jaysen your thinking and mine are the same about the back up power. I guess this means we are in trouble
That is the reason for doubling up on the larger chases.
Posted: Fri Jan 05, 2018 7:16 am
by Jaysen
Yeah fuzz. If we are on the same page It’s either the end of the world or hostile alien invasion (which is pretty much then same thing).
And yes, I wear suspenders with my belt. I’ve stopped using duct tape though. The adhesive was giving me a rash.
Posted: Fri Jan 05, 2018 3:04 pm
Jaysen wrote: ↑Fri Jan 05, 2018 7:16 am
Damn it man I just blew my morning coffee all over my keyboard
Posted: Fri Jan 05, 2018 3:05 pm
by Jaysen
Fuzz wrote: ↑Fri Jan 05, 2018 3:04 pm
Mission accomplished.
Posted: Tue Jan 09, 2018 9:57 pm
I think I need to put a combing/bullwork on the nose of this thing. I am thinking about 3-4 inches tall across the back edge, what do you guys say
Posted: Tue Jan 09, 2018 10:01 pm
With you guys stealing all of our cold weather Santa got lost and could not find my place
Good news is it has cooled down a little so Santa found me and dropped this off today
Now I have to figure out how to work it. Who knew a sander with a vac could be complicated to run
Posted: Wed Jan 10, 2018 1:21 am
by glossieblack
Haven't seen the Fuztool brand before.
No, on closer inspection, it's a Festool. Bet you like it. I do mine.
Posted: Wed Jan 10, 2018 3:43 am
Well to tell the truth after using it for about 30 minutes this evening I do not recommend builders buying it.
The darn thing scares me. I think it is going to make me like sanding. It could get so bad I turn into the "Eric of the North"
Posted: Wed Jan 10, 2018 4:34 am
by glossieblack
Fuzz wrote: ↑Wed Jan 10, 2018 3:43 am
Get a grip man.
You're future as a sanding tragic is blazed across the skies.
First you give repeated glimpses of your obsessional interest in Eric's penchant for sanding.
Then you go and buy a top of the market sanding system.
If this is what lifts your kilt, fine.
If not, intensive counselling may help.
Thanks for your best wishes for my health over this past week.
Posted: Wed Jan 10, 2018 6:58 am
by cape man
Nice purchase! Yes to the coming up front.
Posted: Wed Jan 10, 2018 7:00 am
by Jaysen
Hahahahahahahaha
Hahahahaha
Hahaha
No. Just no.
Posted: Wed Jan 10, 2018 7:06 am
by Eric1
Posted: Wed Jan 10, 2018 7:07 am
by topwater
Fuzz has gone over to the dark side
You baby , couldn't take wearing a respirator being covered in sanding dust
and itching like a two bit whore on dollar day. You are going to miss looking like the loser of tar and feather fight
Posted: Wed Jan 10, 2018 9:05 am
by pee wee
Very Nice! It seems like too much money to spend . . . until you experience the difference. Welcome to the dark side!
Posted: Thu Jan 11, 2018 8:25 am
by topwater
I agree wholeheartedly
I just get shop and tool envy and i like busting Fuzz when i get the chance
Posted: Thu Jan 11, 2018 2:42 pm
Thanks guys
We will see how much I really like my new toy in a few days. I have been trying to spend time with my daughter who is home from college. She graduates in the spring and then off on the next phase of her life so this is probably the last time she will be here for any duration. Sort of tough on Dads to see their little girls grow up and move on
I did note from some of the commits that there seems to be others beside me and Glossieblack who have sprung for the fancy smancy sander/vacs.
Topwater you can not bust my chops much. I seem to recall your shop looking like an operating room while you were building
Posted: Thu Jan 11, 2018 5:19 pm
by gonandkarl
You could not have bought yourself a better Christmas present than a Festool sander. Should I be allowed to build another boat in the future I think I know what to buy. Splashing in half the estimated building hours of Jacques plans. I am serious I think nothing took so long as sanding. Hope you have lots of fun with the new sander.
Posted: Thu Jan 11, 2018 8:59 pm
Thanks Karl. I am hoping the new sander changes the way I view sanding. Too many times I have put off sanding because I just did not want to deal with the mess. I guess time will.
Posted: Thu Jan 11, 2018 9:16 pm
by cape man
Am I losing all my 30 foot finish friends?
Posted: Thu Jan 11, 2018 9:28 pm
by Jaysen
If you count me as a friend, no. Heck no.
30’ is my stretch goal.
Posted: Fri Jan 12, 2018 12:54 am
We are good Capeman, no worries. Even with top quality tools I am still hoping for a 30x30 finish. That would be 30 foot away and passing at 30mph
I keep thinking Jaysen must be a long lost cousin or something
Posted: Fri Jan 12, 2018 1:02 am
Checked the mail today and a sweet little gift from AA showed up
Thank you very much Richard.
Posted: Fri Jan 12, 2018 4:43 am
by Aripeka Angler
You're welcome.
Amazing it only took 4 days from Florida...
Posted: Sat Jan 13, 2018 3:06 pm
by TomW1
OH NO we are unleashing an other Eric into the world.
Posted: Sat Jan 13, 2018 3:29 pm
by Eric1
TomW1 wrote: ↑Sat Jan 13, 2018 3:06 pm
Posted: Sat Jan 13, 2018 4:48 pm
Too funny! I was just going to post this picture when I saw this.
Talk about timing. Glassed the side deck and that gave me an opportunity to run my new toy
Posted: Sat Jan 13, 2018 5:00 pm
by Eric1
Posted: Sat Jan 13, 2018 8:23 pm
by Jaysen
And?
Will you have mirror finished primer?
Posted: Sat Jan 13, 2018 8:40 pm
Jaysen wrote: ↑Sat Jan 13, 2018 8:23 pm
And?
Are we deep into the sauce this evening
You seem to have forgot I am a charter member of the 30 foot club
Posted: Sat Jan 13, 2018 10:28 pm
by Jaysen
Fuzz wrote: ↑Sat Jan 13, 2018 8:40 pm
And?
I have not, but ... you may decide to LIKE sanding. Eric seems to be a BAD INFLUENCE! Just look at that sander...
Posted: Mon Jan 15, 2018 12:39 am
Well I need supports for my hardtop but there is nobody in this area to do fancy pipework so I am trying to fashion something out of wood. We will see how it works
Posted: Mon Jan 15, 2018 6:00 am
by glossieblack
Fuzz wrote: ↑Mon Jan 15, 2018 12:39 am
Go Fuzz! Laminated bent plywood can do the job. Just start building, and you'll soon get a feel for how many laminations you need.
Posted: Mon Jan 15, 2018 6:49 am
by Eric1
That's cool Fuzz. Are you going for a boxed/ tube approach or solid laminate?
Posted: Mon Jan 15, 2018 7:03 am
by cape man
Are you glueing those on a jig or in place?
Posted: Mon Jan 15, 2018 8:09 am
by topwater
What about pool noodles with carbon fiber
Posted: Mon Jan 15, 2018 2:15 pm
Thanks Glossie, Eric, Capeman and Topwater
The plan is to build a box beam with a tube inside. I need some way of draining the water off the top of the hardtop so that is what the tube is for. Using a jig would have been better but I just went for it, we will see how it turns out.
A tube and carbon fibre might have been much nicer but neither one is available around here
Posted: Mon Jan 15, 2018 6:08 pm
Added a layer of 3/8 plywood to the lower beam. The is one layer of 3/8 and one layer of 1/4 top and bottom. I am using 1/4 on the sides to box it in. If it is not stiff enough I can always add more layers top and bottom but I think this will do it, we will see. The blocking is just temporary and will come out.
Posted: Mon Jan 15, 2018 6:22 pm
by Eric1
Fuzz, How do you plan to tab the opposite 1/4" panel?
Posted: Mon Jan 15, 2018 6:34 pm
The side you are looking at is glued on. After it sets and the blocking is removed I can tab the inside. The other side will only be glued on. I will glass the whole outside. Not sure how else to do it.
by Aripeka Angler
I like the shape of the support, it is pretty cool.
Thinking outside the box is awesome!
Posted: Mon Jan 15, 2018 6:38 pm
by Eric1
Fuzz wrote: ↑Mon Jan 15, 2018 6:34 pm
That's what I figured too. Just thought you might have thought of something crazy.
I agree with Richard, it looks great!
Posted: Tue Jan 16, 2018 3:01 am
Eric1 wrote: ↑Mon Jan 15, 2018 6:38 pm
Dang Eric my bent supports aint crazy enough
Thanks for the kind words guys. I really expected commits more like "are you nuts"
No point in keeping rain off your head if it all builds up and pours off on you all at once so I need some way of draining it off the hardtop.
Posted: Tue Jan 16, 2018 5:18 am
by glossieblack
Go Fuzz.
Posted: Tue Jan 16, 2018 1:52 pm
Thanks Glossie, I do appreciate you checking in on me and the words of encouragement. And as you know me and lots of others are addicted to your build
Posted: Tue Jan 16, 2018 5:31 pm
by Browndog
Very Nice! Another case of hold my beer and watch this ingenuity in action. Looks good too.
Posted: Tue Jan 16, 2018 5:55 pm
Thanks Browndog. I am sure enjoying watching your build and waiting to see how it works once it is in the water.
Posted: Tue Jan 16, 2018 7:25 pm
by Aripeka Angler
Fuzz wrote: ↑Tue Jan 16, 2018 3:01 am
If you really want to get slick, drain the roof through the bent support.
Posted: Tue Jan 16, 2018 9:37 pm
Great minds think alike
That is exactly what I have planned.
Posted: Wed Jan 17, 2018 12:27 am
Called Jeff up today to get a few items. Yet again I was amazed by the costumer service
It is a pure pleasure to deal with folks who really want to help any way they can.
Posted: Wed Jan 17, 2018 7:35 am
by Jeff
Fuzz, Thank you for the kind words and of course your business!!! Both of your packages will depart by lunchtime today via USPS!!! You stay warm up there!! Heard about a place in Russia that was down to 60 degrees below zero yesterday!!! They said womens eyebrows were actually freezing in minutes!! Thank you again and great talking with you!!! Jeff
Posted: Wed Jan 17, 2018 8:58 pm
Well I got the drain tubes installed. They turned into a pain in the butt. There was enough spring in them to keep lifting up the hardtop. But with a little persistence they are in.
Not sure why the thumbnails today.
Posted: Wed Jan 17, 2018 9:00 pm
Posted: Wed Jan 17, 2018 9:02 pm
bigger now
Posted: Wed Jan 17, 2018 9:47 pm
by narfi
I kind of like it..... maybe more than stainless tubes....
Posted: Thu Jan 18, 2018 4:53 am
Jeff wrote: ↑Wed Jan 17, 2018 7:35 am
Heard about a place in Russia that was down to 60 degrees below zero yesterday!!! They said womens eyebrows were actually freezing in minutes!! Jeff
When I was in about 8th grade we had a new kid from down south in our class. He had the Fonzi thing going on. At recess he goes into the bathroom to slick it back for the girls before going outside for recess. It was around -40 and he was not out long but it was too long. Few hours later he looked like he had mange
About that same time I saw a girl lick a door knob. Both mistakes that are best not repeated
Posted: Thu Jan 18, 2018 6:14 am
by cape man
28 F in Central Florida...
Posted: Thu Jan 18, 2018 7:57 am
by Eric1
Twelve in Spartanburg S.C. .
Posted: Thu Jan 18, 2018 8:11 am
by Jeff
37 on the Treasure Coast!!
Posted: Thu Jan 18, 2018 10:43 am
by cape man
The Blue Berry field up the road from the house...
Posted: Thu Jan 18, 2018 11:17 am
by Jaysen
Eric1 wrote: ↑Thu Jan 18, 2018 7:57 am
I'm sitting in Greenville right now. Makes me wonder what I've done wrong in my life to deserve the last month
On the plus side, this will make the 100F summers much easier to appreciate.
Posted: Thu Jan 18, 2018 1:33 pm
by Eric1
Jaysen wrote: ↑Thu Jan 18, 2018 11:17 am
100F summer is only fair if we don't freeze in the winter. I filing an official complaint.
Posted: Thu Jan 18, 2018 1:46 pm
cape man wrote: ↑Thu Jan 18, 2018 10:43 am
That is a site I would never have guessed I would see at your place
Posted: Thu Jan 18, 2018 1:50 pm
Eric1 wrote: ↑Thu Jan 18, 2018 1:33 pm
You boys need to spend a "normal" year in Fairbanks. 90f plus in the summer and -60 or less in the winter. now that is a temperature range
It will be a nice balmy 29f here today
Posted: Thu Jan 18, 2018 2:30 pm
by Jeff
Fuzz, again you are warmer than most of the Southeastern States today!!!! Jeff
Posted: Thu Jan 18, 2018 4:58 pm
by Jaysen
I agree it’s not fair. But we WILL appreciate it more this year...
Posted: Sat Jan 20, 2018 9:21 pm
Just about finished with the back supports for the hardtop. The wing looking things are to drain water off of the outside edge because of the roof crown and over to the drain pipes.
I am still trying to figure out what I want to do for the front supports. I will move on to something else and let that perk for a while. Anyone with an idea please chime in.
I think the rear supports are strong enough. I tested them by hanging my 230lbs on the rear edge. Flexed a little but not too much.
Posted: Sat Jan 20, 2018 9:43 pm
by Jaysen
Are you sure you made those? Look a bit fancy for 30x30 workboat finish.
Posted: Sat Jan 20, 2018 11:09 pm
by narfi
Ill say it again. I think I like it better than stainless tubes.
Posted: Sun Jan 21, 2018 1:16 am
narfi wrote: ↑Sat Jan 20, 2018 11:09 pm
Thanks Narfi! I guess this is a case of it being the mother of invention.
Jaysen it is still 30-30 but pictures are all about the angle taken
Posted: Sun Jan 21, 2018 6:53 am
by cape man
Love it David! What if you box in the front supports to match the back down to the dash?
Posted: Sun Jan 21, 2018 7:10 am
by Aripeka Angler
^^^^ What Craig said. Looks good now, it will look great after you build the front posts.
I may actually get a chance to see this rig again this summer. Save some sanding for me.
Posted: Sun Jan 21, 2018 1:21 pm
Thanks Capeman and AA. I am thinking the same way as you guys. I just have to make sure they will not be head knockers when getting on and off the front seat.
As for saving some sanding for you guys why do you think I have a new sander plus an open invitation to come stay with me
Posted: Sun Jan 21, 2018 2:27 pm
by TomW1
Fuzz I think the front boxed beams would also look good.
Posted: Sun Jan 21, 2018 9:13 pm
Thanks Tom.
I think I will make up a set and give it a look. I am not too good at visualizing things and sort of need to build and look.
Posted: Tue Jan 23, 2018 2:11 am
As per the box beam suggestions I got them started today. It is just one layer of 1/4 plywood but it does show the shape I am thinking of.
These are going to be a little smaller than the rear ones so they are not head knockers, I hope
Posted: Tue Jan 23, 2018 7:02 am
by cape man
I like that look. You may need a cross beam but I doubt it. A good ply wood box is going to be strong as hell.
Posted: Tue Jan 23, 2018 7:12 am
by OrangeQuest
Will a mast with a 360 deg light be going on the roof? How about a hand operated spotlight? Chase tube for power can go into the box.
Looks very good.
Posted: Tue Jan 23, 2018 7:36 am
by Jeff
Very well done Fuzz!!! Jeff
Posted: Tue Jan 23, 2018 2:25 pm
Thanks guys. And orangequest thanks for reminding me to put in a chase tube. I would have had a brain freeze, nice thing about posting your work here.
Posted: Tue Jan 23, 2018 8:45 pm
I ordered some supplies last Wednesday or Thursday from Jeff and the team. It was here and ready for pickup Monday
These guys could make a fortune teaching customer service. You just do not see it very often any more and when you do it really stands out
Thank you very much BBC Team.
Posted: Wed Jan 24, 2018 7:22 am
by Jeff
Fuzz, as always, thank you for the kind words and your business!!! Jeff
Posted: Thu Jan 25, 2018 4:56 pm
by glossieblack
Looking forward to seeing those front pillars.
Posted: Thu Jan 25, 2018 5:04 pm
by Eric1
Me Too Fuzz!
Posted: Thu Jan 25, 2018 7:32 pm
by Aripeka Angler
The front beams look great!
See you August 10th.
We will be at Sterling for 8 days, same house as last year.
Posted: Thu Jan 25, 2018 10:14 pm
Glossie and Eric I spent the day glueing up the last of the plywood laminations today. Will put the sides on the pillars tomorrow and post some pictures. Well that is unless I do an Eric and spend the day with my new sander
Posted: Thu Jan 25, 2018 10:17 pm
[quote="Aripeka Angler" post_id=414858 time=1516926742 user_id=8579]
[/quote
Richard you just made my day
Needless to say I will be looking forward to it and have the entire time blocked out for you.
Now if you were able to talk Patti and CapeMan to come with you all I would go outside and dance a jig even at -15
Posted: Fri Jan 26, 2018 6:20 am
by cape man
Be careful what you ask for...just sent you a PM...
Posted: Fri Jan 26, 2018 9:57 pm
cape man wrote: ↑Fri Jan 26, 2018 6:20 am
and one back at you.
Posted: Sat Jan 27, 2018 1:16 am
Had several friends drop by to visit today so I did not get the beams done today. They are glued up but still need trimming and clean up before pictures
Posted: Sat Jan 27, 2018 4:06 am
by fallguy1000
Simply unacceptable. We all want results we can see here. Next time friends come over, pass out the epoxy gloves please!
I have been having a hard time with my build lately. I don't have much room in the shop and I need two new hips; for real.
So, your mockups are kind of nice looking. I like the round sweeps. I can't use them because my boat is all hard lines, but I need to build some type of windscreen/helm enclosure, so I'm interested in your build method, but also interested in doing some carbon. I won't/can't hijack with drawings here, but I will put a sideview on my build page. And watching yours has my brain twirling; especially since Richard wasn't able to get to the cabin drawings yet. And everyone needs to be real nice about it as it is because his 90+ year old father is dying and he had planned to do the drawings while they were enjoying the winter in the islands and sailing, but had to go to England now instead. The trick of my build is I can't build any helm enclosure too permanent. i.e. the back of any enclosure needs to dismount easily..
Anyhow, I will put a view on my page.
Posted: Sat Jan 27, 2018 9:05 am
by cape man
Just booked the flights for a week in the north. God help Alaska with both the Grimes and Watsons there at the same time! Save me some fairing and sanding...
Posted: Sat Jan 27, 2018 2:06 pm
fallguy1000 wrote: ↑Sat Jan 27, 2018 4:06 am
Thanks Fallguy. Never worry about hijacking any of my threads. I do not mind wondering all over the place
My little project is nothing compared to what you have going. I am truly enjoying following along and learning a ton. I keep thinking that boat would be great for doing the great loop in. And after you are done you can relocate by land if you wish. How nice is that
Posted: Sat Jan 27, 2018 2:10 pm
cape man wrote: ↑Sat Jan 27, 2018 9:05 am
I will warn the locals
No sanding for you guys............better to spend time killing fish
If I am not done with the sanding part before you guys get here I will be real disappointed with myself
Posted: Sat Jan 27, 2018 4:39 pm
Posted: Sat Jan 27, 2018 6:07 pm
by cape man
Really like it!
Posted: Sat Jan 27, 2018 6:11 pm
by Jaysen
Fuzz, you willing to consider rounding the lower sections a bit for aesthetics?
Posted: Sat Jan 27, 2018 7:06 pm
by Eric1
That's pretty dang cool!
Posted: Sat Jan 27, 2018 7:53 pm
Jaysen wrote: ↑Sat Jan 27, 2018 6:11 pm
Well I bet I am but first what part are you referring to
Posted: Sat Jan 27, 2018 8:04 pm
by Jaysen
You’ve got nice curves on top of straight lines. A bit of curviness to transition from the slab of the cockpit to the top supports wouldn’t be a bad idea.
Posted: Sat Jan 27, 2018 8:05 pm
by glossieblack
Fuzz, just checking that I've got the layout right. The console with lid is centred mid point between port and stbd, to stbd the side deck carries through to the console, to port the sole runs forward past the console to provide access to the bow anchor locker and the dunny in the front of the console?
She's looking great!
Posted: Sat Jan 27, 2018 10:50 pm
Jaysen wrote: ↑Sat Jan 27, 2018 8:04 pm
I am guessing you are talking about the "wings" coming off the windshield. If that is the case I agree I am not too happy with them myself. I want to do something there but I have to keep enough area to get on and off the seat. I was sort of thinking a straight sweep back but a curved one would look better. I will play with it some and see what I can come up with.
Posted: Sat Jan 27, 2018 10:55 pm
glossieblack wrote: ↑Sat Jan 27, 2018 8:05 pm
Thanks for looking in on me Michael. You have the lay out correct. Most of the time there would be a walk way on both sides but I thought I would only need it on one side and that gives me some dry storage room in SWMBO's dunny.
Posted: Sat Jan 27, 2018 11:16 pm
by Jaysen
Fuzz, front and rear. Think more of adding a line then reducing the size. Just enough to ease the transition from “box” to “swept support”. Look at the line the blue extension it’s makes in the first pic. That kind of line.
Posted: Mon Jan 29, 2018 9:02 pm
Jaysen I see what you are talking about and looked it over. It would have been nicer from the start but I am not sure I want to go that way at this point. Installing windshields on a curve might be interesting also.
Had a boat builders tragedy today, my SOB tool died
The good news is I have been wanting to try one of the newer models and this gave me the excuse
Posted: Mon Jan 29, 2018 9:50 pm
by fallguy1000
I like it; I don’t quite understand the plywood at the bottom; it seems like it could follow the sweep with a radius to the bottom. However, I am not there to understand it all. Other than that question; they look very neat and when you go driving by, it’ll add a lot to the look of the boat.
Posted: Mon Jan 29, 2018 10:11 pm
by Jaysen
The windscreen could be flat. Just be set it flat between the “low” points of the arch. Then use glass and fairing to make it pretty. I’m assuming you’ll have a gutter at the bottom of windscreen and a diversion lip at the top. That will keep pooling under control.
Posted: Mon Jan 29, 2018 10:32 pm
by OrangeQuest
Fuzz wrote: ↑Mon Jan 29, 2018 9:02 pm
One of the guys posted how he heated up Plexiglas and used his center console as the form. Could use the same method to do a curved windshield. But could be a "hold my beer" moment too!
Posted: Mon Jan 29, 2018 10:38 pm
by Jaysen
I’ll hold the beer but you won’t get it back with any remaining contents.
Posted: Tue Jan 30, 2018 12:52 am
Well CRAP
Now you guys have got me thinking
I would need to make the centre support curved like the outside supports but that is not that big of a deal I guess. A fishing buddy stopped by today and told me he thinks he has some 1/4 inch lexan that is big enough for my needs so if it turns out that way I might give it a try.
Posted: Tue Jan 30, 2018 2:48 am
by glossieblack
Go Fuzz! It seems like you're enjoying yourself improvising a nice look.
Posted: Tue Jan 30, 2018 7:16 am
by OrangeQuest
May want to see how to "mold" a curve verses just bending!! If the size of the sheets can fit in a standard oven then it would be easy enough to bring the heat of the Lexan up enough to then place it in your mold. From videos it looks like baking pizza.
Posted: Tue Jan 30, 2018 7:55 am
by Jaysen
I dont' think you need to curve the windscreen. I'd do it in 2 or three flat sections.
But then it's not my boat. If you curve it, please take photos.
Posted: Tue Jan 30, 2018 1:36 pm
by TomW1
Fuzz I wouldn't curve them either. Difficult to get a proper compound curve and you would not be able to use wipers on it. I am assuming you are going to want wind shield wipers with your wet weather up there.
Posted: Tue Jan 30, 2018 6:05 pm
by glossieblack
Build on Fuzz!
Posted: Tue Jan 30, 2018 11:58 pm
Thanks Glossie, it is always nice to hear from you. I sure enjoy seeing your build.
Tom, Orangequest, and Jaysen you guys have me mulling things over but not sure what I will do yet.
So while I am thinking over my windshield delemia I moved on to something else.
I had this wasted pace on both sides so I am filling them with foam. When done I will have 12 gallons of foam in this thing. Should be enough to keep it floating if swamped. I am hoping the foam in the sides would keep it from turning turtle.
Re: Sintes 21 Rebuild
Posted: Wed Jan 31, 2018 12:36 am
by fallguy1000
I have lots of watertight compartments on mine.
Is the foam better than an air chamber?
Posted: Wed Jan 31, 2018 1:24 am
fallguy1000 wrote: ↑Wed Jan 31, 2018 12:36 am
To me if you do not need the added stiffness the foam gives it is a wash. If you punch a hole in something the foam keeps it from filling with water but you have the cost of foam and will if it trap water to think about. In this case the foam will stiffen the cover boards.
On bigger boats I am a big fan of water tight bulkheads and sealed chambers if you have any.
Posted: Wed Jan 31, 2018 6:15 am
by cape man
Wipers work on curved windshields. All my vehicles have curved windshields.
Posted: Wed Jan 31, 2018 7:05 am
by glossieblack
cape man wrote: ↑Wed Jan 31, 2018 6:15 am
Jeez cape man, you must have some of those fancy new fangled models.
Posted: Wed Jan 31, 2018 12:59 pm
by cape man
And they all have those new-fangled wiper blades that automatically bend to match the curve!
Posted: Wed Jan 31, 2018 1:03 pm
by narfi
cape man wrote: ↑Wed Jan 31, 2018 12:59 pm
Which means those 'new-fangled' blades are easily available..... right?
Posted: Wed Jan 31, 2018 1:10 pm
by Jaysen
narfi wrote: ↑Wed Jan 31, 2018 1:03 pm
For those that live in inhabitable parts of the world ... yes. For you ... probably not.
Posted: Wed Jan 31, 2018 1:16 pm
by narfi
Jaysen wrote: ↑Wed Jan 31, 2018 1:10 pm
Hehe.... NAPA (inside joke: National Air Parts Association) is just a phone call away, and they deliver to the airport. If in stock I should see anything within a few days of ordering.
Posted: Wed Jan 31, 2018 1:18 pm
by cape man
It was tongue in cheek...all modern wipers are made so they attach in the middle and are spring loaded in a frame to allow them to take the shape of the windshield as they move. If you can buy wiper blades... I saw the picture of your flight home. Didn't see the auto supply store or Walmart
Posted: Tue Feb 06, 2018 1:39 am
So while I am still mulling over the windshield deal I worked on the gunwales some. The sides were closed up and foam added. The hope is if swamped this will keep the boat upright. I am also adding some half round to act as drip rails.
The drip rails will get taken all the way to the stern.
Posted: Tue Feb 06, 2018 6:20 am
by cape man
Good call on the half round. Man does your shop look like Glossie Blacks or what!
Posted: Tue Feb 06, 2018 7:51 am
by Jeff
Fuzz, I like the drip rails!!
Posted: Tue Feb 06, 2018 2:34 pm
Jeff wrote: ↑Tue Feb 06, 2018 7:51 am
Thanks Jeff.
Posted: Tue Feb 06, 2018 2:38 pm
cape man wrote: ↑Tue Feb 06, 2018 6:20 am
Yeh, yeh ,yeh. I could have made it look like an operating room like some folks do but I did not want to spend the week it would take before taking pictures. It just amazes me how some of you guys can have a picture perfect looking shop and still get anything done. Or maybe I am just a slob
Posted: Tue Feb 06, 2018 4:48 pm
by fallguy1000
My Lund has those drip rails on both sides so there is plenty of stuff left on them-clippers and pliers usually, so far no cell phones or glasses.
Posted: Tue Feb 06, 2018 5:53 pm
by OrangeQuest
I really like the drip rails. May put some on my if it's not to heavy at that point.
My work isn't the cleanest but my work assistant comes in a few time a month and sweeps work benches off and the floor, even empties the trash cans. Makes me feel bad so I clean up my messes and put all the tools back up. But then I start into a project and the dust starts flying.
Posted: Tue Feb 06, 2018 6:00 pm
fallguy1000 wrote: ↑Tue Feb 06, 2018 4:48 pm
I have thought of putting them on both sides for just that reason. Seems like you are always putting something on the rail. If I do it I will need to make sure I am not making a water trap.
Those Lunds are the jeep of the north. The further you get out in the bush the higher percentage they are.
Posted: Tue Feb 06, 2018 6:03 pm
by Aripeka Angler
Looking good, I like the moulding!
Posted: Tue Feb 06, 2018 6:04 pm
OrangeQuest wrote: ↑Tue Feb 06, 2018 5:53 pm
The rails weigh next to nothing. I did not glass over the ones on my dory and they are splitting some. I will put a light layer of glass over these.
As for the cleaning I have been waiting for the clean fairy to show up but I am starting to lose hope
Posted: Tue Feb 06, 2018 6:08 pm
Aripeka Angler wrote: ↑Tue Feb 06, 2018 6:03 pm
Fair warning.
I am getting close to the point of adding or not some bull works around the stern. I know CapeMan hates the idea as it will detract from the looks. Think about things in the context of me having your and his butt 30 or so miles out of Seward
Posted: Tue Feb 06, 2018 7:42 pm
by Aripeka Angler
If bulwarks are done right, in my humble opinion, they look great. I know and understand the need and function of them up there.
I would put them on the inside of the gunwales starting about where the console is and terminating at the transom.
They need to follow the lines of the boat relative to curve of the gunwale. A nice 4" radius on the leading and trailing edges is a must.
What are you thinking, 6" above the gunwales? About 3/4" thick?
If the bulwarks are installed like a trim on the inside of the gunwale, they will look awesome...
Posted: Tue Feb 06, 2018 8:09 pm
by cape man
Looks Shmooks. Build on my man! I gave up a long time ago on how beautiful that hull would be down here with an open deck and modest center console. Make it a Kasilov killing machine!
Posted: Tue Feb 06, 2018 8:18 pm
by cape man
And make it safe! I think I'll die if my foot hits that water!
Posted: Tue Feb 06, 2018 9:26 pm
cape man wrote: ↑Tue Feb 06, 2018 8:09 pm
You were probably thinking this would have looked nice?
http://laytonscustomboatworks.com/index ... &Itemid=70
This is the same design by Dave Sintes. I can not see if there is any difference but it does not look like it.
I agree it looks great for your part of the world. I just do not think I would be able to use it more than one or two days out of the year here.
Posted: Tue Feb 06, 2018 9:29 pm
Good timing AA
I would have carried the drip rail all the way back today if I had not spent the day plowing snow.
PM sent to you.
Posted: Sat Feb 10, 2018 4:58 am
by glossieblack
Aripeka Angler wrote: ↑Tue Feb 06, 2018 7:42 pm
X 2
Posted: Sat Feb 10, 2018 5:32 am
Just got a good start on the bullworks when I had to take time to plow and blow some snow.
That is when my world went tits up. First the winch on the snow plow quits so I think no biggie I will use the new snow blower. Second time starting it the electric starter quits so I use the recoil starter. Take a brake and go back out to hit it some more and the spring on the recoil starter breaks. Some days it don't pay to get out of bed
Hope to make some progress in the morning.
Posted: Sat Feb 10, 2018 5:56 am
by cape man
What's a snow plow?
Posted: Sat Feb 10, 2018 8:33 am
by pee wee
cape man wrote: ↑Sat Feb 10, 2018 5:56 am
What's a snow plow?
I'm not sure, I guess it stays so cold up there that they have to plant in the snow. Not sure what crops would grow in those conditions, though- maybe iceberg lettuce?
Posted: Sat Feb 10, 2018 8:35 am
by topwater
Don't even ask what a snow blower is
Posted: Sat Feb 10, 2018 9:36 am
by Jaysen
topwater wrote: ↑Sat Feb 10, 2018 8:35 am
Dirty snow suddenly means something completely different to me.
Posted: Sun Feb 11, 2018 1:16 am
You guys need to come get you some snow blowing. It is much more fun than you might think it is
Got a little time for boat work. This is the bull works. I think they will be ok.
My neighbour and old fishing buddy dropped off a scrape piece of lexan he had from replacing his front windows a couple of years ago. He promised I would not punch them out. It is 3/8 thick lexan
Posted: Sun Feb 11, 2018 2:40 am
by TomW1
Dang Fuzz she is looking good. This is why I moved away from the Great Lakes
https://www.msn.com/en-us/weather/topst ... spartanntp
Posted: Sun Feb 11, 2018 5:49 am
by glossieblack
She's emerging as a seriously interesting looking boat.
The sort you loiter around, awaiting the chance to talk to her skipper.
Posted: Sun Feb 11, 2018 6:35 am
by cape man
Perfectly stated.
Posted: Sun Feb 11, 2018 8:53 am
by Jeff
Yes, looking forward to see Fuzz’s creation once complete!! Jeff
Posted: Sun Feb 11, 2018 9:55 am
by Eric1
I like the looks of her. No thanks to snow blowing.
Posted: Sun Feb 11, 2018 12:10 pm
Eric1 wrote: ↑Sun Feb 11, 2018 9:55 am
I guess there is not much chance of "Tom Sawyering" this group
Hope things are going well for you and we see an update soon
Posted: Sun Feb 11, 2018 12:13 pm
glossieblack wrote: ↑Sun Feb 11, 2018 5:49 am
Thanks.....................I think
I am not going to ask if this is good or if you just hang around to see what kind of bubba came up with this abortion. Nope some things are better left unasked
Posted: Sun Feb 11, 2018 12:38 pm
by cape man
I like bubbas...
Posted: Sun Feb 11, 2018 6:19 pm
cape man wrote: ↑Sun Feb 11, 2018 12:38 pm
I like bubbas...
Posted: Sun Feb 11, 2018 7:52 pm
by Jaysen
Fuzz wrote: ↑Sun Feb 11, 2018 12:13 pm
I’m not loitering in a place where the precipitation is solid!
But I’d definitely try to find time to hear about that boat.
Posted: Sun Feb 11, 2018 7:59 pm
by Aripeka Angler
I like the bulwark planks as well as your console and tee top
I would put a quart paint can sized radius on the forward side of the bulwark. Leave the angle, just soften it with radius on sharp point.
On the rear edge, I'm going to have to wait to see how it ties into the transom to give you an opinion.
Looking great, can't wait to see your progress in a few months...
Posted: Sun Feb 11, 2018 9:35 pm
Jaysen wrote: ↑Sun Feb 11, 2018 7:52 pm
I am starting to believe you are allergic to cool weather.
Posted: Sun Feb 11, 2018 9:45 pm
Aripeka Angler wrote: ↑Sun Feb 11, 2018 7:59 pm
Thanks Richard. Quart size radius it will be.
I told Liudmila about you guys coming up this summer and she is all excited, me too
Posted: Sun Feb 11, 2018 10:26 pm
by Jaysen
Fuzz wrote: ↑Sun Feb 11, 2018 9:35 pm
You underestimate my disaffection for temperatures requiring pants.
Posted: Sun Feb 11, 2018 11:27 pm
by narfi
Jaysen wrote: ↑Sun Feb 11, 2018 10:26 pm
According to Landon that is somewhere below 0f.........
Posted: Mon Feb 12, 2018 12:57 am
Yah, what Landon says
Posted: Mon Feb 12, 2018 6:14 am
by Jaysen
Let’s use cape man’s definition.
Posted: Mon Feb 12, 2018 2:49 pm
by TomW1
Fuzz she is looking good, can't wait till you finish her and she has a coat of paint for her entrance to the fisherman's ball.
Posted: Sat Feb 17, 2018 11:46 pm
TomW1 wrote: ↑Mon Feb 12, 2018 2:49 pm
Thanks Tom.
As for how it looks...............as my wife would say "we will see"
Posted: Sat Feb 17, 2018 11:48 pm
Got a little time to work on the stern bullworks. still needs a trim and some love from the sander.
Posted: Sun Feb 18, 2018 12:20 am
by cape man
Looking good David. Hurry up! You have 5 months.
Posted: Sun Feb 18, 2018 4:36 am
by glossieblack
Fuzz, Stay your course. Beware of warlords, thieves and urgers!
Posted: Sun Feb 18, 2018 12:19 pm
glossieblack wrote: ↑Sun Feb 18, 2018 4:36 am
Thanks Glossie. I am pretty sure there is some pirate dna in the poster right before you
Posted: Sun Feb 18, 2018 12:24 pm
by cape man
Moi?
Posted: Sun Feb 18, 2018 9:39 pm
by fallguy1000
Gotta meet that Alaska launch window!
Posted: Sun Feb 18, 2018 10:12 pm
by Jaysen
fallguy1000 wrote: ↑Sun Feb 18, 2018 9:39 pm
It only 3 days total...
Posted: Mon Feb 19, 2018 12:18 am
Dang guys, you putting on the pressure. Not gonna work, I still have the SeaSport for backup
But I do need to spend a little more time each day on it.
Posted: Mon Feb 19, 2018 6:52 am
by OrangeQuest
Fuzz wrote: ↑Mon Feb 19, 2018 12:18 am
That's the spirit!!
Posted: Mon Feb 19, 2018 8:26 am
by topwater
Fuzz stop blowing snow and get back to work
Posted: Mon Feb 19, 2018 7:20 pm
by Aripeka Angler
Fuzz wrote: ↑Sat Feb 17, 2018 11:48 pm
Looking nice.
The hard top top supports kind of remind me of the t-top supports on my Pursuit. Swept back and racy looking.
Posted: Wed Feb 21, 2018 1:57 am
by glossieblack
Nice workbench you've added to her transom.
Posted: Wed Feb 21, 2018 3:01 am
glossieblack wrote: ↑Wed Feb 21, 2018 1:57 am
I keep hoping that at some point it will have other uses but I have my doubts at times. The part of building where you see no major changes at the end of the day is tough. But I try to remember what the Cracker said about one bite at a time.
Posted: Wed Feb 21, 2018 11:21 am
by Eric1
Fuzz wrote: ↑Wed Feb 21, 2018 3:01 am
Hang in there Fuzz and keep on building!
Posted: Wed Feb 21, 2018 4:59 pm
by OrangeQuest
Just think, first time you put it in the water and gun it that work bench becomes self cleaning!
Posted: Thu Feb 22, 2018 3:31 am
I have to say having a work bench/storage area is a huge help. If I had a little more room I would build a rolling bench to keep along the side.
Got tired of looking at the same thing every day so I laid a little primer on part of the cabin and bow today. I am sure it will show me places that need more love but at least now I will be able to see them.
Stayed out in the shop late this evening and watched the USA women hockey game. Pure joy for them and heart breaking for the Canadian team. Could not hope for a better or more completive game. Too bad some one had to lose as both teams are gold metal teams.
Posted: Thu Feb 22, 2018 12:31 pm
by TomW1
Fuzz could not agree more with you on the hockey game. I love good hockey and that was it.
Posted: Sat Feb 24, 2018 12:50 am
Got a look at things after some primer. Not there yet but it is coming along.
Posted: Sat Feb 24, 2018 6:54 am
by Jaysen
Are you sure that’s your boat? Looks mighty good for us “30x30” types...
Since you’ve likely not had enough coffee yet, looks good! Must be the new sander.
Posted: Sun Mar 04, 2018 7:41 pm
by TomW1
Hey Fuzz did Alaska weather catch up with you. It's been more than a week since you posted any progress on it.
Tom.
Posted: Sun Mar 04, 2018 8:54 pm
Hey Tom thanks for checking in on me
SWMBO came home from Russia. Needless to say I now have a ton of honey does
After laying some primer on things I saw way too many things that needed more finish work so I have been trying to wear out my new sanders. Not much to show just the old wax on wax off deal
Posted: Thu Mar 08, 2018 1:59 am
Ok I hope to be doing a little painting in the near future. If using Easy Poxy what grit do it need to take the primer to? Lets be clear here I am not looking for the primer to have a reflection like somebodies does
Posted: Thu Mar 08, 2018 6:38 am
by Jaysen
Seat if my pants for our level of quality... 40.
Realistically though 120 should be about right. You want a decent scuff to give the topcoat something to hang on to.
Posted: Thu Mar 08, 2018 11:55 am
by cape man
Posted: Thu Mar 08, 2018 1:15 pm
by TomW1
No less than 180 Fuzz or the sanding marks will show through. I'd even go 220. When I do fine finish work I will even go to 330. It may also state on the label what you need. Paint on my friend paint on.
Posted: Thu Mar 08, 2018 8:15 pm
by Jaysen
TomW1, remember that Fuzz’s goal is 30@30. Those of us in that club could use gravel and still be happy with the finish.
Posted: Thu Mar 08, 2018 11:02 pm
Between Festool and Eric I may have succumbed to a bad influence
But at this point in my life it is too late for a total reform
Posted: Fri Mar 09, 2018 5:52 am
by Jaysen
Great. Next you’ll be posting pictures of shiny primer.
Dang you Festool!
Posted: Fri Mar 09, 2018 2:54 pm
Jaysen wrote: ↑Fri Mar 09, 2018 5:52 am
Dang you Festool!
Not to worry buddy. The smoother I get this hull the less happy I am. Sort of like a super model with acne. Great bones but do not look too closely. Has anyone ever Kiwi Gripped the hull
Posted: Fri Mar 09, 2018 8:04 pm
by Jaysen
So here my current horror story...
There’s a nice 15’ day sailor a guy is unloading around the corner. The motor and trailer are worth more than the asking price. But I want the boat for day trips with the boss lady. It all check out solid EXCEPT the monster liner below the water line. I do t even know if o could get it all off or if I would just glass over it.
Either way it makes me cry every time I walk by it.
Posted: Sat Mar 10, 2018 7:28 am
by topwater
You should be able to sand the Monstaliner off .
Posted: Sat Mar 10, 2018 8:15 am
by Jaysen
Yeah. That was my thought. 40-80-fair-120-s3 high build-aluminum oxide-EMC fighting lady yellow and oyster white.
Need to do topside as well. All match the livery of LilBit if I do it. Just not sure I want the project right now.
Back to Fuzz’s boat... MORE PICTURES!!!
Posted: Sat Mar 10, 2018 12:44 pm
Dude you need something to keep those idle hands busy. You know what is said about them.
As for my boat...............nothing to show a picture of, just been sanding and trying to fix flaws
Posted: Sat Mar 10, 2018 7:58 pm
Mother nature does not want me to work on the boat. It is March so we are getting our winters snowfall. It has been snowing for the past three days. I go out and get things cleaned up and then the wind blows and fills it back in
I guess we have had such an easy winter we are due, maybe over due
Posted: Sat Mar 10, 2018 9:18 pm
by Jaysen
Wait. Don’t you build indoors? Hmmm.
Posted: Sat Mar 10, 2018 10:56 pm
Jaysen wrote: ↑Sat Mar 10, 2018 9:18 pm
Yes but if SWMBO can not get her car out of the driveway you got problems
Posted: Sun Mar 11, 2018 12:45 am
by TomW1
Fuzz for some reason March always wants to kick up and show her anger. I hadn't been down here in NC 2 years when we had a major storm that dumped 3 plus feet of snow on us. I had just put up a brand new 48 x 28 greenhouse. and had gotten heat to it thank goodness. My over wintering sheds were a different story as we had to go out and knock the snow off them every hour.
I don't know why March is such a bear but it seems to happen a lot of years. Our temps are in the low ends right now and we have had snow flurries the last few days.
Posted: Sun Mar 11, 2018 3:57 am
Yep, winter has been a long haul and cabin fever sets in. There starts to be some heat in the sun and you begin to think spring is just around the corner. About that time mother nature reminds you what month it is by dumping all over your hopes.
Posted: Fri Mar 16, 2018 12:35 am
Yesterday was warm and sunny so SWMBO wanted to take a drive to Homer. Worked for me as I needed some paint. While there the boss picked out the hull colour so I guess that is a good thing. As you can see spring might still be a few days off.
So today mother nature just had to show winter is still not over
Posted: Fri Mar 16, 2018 4:12 am
by Aripeka Angler
I saw on my weather app that y'all were getting snow.
Hopefully you will get a break soon.
The photo you took at Homer is cool.
Posted: Fri Mar 16, 2018 6:13 am
by cape man
34 F this morning here!
Posted: Fri Mar 16, 2018 6:32 am
by OrangeQuest
Nice picture of Homer.
It is 70 degrees here in Houston and the humidity 88% with what they are calling a slight drizzly. Forecast is it will be like this all weekend.
Only have enough room to work on one side of the boat in doors-sucks!
Posted: Fri Mar 16, 2018 7:15 am
by Jeff
Nice photos Fuzz!! you guys stay warm up there, Spring is almost here!! Jeff
Posted: Fri Mar 16, 2018 8:03 am
by Eric1
We have a 50 degree morning in Spartanburg. I'm so ready for spring!!!
Posted: Fri Mar 16, 2018 3:44 pm
by TomW1
Eric I had snow and temps in the high 30's on Wednesday. I agree with you I am so ready for spring especially with the flowers blooming and trees in full bloom.
Posted: Fri Mar 16, 2018 6:18 pm
You guys spring is our midsummer. I do not need any of your summer
Been building a kicker bracket on my "work bench" Been plugging along on the boat but not much picture worthy. Like Brown Dog said it is amazing how much time you spend doing the little stuff that does not really show up.
Posted: Tue Mar 20, 2018 2:14 am
So I got my kicker bracket built just need to fair it out some.
So I have a question for you paint pro's. I am using Pettit Easy Poxy to paint my hull sides. Do I need to sand between coats and if so what is recommended?
Posted: Tue Mar 20, 2018 7:13 am
by seaslug
Hey David, I've painted a 68 foot wood Trumpy motor yacht with Easy Poxy 3 times. This was a huge hull, with a big flared bow that while standing on the dock actually flared out over your head. You do need to lightly sand between coats, and we rolled and tipped the same as Awlgrip. Working in a 3 person team, with 1 rolling, 1 tipping, and 1 moving supplies along as we went down the hull, and doing the mixing. It's a 1 part paint, but I would never use this paint without adding Penetrol to get it to flow out better, and in hot weather you especially need it for good flow, and to maintain a wet edge. You won't get the mirror finish of Awlgrip, but it was good enough for a very expensive yacht. The Penetrol is the key though. You can add in as much as you want to get the paint to flow well, it will not change the color, or have any negative effect on the paint. We had to work so fast on days with temps in the 80's or 90's, that the mixer would just keep pouring the Penetrol into the paint tray as we moved along the hull, as the roller and tipper would yell commands, more Penetrol, more Penetrol!!! We were a good team, and had a lot of fun working on the boat each year. The paint sprays really well, and you can also add Penetrol for good flow and shine, and thin with mineral spirits, and I always add a few drops of Smoothie, which is pure liquid Silicone and prevents fish eye. Your boat is coming along nicely, build on. Mike
Posted: Tue Mar 20, 2018 3:02 pm
Thanks Mike
I bookmarked Colemanfire's thread where you and Richard were talking about painting so I knew to get some penatrol. Now I am wondering about the sanding part. 220 wet or something like 320 dry? I might start a new thread in the paint section so the advise can help others.
Posted: Wed Mar 21, 2018 1:29 am
So I followed Mike's and Richard's advise with the paint. Even though I do not have their skill I think this is going to be decent work boat finish. Still need to lay one or two more coats on it. The dark spot near the stern is a shadow.
Posted: Wed Mar 21, 2018 1:52 am
by glossieblack
Looking better than workboat finish Fuzz. You'll have to endure Jaysen's scorn.
Posted: Wed Mar 21, 2018 5:12 am
by Aripeka Angler
Your paint looks great!
Posted: Wed Mar 21, 2018 5:24 am
by OrangeQuest
Does look great!
Posted: Wed Mar 21, 2018 6:22 am
by Jaysen
Apparently he’s a closet Eric.
Posted: Wed Mar 21, 2018 7:00 am
by cape man
Dang David! Gorgeous!
Posted: Wed Mar 21, 2018 7:26 am
by Jeff
David, that is NOT a work boat finish, really well done on the painting!!!! Jeff
Posted: Wed Mar 21, 2018 11:17 am
by narfi
Looking good!
Posted: Wed Mar 21, 2018 1:01 pm
glossieblack wrote: ↑Wed Mar 21, 2018 1:52 am
Not my fault. Festool is to blame. While sanding is still not fun the new sander has changed it into something that is no longer misery.
Thanks for the complements guys. It is nice to read them. But as we all know pictures can hide a lot of sins. This is no where near the quality of work I saw at the last two builders meets but at least I will not be ashamed to let folks look at it
Posted: Wed Mar 21, 2018 1:16 pm
by Jaysen
do not mistake my lack of direct insult as a compliment!
That said, I think you may get a few fish looking at themselves in that glossy reflection.
Posted: Wed Mar 21, 2018 1:25 pm
Jaysen wrote: ↑Wed Mar 21, 2018 1:16 pm
I some how knew this was coming from you
Like I said it is all about the angle when taking pictures. But if I had known it was going to be as good as it is I would have sprung for the good paint. Need to get it outside in the sun before I really know what I have.
Posted: Wed Mar 21, 2018 1:31 pm
by Jaysen
Fuzz wrote: ↑Wed Mar 21, 2018 1:25 pm
I'm calling for a review board. We may have to dis-enroll you from the 30@30 club. That you you need to show some print through or other "not on Eric's boat!" type conditions.
It's probably best that we didn't get into the same room at the builders meet. I have a feeling we'd be more trouble than BBC is willing to accept.
Posted: Thu Mar 22, 2018 9:01 am
by Eric1
Yes Sir, That looks nice!
Posted: Fri Mar 23, 2018 1:56 am
Jaysen wrote: ↑Wed Mar 21, 2018 1:31 pm
I will have to improve on a bunch of stuff before there is any danger of being booted from the club.
As for us getting into trouble I am thinking those days are mostly behind me...........but every once in a while
Posted: Fri Mar 23, 2018 1:57 am
Eric1 wrote: ↑Thu Mar 22, 2018 9:01 am
Thanks for checking in on me Eric. I hope your world is improving so you have some time to get back to that beauty of yours.
Posted: Fri Mar 23, 2018 2:07 am
Spent most of the day doing Honey-do's but did get a chance to run a sander for a hour or so.
If any of you guys have not used a sander with a good vac set up you need to try it. It sure is nice not eating dust
Want to or not I have to run the sander a lot or Craig and Richard will tell me about it this summer
No hiding my sins when they are here in person
Posted: Fri Mar 23, 2018 6:16 am
by cape man
Great to hear we aren't hiding our sins...
Can't wait to see her. And you and Mila.
i have spent way too much time looking at satelite images of the Kenai peninsula.
Posted: Fri Mar 23, 2018 1:25 pm
Mila and I are both ready to see our Florida friends
She is making me nuts already with the we got to do's before they get here.
But it is always nice to be able to show guests this part of the world.
Posted: Fri Mar 23, 2018 1:45 pm
by Jaysen
Only one thing you need to do... FIND THE FISH!
Wait... I'm not going... I still think that's the big one.
Posted: Fri Mar 23, 2018 3:34 pm
the way it works around here is SWMBO catches the fish. I am "allowed" to ferry her to the chosen location
Posted: Fri Mar 23, 2018 4:48 pm
by Jaysen
And you've never GPS'd one of her spots? Get with it man!
Posted: Fri Mar 23, 2018 5:51 pm
by Aripeka Angler
Fuzz wrote: ↑Fri Mar 23, 2018 2:07 am
Told you that you would fall in love with a good vac system.
You know you got it bad when you are excited to fire up a sander.
No worries on the finish, it looks superb in the photos.
Posted: Fri Mar 23, 2018 8:35 pm
Well I pulled the boat outside in the sun for a while today. I am not as pleased with it as I thought but at this point it is what it is.
So on my dory I have a problem with the Kiwi Grip pealing up in spots. I am not sure if I will try it again or go with paint with sand in it. If I go with the Kiwi Grip what prep is needed to give it a better chance to stick?
And after talking with Richard and seeing his set up I will say he is one of the main reasons I got a sander with a vac system. Had a buddy stop by yesterday and the first thing he said was where is all the dust.
Posted: Sat Mar 24, 2018 7:17 am
by glossieblack
Fuzz wrote: ↑Fri Mar 23, 2018 8:35 pm
And you used to take the piss out of me for having a Festool.
Posted: Sat Mar 24, 2018 4:56 pm
by Aripeka Angler
glossieblack wrote: ↑Sat Mar 24, 2018 7:17 am
Fuzz has came over to the dark side with the rest of us sanding junkies.
Posted: Sat Mar 24, 2018 5:08 pm
by Jeff
Good for you Fuzz!!!! Jeff
Posted: Sun Mar 25, 2018 12:19 am
Aripeka Angler wrote: ↑Sat Mar 24, 2018 4:56 pm
Glossie I guess I was making fun of things I did not understand. That is the best excuse
I can come up with on short notice
Richard it is even worse that that. Today I spent the day with my old buddy and his new to him blow boat
Surprisingly 36f and 15 knots is not as enjoyable as it used to be.
But at least I got warmed up packing stuff up and down the ramp at low tide
Posted: Sun Mar 25, 2018 7:41 am
by Jaysen
The equator just seems smarter and smarter to me the more you post pictures. Sure it’s beautiful but ... so hostile.
Posted: Sun Mar 25, 2018 10:04 am
by Bogieman
This is a neat thread. Your rebuild is looking great!
Bogie
Posted: Sun Mar 25, 2018 5:39 pm
Jaysen wrote: ↑Sun Mar 25, 2018 7:41 am
Wait are you talking about the landscape or SWMBO
Posted: Sun Mar 25, 2018 7:00 pm
by Jaysen
Fuzz wrote: ↑Sun Mar 25, 2018 5:39 pm
Certainly not your SWMBO. I’m afraid of her.
I was talking more of “b!tch nature”. Mother is too nice of a word for her attitude up your way.
Posted: Mon Mar 26, 2018 4:54 pm
Bogieman wrote: ↑Sun Mar 25, 2018 10:04 am
Bogie
Thanks Bogie.
I started this little project to keep myself busy during the winter. It has done that and more.
The best part of the whole deal is this forum and the friends I have made from it. I even enjoy
the give and take razzing
Jaysen and I always seem to have something going and it gives me
something to laugh about with my morning coffee.
The forum has allowed me to chat with folks from all over the world and I have enjoyed it immensely.
Posted: Thu Mar 29, 2018 10:34 pm
Yesterday I took a road trip to Seward with another buddy to check out a boat with him. I guess now that I am retired I have become the designated boat inspector for all my friends
Today I repositioned the boat to be able to see and work on the other side. Got some better lighting set up and I see I will be spending some quality time with my buddy Festool. Probably will not be much to show just a bunch of fill and sanding, fill and sand, fill and sand
Posted: Thu Mar 29, 2018 10:50 pm
by Jaysen
Fuzz, I may have an alternate solution for you.
Go to the store and look for something 80proof or more (120 seems right but you might be a light weight). Take the acquisition and sit a chair, bucket of ice and a high ball glass where you have a good, well lit view. Place bottle in ice and go make a sandwich. Once that’s some go sit in the chair. Now here’s the easy part... pour and consume until the hull looks perfect. Have someone more soberish (Siberian is how the phone kept auto correcting that so... you should be set) mark the bottle. This tells you exactly how much you need to drink before getting near the boat going forward.
Seems like a win win solution to me.
What do you say?
Posted: Fri Mar 30, 2018 12:34 am
This very well could be the best idea you have ever had
I just am wondering how well it will work when Capeman and AA see my mess
It might, I say might, fly by Capeman but I am pretty sure Richard would not be impressed
Well crap it just dawned on me it might not be good even if I do spend time with Festool. My finish work is truly not up to some folks standard. No matter what the lying pictures show I am still the charter member of the 30-30 club
Posted: Fri Mar 30, 2018 12:49 am
by glossieblack
I note Jaysen has yet to refute on my build thread that he's en route to becoming an Alaskan.
So it may be on.
The best plan is to await his arrival, you have a drink or two, and he does the fairing and painting in the Sintes.
Posted: Fri Mar 30, 2018 2:11 am
Glossie I believe you to be totally correct
I think he really likes cool weather and would be able to do some of his best work with a multi-tool
Plus a win-win for me if he is not working hard enough to keep warm I will just turn the heat down some
Glad to see you are still making progress on Skinny Dip. I think both of us are at the part that takes lots of time with very little to show for it. I keep telling myself it is the little things that make the difference.
Posted: Fri Mar 30, 2018 2:19 am
by glossieblack
Fuzz wrote: ↑Fri Mar 30, 2018 2:11 am
Yep. I've put in a pretty full day today, doing lots of small jobs, but not much to show for it!
Posted: Fri Mar 30, 2018 2:35 am
If I had been a carpenter I would have been a framer and not a finish carpenter. Boat building is sort of like that for me. But I sure do admire a boat with all the little stuff done right.
Posted: Fri Mar 30, 2018 6:04 am
by Jaysen
Given the current spiral my life seems to be taking and the historical trend that suggest that the universe may in fact have an honest to goodness hatred of me, I choose not to tempt fate by declaring glossieblack’s suggestion utter bull feces.
Of course you’ve just tricked me into doing that. Not sure you have my best interests in mind.
Posted: Fri Mar 30, 2018 6:11 am
by glossieblack
Jaysen, rejoice that Alaska is your missionary calling!
Posted: Fri Mar 30, 2018 6:43 am
by Jaysen
glossieblack wrote: ↑Fri Mar 30, 2018 6:11 am
Why can’t it be more like “go and reform Peter C”? That’s one I can get behind...
Posted: Tue Apr 03, 2018 11:03 pm
Got around to punching holes in the sides for my scuppers today. I am a little worried the hull could be too thin at that spot. It is only 5/8 of solid glass
I did not clean them up for pictures and I cut from both sides so they look a little ragged. The lip is where the glass curves down onto the decks.
Posted: Wed Apr 04, 2018 7:41 am
by glossieblack
Suggest you go to the mirror and cuss out the silly bastard that overbuilt to 5/8" solid glass.
Posted: Wed Apr 04, 2018 8:06 am
by topwater
Looks like you have an ice rated hull
Posted: Wed Apr 04, 2018 2:50 pm
glossieblack wrote: ↑Wed Apr 04, 2018 7:41 am
The sad part is I know the bottom is a bunch thicker. There is enough glass in this hull to have built at least two hulls
Starting to wonder just how much HP it is going to take to move this pig.
On another front I foolishly thought spring was here. I should have known better because the geese have not showed up yet. Those kids are the best weather forecasters ever, they are never wrong
So this morning it is blowing about 30mph and snowing to beat the band
Posted: Wed Apr 04, 2018 7:37 pm
by Aripeka Angler
Those glass plugs look great, the perfect thickness.
That means the gas tank vent I sent you will work.
What was the diameter of the plugs?
I'm about out of salmon and it's getting too dang hot already.
We are booked and heading your way not soon enough.
Full disclosure, I think I like cold weather more than you.
Posted: Thu Apr 05, 2018 1:32 am
Aripeka Angler wrote: ↑Wed Apr 04, 2018 7:37 pm
I used a 2 3/8 hole saw to cut the holes. This will let me use 2 inch plugs in the scuppers.
I sure wish I had taken the time to float test the hull last fall. Given how heavy this pig is I am wondering if the scuppers will be below the water line. They are a little over 7 inches above the chines. My math is telling me it is going to be close.
About now I am sure you like cold weather better than me. It snowed here all day and here I was dreaming of spring. If you run out of salmon and go into withdraws drop me a line.
Posted: Thu Apr 05, 2018 5:55 pm
by fallguy1000
I thought a Sintes had some core in it?
Posted: Thu Apr 05, 2018 9:56 pm
fallguy1000 wrote: ↑Thu Apr 05, 2018 5:55 pm
As far as I know all of Dave Sintes designs were based off of using C-flex. You get a solid glass hull and the thickness depends on the builder. I did not get a lamination schedule with the frame kits I bought. I just did what felt right at the time. Clearly I overbuilt this hull by just a tad
I have been wondering about building a hull with solid glass bottom and everything else cored. Just thinking but not really planning at this point.
Posted: Thu Apr 05, 2018 9:58 pm
by Jaysen
Go big or go home!
Posted: Thu Apr 05, 2018 10:04 pm
Jaysen wrote: ↑Thu Apr 05, 2018 9:58 pm
Go big or go home!
Back when you could buy top quality resin for under $500 a drum how much you used was not such a big deal. A lot of thinking still ran to thicker is better. Fuel was cheap then too
Posted: Fri Apr 06, 2018 5:23 am
by glossieblack
All this talk about being averse to warmer climes. What happened to the snowbird idea?
Posted: Fri Apr 06, 2018 11:39 am
by narfi
I've never been, but are you suggesting New Zealand may-oct and Alaska nov-april?
Posted: Fri Apr 06, 2018 6:16 pm
by fallguy1000
I always figured c-flex was some kind of core.
wth is it?
Posted: Fri Apr 06, 2018 7:16 pm
by cape_fisherman
fallguy1000 wrote: ↑Fri Apr 06, 2018 6:16 pm
wth is it?
It is tubes made out of fiberglass strands (VERY simple definition for sure). It is a core "of sorts". When you saturate the core with resin it becomes the structure. It makes a heavy boat, but it's solid for sure.
Posted: Fri Apr 06, 2018 8:18 pm
Think of 36oz biax tape 12 inches wide. It has a solid glass rod about 1/8 in diameter inbeded in it every inch across the width. The solid rod lets it span 18 inches or so from frame to frame. The rods will bend and because they are not hooked to each other you can make compound curves with it. There is no core to speak of. When wet out with resin what you have is a solid piece of fiberglass. This gives you a hull shaped thing to laminate glass to and produce a hull.
What you end up with is a solid glass hull just like one made in a mold but one that needs a ton of fairing. To me the C-Flex has two things going for it. One if you want a one off glass hull it is a good way to produce one. The second thing it works well for is if you live in remote areas where shipping a hull would be a problem.
After building several C-flex hulls and an OD-18 from here I would tell almost all to go with something from here. You will get a lighter and more efficient hull using wood/epoxy. My C-Flex hulls were built to work in the Alaska commercial fishing industry. My 32 footer was built to bounce off other boats, at speed, and keep laying gear...........many times a day, for the season.
Posted: Fri Apr 06, 2018 8:25 pm
by Jaysen
I thought it was bumper cars not bumper boats.
You Alaskans and your over zealous uniqueness.
Posted: Fri Apr 06, 2018 11:11 pm
You might get a kick out of this summer time fun
https://www.youtube.com/watch?v=wegFjTsn2y0
As you can see rubbing is fishing
Here is another fun one worth watching.
https://www.youtube.com/watch?v=ofjthNGAeqo
Posted: Fri Apr 06, 2018 11:17 pm
by Jaysen
All for those salmon hungry landlubbers who don’t know the difference between raw, properly and over cooked fish.
Posted: Sat Apr 07, 2018 3:27 am
glossieblack wrote: ↑Fri Apr 06, 2018 5:23 am
All this talk
Fair question. Two things have slowed that plan a little. My mother is getting old and needs help full time.
And my last trip down south showed me I no longer deal with hot weather as well as I once did. So while a good plan it may need to wait for a time.
Posted: Sat Apr 07, 2018 6:14 am
by fallguy1000
Alaska was warmer than us this week.
Posted: Sat Apr 07, 2018 1:45 pm
I would not be suprised at all if my winters here are milder than yours. The thing for us is how long they last. October to April
Posted: Sat Apr 07, 2018 1:57 pm
by cape man
Sweating...think I'll jump in the pool...
Posted: Sat Apr 07, 2018 2:02 pm
If it is hot enough to make you sweat it is too hot for me. But at least you have a way to cool down.
Posted: Sat Apr 07, 2018 7:11 pm
by fallguy1000
Typically Nov to Mar
I like to gillnet on open water day after Halloween, but usually have a little ice on the edges.
Posted: Sun Apr 08, 2018 12:56 pm
by TomW1
I'm having what they call Dogwood Winter here in the mountains. Highs in the 40's yesterday, in the 20's last night and the dogwoods starting to bloom. It also snowed above 3500'. I had a few flurries, very few.
Posted: Sun Apr 08, 2018 4:18 pm
by OrangeQuest
Yesterday morning we started in the 70s and it dropped to the high 40s a little after noon. I already had sun screen on!
Posted: Sun Apr 08, 2018 5:56 pm
Tom your weather and mine sound a lot alike at this point. In the next week or so our nights should be staying above freezing and then breakup will begin in earnest.
Orange Quest I remember my father talking about working outside in Texas. He said the temperature could change 20-30 degrees three times in an 8 hour day. That is one thing he really liked about Alaska is no huge changes during a short time period.
Posted: Fri Apr 13, 2018 2:21 pm
Yesterday I started to paint some of the side decks. I had picked up some Pettit Easy Poxy two part. I understand the two part will cure harder and last longer so I thought I would give it a try. I do not know if all two part paints are like this stuff or not but the part "B" stinks
In fact it stinks even with a respirator with organic filters. This stuff is bad enough I am not going to use it any more until it warms up around here and I can do it outside.
Posted: Fri Apr 13, 2018 3:16 pm
by TomW1
Fuzz blackberry winter upon us, we have names for all these weird spring winter phenomenon's. Anyway heavy snow in the high mountains, they closed travel last week. I'll probably get a 1/4". Temps in the 20's and 30's at night and days in the 40's for 2 or 3 daus. It is crazy buy our last frost date for planting out plants is early May and Mothers Day for planting out things like tomato's.
I live in a crazy part of the United States. Within 15 miles of me we have a climatology that supports the same trees and foliage that live in New England. Above 3500' are the same oaks, maples and firs. In the fall the colors are the same as we had when we lived in Boston. It is an amazing but bewildering place to live. One year we had a blizzard that dumped 36" of snow over 2 days.
You take care and don't be breathing to many paint fumes at our age we have breathed enough junk.
Posted: Fri Apr 13, 2018 3:22 pm
by narfi
If you can budget for a forced air full face mask..... They are amazing and make such jobs 'enjoyable'
Posted: Fri Apr 13, 2018 11:07 pm
narfi wrote: ↑Fri Apr 13, 2018 3:22 pm
Where do those masks draw their air from? I ask because this stuff was like you opened up a gallon can of model glue and pored it all over. The shop still stank so bad today I opened up all the doors and aired the place out for a few hours before I could work in there. Most stuff does not bother me much but that paint SUCKED
Posted: Sat Apr 14, 2018 1:47 am
by narfi
There are two types I have used, one uses an air pump you would place in a fresh air area, the other uses shop air + a big filter. If using the shop air you need to make sure that the compressor is fed fresh air (cant be in the same room as you) and it has the cfm to feed both the mask and any tools you are using.
The one I use at work now uses shop air, but my "little" compressor couldn't feed my face and properly atomize the paint. I think you were planning to roll though? If so, you only need the cfm for breathing.
Posted: Sat Apr 14, 2018 1:57 am
by narfi
Here is a quick Amazon search find. I didn't see the one I've been using which was only a few hundred dollars but required a compressor and filter system already in place.
SAS Safety 9800-35 One-Man Opti-Fit Full-face Mask Supplied-Air System, 1/4-Horsepower
https://www.amazon.com/dp/B003AQBA6Y/re ... 0AbAAVQQPA
One thing I really like about forced air is you don't need to shave or have a tight seal like you do with respirators. With positive air flow your face stays cool and dry and fresh. It's hard to describe how glorious it feels if you are used to stinky resperators.......
Protects your eyes too(assuming the full mask) which are mucus membrane and a gateway for those chemicals into your body.
Posted: Sat Apr 14, 2018 6:11 am
by OrangeQuest
Posted: Sat Apr 14, 2018 11:00 am
by BB Sig
Looks like Violet in Willy Wonka!
Posted: Sat Apr 14, 2018 2:14 pm
You owe me a new keyboard
This one has morning coffee all over it now
Posted: Sat Apr 14, 2018 2:19 pm
Thanks Narfi. The paint is the only thing I mess with that bothers me so I am not sure I can justify that set up but who knows. For now I will just plan on using any two part paint when I can have lots of ventilation. The weather is warming up enough that I will be able to open the doors in the next month or so, at least that is my hope.
Posted: Sun Apr 15, 2018 2:12 am
Getting ready to mount my windless and need to coat the bare wood to protect it. It dawned on me that the chain and rode running through the hole would wear the epoxy off so I made up a piece of glass to line the hole.
I made up a glass tube sort of like what Peter and Topwater did for their scuppers.
Now I just have to hope I can get it off the mold.
Posted: Sun Apr 15, 2018 4:07 am
by glossieblack
Yep, that hole will take an absolute flogging, so the glass protecting tube should be about the same thickness as the hull.
The head of the shackle bolt will want to get caught. Are you going to build glass flares at each end of the tube?
Posted: Sun Apr 15, 2018 12:55 pm
glossieblack wrote: ↑Sun Apr 15, 2018 4:07 am
To tell the truth I had not thought about flaring the end but now I will give it a go. Thanks for your input on that
Posted: Wed Apr 18, 2018 2:20 am
by glossieblack
It just occurred to me that my earlier comment about a shackle possibly snagging was incorrect. Since when did anyone try to pull a shackle through a windlass.
Posted: Wed Apr 18, 2018 2:29 am
glossieblack wrote: ↑Wed Apr 18, 2018 2:20 am
Funny you should post about that today. Your suggestion is a good one and I am glad you made it. Here is the glass fairlead I made up for the anchor rode.
While I was at it I lined the hole for the electric cables and over drilled and filled the mounting holes.
Posted: Wed Apr 18, 2018 6:10 am
by cape man
That looks like it will do the job. Is it August yet?
Posted: Wed Apr 18, 2018 7:29 am
by glossieblack
Nice!
Posted: Wed Apr 18, 2018 4:31 pm
cape man wrote: ↑Wed Apr 18, 2018 6:10 am
glad it meets your approval Glossie
Craig the only reason I do not wish it to be August yet is that is too close to the end of summer.
Mila and I are really looking forward to having our Florida guests this year.
Posted: Wed Apr 18, 2018 7:21 pm
by cape man
PM me.
Posted: Sat Apr 21, 2018 3:15 am
by glossieblack
Happy birthday Fuzz! Have a good one.
It's just a little past 5pm Saturday here in Noosa, so I'm about to toast you with a glass or two of good red.
Posted: Sat Apr 21, 2018 5:23 am
by OrangeQuest
Posted: Sat Apr 21, 2018 7:09 am
by cape man
Happy Birthday! Big round one for me on Monday.
Posted: Sat Apr 21, 2018 7:40 am
by gonandkarl
All the best for your birthday David and do like Michael and I are doing drink red wine ... cheers
Posted: Sat Apr 21, 2018 7:50 am
by Jaysen
Congratulations surviving another orbit of Sol. May you not do anything so stupid that Mrs Fuzz ends your next orbit prematurely.
Posted: Sat Apr 21, 2018 7:55 am
by Jeff
Happy Birthday Fuzz, hope you have a great day up there!! Jeff
Posted: Sat Apr 21, 2018 10:26 am
by narfi
Happy birthday!!!
Posted: Sat Apr 21, 2018 1:18 pm
by Bogieman
Happy birthday fuzz!!
Posted: Sat Apr 21, 2018 2:31 pm
by cape man
Have about 40 people here this afternoon to celebrate my 60th (Monday) so well toast the Kasilov Fuzz around the fire tonight.
Posted: Sat Apr 21, 2018 3:13 pm
by TomW1
Nappy birthday Fuzz and Craig would hate to see what a party it would be if you both celebrated together.
Posted: Sat Apr 21, 2018 3:25 pm
cape man wrote: ↑Sat Apr 21, 2018 2:31 pm
Thanks for that Craig. Sounds like you might have quite the party.
Here it is just going to be family but I have been wanting a good steak and our son is going to barbecue. He does much better than me.
Posted: Sat Apr 21, 2018 3:27 pm
TomW1 wrote: ↑Sat Apr 21, 2018 3:13 pm
Craig might have a wild party but it is a pretty rare thing for me to get crazy now days. But still every now and again..........................
Posted: Sat Apr 21, 2018 3:33 pm
Thanks for the birthday wishes from all of you.
I sure enjoy this group and the folks I have meet on it and those in person.
Posted: Sat Apr 21, 2018 7:27 pm
by fallguy1000
Happy Birthday!
Posted: Sat Apr 21, 2018 9:02 pm
by Eric1
Guess I'm late to the party. Happy Birthday Friend!!
Posted: Sat Apr 21, 2018 10:32 pm
Eric1 wrote: ↑Sat Apr 21, 2018 9:02 pm
Man I feel like a rock star
Thank you Eric and ever one else.
Posted: Sat Apr 21, 2018 10:42 pm
My son came over a cooked rib eyes for us. The wife and I split a decent bottle of red and my mother sent over my favourite desert so I have to say I have had a pretty darn good day
Posted: Sun Apr 22, 2018 9:25 pm
by Eric1
Posted: Mon Apr 23, 2018 8:11 am
by glossieblack
Fuzz wrote: ↑Sat Apr 21, 2018 10:42 pm
That's the way to do it Fuzz, a feast for nothing, and the chick for free.
Posted: Mon Apr 23, 2018 1:57 pm
glossieblack wrote: ↑Mon Apr 23, 2018 8:11 am
One witty fella you are Glossie
Posted: Mon Apr 23, 2018 8:11 pm
by TomW1
That's the way Deb and I do it Fuzz. Coming up on number 43rd.
Glad you had a great dayl
Posted: Thu Apr 26, 2018 1:27 pm
So the geese showed up around here and I was all excited knowing it was spring. I swapped out my cars winter tires and made a road trip to Anchorage. Spent the night and came home the next day. Seems winter is still happening in the mountains. Had about a foot of new snow on the roads. The boys with their 4x4 pickups did not let that slow them down any. I came across one on its side in the middle of the road. The driver was walking around picking up his personal stuff. While stopped another 4x4 blows by doing maybe 70. Cops showed up so I left the first guy. A few miles down the road the speed demon is upside down and embedded into a rock face. He will not be doing any walking. Amazes me how people never learn to slow down
Posted: Thu Apr 26, 2018 1:37 pm
by fallguy1000
When you do the math on speed; it does not work out to try for an extra 10mph; especially in poor conditions.
We still got ice on here. Really late!
Some of the lakes up north will not make opener and those that will; the walleyes will be spawning.
Posted: Thu Apr 26, 2018 2:16 pm
by Jaysen
70s and sunny over here. Maybe y'all should come visit.
Posted: Thu Apr 26, 2018 3:11 pm
by cape man
Boarding a plane to Grand Cayman...80 here. 85 there.
Posted: Fri Apr 27, 2018 4:00 pm
by cape man
Put a pic of my bare feet on my gallery, just for you David...
Posted: Fri Apr 27, 2018 9:19 pm
cape man wrote: ↑Fri Apr 27, 2018 4:00 pm
You suck
Reminds me of a Zack Brown song. It might be spring here but winter has not totally given up. It snowed baseball size flakes here for about 2 hours today.
Posted: Sun Apr 29, 2018 10:58 am
by fallguy1000
Lotsa chatter; where is the boat porn?
Posted: Mon Apr 30, 2018 1:27 am
Fair question Fallguy. I have not been doing much that is worth a picture but here is something.
I glassed my "work bench" with kicker bracket onto the transom. I used 6 layers of 6 inch tape so hoping that stays put.
Posted: Mon Apr 30, 2018 1:21 pm
by glossieblack
Now that's a milestone. Well done. Bet you enjoyed it.
Posted: Mon Apr 30, 2018 5:27 pm
by cape man
If that kicker pulls that off, I want one!
Posted: Mon Apr 30, 2018 5:33 pm
by Eric1
Nice Fuzz! I'm trying to decide if I'll put a kicker on my build.
Posted: Mon Apr 30, 2018 6:58 pm
by TomW1
Fuzz only 6 layers you sure they won't fall off. Might want to put a few more on the motor layers
Posted: Tue May 01, 2018 2:05 am
I have never been known to spare the glass. I truly believe you could have built at least two boats out of the glass in this one and they would have still been over built
Posted: Fri May 04, 2018 12:04 am
Well I wont have as nice of weather as CapeMan did on his trip but I am sure happy about this one. I am headed off to Fairbanks for a few days to watch my baby girl graduate collage
Posted: Fri May 04, 2018 3:23 am
by TomW1
Hey Fuzz congratulations. That's a big step in a papas letting go. Does she know where she know where she know where she goes from here.
Posted: Fri May 04, 2018 6:15 am
by Eric1
Fuzz wrote: ↑Fri May 04, 2018 12:04 am
May the road rise to meet you! Congrats to Baby girl!!
Posted: Fri May 04, 2018 7:54 am
by Jeff
Fuzz, Congrats to your daughter!! Enjoy the time away!! Jeff
Posted: Fri May 04, 2018 8:30 am
by glossieblack
Congrats Ms Fuzz, father too.
Posted: Fri May 04, 2018 11:54 am
TomW1 wrote: ↑Fri May 04, 2018 3:23 am
The next step is planned. She has been excepted to a masters program in Scotland.
Not too sure where the brains came from
I know her father and mother
Posted: Fri May 04, 2018 1:46 pm
by narfi
Congrats on the graduate, and sounds like the opportunity of a lifetime she is about to embark upon.
Everything I know about Scotland was learned from the 90s tv series Highlander..... (so basically nothing...)
I have been re-watching it this spring, the acting is bad, the special effects horrid, but the nostalgia is strong.
Interesting observation, after watching this as well as comparing the Old and New MacGuivers (Landon really likes MacGuiver so we started watching the old ones as well),
The early 90s shows had very promiscuous leading men compared to the newer shows I watch.
Could very well just be the shows I watch, or perhaps its because with more channels and more services, prime time has become more (loosely) family oriented, and other channels more niche?
Posted: Fri May 04, 2018 1:47 pm
by narfi
oops double post
Posted: Fri May 04, 2018 2:28 pm
by OrangeQuest
Fuzz wrote: ↑Fri May 04, 2018 11:54 am
Sometimes it skips a generation!
Posted: Fri May 04, 2018 7:27 pm
by TomW1
Hey Fuzz congratulations to her. I wish my mother in law was still alive. She could give her some contacts over there to get in touch with. She was full blooded Scottish and knew her relatives over there.
Good luck to your little girl off on her adventure. Oh and by the way your plenty smart enough.
Posted: Sat May 05, 2018 9:40 am
by pee wee
You might mention to her the definition of a Scottish gentleman: one who knows how to play the bagpipes, and doesn't!
Seriously, it's a wonderful country other than the food.
Posted: Sat May 05, 2018 10:22 am
by fallguy1000
Fuzz wrote: ↑Mon Apr 30, 2018 1:27 am
Are you ready for paint?
Posted: Sat May 05, 2018 6:25 pm
by glossieblack
Fair go fallguy, let Fuzz enjoy sanding a little longer.
Posted: Sat May 05, 2018 6:59 pm
by TomW1
pee wee wrote: ↑Sat May 05, 2018 9:40 am
Pee wee what is wrong with the food? Lamb chops I love. Oat meal is great. Haggis is wonderful when made right. There breads are wonderful. Scones are great. The fresh and smoked salmon can't be beat as well as some of the other seafood. They can grow fresh vegetables year around because of the closeness of the Gulf Stream. They now have some 4 and 5 star chefs. My mother in law was full blooded Scotch and went back every few years to visit her relatives. She was a great cook and made some great dishes.
Fuzz sorry for the hijack.
Posted: Tue May 08, 2018 2:26 pm
Tom and everybody else never worry about a thread hijack with me
My threads tend to wonder all over the place and that is ok with me.
On the boat front the weather is almost warm enough to do some work on the boat trailer. It needs some help before I can use it.
Posted: Fri May 11, 2018 4:11 am
by glossieblack
Fuzz wrote: ↑Tue May 08, 2018 2:26 pm
What I love about this forum is the zig zag threads. Cracker Larry was the master of encouraging it in his threads, and Fuzz, you've got the gift too. Keep doing it!
Posted: Sat May 12, 2018 12:38 am
Thanks Glossie but nobody could tell a story and draw you into it like Larry. I sure miss logging on and getting the latest happening in his life.
Posted: Sun May 20, 2018 4:38 am
by glossieblack
How goes it Fuzz?
With AA and cape man heading your way, my hunch is that you're getting a bit done.
Posted: Sun May 20, 2018 5:47 am
by gonandkarl
Hi,
Congrats to the graduation of your daughter and hopefully she will enjoy Scotland. I have never been there but heard always a lot about their food and experienced never any of it but the Scottish whiskey I definitely enjoy occasionally. I still do not know what food a Haggies is. But coming back to your boat I love the kickers plank being glassed to your "work bench". At last I know how many layers of glass one needs to have something really strong because if that holds your motor I should do fine walking my weight on ta hatch roof of similar construction.
Greetings from Karl
Posted: Mon May 21, 2018 2:03 am
gonandkarl wrote: ↑Sun May 20, 2018 5:47 am
Hi,
Greetings from Karl
Karl thanks for your thoughts for my baby girl
She is a really good girl and I have been blessed with her.
Posted: Mon May 21, 2018 2:08 am
glossieblack wrote: ↑Sun May 20, 2018 4:38 am
How goes it Fuzz?
Glossie I wish you were correct with your guess. My mom is having a tough go of it and needs pretty much round the clock care so that has taken top billing in my life for now. Just sort of wanted to say why things have really slowed for me.
Posted: Mon May 21, 2018 3:41 am
by glossieblack
I'm really sorry to hear that Fuzz. All the very best to both you and your mom.
Posted: Mon May 21, 2018 5:20 am
by cape man
David,
Having just passed the year mark for my father, my heart is with you brother. Tough stuff, but part of the job as a son.
You don't have to do anything to prep for our visit. As you know we are pretty low key. Focus on your mother for sure.
Posted: Mon May 21, 2018 6:03 am
by OrangeQuest
Hoping things get better for you and your Mom.
Posted: Mon May 21, 2018 7:31 am
by Jeff
Fuzz, Really hope things improve for your mom & yourself. Just a really difficult part of life!! Jeff
Posted: Mon May 21, 2018 8:45 am
by Eric1
Hang in there Fuzz. I know how this feels.
Posted: Mon May 21, 2018 2:57 pm
Thanks for all the kind thoughts guys. I know many of you are either going through the same thing or have already been through it. It is just that part of life we all go through.
I still have plenty of time for the forum, just hard to get a long enough block of time for boat work.
Posted: Mon May 21, 2018 3:02 pm
cape man wrote: ↑Mon May 21, 2018 5:20 am
David,
Thanks a lot buddy. Not to worry we both are ready for you guys to visit
The Seasport and dory are both fishing ready so no problems with having something to fish out of. Of course the dory will seem slug slow now that you have a rocket
Posted: Mon May 21, 2018 3:41 pm
by TomW1
Fuzz having lost mom and dad in the last year my prayers are with you and your mom. Spend what time you can with her as we are missing them now on things like Mother's Day and dad's birthday.
God bless
Posted: Sat May 26, 2018 9:33 pm
by glossieblack
Just read Capt UB's bad news about his mother, and thought of you Fuzz. How goes it?
Posted: Sun May 27, 2018 12:48 am
Thanks for asking Michael and all you other guys.
My mom is not at the point where she is ambulatory but she has reached that stage in life where she needs someone with her round the clock. She is just like my father was and will not hear about not living in her home so my family members are all taking turns being with her.
This has pretty much ended my boat building free time for now but some things in life are more important than boats.......hard as that is to say
My little boat job will get done when it gets done, it is not that big of a deal.
Posted: Sun May 27, 2018 6:52 am
by glossieblack
Fuzz wrote: ↑Sun May 27, 2018 12:48 am
Well said Fuzz. You've got your priorities right. All the best.
Posted: Sun May 27, 2018 10:01 am
by Jeff
Yes, fully agree Fuzz!!! Jeff
Posted: Sun May 27, 2018 1:06 pm
by Eric1
Good man Fuzz.
Posted: Mon May 28, 2018 2:44 am
Thank each of you very much.
I still have lots of, maybe even more, computer time so you are not getting rid of me
And there will be small windows of boat time so I will post when I have something worth showing
Re: Sintes 21 Rebuild
Posted: Mon May 28, 2018 3:54 am
by fallguy1000
Good luck friend.
Posted: Wed Jun 06, 2018 10:14 pm
by Jaysen
Meanwhile, somewhere is “why is it cold in June” Alaska, Fuzz sits for a picnic...
[youtube]
https://youtu.be/rbE53XUtVw0[/youtube]
And Walmart runs out of men’s underwear.
Posted: Wed Jun 06, 2018 11:02 pm
That time of the year the bears are so fat and lazy form eating fish they do not have a care in the world. Problem is every once in a while one wakes up on the wrong side of the bed with the result being one or more less humans in their way. Idiots forget they are big, fast, strong animals and then Darwin kicks in. Part that chaps me is when they want to blame the mean old bear. He might be hungry and you are food, end of story
Posted: Wed Jun 06, 2018 11:14 pm
by Jaysen
And end of clean shorts for non-Darwin award elegable humans.
Posted: Thu Jun 07, 2018 2:55 am
by TomW1
Yepper I have been to close to 3 bears since I have moved to NC. The first came up on my deck and dragged off my grill. The second was before the house burned down and was in front of it and Deb had to go to work and it was in front of her car maybe 10 feet away so we just waited till he wandered away. And then the third I showed you the pictures of the one that wandered across the patio.
You don't want to mess with a wild bear no matter where they are, they are quicker bigger and faster than you.
Posted: Thu Jun 07, 2018 7:26 am
by Jeff
Crazy footage!! Jeff
Posted: Thu Jun 07, 2018 8:27 am
by fallguy1000
It had a certain stuffed animal cuddly to it, but in a freakish, it can eat you, way.
Way too close for me.
Remember that idiot who was in bear country during hyperphagia. He and the girl were both killed.
Posted: Thu Jun 07, 2018 2:53 pm
That guy was just begging for trouble. Got his girlfriend and himself killed thinking he was friends with the bears. So you want to be friends with an apex predictor and see what happens
Darwin in action. If you ever hear a really big bear woofing and popping his teeth up close to you it is something you will not forget. Got lots of good stories after living and hunting here over 50 years
Posted: Thu Jun 07, 2018 4:18 pm
by Jeff
Fully agree Fuzz!! He is one lucky guy!! Jeff
Posted: Thu Jun 07, 2018 5:24 pm
by OrangeQuest
Fuzz wrote: ↑Thu Jun 07, 2018 2:53 pm
Have a lot of ZERO stories to tell of me and bears but closest I can say is the HS I went to was the LCM BEARS. End of long story about bears.
Posted: Thu Jun 07, 2018 5:43 pm
by Jaysen
Wait. Beers? Who’s afraid of beers? What’s wrong with y’all?
Posted: Thu Jun 07, 2018 5:46 pm
Jaysen wrote: ↑Thu Jun 07, 2018 5:43 pm
We are just not as brave as you. Pretty sure you have never meet a BEER you are afraid of
Posted: Thu Jun 07, 2018 5:50 pm
by Jaysen
Fuzz wrote: ↑Thu Jun 07, 2018 5:46 pm
I will admit that I've lost a battle or two with a beer. Long fought. Both sides dented and a bit of blood. In the end, I'd do it all over again... All over again.
Although, in hindsight, switching to beer after the rum ran out may have been a mistake.
Posted: Thu Jun 07, 2018 11:31 pm
Ok boat type question. I need to bed my lexan windshield what do I use? First thought is silicone but not sure if that is the correct stuff.
Posted: Thu Jun 07, 2018 11:46 pm
by fallguy1000
Teeth gnashin and hissin beers are the ones I prefer.
Real hoppy ones!
Posted: Thu Jun 07, 2018 11:51 pm
Pretty clever there Fallguy
Posted: Fri Jun 08, 2018 6:03 am
by Jaysen
Silicone will do it.
Posted: Sun Jun 10, 2018 9:46 am
by fallguy1000
Law requires an 1/8" expansion gap, but with good reason. You don't want .... to buckle.
Posted: Sun Jun 10, 2018 9:48 pm
by Jaysen
One of those fuzzies get you Fuzz?
Posted: Sun Jun 10, 2018 10:00 pm
Jaysen wrote: ↑Sun Jun 10, 2018 9:48 pm
Nope just plugging along with lifes fun stuff. Some how I lost my battery charger for my camera
got a new one on order and by the time it gets here I may even have something to show.............maybe
So how did the sailing go?
Posted: Sun Jun 10, 2018 10:33 pm
by Jaysen
Nada. Two weeks and I’m back for ... 2 weeks.
There will be water.
There will be boat.
There will be bait.
There will be sail!
The question is ... will they all be together?
Posted: Tue Jun 12, 2018 2:25 am
Got a fathers day present of sorts
This will let me transplant my old Merc to the Sintes. After a little trailer work with a little luck I just might be able to take her out for a "rat rod" run a little later in the summer. Still hope to have it up and running before the arrival of the Florida crew
Posted: Tue Jun 12, 2018 2:27 am
Hey Jaysen did you see my picture of this cute, cuddly little fellow?
Posted: Tue Jun 12, 2018 5:55 am
by Jaysen
Interesting.
Did he stay over for dinner? I assume you offered him something to eat. Something in the lead family...
Posted: Tue Jun 12, 2018 6:07 am
by cape man
Happy Father's Day.
Posted: Tue Jun 12, 2018 6:09 am
by cape man
Happy Father's Day.
Posted: Tue Jun 12, 2018 11:00 am
by Eric1
Very nice Fuzz! That get Sintas moving!!
Posted: Fri Jun 15, 2018 12:37 am
Made a little progress. We now have a wind shield. Don’t want any of my guests getting a cool breeze on them you know
Paper is still on until things get painted. It is 3/8 lexan, pretty sure it is bullet proof but it was free so might as well use it.
Posted: Fri Jun 15, 2018 1:29 am
I learned something last night from Utube. Pretty sure most or all of you already knew this but I sure did not. While trying to get my new motor primed I pumped the primer bulb until both forearms cramped up. Took the bulb out and replaced it, still nothing. Went on Utube and learned you need to hold the bulb straight up and down with the arrow going up. Went out and tried it this morning and in about 30 secounds the bulb was hard as a rock and I was able to fire up my new toy. Now if the wind will just lay down I can go try to help some poor fish commit suicide
Posted: Fri Jun 15, 2018 2:37 am
by TomW1
HIP HIP HOORAY
I love the look of her head on like that she almost looks mean with the wood trim on the windows.
Posted: Fri Jun 15, 2018 3:10 am
by gonandkarl
Hi,
I love your wind shields and you are cleverer than me leaving the paper on until after painting. But you lost me completely with your bulb on the engine. I have never heard of a bulb on a diesel engine please enlighten me.
Greetings from Karl
Posted: Fri Jun 15, 2018 3:17 am
gonandkarl wrote: ↑Fri Jun 15, 2018 3:10 am
Hi,
Greetings from Karl
Sorry Karl I did not mean to confuse things. I was talking about the squeeze primer bulb on outboard engines.
Whole different set up on a diesel engine. But I have seen one used with a bypass to fill fuel filters after changing them.
And I am glad you like the wind shields. Does not matter what time of the year it is things get a little nippy if you are exposed to the wind at any great speed.
Posted: Fri Jun 15, 2018 3:20 am
TomW1 wrote: ↑Fri Jun 15, 2018 2:37 am
HIP HIP HOORAY
Thanks Tom
I am getting closer to laying some paint on her and then taking her for a spin. More like a rat rod test as there are some things I want to check out. Might be better to rat rod and then paint
Posted: Fri Jun 15, 2018 3:32 am
by gonandkarl
Thanks for the explanation about the bulb but I am so unfamiliar with engines outboard or diesel that I still cannot imagine what or how you used it before starting the engine. Your words, a picture might help a dummy like me.
Posted: Fri Jun 15, 2018 3:39 am
I will try to take a picture for you in the morning Karl.
Posted: Fri Jun 15, 2018 4:20 am
by narfi
The bulb is the rubber squeeze pump inline with the fuel line from the tank to the engine. You squeeze it and a check valve forces the fuel in it toward the engine, then you relax your hand and it goes back to it's normal shape and pulls fuel from the tank to be squeezed again.
The outboard has a pump so when running you dont need to do this, just before starting to get the engine primed with fuel.
Posted: Fri Jun 15, 2018 4:28 am
by gonandkarl
Thank you it is so easy I use the same method wit the garden hose and to get water out of a rain water container.
Posted: Fri Jun 15, 2018 5:39 am
by OrangeQuest
Looking good! Never heard the bulb needing to be pointed up. Is there a reason why it works?
Posted: Fri Jun 15, 2018 5:58 am
by glossieblack
My amateur take would be because liquid fuel is heavier than air.
Posted: Fri Jun 15, 2018 6:42 am
by OrangeQuest
glossieblack wrote: ↑Fri Jun 15, 2018 5:58 am
That does not explain why the check valve doesn't work unless pointed upward. I have always just started squeezing the bulb and a few times it gets hard.
Here is a video on the whole thing.
https://www.youtube.com/watch?v=Mrt38-ulYFc
The arrow is for letting you know which way the fuel needs to go. But his explanation for why pointing it upwards makes it work better may have merit if the balls are metal. The little nylon ones maybe to light for this to work.
Anyway, happy to see the motor running.
Posted: Fri Jun 15, 2018 1:42 pm
I think in my case the upper check valve was not holding very well. When I held it upright the force of gravity helped things work correctly. One thing I know for sure is it worked like a champ for me
Posted: Fri Jun 15, 2018 3:30 pm
by OrangeQuest
Fuzz wrote: ↑Fri Jun 15, 2018 1:42 pm
That's what counts. And you will remember that trick for life. Me too!
Thanks for bringing it up.
Posted: Sat Jun 16, 2018 5:55 am
by cape man
Took Clara out yesterday afternoon. Bulb would not get hard with several pumps. Tilted it up. BINGO!
Posted: Sat Jun 16, 2018 7:59 am
by Jaysen
There has to be a viagra joke in here somewhere ...
Posted: Tue Jun 19, 2018 3:16 am
I note in many threads guys are whining it is too hot to glass
We on the other hand are having no problem with too much heat. Went for a little 7 hour boat ride today to break in the new engine. Water temp a pleasant 42f, air 56f and a nice fresh 20knot breeze
All day and not a drop of sweat
And running lights not needed at any time, it is light all the time
Posted: Tue Jun 19, 2018 4:57 am
by glossieblack
Fuzz wrote: ↑Tue Jun 19, 2018 3:16 am
Which boat Fuzz?
Posted: Tue Jun 19, 2018 6:17 am
by cape man
The one with the new Suzuki on it! The one I get to ride in August! Whoooo Hoooooo!
Posted: Tue Jun 19, 2018 6:48 am
by gonandkarl
Hi,
Should I ever get a small petrol outboard instead of my electrical one I am perfectly clued up what is a bulb and how to use it. I love this good explanations on the forum and Fuzz I would for once change my present utterly hot Summer ( 90 es plus ) anytime with your temperatures. I have only energy to watch 3 world cup soccer games per day but none to get the boat further.
Greetings from Karl
Posted: Tue Jun 19, 2018 7:01 am
by OrangeQuest
That is winter for us when a cold front blows through.
Posted: Tue Jun 19, 2018 7:06 am
by topwater
The only time i feel 42 degree temps now is when i open the refrigerator to get a beer
Posted: Tue Jun 19, 2018 7:22 am
by Jaysen
topwater wrote: ↑Tue Jun 19, 2018 7:06 am
Why are you keeping your beer warm?
Posted: Tue Jun 19, 2018 7:23 am
by Jeff
Nice Fuzz!!!! Jeff
Posted: Tue Jun 19, 2018 8:22 am
by Eric1
I would offer up body parts for 42 degrees right now.
They would not be my body parts but still.
Posted: Tue Jun 19, 2018 8:26 am
by Jaysen
Bicycled into work. It's a mile. Needed a shower. Still not going to consider moving north. Or inland. Or anyplace where I can't wear shorts 13 months of the year.
Posted: Tue Jun 19, 2018 1:39 pm
Eric1 wrote: ↑Tue Jun 19, 2018 8:22 am
Dang, now I can't even trust you. Here I am wiping coffee off my keyboard
Posted: Tue Jun 19, 2018 8:36 pm
by TomW1
Get that baby broken it and we will get a prop on it. WoooHoo
Posted: Wed Jun 20, 2018 12:34 am
TomW1 wrote: ↑Tue Jun 19, 2018 8:36 pm
Thanks Tom! I still need to put a few more hours on it before I can open it up and get some good numbers.
Right at the end of the day the new fancy smart gauge went dead on me
I dropeed it off at the dealers around noon and they called about quitting time to let me know it was ready for pick up. Sure glad I ended up buying from a good dealer.
Posted: Wed Jun 20, 2018 6:56 am
by Jeff
Sounds like good service Fuzz!! Jeff
Posted: Wed Jun 20, 2018 6:55 pm
by TomW1
There is something about good service that makes you happy.
Posted: Thu Jun 21, 2018 3:10 am
TomW1 wrote: ↑Wed Jun 20, 2018 6:55 pm
You got that right Tom
That is one of the things that makes dealing with Jeff and the boys so nice.
Posted: Thu Jun 21, 2018 6:45 am
by OrangeQuest
Fuzz wrote: ↑Thu Jun 21, 2018 3:10 am
I don't mind spending a little more, travel a bit farther or wait for a business to open if they give good service. Jeff and co. do set very high standards for other businesses to try and follow.
Fuzz, you guys I would guess don't have a lot of dealers of the same stuff as we do here in Houston. So having a good one is a very big plus!
Posted: Thu Jun 21, 2018 9:18 am
by Jeff
Guys, thank you all for the nice comments!! We do try hard to provide good service & support!! Thanks again, Jeff
Posted: Thu Jun 21, 2018 4:16 pm
by cape_fisherman
Jaysen wrote: ↑Tue Jun 19, 2018 8:26 am
I think I put on long pants for our work Christmas party last year...other than that I've been at least 12 months in shorts. I have a funeral to go to on Saturday...long pant day #2.
Posted: Thu Jun 21, 2018 5:17 pm
by Jaysen
Charleston makes it harder than Beaufort since I’m more inland here. But I don’t see any reason to live someplace that requires “goose down” anything.
Posted: Thu Jun 21, 2018 6:37 pm
OrangeQuest wrote: ↑Thu Jun 21, 2018 6:45 am
OQ that is so true. One of the things I really envy you folks for is the ability to go look at stuff and see if it is what you want. And if you do need something shipped it does not cost an arm and a leg. Last builders meet Jeff took me and showed me the BBC shop. On the way he took me to a GIANT marine surplus warehouse. I was like a kid in a candy store when mom and dad say you can have nothing
Posted: Thu Jun 21, 2018 6:39 pm
Jaysen wrote: ↑Thu Jun 21, 2018 5:17 pm
Wait................they make boxers out of something besides goose down
Posted: Thu Jun 21, 2018 7:22 pm
by Jaysen
Fuzz wrote: ↑Thu Jun 21, 2018 6:39 pm
Exactly!
Posted: Sat Jun 23, 2018 7:53 am
by glossieblack
Fuzz wrote: ↑Fri Jun 15, 2018 3:20 am
Still thinking of a rat rod run Fuzz?
Posted: Sun Jun 24, 2018 2:03 am
Sure enough Michael,
I need to get a little welding done on the trailer and hook up the steering first. Those are the two big ones holding up the test. If nothing else I will do it one day when CapeMan is here.
It being summer here I get a little distracted by being out on the water and doing some fishing
If I can figure out how to post video I got some good stuff to share.
Posted: Sun Jun 24, 2018 7:52 am
by Jeff
Fuzz, look forward to the video!!! Jeff
Posted: Tue Jul 03, 2018 3:50 am
by glossieblack
How goes it Fuzz?
Posted: Tue Jul 03, 2018 5:55 am
by cape man
I work for board.
Posted: Tue Jul 03, 2018 11:43 am
I have had guests here the past two weeks and will have them for a few more days so no boat work.
I am hoping for some free time before Capeman gets here so we can rat rod it then
Posted: Tue Jul 03, 2018 12:13 pm
cape man wrote: ↑Tue Jul 03, 2018 5:55 am
I work for board.
I am slow...............got it now
Posted: Wed Jul 04, 2018 5:43 pm
by glossieblack
Fuzz wrote: ↑Tue Jul 03, 2018 11:43 am
If it works out this way, very nice. But don't put unrealistic expectations on yourself.
Posted: Mon Jul 16, 2018 6:10 am
by glossieblack
Even allowing for the above, it's uncommonly quiet on the Fuzzfront.
Posted: Mon Jul 16, 2018 2:24 pm
Well I have been trying to catch some fish but so far it has not been my year
In fact it looks like I am going to have to resort to letting SWMBO and the Russian Mafia show me how it is done
I spent a few days working on the trailer so not much to show and tell on that front. It then took me all one day to get it loaded on the trailer, man that pig is heavy
Yesterday I hung the motor so I could drill the mounting holes. I will be working on the fill and redrill of the holes today if all goes well.
Thanks for checking in on me Glossie, I need a little push now and again to keep moving forward.
Posted: Tue Jul 17, 2018 4:19 am
by glossieblack
Good going Fuzz. Sounds as though you'll be ready to take cape man for a rat rod run. Is AA still coming up too?
Posted: Tue Jul 17, 2018 7:17 am
by Jeff
Good update Fuzz!!!! Jeff
Posted: Tue Jul 17, 2018 7:22 am
by cape man
24 days....
Posted: Tue Jul 17, 2018 7:53 am
by Jeff
CapeMan, hope you guys have a great visit with Fuzz!!! I think his weather might be a relief for you guys!! What a hot Florida summer this year!! Jeff
Posted: Tue Jul 17, 2018 1:37 pm
by cape man
Yeah! Kinda like the one last year. Or the one before that. Or the one when I graduated from High school back in '76. Or the one next year...
Summer, Florida = Hot, Humid
Temperature
90 °F July average high 32 °C
76 °F July average low 24 °C
In most years, Tampa averages a daily maximum temperature for July that's between 89 and 91 degrees Fahrenheit (32 to 33 degrees Celsius). The minimum temperature usually falls between 75 and 77 °F (24 to 25 °C).
The days at Tampa warm slightly during July. By the end of the month, the day's average temperature has climbed less than 1 °F (0.5 °C) above what it was at the start.
17 days 90 °F max. or more (32 °C)
0 days 70 °F min. or less (21 °C)
The temperature typically rises every day in July to over 80 °F (26 °C) in Tampa. Temperatures above 100 °F (38 °C) are not expected here this month.
The thermometer dips to 70 °F (21 °C) or below in July on an average of once a decade.
Posted: Wed Jul 18, 2018 2:55 am
cape man wrote: ↑Tue Jul 17, 2018 7:22 am
24 days....
SWMBO and I are both counting the days also.
I sure am hoping AA is able to carve out enough time to make the trip too. That boy needs to clone himself.
Posted: Wed Jul 18, 2018 11:27 am
by gonandkarl
Even when it is not picture worthy, I still would like to see your big pig with the motor on the trailer just to see a real boat on a trailer in comparison to my tiny Adelie. Hope you have more luck with the fishing in the near future especially when Craig is visiting you.
Posted: Wed Jul 18, 2018 6:33 pm
by Bogieman
Posted: Thu Jul 19, 2018 2:28 am
Thanks Karl and Boogie,
I will try to have it mounted and a few pictures here in the next few days.
A few fish have shown up so me and SWMBO have been out trying to fill the freezer. Probably be Saturday before I get time to mess with the boat again.
Posted: Fri Jul 20, 2018 3:54 am
So I sent SWMBO to gather up some fish and this is all she came back with.
Going to send her again in the morning to see if she can do better
I messed around and caught one of these but let it go as it was to small to keep. The gaff is not in a place to hurt it. Lingcod are ugly but some of the best eating there is.
Posted: Fri Jul 20, 2018 6:13 am
by cape man
Is she dipping?
Posted: Fri Jul 20, 2018 10:10 am
by Eric1
Posted: Fri Jul 20, 2018 10:45 am
by OrangeQuest
cape man wrote: ↑Fri Jul 20, 2018 6:13 am
Is she dipping?
Down here in Texas that question has a different meaning. You are not asking about smokeless tobacco are you?
Posted: Fri Jul 20, 2018 11:20 am
by cape man
Posted: Fri Jul 20, 2018 2:38 pm
Yep she is dipping. Normal day you are allowed 3 fish but dipping she can take up to 45 fish for the year. If it is good you can have your limit in a few hours or you can do it all day for 2-3 if it is slow. You just never know.
Posted: Sat Jul 21, 2018 2:40 am
It was SLOW she came home with four fish
So we are headed off to Homer in the morning to try our luck there.
I have not forgotten the pictures for you Karl I am just not making much progress on the boat right now.
Posted: Sat Jul 21, 2018 3:07 pm
by OneWayTraffic
Limit in NZ is two per day. Rod and running line the only legal method. Salmon are regulated like sports fish.
Caught a couple in the Twizel canals the other week. Local fish farm had a net break and 7000 fish escaped. 12 pounds each or so.
Posted: Sun Jul 22, 2018 1:10 am
Got a limit of halibut
Nothing big enough to take pictures of but it was one fine day here today. Had to strip down to my T-shirt and almost broke a sweat........almost
Will be back on the boat tomorrow afternoon if all goes well.
OneWayTraffic salmon fishing is regulated here too. We just have a few special times and rules where you can harvest them, not so much sport fishing. While dipping SWMBO caught a king salmon that was about 70lbs. She had to let it go and man was she pissed. I thought the cold war might return
Posted: Sun Jul 22, 2018 8:34 am
by Eric1
Fuzz wrote: ↑Sun Jul 22, 2018 1:10 am
Glad you're on the fish! Sucks about the king though.
Posted: Sun Jul 22, 2018 9:06 am
by Jaysen
Round these parts we have a "slot" limit on the red fish/spot tail bass/damn that's good eats/what-ever-you-want-to-call-them. I can catch them 3/4" under, and 3/4" over (and much larger) all day long. I've only found one or two a month that are in the slot. 3 years ago I caught my first ever slot sized red. At the time I was on my 9' walmart kayak. I ran the yak ashore while I fought the fish and wound up about 30' from my gear. I'd been trying to catch one of these SOB for nearly a year so I wall paranoid about dropping it in the water. Me being the smart guy I am, I walked about 5yd up the beach and deposited my fish while I went for my stringer (yes, I keep my dinner on a stringer when I'm fishing).
Now one thing you need to know about Beaufort... we love us some 'Merica! in the form of jarheads and blad eagles. The Marines are easy to keep track of... look for a walking attitude that is quick to hold the door, play with children and fight anyone who looks at them without a smile. The eagles on the other hand... I just happened to notice one sitting on a dock about 1/4mi from my fishing hole when I paddled by it. Glorious looking birds. It gave me a death stare, I saluted and left it the heck alone. Then I forgot about it.
If you recall where we were at the end of the first paragraph (Fuzz may need to go back and read it again, which might get him stuck in an endless loop) you may be asking "what the hell if wrong with this moron?" I promise to tie all this together. As I was picking up my stuff I hear this odd rustling sound. At first I thought is was a spoonbill or marsh hen or maybe a gator up the creek a bit. But as I turned around I realized it was that DAMN EAGLE STEALING MY FISH!
These day my "salute" to the eagles uses only one finger and is much less respectful.
I'm sure this is a regular occurrence in Alaska. Just let SWMBO know that at least one southerner knows the pain.
Posted: Sun Jul 22, 2018 12:23 pm
Never had an eagle take a fish I was going to keep but I have had them snatch up a few that I had just released.
Good friend of mine's wife was drinking her morning coffee and watching her high dollar miniature dog do his morning business. Next thing she knows an eagle is flying off with $1000 mutt
I have had a brown bear take a deer away from me but that is a whole nother story.
Posted: Sun Jul 22, 2018 6:32 pm
by glossieblack
And?
Posted: Mon Jul 23, 2018 12:52 am
After church a little get together for the boys birthday sore of put all boat work on hold. Maybe tomorrow, we will see.
Posted: Mon Jul 23, 2018 6:02 pm
by TomW1
Hi Fuzz loving your rebuild of that Sintes. Been thinking on your putting the Merc on her. You may have to go to a lower pitched prop on her. Do your rat run and see what your max rpm's are with the current prop are at WOP is and we will see.
I am basing this on how much you say the Sintes weighs and is well built.
Posted: Tue Jul 24, 2018 4:16 am
Thanks Tom. I will take and get her weighed before taking her for the rat rod run.
I am wondering if this thing will float or if it will go straight to the bottom. Pretty sure it will float but I want to see where the waterline is at. That and I want to see if it has any vices while running.
I am waiting for some paint to dry and then will get the outboard hung and go from there.
Posted: Tue Jul 24, 2018 5:53 am
by OrangeQuest
Fuzz wrote: ↑Tue Jul 24, 2018 4:16 am
Good luck on your boat, the rat rod run, water line and the paint drying.
Posted: Wed Jul 25, 2018 2:19 am
Well as promised here is what her tail looks like. If the paint is dry tomorrow I will get the motor mounted.
Posted: Wed Jul 25, 2018 4:58 am
by gonandkarl
Wow that is a big boat transom, cannot wait to see it with the motor on.
Posted: Wed Jul 25, 2018 5:22 am
by OrangeQuest
Wow! It does look big! Also excited to see it in the water!
Posted: Wed Jul 25, 2018 8:02 am
by topwater
She thick
Posted: Wed Jul 25, 2018 9:08 am
by Eric1
Baby's got Back!
Posted: Wed Jul 25, 2018 9:09 am
by cape man
Let's get her wet!
Posted: Wed Jul 25, 2018 10:30 am
by Jeff
Very nice Fuzz, that will last forever!! Jeff
Posted: Wed Jul 25, 2018 7:17 pm
by glossieblack
Bet that feels like a milestone.
Posted: Wed Jul 25, 2018 8:37 pm
by TomW1
Dang that is a fat ass boat!
Posted: Thu Jul 26, 2018 3:00 am
cape man wrote: ↑Wed Jul 25, 2018 9:09 am
Let's get her wet!
Careful what you wish for
If the train does not jump the tracks you and I are going to see if she will run or not
Posted: Thu Jul 26, 2018 3:14 am
Eric1 wrote: ↑Wed Jul 25, 2018 9:08 am
Baby's got Back!
Yep she has plenty of butt on her
Just want to see if she drags it or hauls it.
Paint was not fully cured yet so motor mount tomorrow.
Glossie it does feel like a milestone of sorts. After watching all the headaches you have been having I thought it best to give this thing a run and see what I have before spending lots more time doing all the little things that seem to take forever.
Thanks for the kind words Tom, Jeff, OQ, Karl and Topwater.
Posted: Thu Jul 26, 2018 9:16 am
by Eric1
I'm sure she will run great Fuzz.
For all the teasing about your "Fat Bottom Girl", Yea, She'll "Make your Rocking World Go 'Round" !!
Posted: Fri Jul 27, 2018 2:26 am
Fat girl has a little iron on her tail tonight.
Posted: Fri Jul 27, 2018 6:47 am
by topwater
Does this make my butt look big
Posted: Fri Jul 27, 2018 2:13 pm
topwater wrote: ↑Fri Jul 27, 2018 6:47 am
Never ask a question if you do not want to hear the answer
Posted: Fri Jul 27, 2018 2:15 pm
by OrangeQuest
Transom doesn't look as big now the motor is taking up some of the space.
Posted: Fri Jul 27, 2018 2:25 pm
I figure after I add the kicker her but will look more like Cindy Crawford's. A little old but diffidently not sagging
Posted: Fri Jul 27, 2018 2:47 pm
by TomW1
Now that looks better Fuzz.
Posted: Fri Jul 27, 2018 3:00 pm
by Jeff
Nice Fuzz!!! Jeff
Posted: Fri Jul 27, 2018 3:17 pm
Thanks guys.
She is still way work boat, pictures can hide a lot
Posted: Fri Jul 27, 2018 3:30 pm
by Jaysen
one main and one kicker, right?
Posted: Fri Jul 27, 2018 3:49 pm
by OrangeQuest
Looks like there is room for the main, a kicker and a side kick for the kicker!
Posted: Fri Jul 27, 2018 3:54 pm
by Jaysen
I thought it was a boarding ladder mount for when Mrs Fuzz gets annoyed and tries to feed him to an orca but the orca realizes he's really old meat and not worth eating.
Posted: Fri Jul 27, 2018 5:42 pm
OrangeQuest wrote: ↑Fri Jul 27, 2018 3:49 pm
The story is I put the kicker bracket on the starboard side first then I got to thinking
With the kicker and batteries on one side I was going to have a built in list. So I built the port kicker bracket.
Some of my questions will be answered with the rat rod run...........I hope
Posted: Sat Jul 28, 2018 6:00 pm
by Aripeka Angler
Man that looks great FUZZ.
If a rat rod run is in the cards, I’m in.
I’ll be up there in 8 days and 4 hours...
Posted: Sat Jul 28, 2018 6:49 pm
by Jeff
AA, I hope you have a great trip to Alaska!! Get us some good photos!!! Jeff
Posted: Sat Jul 28, 2018 11:11 pm
Aripeka Angler wrote: ↑Sat Jul 28, 2018 6:00 pm
My, My, My look who is among the living
Somebody lifted your nose off the grind stone long enough for you to post.
8 days and 4 hours.............you are not looking forward to getting both a break and out of the heat are you
Weather is looking like it could be better than last year, well we can at least hope so
Fishing has been a little shaky so far but we will give it a go.
Posted: Sun Jul 29, 2018 2:19 am
by Aripeka Angler
Jeff, the camera will be along for sure!
Fuzz, I’m for sure ready for a break from work and the heat. It will be great to see you and Luda again.
Spent my Saturday helping put in a new Corian countertop in Capeman’s home on the Alafia river.
He is stoked and ready for AK...
Posted: Sun Jul 29, 2018 4:59 am
We both are really looking forward to seeing all of you.
Posted: Mon Jul 30, 2018 2:35 am
Spent the day trying to get the hydraulic steering hooked up. I say trying because the steering rod did not want to go through the rigging tube. There was corrosion inside the tube that would make the rod bind up. Getting it cleaned out turned into a goat rope.
Posted: Mon Jul 30, 2018 4:32 am
by glossieblack
Fuzz wrote: ↑Mon Jul 30, 2018 2:35 am
As a first timer tackling a project longer than half a day using my hands, I'm amazed at how often I manage to achieve little more that another goat rope. At least it sounds as though you've now got it cleaned Fuzz.
I'm really looking forward to your rat rod test run. Remember, if it goes well, you're a genius, if there are problems, cape man and AA have been advising you.
Posted: Mon Jul 30, 2018 7:10 am
by cape man
I'll own it
Posted: Mon Jul 30, 2018 1:35 pm
by cape man
Good friends are the most valuable thing one can earn in this life!
If everyone knew how hard and long AA has worked this year without a break....Giving me his Saturday meant a LOT. The wife is thrilled as the countertop was the last item in the Kitchen!
Sorry for the high jack Fuzz, but didn't need a whole new thread for this...
Posted: Mon Jul 30, 2018 2:08 pm
by Jeff
Really well done CapeMan (with the help and assistance of AA), good friends make life a whole lot better!! Jeff
Posted: Mon Jul 30, 2018 2:09 pm
by Jaysen
That live edge in the ceiling... I want that. That's beautiful.
Posted: Mon Jul 30, 2018 3:29 pm
by TomW1
Very nice.
Posted: Mon Jul 30, 2018 4:21 pm
First of all folks adding to my thread is NEVER a hijack. I enjoy every post no matter the subject
I am sure Patti is thrilled with her new kitchen. It looks great, you have made a ton of changes.
About Richard giving his time I am not surprised in the least. When I learned of all he did for folks before, during and after the last hurricane I knew he was a hell of a good guy. One I am proud to call friend even though I have not known him for very long.
You do not get and keep friends like Richard for long periods of time without being a truly good person yourself. Craig, the Cracker and Richard were long time friends as far as I know. Larry was held in high regard by many here. I have seen pictures of him helping Craig build his dory. That should tell everyone all you need to know about the CapeMan.
These guys would never say it themselves but I think this is a good time to say it about them.
Posted: Mon Jul 30, 2018 4:37 pm
by Jeff
Nice Fuzz!!!!!! Jeff
Posted: Mon Jul 30, 2018 6:08 pm
by TomW1
Well said Fuzz those guys were like the 3 Musketeers. Always fishing together even when there wasn't a Bateau meet. I miss Larry because he and I had a few good times on his GF16 and talking about his builds and regulations and props.
Posted: Tue Jul 31, 2018 12:21 am
Got all the tubing for the steering done today. Just waiting for some cable boots to show up before I can finish that part up and test it. If they do not show in a day or two I think I will go ahead and test the system and install the boots at a later date.
Posted: Thu Aug 02, 2018 3:16 am
Got side tracked with a little trip to Seward yesterday. Today I found a cable boot and went ahead and finished hooking up the steering, filling the system and getting it bled. Probably will still need to get the last of the air out but at least it turns the outboard. One system at a time, getting closer to rat rod time.
Posted: Thu Aug 02, 2018 5:25 am
by OrangeQuest
Had to go get more popcorn waiting!!
getting closer to the water!!!
Posted: Thu Aug 02, 2018 3:59 pm
OrangeQuest wrote: ↑Thu Aug 02, 2018 5:25 am
Question is are you guys watching to see this pig float or sink
Either way if I can be ready in the next week there will be a couple of witness’s.
Posted: Thu Aug 02, 2018 4:51 pm
by OrangeQuest
Oh, no doubt it is going to float, it is going to float!! It's is always very exciting to hear/see a boat launch after following what and how things were done to it. We are all there with you feeling the build up of splash day and expecting great results. As a beginner I get excited as a build/repair gets closer to the water.
Posted: Thu Aug 02, 2018 6:14 pm
by TomW1
Five bucks it floats.
Another ten it will not go faster than 25mph.
Posted: Thu Aug 02, 2018 10:24 pm
Well we will hope it floats
Pretty sure AA and CapeMan will not be very pleased with me if they get dunked in a glacier fed lake
I would take those bets Tom but I do not want to bet against myself on the first part. And the second part I need to ask if you understand it will have 200hp on the transom
Heavy as a pig or not if it will not do over 40 I am going to be really disappointed
Posted: Fri Aug 03, 2018 6:17 pm
by Aripeka Angler
Fuzz wrote: ↑Thu Aug 02, 2018 10:24 pm
I’m officially on vacation as of 15 minutes ago, woo hoo!! It’s been a long run without any time off...Looking forward to 40ish degree weather.
I’ll be heading your way in 59 hours and 27 minutes.
I’m not counting though...
Can’t wait to see the Sintes, I bet she will do 40 or we will have to just say she did and take their money.
Looking great, see you soon!
Posted: Sat Aug 04, 2018 3:26 am
Got bad news for you AA
Been dang hot around here the past few days, it hit mid 70's today. Good news is it supposed to cool down a little in the next few days. Drop me a line when you get to Primrose and settled in.
On the boat front I got a few more items knocked out today. With a little luck either tomorrow or Sunday afternoon I will be able to put a little fuel in her and see if it will make smoke
Posted: Sat Aug 04, 2018 4:41 am
by glossieblack
Go Fuzz!
Posted: Sat Aug 04, 2018 5:48 am
by Jaysen
Just to level set the expectations...
Smoke from internal combustion or smoke from you intentionally setting fire to the hull to cover evidence?
Just making sure we know what smoke to look for.
Posted: Sat Aug 04, 2018 7:45 am
by cape man
6 days...
Posted: Sat Aug 04, 2018 8:24 am
by Jeff
Nice Cape Man!!!! Enjoy the trip!! Jeff
Posted: Sun Aug 05, 2018 2:38 am
Jaysen wrote: ↑Sat Aug 04, 2018 5:48 am
Well if you asked me today it would be from soaking it in gas
Thought I was going to light her up but if it could be a pain it was today. Oh well some days you win and some not so much. Still hoping to have it up and running sometime tomorrow. As SWMBO would say "we will see"
Liudmila and I are about ready to make a little road trip and gather us up some Cracker types
Posted: Mon Aug 06, 2018 11:37 pm
Cut a hole in the side today up near the gunwale for a bilge pump through hull. This is what it looked like, strong 5/8 to light 3/4 inch of glass. Not sure if this tank will float or not
Things sort of fell in place so I lit up the outboard. That part went well and seems like it might do its thing if it stays above the water
Posted: Tue Aug 07, 2018 4:59 am
by glossieblack
Good stuff Fuzz! Looking forward to hearing how the rat rods tests go.
Posted: Tue Aug 07, 2018 6:38 am
by cape man
4 days...
Posted: Tue Aug 07, 2018 4:19 pm
cape man wrote: ↑Tue Aug 07, 2018 6:38 am4 days...
Mila and I are also counting the days
Posted: Tue Aug 07, 2018 7:24 pm
Well she poked her nose out into the sunshine today. For those who never saw it she went from this
To this
Still a lot of finish work left but I do not want to go through another winter wondering if she will run or not.
Will know more in a few days.
Posted: Tue Aug 07, 2018 7:34 pm
by Jeff
Very cool build Fuzz!!! Can’t wait for some results in a few days!!! You guys have fun with your visitors/friends from the State of Florida!!!! Jeff
Posted: Tue Aug 07, 2018 10:17 pm
by glossieblack
This sure is a good news photo!
Fuzz wrote: ↑Tue Aug 07, 2018 7:24 pm
Posted: Wed Aug 08, 2018 12:09 am
Thanks Jeff and Glossie
AA is in Alaska now and will be ready for some fishing in a few days I bet. And Capeman and spouse are not far behind them. We are pretty pumped to see all of them.
Posted: Wed Aug 08, 2018 5:38 am
by OrangeQuest
Really looks like she is ready to see some water and she is looking good!
Posted: Wed Aug 08, 2018 7:01 am
by fallguy1000
Well thar she blows!
Good luck running it.
Let us know the details.
Posted: Wed Aug 08, 2018 7:23 am
by cape man
3...
Posted: Wed Aug 08, 2018 7:50 am
by Jaysen
Sure hope Mrs AA and Mrs Cape_man made those premium payments on y'alls policy this month.
Make sure someone gets vid evidence. We won't let fuzz get away without supplying some level of the boat porn.
Posted: Wed Aug 08, 2018 10:55 pm
by TomW1
Fuzz the boat looks great. Have fun with your Florida guests. Hope the fishing is good.
Posted: Thu Aug 09, 2018 2:21 am
TomW1 wrote: ↑Wed Aug 08, 2018 10:55 pm
So far this year the fishing has SUCKED
I am hoping it will turn around while the boys are here but we will see.
Tom I sent you a PM.
Posted: Thu Aug 09, 2018 2:22 am
cape man wrote: ↑Wed Aug 08, 2018 7:23 am3...
We are not counting the days are we
Posted: Thu Aug 09, 2018 6:27 am
by cape man
2...
Posted: Thu Aug 09, 2018 7:42 am
by topwater
Cape man you still suck
Posted: Thu Aug 09, 2018 8:26 am
by Jeff
Almost on your way CapeMan!! Jeff
Posted: Thu Aug 09, 2018 10:45 am
by cape man
Posted: Thu Aug 09, 2018 1:58 pm
by Aripeka Angler
I've already been here for 3 days.
Posted: Thu Aug 09, 2018 4:21 pm
by Jeff
AA, you guys enjoy yourself up there with Fuzz!!!! Jeff
Posted: Fri Aug 10, 2018 3:25 pm
by cape man
In Chicago for Anchorage flight. Hide the women and kids and lock up the animals!!
Posted: Fri Aug 10, 2018 3:36 pm
Dang you must have a long layover there
Posted: Fri Aug 10, 2018 3:43 pm
by Jeff
You guys have a great time!! Jeff
Posted: Fri Aug 10, 2018 3:45 pm
Thanks Jeff.
I sure hope everyone has a good time.
Posted: Fri Aug 10, 2018 3:55 pm
by Jeff
I am 100% confident that all of you will have a great time!! Jeff
Posted: Fri Aug 10, 2018 7:22 pm
by TomW1
Posted: Sun Aug 12, 2018 12:51 am
Off to do a little fishing with the Florida boys in the morning.
One complaint about them.............they are not worth a crap for bringing sunshine with them
Posted: Sun Aug 12, 2018 5:26 am
by glossieblack
Fuzz wrote: ↑Sun Aug 12, 2018 12:51 am
Enjoy.
Posted: Sun Aug 12, 2018 5:27 am
by OrangeQuest
Tight lines to all!
Posted: Sun Aug 12, 2018 7:27 am
by Jeff
Good luck OQ!! Jeff
Posted: Sun Aug 12, 2018 10:05 am
by Aripeka Angler
100% chance of rain, 48 degrees, 15 knot winds. Perfect
Posted: Sun Aug 12, 2018 10:08 am
by Eric1
Have fun y'all!
Posted: Sun Aug 12, 2018 10:20 am
by Jeff
48 in August!! Wow, that is a change!! Jeff
Posted: Sun Aug 12, 2018 12:13 pm
by TomW1
AA sounds like perfect fishing weather.
Posted: Sun Aug 12, 2018 11:50 pm
So we chose to NOT go fishing in Seward. It was not going to be any fun at all. After leaving the weather jinx in Seward we came back home to clear skies, wind less than 10mph and 70f for temps. Craig and I did not know what to do for the afternoon so we took the Sintes for a rat rod run.
She floats
She runs dry
After looking at her while running the motor is way too low but even with that we were able to top 30 knots at 4300 rpm. Going to raise it up some and give it another shot in the next few days.
Posted: Mon Aug 13, 2018 2:10 am
by narfi
Was thinking about you guys today. Was raining like crazy this morning then turned sunny and was hot all day then turn cloudy and rainy again tonight. Wondered if you got that same window of nice weather for your guests.
Posted: Mon Aug 13, 2018 2:47 am
narfi wrote: ↑Mon Aug 13, 2018 2:10 am
We meet AA and son in Seward in the morning. Weather was BAD. We came back home and the afternoon was great. I think AA brings bad weather
Florida folks should bring sunshine.........but nooo
Posted: Mon Aug 13, 2018 3:01 am
Just about to launch
Headed up the river testing out the kicker
Cruising up the river at about 30 knots.
With some fine tuning there is a ton of speed left in her. At least I know she works now
Posted: Mon Aug 13, 2018 4:13 am
by glossieblack
Fuzz wrote: ↑Mon Aug 13, 2018 3:01 am
Cruising up the river at about 30 knots. With some fine tuning there is a ton of speed left in her. At least I know she works now
Justf fanfuckntastic news Fuzz. Congrats. Make sure your cracker mates buy the drinks
Posted: Mon Aug 13, 2018 5:20 am
by OrangeQuest
Congratulations!
Posted: Mon Aug 13, 2018 6:40 am
by Eric1
The pictures are great! I hope you get some tight lines soon.
Posted: Mon Aug 13, 2018 8:08 am
by Jeff
Congratulations Fuzz, a build very well done!! I also might add that the water is beautiful!! Jeff
Posted: Mon Aug 13, 2018 11:09 am
by Jaysen
Make sure someone get's some video of that thing going "at speed". Bonus points of they get video of something being caught.
Posted: Mon Aug 13, 2018 1:04 pm
by cape man
Weather is challenging us, but this place is gorgeous. We are going to try and take the dory up the Kenai river today. Gale force winds predicted out of Homer. There's a lot of these REALLY BIG cervids walking around here! Pics to come.
David and his family are great hosts, even though his daughter cheats at cards.
Posted: Mon Aug 13, 2018 1:17 pm
by narfi
I love the look of the curved supports for the top.
Hope weather clears up a little for you, its a heavy downpour here right now.
Posted: Mon Aug 13, 2018 2:09 pm
by piperdown
Congratulations! Beautiful build!
While my sister and BIL live up there I sadly have not made the trip to Alaska.
Posted: Mon Aug 13, 2018 5:11 pm
by TomW1
Congratulations Fuzz. Beautiful place you live. I had a black bear and 4 deer in my yard yesterday.
Different times, different places of course.
Posted: Tue Aug 14, 2018 1:16 am
These Cracker idiots don't know crap about a good boat, and check out that jerk hogging the center of the picture, leaning on the trailer like its his!!!
Then the jerk says he's gonna help me fair the hull and spends 30 minutes focusing on a little blip on the corner of the transom!
(Cape Man posting as Fuzz....).
Posted: Tue Aug 14, 2018 1:25 am
by glossieblack
Now that's funny CM.
Posted: Tue Aug 14, 2018 1:49 am
by cape man
First, gonna rotate that pic... After all, it was 30 minutes of work.
And if you want to see something really funny...
Posted: Tue Aug 14, 2018 2:26 am
Was going to try fishing today but the weather jinx came to visit this morning. This afternoon we have a full gale.........................just saying
Posted: Tue Aug 14, 2018 4:27 am
by Aripeka Angler
Fuzz,
We all enjoyed our visit today.
The Sintes looks awesome!!!
We absolutely destroyed the coho salmon over at Big River Lake when we left you guys.
Saw a few tons of moose and 6 or 8 brown bears.
I’ll post pics soon....
Posted: Tue Aug 14, 2018 7:05 am
by Jaysen
Let’s see... which one might be Fuzz? The ones in long sleeves/jackets inside it the one on short sleeves?
I thought cape man didn’t own long pants...
Posted: Tue Aug 14, 2018 7:28 am
by Eric1
HA! And y'all give me grief about sanding!!
Great pictures! Please no more photos of your Morning wood.
Posted: Tue Aug 14, 2018 7:48 am
by Jeff
Great photos guys and sure looks like you guys are having a great time!! Jeff
Posted: Tue Aug 14, 2018 1:07 pm
by narfi
Fuzz wrote: ↑Tue Aug 14, 2018 1:16 am
Glad you dressed up for their visit!
Co-workers this morning told me that we are getting the left overs from a Chinese typhoon.
Transom corner is looking good too!
Posted: Thu Aug 16, 2018 6:12 pm
by TomW1
Hey Fuzz no reports? What are you and capeman doing?
Posted: Thu Aug 16, 2018 6:40 pm
by Jaysen
Tom, he may be avoiding culpability by not posting what they are doing.
Just a thought.
Posted: Thu Aug 16, 2018 10:21 pm
Been in Seward the past two days. Going to Homer tomorrow. Will post some Friday I am guessing. Craig has some good pictures he might post.
Posted: Sat Aug 18, 2018 4:17 pm
by cape man
We are waiting for a flight to Anchorage from Kenai. David and Mila were more than gracious. At breakfast I spoke of the similarities between fish and house guests...
Caught my first Pink salmon on the Kenai river, and we caught some gorgeous Coho fishing two days out of Seward. Yesterday we caught a limit of halibut out of Homer. Have a 42 lb box of vacume sealed filets checked as baggage. Saw lots of moose, sea otters, seals, eagles, puffins, etc. Pics to come.
It's mid 50's this morning and 86 back home...
1 night in Anchorage and the red eye home tomorrow night.
Oh...and I now want a 20' Sintes
Posted: Sat Aug 18, 2018 10:11 pm
SWMBO had to show she could catch fish as good as the Florida boys.
And this guy was able to keep things interesting
We really enjoyed having Craig and Patti for guests. Seeing Richard, Sandy and their team again was very nice also. Just wish all of them had more time to spend here.
Posted: Sun Aug 19, 2018 5:43 am
by Eric1
Nice vPictures Fuzz.I'm glad y'all had a good time.
Posted: Sun Aug 19, 2018 5:59 am
by OrangeQuest
Some really nice fish!
Posted: Sun Aug 19, 2018 9:32 am
by Jeff
Fuzz, looks like all of you had or are having a great trip to your part of the world!! Jeff
Posted: Sun Aug 19, 2018 6:19 pm
One more here. This would be a Seward fashion statement.
The weather was not the best for sure but I think all in all our visitors had a good time. I know they will be missing the cool weather their first few days home
For some reason I did not have a scale on the boat but several of the silvers went 28-29 inches long. By any standard those were nice salmon.
Posted: Mon Aug 20, 2018 4:07 am
by glossieblack
Interesting and happy people, impressive fish, and stunning seascapes! You're a deadset cert to win the 2018 bateu2 boat porn of the year award Fuzz!
Posted: Mon Aug 20, 2018 4:41 pm
by cape man
Home. 90 degrees in the shade. Freezer full of salmon and halibut. Cell phone getting repaired (fell off the truck). Red eye tired but we are powering through. Awesome trip and the Sintes is going to scream when the motor is raised.
Posted: Mon Aug 20, 2018 7:16 pm
by Jeff
Glad you guys had a great trip/memory!! Beautiful photos showing some really happy folks!!! Really good stufff Fuzz!! Jeff
Posted: Tue Aug 21, 2018 1:45 am
Jeff wrote: ↑Mon Aug 20, 2018 7:16 pm
Thanks Jeff. From what I can tell everyone had a good time. The weather was not the best but we were able to work around most of it. We still had a bunch of stuff we wanted to do but like all/most vacations time ran out too soon.
Posted: Tue Aug 21, 2018 1:47 am
glossieblack wrote: ↑Mon Aug 20, 2018 4:07 am
Dude that sexy beast you are building is in a totally different class than the rest of us. Nice of you to say but it ain't happening
Posted: Wed Aug 22, 2018 3:20 am
One more picture of some little halibut with Capeman
Posted: Wed Aug 22, 2018 3:24 am
Raised the motor up three holes and gave it a try today. Picked up another 5 mph and 500 rpm. Still too low so I am going to need to do a little transom work this winter.
Posted: Wed Aug 22, 2018 7:34 am
by Jeff
Fuzz, you will get there!! Good catch with CapeMan!! Jeff
Posted: Fri Aug 24, 2018 5:27 pm
by TomW1
[quote=Fuzz post_id=429794 time=1534922691 user_id=5406
Sent you a PM
Posted: Sat Aug 25, 2018 8:04 am
by cape man
Unrelated to the Sintes, on the Kenai river fishing for Pinks, the value of a 1" spray rail on an OD18 was proven to me. Trying to decide when and how to install on mine.
How high did you get the motor without modifying the transom? Before you go crazy on getting it higher you might put a set of fins on the lower unit and see what it does to the porpoising.
Shared some Coho with the neighbors on Wednesday. Don't think those Crackers have ever seen fish like that! While I'm a huge supporter of farmed fish, they can't compete with those fat Silvers beyond cost and availability.
Posted: Sun Aug 26, 2018 1:13 am
cape man wrote: ↑Sat Aug 25, 2018 8:04 am
Wind was blowing and we had a pretty good chop at the river mouth. Everyone was taking a little more cool water than was fun. I was trying to ease my way and not drench us when Craig said speed up and get on top of this. Once I did as directed the splash rails did their thing and no more water in the face.
Anyone building a dory really needs to put good splash rails on it.
Posted: Sun Aug 26, 2018 1:23 am
For years the salmon industry has been shooting themselves in the foot. They send the good stuff overseas and then try to dump the trash on Americans who did not know better. Canned pinks are best fed to the pets. I have seen fish called "Silver-Brights" in stores down south. After looking close at them they were Chum salmon. Chum's are also called "dog salmon" and for a reason. The natives have always caught and dried them to feed to their dogs in the winter. It is a shame as folks try salmon, don't like it (I would not either) and will never try it again. All without ever having tried the good stuff.
Posted: Sun Aug 26, 2018 1:45 am
There has been some discussion of porpoising so here is the story.
When Capeman and I took it out for a rat run she would porpoise bad anything over 30. I tried moving my 240 lbs to the bow and it dang near tossed me out
Engine was clearly buried and would only reach 4300 rpm.
I raised the motor all I could, 4 holes, and tried it again. This time the av plate was still buried but was able to reach 4800 rpm and 35 before the porpoising got out of hand. So now I have taken the Bob's jack plate off of my dory and put it on the sintes. With the jack plate I will be able to raise it more than enough. I think I will start way too high and work my way down as needed.
I knew from the start when I built the bracket it might be a problem and was willing to take the risk. I have not and will not ask JM for his advise as he wants nothing to do with homemade brackets and for very good reasons. Early on I said if it does not work I would cut it off and make it a standard transom and that is what I will do if I can not get her lined out. A fin and trim tabs will be tried before I go the saw route
Posted: Sun Aug 26, 2018 7:23 am
by Jeff
Fuzz, keep us updated and I hope the jack plate works for you!!!! Jeff
Posted: Sun Aug 26, 2018 7:29 am
by topwater
Fuzz start with an 1 inch above hull bottom for every foot back from the transom . Thats a good starting point
you will probably be able to go higher but that also depends on the prop . Don't know what you are running for a prop
but a 4 blade will give you more lift at the transom and help keep that nose down. Tom will straighten you out if needed.
Posted: Sun Aug 26, 2018 9:32 am
by glossieblack
Go Fuzz! Experiment - test, evaluate and refine. Is there a better or more enjoyable reason to DIY boat build?
Posted: Sun Aug 26, 2018 1:25 pm
Thanks Guys
As you say Topwater I have a 4 blade prop on it now. I thought I had the motor high enough but must have been cross eyed or something. First thing AA said was the motor needed to go up............a bunch. So now with the jack plate installed I should be able to go up plenty. Just need the weather to allow me to do some more testing. I really want to see if I can get her to run right without resorting to a fin or tabs but we will see what happens.
Posted: Tue Aug 28, 2018 11:06 am
by cape man
You definitely need a scale on your boat! I think we might have been close on a few of those silvers...
https://www.adn.com/outdoors-adventure/ ... continues/
Posted: Wed Aug 29, 2018 12:52 am
Only problem with having a scale on the boat is it makes it harder to keep a straight face when telling a good fish story
Took a run to Homer with SWMBO today. She wanted to fish and did not want to hear about the weather.........girl likes to fish
Had 6-8 foot rollers on the nose and then the wind started to pick up. All of a sudden she says maybe we could go home and try it another day
Posted: Wed Aug 29, 2018 5:36 am
by OrangeQuest
Fuzz wrote: ↑Wed Aug 29, 2018 12:52 am
Even she has her limits!
Posted: Wed Aug 29, 2018 8:05 am
by Jeff
Fuzz, that is tough water!! You guys stay safe up there!! Jeff
Posted: Thu Aug 30, 2018 1:02 am
Jeff wrote: ↑Wed Aug 29, 2018 8:05 am
Thanks Jeff! We have tried to learn not to push things too far any more.
On the Sintes front I got the motor raised enough that the av plate is just showing when running. I was amazed how far it needed to come up but up it went. Results were good but not perfect. 39.2 mph and 5400 rpm before she started to bounce. With my bracket I think she is just a little too tail heavy. I do not have anything forward of the mid point at this time. I thought of putting a couple hundred pounds of sand bags in the nose but I wanted to see what happened first. As of now I am thinking a set of trim tabs would take care of things if I can fit them in.
Posted: Thu Aug 30, 2018 6:20 am
by cape man
Did it get rid of that funky wake?
Posted: Thu Aug 30, 2018 11:10 am
Funny you ask that. My buddy that went with me noticed the wake and said it was the smoothest one he had ever seen a boat leave.
Posted: Thu Aug 30, 2018 11:33 am
by narfi
Sounds like you are getting closer!
Posted: Thu Aug 30, 2018 11:46 am
by cape man
Sweet! Sounds like you are getting there! Even though the boat is heavy given the construction method, you do have a lot of weight and power on her ass! I think Richard is right...trim tabs are in her future.
Posted: Thu Aug 30, 2018 12:42 pm
So what brand of tabs do you guys like? Electric or hydraulic?
Posted: Thu Aug 30, 2018 1:46 pm
by Jeff
Fuzz, When you figure out what you need, give me a shot as I might be able to get you a better price on the tabs!! Talk with AA & CapeMan as they can advise and I can get several of the best manufacturers!! Jeff
Posted: Thu Aug 30, 2018 5:28 pm
by TomW1
Hey Fuzz raise the motor to where your getting ventilation at speed on a sharp turn and back down 1/2 inch. That is where you need to be. Once you have that we can dial in the pitch you need. Record your rpms there also.
Posted: Thu Aug 30, 2018 11:19 pm
Tom it might be a while for the prop. I think I am right where I need to be for the height but I do not know about the prop. I was seeing 5400 rpm and still climbing when it started to porpoise enough to make me back off. I think 5400 is in the lower end of the recommended range so I will live with things until I get her all dialed in.
Jeff thanks for the heads up. When I figure out what I need and see if it will fit I will give you a call.
Posted: Thu Aug 30, 2018 11:23 pm
by fallguy1000
I have some tabs that were on a 24', but ram condition is unknown.
I could send them to you. Pretty sure the pump was trashed and I have no controls.
I could also just cut em up for backers, but seems wrong.
I can post a picture if you like. Thought they were a little wide.
Posted: Fri Aug 31, 2018 1:17 am
fallguy1000 wrote: ↑Thu Aug 30, 2018 11:23 pm
That is a very generous offer Fallguy
I think I will pass. I am pretty sure I would have more time and maybe money in them than just buying a complete new set. This is one of the things I envy you folks down south for, you have outlets for good used parts and can find stuff. No such luck around here.
I am interested in hearing others choice in type and brand of tabs. I have only had one set so not much personal knowledge to draw from.
Posted: Fri Aug 31, 2018 4:57 am
by Eric1
I've only had Bennett on my boats. Never know anyone that had the electric. I'm curious too Fuzz.
Posted: Fri Aug 31, 2018 7:06 am
by cape man
Never had trim tabs, but will be interested to see what folks recommend. Thinking the SC16 might need a set.
Posted: Fri Aug 31, 2018 8:34 am
by topwater
Cape man if you put tabs on the SC you will get 11 mph
Posted: Fri Aug 31, 2018 2:01 pm
by TomW1
Fuzz looked up the power band for the Mercury Four Stroke 200. It shows a range from 5000 to 5800 rpms so you are right in the middle of the range before you begin porpoising at 5400.
As far as trim tabs I would not worry about them as you have said that you will rarely run at full speed any way. You didn't say what your speed was at 5400 rpms but if your happy with that the cost of trim tabs will not be worth it for you. You can always add them later if you want.
Posted: Fri Aug 31, 2018 10:44 pm
by Aripeka Angler
Fuzz wrote: ↑Thu Aug 30, 2018 12:42 pm
Hydraulic tabs are all I have ever used on 3 of the 4 offshore type boats I have owned, all were bought new.
My GW 1996 26’ Islander had Bennett tabs. They worked great but would blow a fuse every time you tried to tab up the starboard side while simultaneously tabbing down the port side. Once I figured out this was a bad idea, I never had another problem. Bennett fixed this issue eventually.
Had a year 2000 model 3000 offshore Pursuit with Lenco tabs, no issues. Smooth, worked great.
Our current boat is a 2004 model 2670 Pursuit with Bennett hydraulic tabs, I have not touched them or done any maintenance to them whatsoever in 14 years.
Posted: Sat Sep 01, 2018 12:36 am
Thanks AA. I am pretty sure I will skip the electric tabs as it just feels like they could be more problems.
from all I have read both the Bennett and the Lenco tabs are good and both companies support their stuff really well. Cost seems to be about the same also.
Posted: Tue Sep 11, 2018 1:06 pm
by tcason
I have had great customer support from Bennett - They rebuilt a hydraulic unit for me at no cost and walked me through a electrical issue and again sent free part to fix the issue. This is on a 15 year old boat with over 1500 hours.
I also installed the Self-Leveling Tabs on my Garvey 13 and it corrected my porpoising at full throttle and improved hole shot.
Posted: Mon Sep 17, 2018 11:30 pm
Jeff and Jaysen were talking about our weather her now so this is what it looks like.
Our fall does not last very long. Old man winter is just around the corner. But the past few weeks have been very nice. I would say the best weather of the year.
Posted: Tue Sep 18, 2018 4:58 am
by Eric1
Nice picture Bro. I think fall is the best time of the year.
Posted: Tue Sep 18, 2018 5:03 am
by cape man
That looks like a Russian tree...
Posted: Tue Sep 18, 2018 8:15 am
by Jeff
Beautiful Fuzz!! Glad you guys have had some really nice weather before the real cold gets there!! Jeff
Posted: Sun Oct 14, 2018 9:19 am
by Bogieman
Posted: Sun Oct 14, 2018 1:48 pm
Thanks Boogieman and Jeff. Looks like my weather is better than Fallguys is
Posted: Mon Oct 15, 2018 8:05 pm
by TomW1
Any updates?
Posted: Tue Oct 16, 2018 12:45 am
I have been getting ready for freeze up. I do not think I will be messing with it anymore for a couple of months but thanks for asking.
Posted: Tue Oct 16, 2018 6:22 am
by cape man
Getting ready for mornings below 70 here....
Re: Sintes 21 Rebuild
Posted: Tue Oct 16, 2018 7:43 am
by Jeff
Fuzz, we are still in the high 80'S & 90'S here in Florida!! You stay warm!! Jeff
Posted: Tue Oct 16, 2018 4:23 pm
Thats the way it goes. You guys have been cooking and now the best half of your year is about to start. Well that is IF the hurricanes give you guys a break. We have had our nice weather and now have to pay the piper
Posted: Tue Oct 16, 2018 5:28 pm
by OrangeQuest
It went from 90's to the mid 50's here in Houston area.
Posted: Tue Oct 16, 2018 10:52 pm
OrangeQuest wrote: ↑Tue Oct 16, 2018 5:28 pm
Dang 50's in Houston
Are you folks keeping EMS busy with hypothermia calls
Posted: Wed Oct 17, 2018 5:55 am
by OrangeQuest
Fuzz wrote: ↑Tue Oct 16, 2018 10:52 pm
It is a shock to the system! Now is the time to buy summer clothes!!
I have to work a venue this weekend and stand in the water waist deep for 8 hours. I am going to be wearing my rubber pants!
Posted: Fri Oct 19, 2018 1:27 am
This is a pretty good clue the boating season is over.
Cape Cleare to Gore Point-
346 PM AKDT Thu Oct 18 2018
...STORM WARNING THROUGH FRIDAY...
.TONIGHT...E wind 35 kt becoming NE 60 kt with gusts to 70 kt after
midnight. Seas 12 ft building to 26 ft after midnight. Rain.
.FRI...NE wind 55 kt becoming W 40 kt in the afternoon. Seas 25 ft
subsiding to 19 ft in the afternoon. Rain showers.
.FRI NIGHT...W wind 40 kt. Seas 19 ft.
.SAT...SE wind 30 kt. Seas 13 ft.
.SAT NIGHT...E wind 35 kt. Seas 19 ft.
.SUN...SE wind 35 kt. Seas 24 ft.
.MON...E wind 15 kt. Seas 13 ft.
.TUE...E wind 15 kt. Seas 7 ft.
Posted: Fri Oct 19, 2018 5:57 am
by Jaysen
What I think you’re saying is that it will be a bit lumpy on the water.
Those sound like hurricane conditions. How does that present over land? Wind and snow?
Posted: Fri Oct 19, 2018 6:29 am
by cape man
Take the Dory out! Be a man!
Posted: Fri Oct 19, 2018 7:16 am
by Jaysen
cape man wrote: ↑Fri Oct 19, 2018 6:29 am
I was going to say something similar but then I realized I’m the guy that really shouldn’t poke fun like that. Someone will make a similar statement in my direction and my wife would be widowed. Mostly because I’m stupid and WOULD take it as a challenge.
Of course Mrs Fuzz may be encouraging similar behavior...
Posted: Fri Oct 19, 2018 8:00 am
by Jeff
Wow Fuzz, that is some serious seas!!!!! I agree, the boating season is over for you guys!! Still high 80's & low 90's here in South Florida!!! Waiting for the fall!! Jeff
Posted: Fri Oct 19, 2018 12:13 pm
Jeff wrote: ↑Fri Oct 19, 2018 8:00 am
Well high 80's is getting closer to liveable conditions but not quite there yet. 70s and then we are talking
I am pretty sure you guys look forward to fall like we do to spring.
Posted: Fri Oct 19, 2018 12:26 pm
Jaysen wrote: ↑Fri Oct 19, 2018 7:16 am
My days of having to be on the water no matter the weather are in the past. And to tell the truth I do not miss that part at all. The dory would probably do just fine if it had much bigger scuppers. And you had a snorkel while driving. I am pretty sure the top 4-5 feet of the waves is getting blown off today. If one of you wish to show me how well the dory can do I will gladly loan it to you but I aint going with you
As for on land I woke up to no power this morning. The root system for the trees here is all on the surface. They only go down maybe 3 feet so high winds blow lots of them down. After freeze up they can stand a lot more wind. The power crews get lots of practice and are normally pretty quick at getting the power back on.
Posted: Fri Oct 19, 2018 12:59 pm
by Jaysen
Fuzz wrote: ↑Fri Oct 19, 2018 12:26 pm
Dang it fuzz! now I feel like I have to go get a ticket and take you up on that!
Posted: Fri Oct 19, 2018 5:24 pm
by Aripeka Angler
Based on the weather forecast, it looks like it’s laying down.
Posted: Fri Oct 19, 2018 6:11 pm
by OrangeQuest
Posted: Fri Oct 19, 2018 9:23 pm
Aripeka Angler wrote: ↑Fri Oct 19, 2018 5:24 pm
Yes indeed all it needs to do is cool down a little and it would be a double A fishing day
Posted: Sun Oct 21, 2018 8:19 pm
by Aripeka Angler
Fuzz wrote: ↑Fri Oct 19, 2018 9:23 pm
I literally read your weather forecast every day vicariously wishing for some cool weather...
Posted: Mon Oct 22, 2018 9:35 am
by cape man
This is one reason to make sure you have the right prop on and the motor works!
https://www.wideopenspaces.com/video-ye ... ium=manual
Posted: Mon Oct 22, 2018 2:31 pm
Aripeka Angler wrote: ↑Sun Oct 21, 2018 8:19 pm
Funny how that works. I have Dade City on my weather apt. I see it has just cooled to the point I would be happy.
Posted: Mon Oct 22, 2018 2:32 pm
That is a great video CapeMan
It is amazing how fast they are when they want to move.
Posted: Mon Oct 22, 2018 8:10 pm
by Aripeka Angler
cape man wrote: ↑Mon Oct 22, 2018 9:35 am
Besides the motor working it’s also important that the expert recommended prop actually turns the correct way...
Posted: Mon Oct 22, 2018 8:47 pm
Boy am I happy I was not drinking coffee when I read that
Posted: Tue Oct 23, 2018 6:58 am
by cape man
Posted: Tue Oct 23, 2018 8:50 am
by topwater
I am not even going to ask
Posted: Tue Oct 23, 2018 8:58 am
by Jaysen
topwater wrote: ↑Tue Oct 23, 2018 8:50 am
I'll bite...
Aripeka Angler wrote: ↑Mon Oct 22, 2018 8:10 pm
My imagination is running wild on this. Someone find Lucy so she can 'splain it.
I miss that show.
Posted: Tue Oct 23, 2018 6:21 pm
by Aripeka Angler
Great idea, don’t ask don’t tell.
Posted: Sat Nov 10, 2018 2:00 pm
by Bogieman
Posted: Wed Nov 28, 2018 7:08 am
by Bogieman
Fuzz wrote: ↑Mon Dec 12, 2016 1:39 am
fallguy1000 wrote:Does that boat have the c-flex?
Edit - I see that it does..Starting to look good. Yeah, that air gap is a good insulator for temporary work.
This is the first C-Flex boat I ever built. It was not a bad way to go 30 years ago but not sure it still is. I do know it is now where as much fun as they way they are done here. Plus there is no support group like here and that makes a world of difference.
When I was much younger and full of energy I build this one also. It is 32x13. Not a very good finish on it but not needed for a work boat.
Hi Fuzz!
Was perusing your thread when I came across this beautiful behemoth. Very nice looking boat. Bet this one took a while to build. Looks like she could handle almost anything.
Hope all is well,
Bogie
Posted: Wed Nov 28, 2018 2:23 pm
Hello Bogie,
It took me about 8 months to build it. But I was in my 30's and had two other guys helping me. They worked 8 hours a day 6 days a week. It was more like 12 hours a day 7 days a week for me
There is no way I have the energy to do it again at this point in my life
How is your project coming along? Are you still having fun?
Posted: Wed Nov 28, 2018 5:55 pm
by OrangeQuest
Man, I love the look of that hull! That thing looks like it was a brute!
It's hard to tell in the picture but is that snow or were you doing some sanding before Festool?
Posted: Wed Nov 28, 2018 9:45 pm
Posted: Wed Nov 28, 2018 10:08 pm
by OrangeQuest
I have seen a show on those guys out there. That is just crazy!
Posted: Wed Nov 28, 2018 10:19 pm
For a large part of my working career that is what I did for my "vacation" I got a promotion at work that forced me to make a choice either job or fishing. I took the job but I still miss the fishing. Kept the boat just in case I had the chance to go fishing again.
Posted: Wed Nov 28, 2018 11:04 pm
by cape man
I've seen it! It's a tank for sure!
Posted: Thu Nov 29, 2018 7:40 am
by Jeff
Fuzz, that is one tough looking boat!!!! Is she still in use? Jeff
Posted: Thu Nov 29, 2018 1:30 pm
Unfortunately not
The plan was to go back to commercial fishing when I retired but that has not worked out for a number of reasons.
Posted: Thu Nov 29, 2018 1:36 pm
by Jeff
Got it!! Jeff
Posted: Thu Nov 29, 2018 7:53 pm
by Bogieman
Fuzz wrote: ↑Wed Nov 28, 2018 2:23 pm
Hello Bogie,
Hi Fuzz!
Unfortunately I'm in a bit of a holding pattern as I'm saving up boat building funds to buy the rest of the plywood , flotation foam and more epoxy. It's going to take a few more months
I refuse to dip into any of our savings, instead I set $ aside every month until I reach my goal. I'm dreaming about her all the time.
Posted: Thu Nov 29, 2018 9:04 pm
by OrangeQuest
Bogieman wrote: ↑Thu Nov 29, 2018 7:53 pm
Hello Bogie,
Hi Fuzz!
Hang in there Bogie! Your funds will get there and you could always find something that needs sanding!
Posted: Thu Nov 29, 2018 9:09 pm
by Bogieman
OrangeQuest wrote: ↑Thu Nov 29, 2018 9:04 pm
Hello Bogie,
Hi Fuzz!
Thanks OQ!
Posted: Thu Nov 29, 2018 10:47 pm
Yeppers very few builders don't face budget issues one way or another. We are either short money or time. Sometimes both. Just hang in there and make a little progress when you can. And when finished you will feel a sense of accomplishment no one who buys will ever know.
Posted: Mon Dec 24, 2018 5:18 am
by glossieblack
Seasons greetings Fuzz. Looking forward to more Sintes 21 rebuild adventures in 2019.
Posted: Mon Dec 24, 2018 8:46 am
by Bogieman
Fuzz wrote: ↑Thu Nov 29, 2018 10:47 pm
Just found this and it's already a month old
. Guess my Detective skills have diminished since retirement
Anyway, thank you!
Merry Christmas to you and yours,
Bogie
Posted: Thu Feb 28, 2019 1:18 am
Well just to prove I have not been sleeping all winter. And to give Jaysen something to razz me about. I raised up the transom and modified the stern so I can put a set of trim tabs on.
Posted: Thu Feb 28, 2019 5:42 am
by cape man
Damn David. Stealth building is not allowed!
Posted: Thu Feb 28, 2019 6:19 am
by Jaysen
So your built a big hull around an fs14? I bet the horsepower required will be more than 15...
It might be too early to make jokes about the transom shape.
Posted: Thu Feb 28, 2019 7:19 am
by topwater
Tombstone comes to mind
Just kidding , how high did you raise it
Posted: Thu Feb 28, 2019 7:26 am
by fallguy1000
I have been wondering about this build. How far down are the knees or tie into the floor? Probably at the dexk eh?
It looks strong, but I forgot if you are hanging a 200 or a 425 back there.
Jist curious why you didn't wrap the thing around at the deck and build a box...
Have you seen that done up there?
Do you expect a lot of water ober the back that way? So then the sides of the splashwell are jist massive drains?
Posted: Thu Feb 28, 2019 2:49 pm
cape man wrote: ↑Thu Feb 28, 2019 5:42 am
Other than this I have been mostly just cleaning up ugly warts on her. As you well know there are plenty to keep me busy but there is not much interesting to show or be picture worthy. I do have some rubrail to install and will be posting about that.
Posted: Thu Feb 28, 2019 2:54 pm
topwater wrote: ↑Thu Feb 28, 2019 7:19 am
I made up two pieces of 1/4 inch glass and glued the plywood in between them. I raised things up 6 inches. That was about how far I had to go with my Bob's Bracket to get her to run right last fall.
Posted: Thu Feb 28, 2019 3:01 pm
fallguy1000 wrote: ↑Thu Feb 28, 2019 7:26 am
When I am done I will put a hatch over the hole you see on top now so being sealed it will not matter if water rolls over the bracket. I ran my stringers through the transom and out to the end of the bracket. I am running 200hp on her for now. That gives me around 40 mph so that is enough..........for now
Posted: Thu Feb 28, 2019 5:16 pm
by Aripeka Angler
I knew you were up to something.
Looks great and should work fine!
May see you this summer if it all shakes out...
Posted: Sat Mar 23, 2019 12:15 am
So Jaysen reminded me I was supposed to be doing something. I got trim tabs installed over the past few days. After spending so much time rebuilding the transom and making sure it was all sealed up it was tough to drill 12 holes in it below the water line. I over drilled the holes and filled with epoxy glue. When I was drilling the pilot holes I could tell I had voids. It is hard to pack filler in a hole and not trap any air. So I drilled them out again
The next time I used a syringe filled with epoxy glue and started at the bottom of the holes and worked my way out. After curing when I drilled the pilot holes I did not feel any voids
Still have some painting and clean up work to do but I am hoping this will keep her nose out of the air.
Posted: Sat Mar 23, 2019 6:39 am
by cape man
That looks like it will work.
Posted: Sat Mar 23, 2019 7:33 am
by Jaysen
I was beginning to think you just pushed her into the back yard to make a bear jungle gym.
A bit paint and then...? How long till you’re getting fish with her?
Posted: Sat Mar 23, 2019 7:40 am
by topwater
David i use a plastic bag
with a straw taped into the corner of the bag. That way thickened epoxy material comes out better.
Stick it into the back of the hole and slowly back out as you squeeze, have a piece of tape ready to
put on until hard. Worked well for me.
John
Posted: Sat Mar 23, 2019 2:26 pm
Craig It was getting close to running right last fall so I am hoping the trim tabs will tame the last of her bad habits.
Jaysen it will be around mid May before the fishing picks up around here. I can go winter King fishing but that is pretty hit and miss. Still it is better than nothing so I may give it a try depending on weather.
John I always use tape to hold the epoxy in place but I never though of a plastic bag and straw. That is a good one I need to remember it. Thanks for the tip.
Posted: Sat Mar 23, 2019 7:09 pm
by cape man
I bet you just solved it.
Posted: Wed Mar 27, 2019 10:37 pm
Never seen a gal that was not improved with a good looking tail.
I am trying something called Shark Skin for non skid. It is just sand like added to your paint. We will see how it works out.
Posted: Wed Mar 27, 2019 10:52 pm
by fallguy1000
I am real curious about shark skin and softsand.
Let us know how it does in traffic areas.
Do you guys have rockfish or bottom fish in winter? Or are they outta season or not there?
Posted: Wed Mar 27, 2019 11:20 pm
Most of our bottom fish move out into the Gulf in the winter. We are about two months from good bottom fishing. You can still catch them year around but they are fewer.
Posted: Thu Mar 28, 2019 7:52 am
by cape man
That looks too pretty for you!
Posted: Thu Mar 28, 2019 8:58 am
by Jeff
Nice Fuzz!!! Jeff
Posted: Fri Mar 29, 2019 1:17 am
It always amazes me how little things can turn into a total goat rope. I went to start hooking up things on the inside for my new trim tabs. The pipe nipples running through the transom are 3 inches long. By the time you screw into fittings on both ends you have 2.5-2.75 inches of usable pipe. Not enough for this girls tail
No problem go to town and get longer one right
Nope not around here............have to special order two 1/8 by 4 inch nipples out of Seattle
Posted: Fri Mar 29, 2019 5:13 am
by cape man
Posted: Fri Mar 29, 2019 6:59 am
by BB Sig
So how I read that was you don’t have enough for one fine tail. Went to town and everyone’s is short. Now you are trying to find 4" nipples?!
Alaska is full of problems!
I stopped Jaysen from having to do it!
Posted: Fri Mar 29, 2019 2:26 pm
BB Sig wrote: ↑Fri Mar 29, 2019 6:59 am
Drinking my morning coffee when I read this. Stopped and wiped up the area......................
And to think this came from someone other than Jaysen, that boy don't need this kind of help
On a different front I went winter king fishing with a buddy yesterday. Skunked again
It is really hit and miss this year so far. He went last Friday and caught 3. On Saturday they held the Homer winter king derby so he enters and goes back to the same area and gets nothing. Bad part is one of the fish from Friday would have won the derby and been worth 70K. I guess it is all about timing in life
Posted: Fri Mar 29, 2019 3:25 pm
by Netpackrat
At least he's not trying to rebuild a wooden boat up here. It's not easy to find a good piece of ash in Alaska.
Posted: Fri Mar 29, 2019 5:44 pm
by Jaysen
Netpackrat wrote: ↑Fri Mar 29, 2019 3:25 pm
Bah!
Although you might have one type...
Alaska is full of fuzzy problems...
Posted: Fri Mar 29, 2019 6:59 pm
by fallguy1000
Fuzz wrote: ↑Fri Mar 29, 2019 1:17 am
I don't even know what I'd do with a four inch long 1/8 inch nipple.
Posted: Sat Apr 06, 2019 1:44 am
Got my nipples today so will go back to working on the trim tabs in a day or two. In the mean time I started putting the rub rail on. Not sure if the bottom part works easier if it is warm or what but it was stiffer than the proverbial wedding dick.
Fought that sucker all dang day long. Sure hope putting the other part on is easier.
Posted: Sat Apr 06, 2019 8:05 am
by topwater
I am not saying a word
Posted: Sat Apr 06, 2019 8:24 am
by Jaysen
Wedding? Then how do I explain the days since then?
Posted: Sat Apr 06, 2019 9:12 am
by BB Sig
Using heat on things generally makes it more compliant.
Jaysen,
A good woman is the key to not having to explain that!
Posted: Sat Apr 06, 2019 10:14 am
by fallguy1000
Hot water bath. Keep the free end in the water.
Use a tote. Keep it hot.
Posted: Sat Apr 06, 2019 12:38 pm
by cape man
Looks awesome
Posted: Sat Apr 06, 2019 3:48 pm
I am sure heat would have helped but it is too late now. If I lived down south I would have laid it out on the driveway and got it to all lay flat. Working with it still curled up is a pain.
Good move John, and thanks Craig the Sintes will be ready and waiting for your next trip
Posted: Sat Apr 06, 2019 3:50 pm
by Jaysen
what’s the plan with London’s Legacy?
Posted: Sat Apr 06, 2019 6:44 pm
No plan at this point. we will see what the future holds.
Posted: Sat Apr 13, 2019 2:09 am
Got the rubrail installed.
I was pretty sure it would not go around the sharp edge at the transom but I went ahead and tried it as there was enough extra material. Just as I feared it would make the turn but looks like crap all puckered out.
So I think I will end the rail just short of the transom unless someone has an idea
Posted: Sat Apr 13, 2019 5:39 am
by OrangeQuest
Terminate looks like the best option. The rub rail doesn't look like it would help where it wraps around the corner anyway. I like the look though.
Posted: Sat Apr 13, 2019 5:53 am
by cape man
What if you cut a wedge out, right on the inside of the corner, but not all the way through? Call it a Kasilof Kerf. Worth a try if you are going to terminate it anyway. Dont think it will really work, but might...
Posted: Sat Apr 13, 2019 7:12 am
by Aripeka Angler
I think you might have cut the rigid backing strip a little short. The keyway that holds the flex on needs to almost touch the 90’ corner on both directions. About 1-1/2” short or less. Try pulling off the 4-5’ of the flex and add some scrap pieces of rigid backing. I’d try that before kerfing, that’s kinda permanent. You might have to trim back the existing backing so your add-on rigid strips can receive at least 3 screws.
Posted: Sat Apr 13, 2019 9:36 am
by Larry B
dont know if this will help, but here are a couple of pictures of mine. I believe I did as capeman mentioned, it's been almost 10 years
Anyway you can see I got the top part looking good, but the bottom I had to file/grind the bulge off. You can't see it normally so I'm happy with it.
Anyway hope it helps you? btw this I believe is the taco rubrail.
Posted: Sat Apr 13, 2019 10:36 am
Thank you for the ideas guys. I have a couple feet of extra material so I will try a few things before cutting the rail back.
Posted: Sat Apr 13, 2019 11:29 am
by fallguy1000
Fuzz wrote: ↑Sat Apr 13, 2019 2:09 am
Hull modifications necessary.
Show me a profile picture of the rubrail and I will tell you what to do. Basically, you'll need to put a relief in it right on the corner. Knife cut sorta thing..or you can try it on your own.. The relief would remove all the 90 degree sections that head back into the corner. I removed a rubrail on the old Starfire and they had relief cuts in it and it took a hard 90. I even have the stuff sitting out back, so I can take a picture if you like
Otoh, the rubrail looks a little silly in the wraparound, but it will not fall off that way...oh, I think you just haven't cut it off yet, so it looks silly
Posted: Sat Apr 13, 2019 2:37 pm
Larry B it is great to hear from you. How are you and that beautiful dory doing?
Posted: Sat Apr 13, 2019 3:01 pm
Fallguy I will post a picture later today.
I do not think I will get hit on the corners because the bracket sort of protects that area.
I have some good advice so now I just have to try some things.
Thanks again guys
Posted: Sun Apr 14, 2019 12:58 am
Here are the pictures of what the rail profile looks like.
Better one of just the rubber part
I have tried a couple things today but so far no joy. The big problem is trying to make a hard 90. If there was just a little radius like at the bow then even a 120-150 bend can be done. If you plan on using this rubrail make sure to round over that area
Posted: Sun Apr 14, 2019 8:05 am
by Bogieman
I think it'll look good wrapped around or cut off. The boat looks great, Fuzz!
Posted: Sun Apr 14, 2019 8:18 am
by fallguy1000
Based on what I saw on the Starfire, you would cut off the top of the base profile.
TT
To the bottom of the TT
And then you would cut off the lock tabs on the cap, but you could do the base first and try the cap before cutting the tabs.
You only do that for the very corner so when you look down the flat sections of boat have the base, but the corner has none. I am assuming you screw or glue the ends.
I am just waking up. After I get a cup of coffee, I will go see if I can trudge through our last 9" of snow and find the one I removed, but the concept is same.
Posted: Sun Apr 14, 2019 8:22 am
by fallguy1000
Take a picture of the base on the boat with the cap off and I will mark it up where I would cut it.
The Starfire used some adhesive on those spots, but it looked flawless. It was an aluminum base with rubber cap, so a bit different, but like I said, same concept. The corner can't have much profile out.
I can't post pics here, but I'll post the concept on my build thread. You probably get it, so forgive me if I am patronizing at this point.
Posted: Sun Apr 14, 2019 12:36 pm
by cape man
Check out Wouter's Phantom. Pretty slick...
Posted: Sun Apr 14, 2019 12:38 pm
Bogieman wrote: ↑Sun Apr 14, 2019 8:05 am
Thanks Boogie
Not sure how good it looks but I do know it is a lot better than when I first started.
Posted: Sun Apr 14, 2019 12:40 pm
Fallguy I have tried what you are suggesting but so far I am not happy with the result. I have a few more things to try.
Posted: Sun Apr 14, 2019 12:47 pm
cape man wrote: ↑Sun Apr 14, 2019 12:36 pm
That is my thought also. It looks great and will work just fine I bet. More than likely I will go that route
Posted: Sun Apr 14, 2019 12:53 pm
by OrangeQuest
You will really start messing with the "work boat" finish if you start making custom end pieces.
Posted: Sun Apr 14, 2019 9:42 pm
OrangeQuest wrote: ↑Sun Apr 14, 2019 12:53 pm
No chance I will make something a fancy as Wrouter or some of the other guys.
Posted: Thu Apr 18, 2019 2:21 am
Yesterday on Boogie's thread I posted a picture of a moose. Karl was surprised they would come that close to the house. This evening while I was out in the shop we got Narfi's snow
I walked out of the shop and saw fresh tracks in the snow. It was about dark but luckily I could make out momma moose and last years baby about 20 foot away. She was busy grazing and only gave me a brief glance. You just never know where the dang things will be.
Posted: Thu Apr 18, 2019 6:21 am
by Aripeka Angler
You got more moose than anyplace I have seen in AK.
Posted: Thu Apr 18, 2019 8:39 am
by Jeff
Good to hear from you Fuzz!! Hope Spring is in full bloom up there!! Jeff
Posted: Thu Apr 18, 2019 5:48 pm
Jeff wrote: ↑Thu Apr 18, 2019 8:39 am
It was looking good until I woke up to snow all over the yard
It has mostly melted now and the days are getting longer so spring is coming
Posted: Thu Apr 18, 2019 5:51 pm
Aripeka Angler wrote: ↑Thu Apr 18, 2019 6:21 am
I have heard it said that there is a higher concentration of moose in a 5 mile radius of here than any other place in Alaska. I do know it is not unusual for me to see over 20 moose on the way to town.
Posted: Thu Apr 18, 2019 5:52 pm
by TomW1
Dang Fuzz I only get deer and bear that close or closer. The deer I don't mind, the bear I tell the hunters about when they are in season.
Posted: Thu Apr 18, 2019 8:13 pm
by fallguy1000
Fuzz wrote: ↑Thu Apr 18, 2019 5:51 pm
Do you eat much moose meat? Never had it; assume it woukd be ground into a patty with pork and you could call it mork. What do I know? We can't seem to keep the population here in Mn. This thing called wolf.
Posted: Thu Apr 18, 2019 10:01 pm
Growing up we would eat about 1.5 moose a year. The other half always went to somebody who did not get one that year. There was no sport involved in moose hunting. It was a fall job that had to be done. Moose is pretty good eating but very lean. Ate a lot of moose and drank powered milk. Beef and whole milk tasted strange to me and I didn’t really like it. A moose is about like a whole cow. Way too much for two people so it has been a few years since I hunted for one. But if a legal bull wonders into the yard during hunting season he might be in trouble
Posted: Thu Apr 18, 2019 11:47 pm
by Netpackrat
Moose are delicious but processing one is a huge amount of work.
View from my driveway in east Anchorage one night a few years ago:
I backed up into my spot beside the house totally unaware he was there... Was a bit of a shock when I noticed him.
Fuzz wrote: ↑Thu Apr 18, 2019 10:01 pmAte a lot of moose and drank powered milk. Beef and whole milk tasted strange to me and I didn’t really like it.
Yeachh.... Substitute salmon for moose and you just described my childhood. I
will not drink milk and will only reluctantly consume salmon to this day.
Posted: Thu Apr 18, 2019 11:56 pm
by Netpackrat
Posted: Fri Apr 19, 2019 8:53 am
by Jeff
NetPackRat, that is a HUGE Moose!!!! Jeff
Posted: Sun Apr 21, 2019 5:06 am
by Aripeka Angler
Happy Birthday and happy Easter to you David.
Sandi sends her birthday wishes as well.
Have a great day!
Posted: Sun Apr 21, 2019 5:22 am
by OrangeQuest
Happy birthday!
Posted: Sun Apr 21, 2019 5:33 am
by cape man
Damn! You still celebrating birthdays?
Posted: Sun Apr 21, 2019 7:50 am
by topwater
I think he's gone past his sell by date
happy birthday
Posted: Sun Apr 21, 2019 8:30 am
by Aripeka Angler
topwater wrote: ↑Sun Apr 21, 2019 7:50 am
happy birthday
Posted: Sun Apr 21, 2019 11:23 am
by glossieblack
Yes happy birthday Fuzz!
Posted: Sun Apr 21, 2019 12:47 pm
Thanks Guys.
Not sure if it is the years or the miles but they are starting to add up so I feel them
Topwater wins the best line award
Posted: Sun Apr 21, 2019 2:02 pm
by TomW1
Happy birthday Fuzz. Many more just time to stop counting them
Posted: Sun Apr 21, 2019 2:16 pm
by BB Sig
Happy Birthday!
Posted: Sun Apr 21, 2019 5:26 pm
by Jaysen
I’ve been thinking about it all day and I can’t beat topwater.
I will congratulate you on avoiding a few serious perils over the last solar orbit...
1. You didn’t become bear food
2. You aren’t orca fodder yet
3. You didn’t become decoration on the exterior of a moose
4. No Russian hit men received “the contract”.
Hopefully the next year will be as fortunate for you.
Posted: Sun Apr 28, 2019 3:58 pm
The flu and life in general have slowed down boat work for the past week. Speaking of work an old buddy asked me to help him out by running a piece of equipment part time for him. Do any of you guys know what it is
Posted: Sun Apr 28, 2019 5:58 pm
by fallguy1000
I'm thinking a pile driver or a drill, but looks like a pile driver.
Posted: Sun Apr 28, 2019 6:00 pm
by fallguy1000
Oh shoot. Is that a dredge of some kind? I jist saw the bucket.
Just never saw one with all those stays.
Posted: Sun Apr 28, 2019 6:23 pm
by cape man
Log skidder
Posted: Sun Apr 28, 2019 7:30 pm
Dang Cape Man you hit it on the head
Fallguy was close too. It is an old log skidder that has be converted to work like a dredge. There is a layer of gravel about 40 foot thick under the water out in the swamp. My buddy is trying to mine the gravel in an environmentally friendly manner. He has a concrete company and needs the product to feed the plant.
Not really a boat deal but it will provide me "free" boat bucks
Posted: Thu Jun 27, 2019 1:40 am
I have been bad about posting updates, sorry
I spent some of my dredge money and got new top mount controls for my Mercury. Got everything hooked up and working except the trim. Trim works back on the motor but not at the console
Posted: Thu Jun 27, 2019 1:41 am
Storage doors on my seat
Unlike some folks I do not clean up before taking pictures
Posted: Thu Jun 27, 2019 1:43 am
Sky light over mommas potty area
Posted: Thu Jun 27, 2019 1:46 am
Have to do some trailer work so I blocked her up and got the trailer where it is easier to work on. You can see the new rubrail. It is not perfect but will do for a work boat.
Posted: Thu Jun 27, 2019 2:21 am
by narfi
I had forgotten how much I like your curved box pillars.
Posted: Thu Jun 27, 2019 5:27 am
by Aripeka Angler
Fuzz wrote: ↑Thu Jun 27, 2019 1:46 am
This looks a lot better than a work boat.
Very nice!
Posted: Thu Jun 27, 2019 5:56 am
by glossieblack
Agree with Richard. She's looking great!
Posted: Thu Jun 27, 2019 6:02 am
by cape man
Glad you thought of working on the trailer before you bring her down to Florida.
Posted: Thu Jun 27, 2019 7:04 am
by OrangeQuest
She is a beautiful boat!
I am going to adjust my standard on "work boat" finish!
On my R/C tug boats I would tell people that the "tug is a work boat, so there will be areas of damage and quick repairs"
Posted: Thu Jun 27, 2019 7:47 am
by topwater
Kinda looks like a PT boat from that angle, where are the torpedos
Posted: Thu Jun 27, 2019 8:10 am
by piperdown
That's a good looking boat Fuzz!
Posted: Thu Jun 27, 2019 8:20 am
by Jeff
Fuzz, that is a great looking boat and far from a work boat!! Really well done!! Jeff
Posted: Thu Jun 27, 2019 8:47 am
by Jaysen
We clearly need an “unbiased” witness to verify the “workboat” on that boat. I volunteer.
Posted: Thu Jun 27, 2019 11:33 am
Thanks to all of you guys
You know the drill, pictures can lie. She has lots of warts I am not happy about.
Gives me something to shoot for on the next one
Hoping to get her done and take her out for a little shake out run in the next couple of weeks.
Posted: Thu Jul 04, 2019 12:51 am
I decided I did not like the guppy mouth look
So a little sanding and a little paint we have a new look.
Posted: Thu Jul 04, 2019 6:14 am
by Aripeka Angler
Much better.
Is the plan to use this boat for your excursions to Resurrection Bay?
Posted: Thu Jul 04, 2019 11:47 am
I think just about anywhere when the weather is warm.
Posted: Thu Jul 04, 2019 11:59 am
by cape man
So out of state trips?
Posted: Thu Jul 04, 2019 12:05 pm
A centre console model would look good parked at your house
Posted: Thu Jul 04, 2019 12:14 pm
by Jaysen
I’ve been told that you can ship things over land.
Posted: Thu Jul 04, 2019 1:00 pm
by Aripeka Angler
We could drive it down. I’ll chip in for gas.
I can promise you it’s plenty warm enough here for your liking.
Posted: Thu Jul 04, 2019 3:59 pm
Jaysen wrote: ↑Thu Jul 04, 2019 12:14 pm
You are just trouble
Posted: Thu Jul 04, 2019 4:05 pm
Aripeka Angler wrote: ↑Thu Jul 04, 2019 1:00 pm
Craig seems to really like the hull. We could build him a hull ready to flip in a couple of weeks at his place.
Speaking of warm...................did the trailer swap at the Kasilof river this morning. 1000 am and it was 77f. I was sweating like a pig. Had to get home and in some shade.
This afternoon it hit 89f in Kenai. To put that into perspective for here the highest temperature I had ever seen in Kenai was 82f
Might not be hot for most of you guys but when you are used to 50-60 for summer temps 89f is dying hot. Previous record on this date was 75f.
Posted: Sat Jul 06, 2019 8:51 am
by Browndog
Looking good!
Posted: Mon Jul 08, 2019 3:13 pm
by boguesounder
Fuzz,
She is stunning. Nice work and congrats!
Posted: Tue Jul 09, 2019 10:03 pm
by fallguy1000
Fuzz wrote: ↑Sun Apr 28, 2019 7:30 pm
Prolly full of gold!
You mine it all for a few pennies and he encapsulates it into driveways!
Boat looks good, but we need the dock pic man.
Posted: Thu Jul 11, 2019 1:16 am
Thanks Boguesounder and Fallguy
I will try to have some in the water running pictures in the next few weeks.
I have to say pictures can be deceiving. Sort of reminds me of a Playmate of the Year I saw once. Looked real good in pictures, dang nice from 50 feet, but when you got up close and could see under the 1/4 inch of makeup there were a lot of warts.
Posted: Thu Jul 11, 2019 5:59 am
by cape man
You need my smoker
Posted: Fri Jul 12, 2019 2:08 am
cape man wrote: ↑Thu Jul 11, 2019 5:59 am
You need my smoker
I need you to come build me one
Posted: Fri Jul 19, 2019 9:55 pm
Ok here you go first video of it running
https://youtu.be/YL939179zxw
Posted: Fri Jul 19, 2019 9:59 pm
by Jaysen
Nice! When are you fishing it?
Posted: Fri Jul 19, 2019 11:29 pm
Waiting on you buddy
Posted: Fri Jul 19, 2019 11:32 pm
Took the video from my dory. It was running mid 20's as the Sintis passed by.
https://www.youtube.com/watch?v=DerwfhT ... e=youtu.be
One more.
Posted: Sat Jul 20, 2019 1:34 am
I think I got the motor about right or maybe a little high. It will cavitate a little in a hard turn.
Posted: Sat Jul 20, 2019 5:23 am
by seaslug
Damn! Dave, that looks amazing, and hauling ass as well. Nice job, now bloody it up real good. Mike
Posted: Sat Jul 20, 2019 6:10 am
by cape man
No more porpoising! Way to go David!
Posted: Sat Jul 20, 2019 6:42 am
by Jaysen
That’s a lot of pressure. Good thing I’m used to being a disappointment. I’ve already packed extra Dramamine so already it will be fish we wash off the deck not lunch.
Posted: Sat Jul 20, 2019 11:39 am
by glossieblack
She's a real head turner Fuzz! Congratulations.
Posted: Sat Jul 20, 2019 12:39 pm
Posted: Sat Jul 20, 2019 12:46 pm
by cape man
No help here! Freaking electronics!
Posted: Sat Jul 20, 2019 1:33 pm
by Jaysen
You have wiring diagrams and pin outs for both ends?
Posted: Sat Jul 20, 2019 4:02 pm
by Aripeka Angler
Outstanding, she looks like a bunch of fun!!!
I think you might have hit the sweet spot.
Posted: Sat Jul 20, 2019 4:07 pm
by Jaysen
Loaded the vid... said to the boss lady “look at this!” She said “you’re gonna die.” Then she said “you better bring a pile back.”
Posted: Sat Jul 20, 2019 4:33 pm
by Aripeka Angler
You’ll be safe as long as Fuzz stays away from the Morning Wood.
Posted: Sat Jul 20, 2019 4:55 pm
by Jaysen
Hahahahaha!
Yeah. I forgot about that. Now I’ve more things to be nervous about.
Posted: Sun Jul 21, 2019 3:51 am
by gonandkarl
Hi,
I cannot judge anything about power boats but yours turned out for me like a dream and did you put it to work ( fishing ) already ?
Congratulations
Greetings from Karl
Posted: Sun Jul 21, 2019 6:18 pm
I still have the starting issue to work through before I take it fishing. For some strange reason I want to be pretty darn sure it will start before taking it out in the ocean
Took the SeaSport over to Seward for silvers again. Total bust, not sure what happened to all the fish. Lots of jumpers but they had lockjaw
Weather was perfect so we went for a boat ride out into the gulf. Further out than I have been in many years. Left the halibut gear at home, big mistake
Posted: Sun Jul 21, 2019 6:19 pm
Aripeka Angler wrote: ↑Sat Jul 20, 2019 4:33 pm
I needed that laugh
Posted: Sun Jul 21, 2019 6:57 pm
by Jaysen
FYI if you’ve got the tech specs I can probably figure it out. Almost certainly a simple swap of a pin from the 21 to match the 7.
Posted: Sun Jul 21, 2019 7:25 pm
Good I love putting my guests to work. Last year I made CapeMan do some sanding for me.
Posted: Sun Jul 21, 2019 7:35 pm
by cape man
And I cleaned fish...
Posted: Sun Jul 21, 2019 7:57 pm
by Jaysen
cape man wrote: ↑Sun Jul 21, 2019 7:35 pm
To do that you have to catch them. I’m not holding my breath on that...
Posted: Sun Jul 21, 2019 9:20 pm
by Aripeka Angler
Does the moon affect the daytime ocean salmon bite?
A full moon can sometimes wreck our daytime reef fishing.
Posted: Mon Jul 22, 2019 1:51 am
That might be what the deal was. Tons of jumpers all over but they all had lockjaw
Was not a total busted trip though. We saw the biggest Orca I think I have ever seen. When I first saw his dorsal fin I thought it was the conning tower of a sub. Must have been close to 8 feet tall
Where we anchored up for the evening we were treated to humpbacks feeding all around the boat for more than two hours. We were 100 foot offshore in 140 foot of water and they were passing between us and shore. Dive down and come up with their mouth wide open scooping up the bait fish. Amazing to watch mother nature at work
Posted: Tue Jul 23, 2019 10:43 pm
So my starting problem persists. I went to my local dealer to talk about the problem. After I described the symptoms he looked at me like I had three eyes
Anyone with an idea I am all ears.
Posted: Wed Jul 24, 2019 12:16 am
by Jaysen
Jaysen wrote: ↑Sun Jul 21, 2019 6:57 pm
Posted: Thu Jul 25, 2019 2:45 am
Jaysen wrote: ↑Wed Jul 24, 2019 12:16 am
Nope, left Jaysen muttering "that's the craziest thing I have ever seen" After fishing I will hit up the dealer again.
Posted: Thu Jul 25, 2019 9:41 am
by Jaysen
Yes... but we did confirm no bad pins. And we may have identified a behavior that we can take back to the dealers and say “y’all sold something that doesn’t work, here’s proof.” You just need problems that happen faster!
Posted: Sun Aug 04, 2019 6:45 am
by Jaysen
Yo Fizzy!
Since you shipped the bad luck charm out of town (how does anyone go to Alaska and NOT catch fish?) has the cold start situation improved?
Posted: Sun Aug 04, 2019 12:09 pm
Still waiting on the dealer to get me the parts. Been taking a break from fishing and catching up on other things.
Posted: Sat Aug 10, 2019 6:08 am
by glossieblack
Any update on the Sintes?
I've just replayed the video, and have a smile on my dial.
Posted: Sat Aug 10, 2019 12:57 pm
glossieblack wrote: ↑Sat Aug 10, 2019 6:08 am
Glad it put a smile on you face Michael
I have to admit it puts one on mine also to see it run. I got the new key harness and installed it two days ago. Afterwards the motor fired right up like it should but I need to do a little more testing to make sure it is reliable. Once I can trust it will start I will be a lot more motivated to finishing some small things and taking it fishing.
My sisters and I are moving my mother into an assisted living home and that has been taking up my time for the past week or so. Getting old is not for a sissy
Posted: Sat Aug 10, 2019 1:02 pm
by cape man
I know how hard moving her is, but in the end it is the right thing to do. With your daughter gone and Mila in the motherland you need the help.
I want another ride on the Sintes.
Posted: Sat Aug 10, 2019 4:20 pm
by Jaysen
Very glad it was just the key harness. I think you’re good to go with that motor at this point.
Sorry about mom, but you all know what’s right. I’m sure it will work out in time.
Posted: Sat Aug 10, 2019 11:40 pm
Thanks Jaysen and Capeman. Mom turns 90 in a few days so all in all she has had a good run. Still does not make this part easier but there is no way around it.
Posted: Sun Aug 11, 2019 12:03 am
cape man wrote: ↑Sat Aug 10, 2019 1:02 pm
You come for another visit and we will run the tar out of it. Heck if I am busy I will give you the keys to it and a truck. Have to see if you can put cracks in its transom
Posted: Sun Aug 11, 2019 6:52 am
by cape man
You daring me?
Posted: Sun Aug 11, 2019 9:07 am
by fallguy1000
Fuzz wrote: ↑Mon Jul 22, 2019 1:51 am
sounds like a lot of fun to watch
Posted: Sun Aug 11, 2019 1:15 pm
cape man wrote: ↑Sun Aug 11, 2019 6:52 am
You daring me?
No dare, invite
Mila and I really enjoyed having you and Patti here. It is nice to have guests and show them this country.
Heck, it was even fun having Jaysen. Not sure what was better watching him shiver or turn green
Still can't believe his timing. The only cool week all summer and that was when he was here. Been warm and sunny since he left
Posted: Sun Aug 11, 2019 4:02 pm
by Jaysen
The green was more fun. Out on the water always wins.
108F inland yesterday. Was 98f at the house. Almost thawed out from your “warm summer”.
Posted: Mon Aug 12, 2019 9:11 am
by Jeff
Crazy weather Fuzz!!!! Jeff
Posted: Thu Sep 05, 2019 9:32 am
by glossieblack
Any update on the with attitude Sintes?
Posted: Thu Sep 05, 2019 3:23 pm
Thanks for checking in on me Glossie
I have only been able to get out fishing one time in the past month. Life issues keep getting in the way
The few times I have thought I might get the boat out the smoke from the fires has been too heavy. It is looking like the only thing that will put the fires out will be snow
In a normal year it would be raining about every day in September but not so far this year. Rain is forecast for the next week but we will see.
Posted: Thu Sep 05, 2019 4:04 pm
by Jeff
Fuzz, that is terrible weather for you!!! Keep us updated!! Jeff
Posted: Thu Sep 05, 2019 8:44 pm
Jeff wrote: ↑Thu Sep 05, 2019 4:04 pm
Thanks Jeff.
We are just paying the price for the warmest summer I can remember. You have to learn to take the good with the bad. Heck you guys suffer through brutal heat, humidity and hurricanes to have those wonderful winter days. Very few places have nice weather year around and if they do then over crowding is sure to be present.
Posted: Fri Sep 06, 2019 7:46 am
by Jeff
Agreed Fuzz, Jeff
Posted: Tue Apr 21, 2020 6:52 am
by glossieblack
Happy 4th CLOOF birthday Fuzz!
I admire the way you reach out to closet CLOOFs.
Posted: Tue Apr 21, 2020 7:37 am
by Jeff
Happy Birthday Fuzz!!! I hope you have a great day, Jeff
Posted: Tue Apr 21, 2020 11:06 am
by cape man
I've been OUTED!
Posted: Tue Apr 21, 2020 1:52 pm
Glossie, Jeff and Capeman it is great to hear from each of you. I hope to be able to make it to Florida again at some point to see the guys there. And Glossie your little slice of heaven is just about the last thing on my bucket list.
Posted: Wed Apr 22, 2020 4:16 am
by glossieblack
Fuzz wrote: ↑Tue Apr 21, 2020 1:52 pm
I would prefer it was a little higher.
