C17 open in France
Posted: Sun Mar 19, 2023 1:52 pm
by OlivierP
Hello to all builders
I'm starting the build of a customized C17 with an open layout and a center console. I chose this plan because I wanted an offshore-capable small fishing boat, easy to launch single handed. It will be powered with a 50hp 4 stroke Yamaha.
It may be named "Fair Enough", to remind me that I have to stop fairing and go fishing instead... I'm not after a boat show finish, more a work boat, as neat as possible compatible with a short build time frame (I hope to finish it this year for next spring launch).
For plywood, I ended up buying full okoume marine in 8mm and 10mm. I can't find 5 plies 6mm marine around here, 8mm is the thinnest 5 plies available, so it will do for the hull sides and bottom. 10mm will substitute for 9 and 12mm, a little too thin for the sole so I'll add some supports between frames because the central span is quite large.
I had to redo all the nesting because the plywood sheets are much larger than specified (310x150cm), but the benefit is that all long panels fit in 2 sheets instead of 3. I added the seats and console in the nesting as well so all is cut from the same plywood.
Otherwise it will be foam-filled, with chase tubes to the console, and above-deck 42 liters plastic fuel tank in the console. Minimal instrumentation (a GPS/sounder and that's about it), a swim ladder, a kicker bracket just in case, a bimini top.
I have cut the parts in my small garage, I'll move to a larger workshop and intend to start the gluing and assembly shortly, waiting for temperature to be consistently above 15°C, which should happen soon hopefully.
First pictures below, to be continued.
Plywood :
9802
Panels :
9804
9813
9814
Frames with rod holders :
9806
Frames sides are doubled
9805
Console back and front, with seat and space for the fuel tank
9810
9811
9812
Building frame on wheels
9809
Re: C17 open 'Fair Enough' in France
Posted: Sun Mar 19, 2023 3:05 pm
by fallguy1000
Congrats Olivier,
The only caution I will give you is venting the fuel tank is hard to do properly with the fuel in the cc. The proper venting is always, always overboard. So, if the boat is inspected, it would be required to vent all the way to the side. This is achievable by lowering the tank into the hull, but not a great idea for the vent line to have any low spots either, so it is a real difficult challenge.
Some of our US builders do not care because they are not getting inspected. As you are in France, I am only looking out for you.
Fuel landing in the bilge, if spilled is also bad. If I were building this boat, I would not put the fuel in the cc because I would not want to smell fuel vapors or worry about my friend smoking by the vent.
All the best, we will help you in anyway we can and look out for anything we see going wrong. Like a friendly QA team.
Dan
Posted: Sun Mar 19, 2023 4:05 pm
by MikeyGnz
fallguy1000 wrote: Sun Mar 19, 2023 3:05 pm
You let people smoke on your boat? That action has a walk-the-plank punishment on my boat.
All the best for the build Olivier. Looks like you are off to a good start.
Posted: Sun Mar 19, 2023 4:19 pm
by OlivierP
Thanks Dan, I welcome any help or comment.
Regarding the tank I'll double check the venting regulation but venting the console in the cockpit appears sufficient here for an open boat, at least it is on my current commercial RIB which uses the same principle of plastic tank in the console, without any vent or filling device, and it seems to have passed all needed certifications...
Yes this will also be a non smoking boat :-)
Posted: Sun Mar 19, 2023 4:54 pm
by fallguy1000
To each, but I would not want fuel vapors in the cockpit...
Posted: Sun Mar 19, 2023 8:54 pm
by joe2700
Most boats this size would have portable tanks and people wouldn't give that a second thought even though they vent and would often be filled in the cockpit. I think the console is really one of the few viable options for a built in tank in a small boat. Certainly some boats come from the factory that way, and I have never had an issue with smelling fuel in my FS17. Being near the center also means trim doesn't change much with fuel level
All that said, I would be very careful to separate the tank and hoses from any electronics in the console. It's safe because an open CC has a lot of ventilation, if vapors build up inside your console in a space with any chance of spark that would be dangerous.
Posted: Tue Mar 21, 2023 5:12 am
by Rmarsh
Congrats Oliver. Excellent choice on the open C17. You wont be disappointed. I have my gas tank in the console seat....19 gal....which as it turns out is larger than my 60 hp Yamaha needs for all day and more.... its vented and sealed from the upper console and wiring. Boat is going on ten years old...no problems or ever any noticeable fumes......I would not hesitate to do it that way again. My boat was inspected before being registered.
Looking forward to watching as you go forward.
Posted: Thu Mar 23, 2023 3:25 pm
by OlivierP
Progressing, the jig is built and I have started assembling the transom and stringers
9824
9825
Posted: Fri Mar 24, 2023 1:13 am
by TomW1
I see what could be two errors in cutting out the notches for the stringers. First it looks like you cut out notches in the transom, there should not be any there as the transom pushes against the stringers and you tape the stringers to the transom. Second, you have not cut any notches in the second panel back or mold B. There needs to be notches there for the stringers to run forward to mold A.
Posted: Fri Mar 24, 2023 4:02 am
by OlivierP
Tom,
Thanks but I believe this is incorrect. On the plan the stringers end right at the back of frame B and don't cross it to frame A (which is way above the sole anyway). Besides I have not cut notches in the transom, what you see on the jig is Frame E, the transom is not mounted yet.
But thanks for the close examination, I'm sure there will be mistakes, there has been already.
Posted: Fri Mar 24, 2023 3:35 pm
by TomW1
OlivierP wrote: Fri Mar 24, 2023 4:02 am Tom,
Good enough just going on memory and did not realize you did not have the transom mounted. Carry on with the good work. Tom
Posted: Tue Mar 28, 2023 3:18 pm
by OlivierP
Progressing, slowly. Busy assembling the stringers, transom, bottom panels. Made also some good progress on the console and pilot seat. The temperature is still low, gluing is only possible for a couple of hours in the afternoon.
9830
9829
9828
Posted: Tue Mar 28, 2023 3:21 pm
by Jeff
Good progress!!! Jeff
Posted: Fri Mar 31, 2023 1:12 pm
by OlivierP
Dry fitting the motor well sides and transom. They fit :-)
9833
9834
Posted: Sat Apr 01, 2023 9:50 am
by pee wee
That looks right! Take your time at this stage to check everything for square, for alignment, hook or hog in the aft section, etc. Take diagonal measurements, pull string, use a laser, whatever you have available, this is your easiest time to get things right or wrong.
Posted: Sun Apr 02, 2023 10:23 am
by Dan_Smullen
Looks clean and fair!
May be too late, but something that I believe is worth mentioning.
One thing I would have differently on my C19, would have been to delay cutting out for the motor until I had a motor in hand. Imagine prepping the transom or a 20" shaft motor, and then finding a deal on a 25. Also, after building up glass on top of the clamping board, and shaping the "v" at the bottom of the hull, I wound up with about 21" from the top of the clamp to the keel. While mounting the outboard this was enough for us to question whether or not the motor will be too high. We will soon find out...
Maybe the best case is prepping for a 25" shaft, but allowing enough meat to cut it out further if required.
Posted: Sun Apr 02, 2023 1:18 pm
by OlivierP
Thanks to all.
Regarding the motor, I have it already, a 50hp Yam on my RIB that I'll transfer in due time, so dimensions should be ok. I have even already drilled the mounting holes.
I'll double check alignment. I have used a laser when mounting the jig but nothing is perfect. I have a couple more days before assembly because I intend to pre-drill the transom for the swim ladder and the kicker bracket, easier when the transom is laying flat and not yet painted.
Posted: Thu Apr 06, 2023 5:05 pm
by OlivierP
I'm progressing, slowly, to get the plywood to bend and take shape. I'm using thicker plywood than specified and it's very reluctant to strong bending... getting there, with patience. I don't know if spot welding with epoxy will be strong enough to hold everything together when I remove the stitches, there's so much tension, I may need to tape some places at the bow with small pieces of tape. We'll see, I'll dry fit the upper side panels first.
You may notice that the side panels overlap the bottom. As discussed in a previous thread, I have decided to include built-in reverse chines filled with epoxy (like the OB15), as I had enough plywood available in the new nesting, the lower side panels were extended by 1 inch for that purpose. I thought I could still cut them down if I didn't like the result but it looks good and I'm keeping them.
9837
9838
Posted: Tue Apr 11, 2023 2:05 pm
by OlivierP
Stiches removed, sanded, upper panel dry fitted.
Next step, fill stitching holes and gaps, build reverse chines, glue the upper panels.
9843
9844
9845
Posted: Tue Apr 11, 2023 5:02 pm
by OneWayTraffic
I was going to recommend that you glass the bottom before gluing the upper side panels. Easier to reach.
I'd run the bottom glass to the panel overlap, and cover with a fillet there. Easier to fair the transition.
It's also a good time to precut the rubrail pieces before gluing on the upper side. You can trace the outline, cut and check for fit on the shop floor. Obviously don't glue them until the panel is on.
Posted: Tue Apr 11, 2023 5:15 pm
by OlivierP
Good points, thanks, access is indeed an issue, but I thought it would be better to run the tapes in one piece over the bottom and both side panels, especially at the bow - or would you tape the upper panel separately ?
Posted: Tue Apr 11, 2023 11:09 pm
by OneWayTraffic
Structurally speaking it doesn’t matter either way. Tapes with an overlap are strong as one continued tape.
Posted: Wed Apr 12, 2023 1:07 am
by TomW1
One thing I see a problem with is the taping of the chine seams with tape sine you left the sides extended. Hou are you going to get 2 or 3 layers of tape offset on the hull and side.
Posted: Wed Apr 12, 2023 3:13 pm
by OneWayTraffic
I think the plan is to fill before rounding to 13mm and glassing over. One trick I learned is that the first layer of tape tends to lay better if you put down some slightly cabosil thickened epoxy underneath first.
Posted: Fri Apr 14, 2023 2:08 pm
by OlivierP
Yes I'm filling the chine flats with scrap plywood pieces, epoxy and wood flour, I'll round the edges, tape and glass over them.
Looks ugly right now, but I was in the middle of gluing scrap plywood. It will be flat eventually, as it should be for chine flats...
9846
Posted: Fri Apr 14, 2023 3:07 pm
by Dan_Smullen
OlivierP wrote: Fri Apr 14, 2023 2:08 pm Yes I'm filling the chine flats with scrap plywood pieces, epoxy and wood flour, I'll round the edges, tape and glass over them.
9846
My man with a plan! Great way to do that!
Posted: Mon Apr 17, 2023 1:57 pm
by OlivierP
Thanks Dan.
More filling of the chine flats, still not flat but getting closer. They go all the way to the front.
9849
9848
Posted: Mon Apr 17, 2023 5:17 pm
by OneWayTraffic
Assuming that new layers of fill are going on before the old fully cures, I'd put some microballoons in the last to help the sanding process before you glass. Alternatively, a grinder with 24grit will do it.
Posted: Thu Apr 20, 2023 2:48 pm
by OlivierP
Thanks Oneway, I managed to sand what I needed with 40 grit.
Now the tape is on the bottom, transom and chines. It went well around the chine flats after rounding the edge.
Also some progress on the console.
The project will be on hold for a week as I go fishing...
9854
9853
9852
Posted: Wed May 03, 2023 11:24 am
by OlivierP
Back to work, the bottom is glassed and the upper side panels are glued. Hull complete ! Well, still a long way ahead.
9863
9862
Posted: Thu May 04, 2023 2:06 pm
by OlivierP
Looking at the profile after gluing the side panels, it seems that I have some droop at the bow. Maybe the thicker panels did not bend exactly as expected. I'll probably try to pull the bow back to see if it helps before installing the rub rails, or add a spreader close to the bow, otherwise the droop may become permanent. Not a deal breaker but I'd rather avoid it. Any advice welcome. Thanks
Posted: Thu May 04, 2023 2:46 pm
by Reid
Not sure what you are referring to since I see that you have all the panels filleted and laminated. Please provide some pictures for reference if you can.
thanks,
Reid
Posted: Thu May 04, 2023 3:46 pm
by OlivierP
Thanks, I'll take a picture when I go back to the workshop, likely Saturday. Everything is glued, but the tip of the bow droops (actually lifts, since it's upside down...) by a few centimeters when seen from the side. Maybe the panels aren't spread enough towards the front, between the bow and frame A. You can't see that from the current pictures.
Posted: Thu May 04, 2023 6:59 pm
by Dan_Smullen
This pops up a lot in the C series boats. 17, 19 and 21.
I wasn’t partial to the look and flattened it out after the flip, before sticking the deck on top of the frames. Shaving out the hump left some skinny sections of rub rail, but I was able to fill these to a batten which made it all go away.
Regrettably, I didn’t correct it where it shows on the bottom edge of the upper panel. Maybe next winter.
Point being, it’s there, but you can make it go away.
Posted: Thu May 04, 2023 7:49 pm
by TomW1
Like Dan said this really happens a lot if you do not pay attention and pull the panels down hard when stitching. Follow his lead and you can fix it.
Posted: Thu May 04, 2023 8:24 pm
by Dan_Smullen
Found a pic of the correction. From October 2021.
Posted: Thu May 04, 2023 8:43 pm
by OneWayTraffic
I discovered mine after flipping, and the rubrail was on.
I glued the backing block for the cleat on top rather than under the front panel. This somewhat hides the droop. I may eventually bolt a bow roller on it.
Posted: Fri May 05, 2023 2:57 am
by OlivierP
Thanks to all, it's about similar to what Dan shows. I'll probably fix what remains after the flip the same way.
I think I'll pre-cut some extension pieces for under the last meter or 2 of the rub rail at the front, before mounting the rail, to be ready to extend it if I have to cut it down. It also means that I won't paint the sides before the flip as I initially planned, probably only the bottom and maybe the lower side panels
Posted: Mon May 08, 2023 3:11 am
by OlivierP
This is the droop at the bow
9872
I've pre-cut rub rail extensions to fix it after the flip.
9871
Otherwise, installed the keel and built dams to sharpen the edges of the last 2 meters of the sides and the transom
9870
And busy glassing the console
9873
Posted: Mon May 08, 2023 11:17 am
by TomW1
Just remember after sharpening the edges you will need to round them slightly say a 1/16" - 1/8" so the paint will hold. It can create a crack on a sharp corner. Tom
Posted: Mon May 08, 2023 2:25 pm
by OlivierP
Yes that's right, currently edges are so sharp they would cut
9875
Started filling the bottom with fairing mix. I'll add graphite layers next.
9876
I'm leaving the topsides raw, as specified in the plans, the plywood is of sufficient quality.
Posted: Fri May 12, 2023 2:50 am
by OlivierP
After 3 layers of fairing and sanding, I'm adding graphite to the bottom.
The project will be on hold for another week as I go fishing again.
9881
9882
Posted: Fri May 12, 2023 10:03 pm
by TomW1
Nice. Tom
Posted: Sun May 14, 2023 4:47 pm
by OlivierP
I managed to put one more coat of graphite before leaving. Still to be faired but it's starting to shine !
I have planned to paint everything, but I'm still wondering if I shouldn't leave the bottom with bare epoxy/graphite... it's what I did on my GF14 and it's working very well, the bottom is tough and never sees the light anyway, so no UV problem... did anyone try that too ?
9884
9883
Otherwise the console is fully glassed, fairing next.
9885
Posted: Sun May 14, 2023 6:49 pm
by OneWayTraffic
You will get a slow degradation of the epoxy on the bottom due to reflected light. If stored out of the sun, this could take decades. If going just with an epoxy coat above the waterline, use a couple extra coats. I put on a light glass, which is not really much more epoxy, but a lot of extra sanding and fairing.
Posted: Mon May 15, 2023 12:45 pm
by TomW1
No need to cover the graphite it will last forever. There are boats that are 15 years old that still have bare graphite bottoms. Tom
Posted: Thu May 25, 2023 3:37 am
by OlivierP
After much deliberation, I'll stick to the original plan and shall paint everything.
Back at it, installed the rub rail, more fairing and sanding, and a last coat of epoxy. Looks like orange peel from an angle but will smoothen with sanding.
Then, painting will start. 2/3 coats of 2 parts primer, then 2/3 coats of 2 parts polyurethane.
9908
9907
Posted: Sun May 28, 2023 11:48 am
by OlivierP
Prime time !
9913
9912
9911
2 layers on the bottom and transom, 1 on the sides for now.
The extension on the transom is a support for the sounder transducer, I didn't want to screw it directly in the transom as it's under the waterline.
Also preparing the frames for deck hardware and hatches.
9914
The flip is scheduled Wednesday next week (7th June), I plan to to finish the top coats this week.
Posted: Sun May 28, 2023 6:36 pm
by Dan_Smullen
Great plan and forethought for the transducer mount! Looks great!
Posted: Tue May 30, 2023 10:05 am
by OlivierP
Top coat#1 (Mauritius Blue)
9932
9931
Posted: Tue May 30, 2023 10:08 am
by Jaysen
Man! that feels good, doesn't it?
I like that color. What is the topside color going to be?
Posted: Tue May 30, 2023 11:12 am
by TomW1
Very nice color. Tom
Posted: Tue May 30, 2023 11:26 am
by OlivierP
Thanks guys. The top (rub rail, deck, console...) will be off white (Dover white ?). There will be cream non-slip paint on the sole. Very classic colors, but I'm fine with classic on a Classic...
Posted: Tue May 30, 2023 11:38 am
by Jaysen
That will be glamorous. Like a dark navy suit and a cream shirt. Classic.
Posted: Wed May 31, 2023 12:13 pm
by OlivierP
Top coat #2. I see a #3 coming. The surface is less smooth than I was used to with that paint (International Perfection) on my previous builds, maybe it's the rollers that leave very tiny bubbles on the surface. I'll probably try a different roller for coat #3.
9941
9942
Posted: Thu Jun 01, 2023 10:21 am
by pee wee
You're talking the black art of finish painting! Could be the roller texture, or amount and type of thinners . . . if the paint is not leveling out before it sets, then it won't be smooth.
I remember years ago I was into building plastic airplane models and before I bought an airbrush I brush painted, with predictable results- except this one time when all the stars aligned and I got this super shiny and flawlessly smooth 747 airliner perfectly done. It wasn't the brush, it was the consistency of the paint that was correct for the temperature and humidity at the time I was painting.
Do you have a practice board to check the paint behavior before you start on the hull?
Ultimately, it does look nice and once it's flipped and in the water it will still look beautiful.
Posted: Thu Jun 01, 2023 11:38 am
by Jaysen
1. the fish don't care.
2. If you don't care, then who else has a right to an opinion?
3. If #2 is "no one" then anyone that complains is shark food.
That said, my unfortunate experience is that if you want a "smooth finish" you are not going to like my next couple of sentences.
To make that smooth you need to sand the texture out. FG1K went crazy chasing a series of paint issues looking for good roll and tip finishes. Everytime there was a problem, the only solution was to erase it, not cover it. That means sand it off. Sorry.
As to the smoothness question, pee wee has it. the bubbles are from surface adhesion to the roller or air bubbles from mixing/pouring paint. orange peel is due to overly thick paint not smoothing which is partially due to surface tension with the roller. answer to both is thinning paint with proper thinning agents and slowing flashtime to allow for proper leveling.
Where pee wee has it wrong is "black art"... it's more "multiple deals with the devil followed with more deals with the devil topped with deals with the devil". If you can find a way do spray, you won't hate making that transition. it reduces the devil deals to 2 layers.
Posted: Fri Jun 02, 2023 4:53 am
by OlivierP
Thanks, that's more or less what I thought, I can't sell my soul to the devil because it's sold out already, so I'll try sanding, different rollers, and thinning. I guess I was just lucky on the previous builds...
Posted: Fri Jun 02, 2023 6:08 am
by OneWayTraffic
An alternative is a vinyl boat wrap. Any colour you like, and any design you like. No worries about orange peel or anything.
Posted: Fri Jun 02, 2023 12:13 pm
by OlivierP
Ok that's it, 3rd coat with different roller and a little thinner. It went better, still not perfect but I'll live with it, it's "fair enough"...
Next step is the flip next week.
9945
9944
9943
Posted: Fri Jun 02, 2023 3:13 pm
by TomW1
Looks good guy!!! Time to flip her and get the insides built. :D Tom
Posted: Sat Jun 03, 2023 6:48 am
by fallguy1000
When you paint dark without post curing; the sun will hit it some hot day and modify all the glass and you'll emd up repainting it someday..
Bubbles on the surface are ~usually~ caused by too deep a roller nap or foam rollers with porous surfaces.
It is hard to paint dark colors. They show much..
Painting is hard..
Posted: Sat Jun 03, 2023 10:52 am
by OlivierP
In this case the main culprit for bubbles seems to be the new rollers with short hairs. I reverted to the last of my old rollers for the last coat and it went better. Nowhere close to a professional finish, but I knew that. Anyway what's done is done and it's good enough now. And yes I'll repaint some day, I expect that too.
Posted: Wed Jun 07, 2023 3:04 pm
by OlivierP
Flipped ! It went well, the hull is so light, at 6 it was a piece of cake. It's now on its trailer.
I have decided to pre-glue the stringers from underneath to provide more support for the bottom on the trailer as I didn't build a specific support for the hull after the flip. I'll fiberglass between stringers.
The bow droop is still quite pronounced but will bet fixed as planned.
9948
9947
9949
Posted: Thu Jun 08, 2023 9:27 am
by pee wee
I can understand why you'd be tempted to install the stringers now for more support, but if it were me I'd shim and support from underneath as much as it takes, so I wouldn't have to fiberglass around those stringers.
Posted: Thu Jun 08, 2023 12:26 pm
Nice to have lots of helping hands when you need them. Boat looks really nice. You are doing a good job on it.
Posted: Thu Jun 08, 2023 1:35 pm
by OlivierP
Yes it's good to have a team when you need it ! With lots of champagne and beer of course.
To pee wee : gluing the stringers was done after careful consideration of pros and cons, but I'm glad I did, the stringers are perfectly in place already and strengthen the hull as I walk inside. I'll lay the glass in 4 half width rolls instead of 2 full width. Note that I could lay a full width in the center but I prefer to respect the lamination schedule and keep an overlap on the keel.
By the way: first step in the hull, feels like a first step on the moon !
9950
Posted: Fri Jun 09, 2023 4:55 pm
by OlivierP
I fixed the sheer line and removed the bow droop today. Took a couple of hours but I'm happy with the result so far.
Before
9954
After
9953
Rub rail extension glued
9951
Much happier with the sheer now
9952
Posted: Fri Jun 09, 2023 6:15 pm
by fallguy1000
I have a pet peeve in low bows..
Good going..
Posted: Sat Jun 10, 2023 9:13 am
by pee wee
fallguy1000 wrote: Fri Jun 09, 2023 6:15 pm I have a pet peeve in low bows..
Good going..
Me, too! Looks great now.
Posted: Sat Jun 10, 2023 6:15 pm
by OneWayTraffic
I glassed my inside in boxes formed between stringers and two frames. I prefered it, mainly for the reason that I could do a box every day. I don't believe that there's a major loss of strength, just make sure to have good fillets and sufficient glass on the stringer hull transition.
Posted: Sat Jun 10, 2023 9:02 pm
by TomW1
OlivierP wrote: Thu Jun 08, 2023 1:35 pm Yes it's good to have a team when you need it ! With lots of champagne and beer of course.
9950D
Did you fasten the stingers wood on wood or leave a gap for the epoxy to flow under the stingers. If you did wood on wood you have a hard spot that will wear instead of an wood to epxoy to wood joint which would be stronger and more flexible. A gap of 1/8 to 3/16 is needed to prevent wood on wood wear as in all stich and glue joinery.
Posted: Sun Jun 11, 2023 2:37 am
by OlivierP
Tom, I think the joint is at least 99% epoxy, since the stringers are flat and the hull bottom inclined there is a large triangular gap anyway, fully filled with epoxy.
Posted: Fri Jun 16, 2023 8:35 am
by OlivierP
Nothing spectacular but steady progress this week, the hull is completely filleted and taped, with 2 or 3 layers of tape where needed, and the first of the 4 pieces of fiberglass is glued on the bottom and up the stringer.
Next week, I intend to finish glassing and install the bulkheads. Then I'll move the boat to my house by the sea, to complete it over the summer.
In total, that's 9 layers of 450g/m2 biax on the keel, that will be tough as an icebreaker !
9956
Posted: Fri Jun 16, 2023 12:04 pm
by Dan_Smullen
Looks very clean! The stretch of between the hull and the underside of the sole may be the least fun part of the process. I found it helpful to keep a level and winding sticks on top of the stringers and bulkheads to ensure the tops of all stayed relatively planer.
At one brief moment, I lamented not glassing the faces of stringers and bulkheads before tabbing in place, but soon got over that. Would probably do it on the next one.
Keep it going!
Posted: Fri Jun 16, 2023 4:08 pm
by jbo_c
TomW1 wrote: Sat Jun 10, 2023 9:02 pm
Did you fasten the stingers wood on wood or leave a gap for the epoxy to flow under the stingers. If you did wood on wood you have a hard spot that will wear instead of a wood to epoxy to wood joint which would be stronger and more flexible.
I know this to be true, and have abided by it in my build, but I don’t understand it. Why would wood to wood be any harder than wood to cured epoxy/wood ‘glue’?
Would love to understand it rather than just doing it because “they said so”. :)
Jbo
Posted: Fri Jun 16, 2023 4:19 pm
by OlivierP
Dan, thanks, yes keeping the sole level is one of the next challenges. At least I know the stringers are level so I shouldn't be too far off. The sole will be built in sections between frames, and glassed with 200g cloth.
Not sure about the benefit of glassing the frames, I have doubled (most of) them already so they're 20mm thick now, and they will be set to the hull with biax tape. But for abrasion / shock resistance it might help ?
Posted: Fri Jun 16, 2023 5:41 pm
by OneWayTraffic
jbo_c wrote: Fri Jun 16, 2023 4:08 pm
Jbo
Without putty in the joint the hull panels are unlikely to meet the stringer or frame evenly everywhere. The slamming forces might become concentrated on just one area of the hull that pushes more strongly against the much stiffer stringer. This is not good. With putty in between, cured into place you know that this will not happen. It's ok if they touch in places if there's no pressure applied, but if you have a gap, then you know that the loads will not be concentrated.
In larger boats (especially foam core) the stringers or frames are lifted off the hull with a foam pad, so that the tabbing take all of the loads. This is the ideal, but absolutely not required for boats of this size.
viewtopic.php?p=47547&hilit=hardspot#p47547
Posted: Fri Jun 16, 2023 5:50 pm
by OneWayTraffic
OlivierP wrote: Fri Jun 16, 2023 4:19 pm Dan, thanks, yes keeping the sole level is one of the next challenges. At least I know the stringers are level so I shouldn't be too far off. The sole will be built in sections between frames, and glassed with 200g cloth.
No need to glass the frames aside from the tabbing, unless at a place where there will be the possibility of damage.
The Sole is structural. You need to have solid plywood butt blocks underneath adjoining sections. If your intention is to build level with the tops of the frames then each piece must be well secured and cleated in. I made my sole from 9mm ply glassed both sides with 400g.
Posted: Sat Jun 17, 2023 8:04 am
by jbo_c
Thanks, OneWay.
That makes sense.
Jbo
Posted: Sat Jun 17, 2023 3:51 pm
by TomW1
As I recall the frames only require coating with epoxy. If you want add fiberglass fibers to make a sturdier coating.
Posted: Sun Jun 18, 2023 9:55 am
by pee wee
TomW1 wrote: Sat Jun 17, 2023 3:51 pm As I recall the frames only require coating with epoxy. If you want add fiberglass fibers to make a sturdier coating.
I know Jacques maintained that there was no need to fiberglass everything, and some designs don't even require the whole hull to be covered in fiberglass. Where the strength of the fiberglass is not needed, it becomes an issue of minimizing weight but still protecting the wood. I've seen more than a couple experienced builders that ended up with problems in areas that hadn't been covered in glass, and resolved to glass everything in their future build. Three coats of neat epoxy (paying extra attention to plywood edges) covered in paint is touted as adequate protection over quality okoume or maranti marine plywood, but is it really? :doh:
Posted: Sun Jun 18, 2023 4:15 pm
by TomW1
pee wee I would advocate only coating with epoxy in areas that never see sunlight. Otherwise, it gets fiberglass, epoxy and paint. Tom
Posted: Tue Jun 20, 2023 3:20 pm
by OlivierP
Bottom fully glassed. Not the funniest task, I'm glad this is over. I'll start with the bulkheads.
9958
9957
Posted: Wed Jun 21, 2023 2:14 pm
by OlivierP
Bulkheads dry-fitted, ready for gluing, that will be for tomorrow. The motorwell sides will be resized too.
9960
9959
Posted: Wed Jun 21, 2023 5:52 pm
by jbo_c
Nice clean work. Wish I was that disciplined. :)
Jbo
Posted: Fri Jun 23, 2023 2:32 pm
by OlivierP
It took 3 days, but all bulkheads are glued. I still have to fine tune the fillets and tape them, but all frames are in place.
Next week I'll move the boat to its final destination, my house on the coast of Brittany, and I'll transfer the workshop to complete the build there.
9961
9962
Posted: Fri Jun 23, 2023 3:05 pm
by mhd
That is already a fine looking boat. Very neat and precise build. I'll echo an earlier post and say that I wish I worked so clean. I'm almost at the same point. 1/2 way through glassing the interior and preparing to fit bulkheads.
Looking forward to seein the build progress. Good luck with moving the boat and workshop!
Mick
Posted: Fri Jun 23, 2023 3:46 pm
by OlivierP
Thanks Jbo and Mick for the kind comments. It sure does not look so clean up close, but fair enough...
Good luck for your own projects.
Posted: Fri Jun 23, 2023 3:48 pm
by TomW1
She looks great and is about as strong as she will get. Should be no problem trailering to Brittany. You are building a fine C17 :D
Posted: Fri Jun 23, 2023 3:52 pm
by OlivierP
Thanks Tom
Posted: Mon Jun 26, 2023 8:55 am
by OlivierP
Ready for departure
9963
New home by the sea - as I suspected, I need to lower the wind screen by about 1'' to fit under the car port. 2 bolts that stick below the roof at the entrance of the car port... No big deal.
9964
Posted: Wed Jun 28, 2023 5:36 am
by glossieblack
Nice C17 build to date, and congrats on the seamless move - they don't just happen. :wink:
Posted: Thu Jun 29, 2023 4:55 am
by OlivierP
Thanks Glossieblack ! Just to let you know, I'm following your Australian adventures with nostalgia, having lived there for 2 years and absolutely loving Australia.
Posted: Fri Jun 30, 2023 5:46 am
by glossieblack
OlivierP wrote: Thu Jun 29, 2023 4:55 am Thanks Glossieblack ! Just to let you know, I'm following your Australian adventures with nostalgia, having lived there for 2 years and absolutely loving Australia.
Thanks for letting me know.
And please comment on my Australian adventure posts every now and again, as you have a unique perspective. :D
Posted: Thu Jul 06, 2023 8:19 am
by OlivierP
I resumed the project this week. First taped all frames and bulkheads, quite a lot of work, I glassed the anchor well for extra protection, and finally I started working on the cockpit drains and chase tubes. Took some thinking before drilling 40mm holes in the transom and 80mm is the frames...
I'll install 2 master 80mm chase tubes to port and starboard, with small flexible inner tubes as required. Only dry-fitted at this stage, I'll finish next week. All electrical systems to port, fuel and controls to starboard. The battery will be in the aft port locker.
I'm using a 40mm fiberglass-epoxy tube for the cockpit drains. It will be cut to fit.
9977
9976
9975
Posted: Thu Jul 06, 2023 9:49 am
by Dougster
Good looking tape job, better than mine. And yes, it's old fashioned bend over wear out the back work!
Posted: Thu Jul 13, 2023 1:51 pm
by OlivierP
Most of the cockpit cleats are installed. Quite a task, and I only have 2 stringers!
I've built a front desk support out of 25x50mm oak, should be plenty strong.
The cockpit drains were cut flush to the transom and the cockpit bulkhead, and epoxy glued. I have added a third central drain going straight to the bilge, so I'll have the option of draining to the transom or to the bilge.
9988
9989
9991
9990
Posted: Thu Jul 13, 2023 2:00 pm
by Jeff
Posted: Fri Jul 14, 2023 5:17 pm
by OlivierP
Testing the cockpit drains. As expected, they're almost flush with the sole, 2-3mm recessed, so they should trap all water in the cockpit. I'm happy with fiberglass-epoxy tubes, they can be glued exactly where desired without overhang.
9992
Posted: Fri Jul 14, 2023 6:04 pm
by TomW1
Looks good. Tom
Posted: Sat Jul 15, 2023 2:03 pm
by OlivierP
Today I cut and adjusted 3 sole panels, and cut the holes for the chase tubes, after testing on a template
9997
9999
9998
Posted: Sun Jul 16, 2023 10:00 am
by pee wee
Nice work, especially getting things to fit like you have. Very neat. Looks like you are enjoying good ventilation in your work area, too.
Posted: Sun Jul 16, 2023 11:29 am
by OlivierP
Thanks Hank, yes it's a real pleasure to work outside under cover
Posted: Sun Jul 16, 2023 11:53 am
by OlivierP
More cleats, this time along the sheer for the gunwales. Each cut to shape because the hull has a different angle in each section... lots of slits to fit the curves of the sheer. Only half glued so far, I'm running out of clamps.
The chase tubes are glued, I'll soon start filling the compartments with foam and gluing the soles. I'm prepping them with epoxy on the underside.
10002
Posted: Sun Jul 16, 2023 12:53 pm
by TomW1
Where is the tube for the gas line it needs to have its own separate tube for safety, unless you are putting in the stern. Tom
Posted: Sun Jul 16, 2023 4:09 pm
by OlivierP
The concept here may be unconventional.
I have used large diameter tubes to run individual lines (including fuel) through separate flexible tubes (like those used to route electrical cables through walls or gardens) for isolation inside the main tubes.
For extra safety, all electricals will run to port, fuel and controls to starboard. Fuel will be separated from controls by individual sub-tubes inside the master starboard tube.
You could say that the conventional chase tubes are the sub-tubes, the master tubes are tunnels shared by the chase tubes.
Posted: Thu Jul 20, 2023 10:24 am
by OlivierP
Slow progress. More sheer battens, chase tubes completed, motor well bulkhead dry fitted.
10006
10007
Posted: Thu Jul 20, 2023 1:19 pm
by OlivierP
First compartment foamed. I used a dummy sole, cut in the corners and covered with pvc, and sat on it to control the expansion of the foam towards the corners. As a result I have a foam pack almost flat with little to cut.
10008
Posted: Thu Jul 20, 2023 1:36 pm
by OrangeQuest
Looks like you dialed in just the right amount of foam to fill up the area you wanted to foam. Great job!
Posted: Fri Jul 21, 2023 11:25 am
by Dougster
Very well done---I never managed it that well.
Posted: Fri Jul 21, 2023 3:34 pm
by OlivierP
Thanks, yes it works, but in retrospect and looking at how much foam I needed I'll only use this process for the complex bow volume but not everywhere. The reason is that the sole directs but also blocks some of the foam expansion, and as a result you may end up with a denser foam and heavier compartments than if you let the foam expand fully and cut the excess.
Re: C17 open in France
Posted: Sat Jul 22, 2023 2:55 pm
by OlivierP
3 out of 4 sections foamed/decked
10012
10013
Posted: Tue Aug 01, 2023 2:21 pm
by OlivierP
Completed the foaming and glued the last piece of sole. Cut and dry fitted the front and rear decks. Built a dam filled with epoxy around the chase tubes, probably overkill but 100% waterproof !
10024
10025
10026
10023
Posted: Tue Aug 01, 2023 2:34 pm
by Jeff
Posted: Tue Aug 01, 2023 5:57 pm
by glossieblack
Well thought through and clean work. :D
Posted: Mon Aug 14, 2023 8:05 am
by OlivierP
Slow progress as many other things are going on.
The sole has been completed and covered with biax, the console and pilot seat are installed. They will be taped next. Then, gunwales and front seats to be built.
Bad news, I have to buy more epoxy (but who doesn't?)
10044
10045
Posted: Mon Aug 21, 2023 1:34 pm
by OlivierP
I managed to cut 5 meters long battens in one piece, I'm installing them to support the gunwales
10056
10055
10054
Posted: Mon Aug 21, 2023 1:46 pm
by Jeff
Posted: Mon Aug 21, 2023 4:47 pm
by TomW1
Looking good!! Tom
Posted: Wed Aug 23, 2023 1:38 pm
by OlivierP
Gunwales cut and installed (dry fitting pictures, but glued afterwards)
10060
10059
Posted: Sat Aug 26, 2023 11:57 am
by OlivierP
Gunwales completed; inwales will be added. I made them wide (23cm, 9'') for safety.
10061
Front benches and lockers built and dry fitted, to be tailored and glued
10062
Posted: Sat Aug 26, 2023 12:27 pm
Very nice work! I too like them wide, gunnels that is :lol:
Posted: Sun Aug 27, 2023 1:21 pm
by TomW1
Looking nice :D Tom
Posted: Mon Aug 28, 2023 7:11 am
by OlivierP
Thanks guys !
Cut the inwales and started to glue them, it takes a lot of clamps so one side at a time.
10063
Posted: Mon Aug 28, 2023 4:00 pm
by OlivierP
Cut 5m battens to double and reinforce the inwales
10064
10065
Posted: Thu Sep 28, 2023 12:46 pm
by OlivierP
Hi all
After a month of interruption due to a motorbike "tour de France" with friends, I'm back at work.
I have completed the inwales, rounded all corners and filleted the edges.
10071
10073
I have also finished building the front benches and lockers.
10072
Actually there is no more part to build and install, except closing the rear decks which are already cut and dry fitted, so the construction itself is essentially finished. Feels good ! Now it's time for fairing, installing hardware, painting, then transferring the motor from the donor boat (my RIB). Hope to finish before winter as planned.
I'm also considering installing a keel guard.
Posted: Thu Sep 28, 2023 1:32 pm
by Jeff
Nice work!! Jeff
Posted: Mon Oct 30, 2023 3:55 pm
by OlivierP
That's it, I have finished preparing the hull for painting, and I started priming the deck today (no pictures of the paint yet).
I have installed the rear decks, built a battery support in the aft port locker, a support and evacuation for the bilge pump, drilled holes for the controls in the console and the motor well, and drilled-filled-drilled hundreds of holes for the deck hardware. I thought it would be good enough and time to paint before winter comes.
10084
10085
Posted: Tue Oct 31, 2023 9:32 am
by pee wee
That looks really good, nice progress!
I see the console wind screen frame is about even with the bottom of the overhead frame, careful measuring on your part? :P
Posted: Tue Oct 31, 2023 12:45 pm
by OlivierP
Well, I though I had carefully measured, but I had measured the first frame and had not realized that the following were slightly lower, so I had to shave a couple of centimeters off the windscreen frames... no big deal.
Deck (including all lockers, a pain in the neck...) fully primed now.
10086
10087
Posted: Fri Nov 17, 2023 12:04 pm
by OlivierP
Well, we've been hit by storm after storm on the west coast of France lately, with winds gusting to 150km/h, so it has been impossible to progress with painting as the boat is outside under a car port. Finally a calm day today and I managed to put top coat on the deck, but I think that's it for this year.
I'll resume the project next spring with a final top coat, non slip paint on the sole, mounting the motor and deck equipment, and launch.
So let's call it a year.
All the best to all.
10096
10095
Posted: Fri Nov 17, 2023 3:55 pm
by jbo_c
Looks good.
I hate stopping for the year. I think I have a week or so left, unless we have a warm spell between now and Christmas.
Jbo
Posted: Mon Nov 20, 2023 9:24 am
by Jeff
Looks good!! Jeff
Posted: Mon Nov 20, 2023 9:26 am
by narfi
Looks good!!
I'll bet you could gain a little space by letting air out of the tires getting out.
Posted: Tue Nov 21, 2023 7:20 am
by OlivierP
Yes I could, thanks, but I'm ok now, I just have to lower the support wheel of the trailer at the hook. A tight fit for sure.
Posted: Sat Dec 16, 2023 11:40 am
by OlivierP
After a few weeks of drying, I thought that the top coat was good enough, only the transom will need touch ups. So I had a go at installing most of the deck hardware.
Posted: Mon Jan 08, 2024 3:04 am
by TomTom
Your boat looks awesome. Love the layout particularly at the bow of the lockers.
My only comment would be that you will get lots of wear on your gunwales/ paintwork from the ropes if you leave those front side cleats as they are; perhaps mount them on a sacrificial piece of wood, or a small piece of stainless plate under them that contours round the side of the gunwale a little.
Posted: Mon Jan 08, 2024 9:26 am
by OlivierP
Thanks for the kind comments, and for the suggestion. You're right, the gunwale paint is somewhat exposed around the cleats and more protection would be useful. I doesn't worry me too much for now because the boat won't rest at the dock but will be launched from the trailer, so the cleats will see very little use, only for a few minutes while boarding / landing. I'm also about to add a rubber rail around the rubrails.
Posted: Mon Feb 26, 2024 2:57 pm
by OlivierP
Back at work and getting closer to the finish line. The motor will be installed on Wednesday, along with the remaining controls.
In the meantime I have installed the rub rail (not finished yet), the swim ladder, the bilge pump and bilge drain, the pilot seat, the steering and a few other things, and touched up the hull paint where needed. It' too cold to glue the keel guard so that will wait.
Posted: Mon Feb 26, 2024 2:58 pm
by Jeff
Nice!!! Jeff
Posted: Tue Feb 27, 2024 9:15 am
by pee wee
She sure looks pretty with some jewelry on!
Posted: Wed Feb 28, 2024 11:43 am
by OlivierP
Getting there ! Can't finish today unfortunately, the wiring of the control handle is 1m too short, I have to wait a couple of days for an extension. But everything else is on.
Posted: Thu Feb 29, 2024 10:00 am
by OlivierP
Looks more and more like a boat.
I have the name, awaiting the stickers...
Posted: Thu Feb 29, 2024 10:07 am
by Jeff
Nice!! Jeff
Posted: Thu Feb 29, 2024 3:24 pm
by cape man
What an awesome build. Thanks for sharing. I bet she'll fly with that 50 on her!
Posted: Thu Feb 29, 2024 5:41 pm
by OlivierP
Thanks Cape Man, Jeff and Pee wee, much appreciated. I'm impatient to see how she handles at sea, we should find out pretty soon now.
Posted: Sat Mar 09, 2024 12:34 pm
by OlivierP
Back at home with motor and equipment mounted and tested.
I have applied 3 layers of non-slip paint on the sole. Now it has to dry before launch.
Posted: Sat Mar 09, 2024 1:10 pm
by mhd
Fingers crossed for the big day. Looking forward to seeing photos of her in the water!
Good luck!
Mick
Posted: Sun Mar 10, 2024 12:41 pm
by OlivierP
Launched !
The launch was very easy, single handed from the trailer and back.
She floats in hardly any water empty, the scuppers are way above the waterline, which is what I expected, I have raised the sole by 3.5 cm.
She handled perfectly at sea for this first hour of tests, felt very stable and confident and cut through waves quite well, not a drop of water in the cockpit so far. I like how she behaves at moderate speed (around 15kts) in wavy seas where she can handle whatever comes.
I have tested the top speed on flat water in an inlet, around 27kts with the 50 Yam, which is fine and more than I need, I either sail in the open sea with chop and waves so below 20kts, or in the Gulf of Morbihan where the speed limit is 10kts. Top speed was at 5800 rpm, which is just right, so the stock prop pitch is ok by chance.
I just need to install the keel shield and the bimini, and go fishing !
Re: C17 open in France - launched!
Posted: Sun Mar 10, 2024 12:56 pm
by narfi
Awesome!!!!!
Posted: Sun Mar 10, 2024 2:33 pm
by cape man
Congratulations! Felicitation! She's beautiful and doing what you want!
Posted: Sun Mar 10, 2024 6:27 pm
by mhd
Congratulations!!! Deserved reward for all the hard work.
Posted: Mon Mar 11, 2024 8:00 am
by OlivierP
Many thanks to all.
Here it is with the name stickers and the bimini.
For the name, the boat was built and will be based in Arzon, Britanny. I just hope a certain brand has a sense of humor...
I installed a short bimini to cover the helm station and leave the fishing decks uncovered.
Posted: Mon Mar 11, 2024 9:58 am
by Jeff
Congratulations!!! Jeff
Posted: Tue Mar 19, 2024 10:06 am
by OlivierP
I did some post-launch calculations to confirm the specs, for anyone interested in the C17
- my boat weighs around 580kg (1300lbs) fully equipped, with motor, battery, full tank, all equipment, but no crew. This is what I had estimated and is confirmed by the waterline level at launch. The hull alone weighs around 380kg, vs 280kg in the plans. Differences, for about 1/4 each : more epoxy, thicker plywood (8mm vs 6), floatation foam, deck equipment. Fiberglass just as specified, I didn't go the "glass everything" route to avoid more weight.
- I have raised the sole by 3,5 cm (1.4") vs plans. This puts the sole 5cm (2") above the water with no crew, and at water level at 900kg, or 2000lbs, vs the 1500lbs DWL in the plans. That leaves 320kg (a crew of 4 , or 3 + lots of beer), before the sole reaches water level. So the boat is self bailing and the scuppers can be left open at all times with a crew of 1 or 2 (I'll rely on the bilge pump above 3), which is what I was looking for for fishing. I think raising the sole by 2" would still work, the C17 can take it and remains very safe with its high freeboard.
Posted: Sat May 04, 2024 11:47 am
by forgeandfruition
Great work!!!
Sweet boat
Posted: Fri May 10, 2024 2:24 am
by OlivierP
First blood on the deck, she's officially a fishing boat !
Posted: Fri May 10, 2024 8:41 am
by mhd
Congratulations! Beautiful lines, beutiful boat, beutiful build.
Happy fishing!
Mick
Posted: Sun May 12, 2024 9:22 am
by pee wee
Congratulations on the launch! Beautiful results, great job. May she live long and carry you safely.
Posted: Sun May 12, 2024 11:40 am
by OlivierP
Thanks forgeandfruition, Mick and Hank. So far she's been just what I wished for. I wish I could thank Jacques again for his great designs.
Posted: Sun May 26, 2024 9:53 pm
by fallguy1000
Nice work!
Posted: Sun May 26, 2024 10:11 pm
by TomW1
Beautiful boat Olivier, hope you enjoy her for many years to come. Tom
Posted: Mon May 27, 2024 2:08 am
by OlivierP
Thanks Tom, and I take this opportunity to thank again all forum members for your advices and encouragements during the build.
Posted: Thu Jun 13, 2024 1:18 am
by OlivierP
Hi, I finally managed to shoot a short video of the C17 in action while going fishing, at cruise speed around 20kts, 4800rpm.
Posted: Thu Jun 13, 2024 8:45 am
by Jeff
Nice!!! Jeff
Posted: Fri Jun 14, 2024 12:33 pm
by forgeandfruition
AWESOME!!!
Posted: Sat Jun 15, 2024 11:56 pm
That is really nice and quite too :D
Posted: Sun Jun 16, 2024 2:34 am
by OlivierP
Thanks all. Yes the 50 Yam is very quiet, although covered here by the wind noise, and pushes the C17 well, 26 to 27 kts (30 to 31mph) depending on the presence of the bimini. It consumes about 7l/h (+/- 2 gallons).
I'll try to shoot videos in rough seas, but then I need both hands on the wheel...
Posted: Sun Jun 16, 2024 8:58 am
by pee wee
I like the way it turned out, and I bet you love it! Very nice.
Posted: Mon Jun 17, 2024 9:05 am
by OlivierP
Thanks Hank, yes so far so good, just what the doctor ordered.
Posted: Sun Aug 25, 2024 11:31 am
by OlivierP
Hi all
I have finally added ball-type one-way scuppers and had a chance to test them for a day of fishing today. They work perfectly ! I've spent the whole morning drifting in pretty agitated water with waves, chop and lots of boats wakes, and not a drop of water entered the cockpit. Only issue, they're a little noisy when the ball falls back in its cage.
Validated and highly recommended !
Posted: Mon Sep 02, 2024 11:13 am
by forgeandfruition
Nice piece!
Posted: Fri Sep 20, 2024 9:55 am
by OlivierP
I've just installed the Keelshield that was laying around for some time. Man, that was hard, literally a pain in the back as I've been crawling under the trailer for 1 hour at least. An advice to all builders, do it at construction time while the hull is upside down!
It takes quite a few steps: dry fitting the shield, marking the perimeter with masking tape, cleaning, sanding, cleaning again, laying the activator, and finally gluing the shield on the bottom, center first, then both sides.
But I trust it will be worth it, the shield goes up to the skeg, so I should be reasonably protected against unforeseen encounters with the ground.
