What kind of finish were you planning? Are you going to be fairing the hull?
If you are going to fair, you could *carefully* sand out those areas (or dremel or grind, then sand), reseal it with epoxy, cure, scratch up the new sealing cured epoxy a little for *tooth* and then fair. Small areas like that should be alright on this hull to be finished in that way. You will still have plenty cloth over the entire surfaces protecting things.
I had a few areas like that on my railcaps, but my problem was a little different because the railcaps are finished *bright*. To remedy the problem on them, I ultimately had to sand off the glass in the areas where the doug fir was gassing out and causing bubbles each season in the sun.
http://gallery.bateau2.com/thumbnails.p ... 202&page=6
You might have put a little too much epoxy on the cloth that overlapped the cured tape seam. The excess epoxy did not then *soak into* wood beneath, since there was a cured glass laminate beneath it, and the glass cloth floated up on top of the excess epoxy. I had this too in some small areas, being inexperienced with wetting out with epoxy. I didn't get air bubbles trapped.... I squished all those out with a stiff chip brush... but before the epoxy cured, I had slight bulges in the cloth by the time it cured, because the cloth floated up, as epoxy gathered under the floating cloth in small dime to quarter size areas. When I sanded prior to fairing, it made dime to quarter size areas where the cloth was completely removed, in maybe half a dozen spots. I sealed, cured, scratched for tooth, and faired over this and have had no problems at all in those areas, for several years of use.
If you want to absolutely have glass coverage there, grind out the larger bubbly areas, and put a glass patch over it with about 2 to 3 inches overlap, and then you'll need to fair that to feather the *bump scar*. I had one here, and the fix is doing fine... start at the 5th picture in. Since this was the bottom, I wanted the assurance of knowing the entire bottom, everywhere, is protected by glass, and that the football patch (that was causing the high spot) would not one day break out. Ah... the joys of working with cheap wood... NOT
http://gallery.bateau2.com/thumbnails.p ... 44&page=10
Larger bubble areas may bulge and delaminate if they get hot in the sun over time. A few tiny bubbles in an area where the hull will never get *hot*, should be alright, but again, if you want absolute assurance, you can clean it up and patch and fair. I have a feeling there are areas worse than that on quite a few hulls, that are doing alright, but the *peace of mind fix* is not difficult at all.
![Smile :)](./images/smilies/icon_smile.gif)
