Page 18 of 20
Re: XF20 - New project: Questions (and more to come!)
Posted: Wed May 20, 2009 7:21 pm
by Mando-in-kingwood
Thanks Richard, will do.
Posted: Fri May 22, 2009 10:59 am
by majorgator
Little late getting to this one, but here's a picture of a Microdraft brand boat which shows everything you're talking about. The transom is raised, it has a jackplate, and motor is a tiller style. Its a mercury 60 with a 4-blade prop.
Posted: Sat May 23, 2009 1:23 pm
Here is a side view.......it is looking like a boat!
Posted: Sat May 23, 2009 1:42 pm
by majorgator
lookin good :lol:
Modified transom (taller)
Posted: Sun May 24, 2009 12:05 pm
OK, here is the modified transom, 20" from top of tunnel to top of transom........4 to 4 and 1/2" taller than what is shown on the plans. This should allow me to use the jack plate to raise the prop up to be running in the water shooting out of the tunnel.
Luckily I had not glued in the clamping board when Sticky Stuff and Aripeka Angler pointed out that the transom did not look tall enough. Cut the clamping board (2 layers of 3/8" marine ply laminated together) taller, glued and glassed it in, then laminated a 1/2" marine ply piece on the outside.
Will put a couple of layers of tape over the seam between the old transom and the extension.
Thanks all for the advice.
Posted: Sun May 24, 2009 1:18 pm
by Dog Fish
That's more better :) Now your cooking, I sure wish I was building a xf-20 along with ya. Looking good :!:
Brian
Posted: Tue May 26, 2009 5:52 am
by cape man
Nice job! Lookin' like a boat it is!
Biaxial cloth
Posted: Sun May 31, 2009 4:00 pm
I bought the fiberglass kit (resin and cloth) from this site. I have not wasted any cloth in glassing the hull exterior (kept all the scraps) and now am glassing the interior. I am finding that I need literally every scrap of the fiberglass cloth in order to get one layer of cloth on the interior.
Are other XF20 builders finding the same thing?
Posted: Sun Feb 21, 2010 3:47 pm
Wow, I can't believe it has been almost 9 months since my last post on this thread. After a too hot summer + too much travel + too cold winter, I am finally back building.
Inside of the boat is entirely glassed, now time to put in the stringers and frames.
I have a question about doing the stringers/frames......is it best to glue the stringers & frames in (using EZ Filet) and then glass in with 6" tape, or, is gluing in not needed?
Thanks in advance for any advice.
Mando
Posted: Sun Feb 21, 2010 4:56 pm
by chrisobee
Mando-in-kingwood wrote:I have a question about doing the stringers/frames......is it best to glue the stringers & frames in (using EZ Filet) and then glass in with 6" tape, or, is gluing in not needed?
I would glue them in.
