Vg20 finally underway
new to sail
Re: Vg20 finally underway
Post by new to sail »
Thanks Mick,
I followed the plan by inserting SS screws on each side of the HDPE pin to prevent movement. At this time there is no cover to block the pin. I will check before and after launch to see what the pin has done.
New to this, so I will watch and learn from others as time go
Rick
rick berrey
Post by rick berrey »
I think i would use glass for a cover and drill out both sides of the cover to remove the pin if it is ever needed .
OrangeQuest
Post by OrangeQuest »
What a beautiful boat, will look even better in the water and fully rigged. (hope that was some sailor talk)
This pivot pin thing. Maybe post a few photos and better description these covers and access covers do and why cover.
Sorry, I try to follow along but sailboat talk makes my head spin... and I bought books even! :doh:
A. A. Milne-- Winnie the Pooh
new to sail
Just started to think about the cover. Has there been situations where the pivot pin as come out? Does the weight of the centerboard on the pin help to keep it in place or does the healing motion put extra force on the pin causing it to move?
Rick
mhd
Post by mhd »
This is what I have from the VG23 plans...I assume it is the same for Rick and the VG20?
I'm using a bolt for the CB pivot - currently drilled for 1/2 inch but thinking of going up to 3/4" or even 1". Hard to explain or get your head around without seeing the CB case installed inside the keel, that is inside the boat. The issue I have is that once installed inside the keel, the keel width isn't enough to be able to remove the bolt/rod for inspection or replacement.
The pivot design is good, but I'm worried that any side-impact on the CB would create huge shear-forces on the CB and bolt. If anything like that happens I want to be assess the damage. Probably over-thinking but it is the one bit of the boat that just can't be easily accessed once built.
After seeing Rick's keel photo last night I had a brain-wave, for good/bad, and was thinking of sealing that part of the keel off from the rest of the boat interior within the keel. Then installing the equivalent of a steel deck fuel/water screw hatch flush with the keel to minimize any drag or turbulence generation. It won't be a major problem even if there is any water ingress. Doing it that way I can always get to the pivot in the event of a problem - even in the middle of the ocean. Hope my explanation makes some kind of sense. I'm not at this stage yet with my VG23 but I've probably spent more time thinking about that pivot than anything else on the entire boat!!! Everything else on the design is fixable and accessible.
And until last night I was going the way Rick suggested - simply cover with glass and drill through if/when I ever decided to replace the pivot.
Hope that makes sense!
Mick
Reason: Fixed image embedding
TomW1
Post by TomW1 »
The only problem you will encounter with a centerboard pivot if properly built is needing to removing the centerboard due to grounding or other accident. I have owned two a 13' and a 30' thru my father-in-law. Never had to replace either.
new to sail
The centerboard swings around a teflon tube that is placed inside a SS tube on the VG 20
It is a different than the example Mick shows.
mhd
Post by mhd »
Interesting! Completely different design. Now I see why you have the holes drilled in the keel.
Thanks so much for posting this. I'm going to think on it some more - still a way to go before I have to finalise my own pivot.
Good luck getting your boat in the water - I'll be following along!
Mick
new to sail
This may show a little more detail
mhd
Post by mhd »
Okay, that makes sense now. In contrast, for the VG23, the pivot bolt does not extend out to the keel sides. So I may cut a hole in the keel to be able to access it via a small port/hatch. I'll post photos when I get to that part of the build.
Interesting how the different versions of this boat have evolved (VG18, VG20, VG23 and on to VG26!).
Good luck with your build!
Mick
