Tried an impact wrench and the entire fitting spun. Tried a puller and was only able to grunt. Emailed a pic and discription of my problem to the tech support at Moeller and they pretty much said I need a new tank since the fitting spun, and that based on the pic it is a threaded fitting... No retrofit available from them, and I can appreciate that given the liability for a gas tank in a boat. However... cutting the deck and removing the tank is NOT an option, and certainly not my preferred.
Did some digging and talked to some friends that have a lot of experience in boats and fuel tanks. On my Moeller tank, the fuel sending unit is immediately adjacent to the fuel pickup fitting and is a circular plate screwed into the tank top with 5 screws. You can take that off and replace it if needed. So why not do the same with the fuel pickup?
Step 1, and the BIG step was to get the courage to break out a 1 3/4" hole saw and cut out the whole fitting around the nut. Was waiting for an internet service guy yesterday afternoon so decided it was time to bite the bullet, pull the trigger, stop being a sissy, and get on it! It actually went a lot easier than I expected!
Now I can see inside and there's very little fuel, but it is a dark yellow brown. I'm bringing home some airline tubing (like you get for an aquarium) and a glass pipette that fits it to slowly siphon out the fuel from the lowest corner of the tank. The solution afterwards is to use something like this to replace the pickup.
I sent an email to them to get the dimensions of the plate and the length of the pickup tube. If their off-the-shelf part doesn't work my welder buddy says he'll make me one out of stainless.
The internet service guy was running late so I decided to remove the numbers and registration decals from the bow using Goof Off and alcohol
Seemed appropriate as by now I'm just goofing off and having a beer.
15 minutes befor the deadline for the service appointment (1 - 5pm), the guy calls to say he was on his way but got pulled off of our problem to service a FEMA job?!!! By now I'm really pissed as the problem has been a week in the process! But I know what calms the soul of this old fart... Break out the Sander!
Got the port side gunwale and foredeck sanded! If nothing else it will show the guys where to stop and it allowed me to go to that Zen place that only the sound of a random orbital sander provides...
Have a fun surprise for this issue...
